Author Topic: [IC] GMK Jamón - [RAMA X JAMÓN AVAIL]  (Read 238561 times)
Offline lee jeong woo
Re: [IC] GMK Jamón - Group Buy Coming Soon!
« Reply #250 on: Thu, 27 December 2018, 08:41:30 »
I have a question about color.
Alphas = burgundy
modi = Ceresia
Are these different colors of Jamon?
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #251 on: Thu, 27 December 2018, 09:49:18 »
Alphas = burgundy
modi = Ceresia
Here is an update regarding GMK Jamón:
OK, let's start with the huge elephant in the room: still no kit updates.
Updating the kits didn't really take me that much, in fact it was quite the opposite honestly specially since I knew exactly how I wanted to make them. However, since I was going to have to remake the whole keyboard gallery, and all the kits presentation and descriptions, I thought it would be the perfect chance for me to scrap the current project page on my site and start from scratch.
This is obviously taking me longer than just updating some renders and the kits, but I think it's worth it and that's enough for me.
Now, let's talk a little bit about color matching to solve some concerns that have raised because of other keycap projects.
Like I've addressed on a previous post, many of the colors used from this set will be standard or I have already used them in the past (standard N9 dark grey, N6 yellow, Serika's alphas) and for some other I do not have a final answer. This is the case of the alphas and modifiers. While GMK offers some standard colors that are close to what I want (R01 for the alphas and P3 for the modifiers) neither of them are exactly what I want. Yes, they are close, but not exactly what I want. And while the difference is small, it's enough to bother me. So, for those two colors, we are going to do some color matching and if we manage to get something that I like more we'll use it, if not, we'll use the standard colors.
For the color matching, we are going to use the same system we used for Serika, we'll stick to the RAL color palette which was actually super accurate and worked really well. This process should be faster now that I own one.
Offline ninjacore
« Reply #252 on: Thu, 27 December 2018, 10:11:27 »
Alphas = burgundy
modi = Ceresia
I was pining hard for Jamon earlier this year and picked up Ceresia and Burgundy.  "White" accents in top photo are epbt BoW and in the bottom, OG Cherry off-white.
I can't comment as to whether these are a direct match, but it was close enough.
« Last Edit: Thu, 27 December 2018, 10:21:48 by ninjacore »
Offline fer.real
« Reply #253 on: Thu, 27 December 2018, 13:38:47 »
Hi,
I usually map the function key on my keyboards to the Caps Lock key.  Is there any way you can add an R3 1.75u function key to replace the Caps Lock key?  It doesn't need to be a Fn or Function key, it could be something generic like Meta or Super, a novelty, or even a blank.
Offline Zambumon
    • Keyset projects
« Reply #254 on: Thu, 27 December 2018, 17:48:24 »
Hi,
I will think about it, maybe I can add it as a novelty and avoid increasing Core's size.
Offline Zambumon
    • Keyset projects
« Reply #255 on: Thu, 27 December 2018, 17:50:00 »
Novelkeys x Jamón Deskmat samples
Nice.
Offline Lepr3chaun
Re: [IC] GMK Jamón - Group Buy Coming Soon! [Deskmat update]
« Reply #256 on: Thu, 27 December 2018, 22:28:01 »
The mats look great!
Offline digid3ar
« Reply #257 on: Thu, 27 December 2018, 23:56:38 »
could we add 2  R3 1.50 in the 40s set, or would be too expensive?
Offline Zambumon
    • Keyset projects
« Reply #258 on: Fri, 28 December 2018, 04:56:01 »
Why 2? For which layout?
Offline snelltrail
« Reply #259 on: Fri, 28 December 2018, 05:01:27 »
I'm guessing it's for the Pearl. Also the Prelude 40% which is currently in IC.
Offline fer.real
« Reply #260 on: Fri, 28 December 2018, 06:09:47 »
Hi,
Thanks for the consideration!
Offline Zambumon
    • Keyset projects
« Reply #261 on: Fri, 28 December 2018, 06:33:16 »
The reason I haven't added them is partly because there's there are no plans to run the Pearl again, and since there's only around 100 of them, its userbase is very limited. On the other hand Vortex Core, DDMicro, and Plancks have lots of stock and the current kit also allows for most of the 40% layouts which trim the left side 0.5U and use a 1.75U enter key.
Offline Owl-
« Reply #262 on: Sun, 30 December 2018, 07:24:13 »
Would highly love to see an extra 2u bar in the 40s kit! Apart from that, looking forward to GB day :D
Offline Zambumon
    • Keyset projects
« Reply #263 on: Sun, 30 December 2018, 12:13:22 »
- Possible kit updates: So, most people have suggested about the new kits to add some of the what I'd call "splitbars" to the spacebar kit (or add a second 2.00U spacebar). Since I'd prefer not having duplicate spacebars, I'm probably going to add a 2.00, 2.25, and 2.75U accent spacebar to the spacebar kit. Regarding the addition of R3 1.50 Tab and Enter keys I'll have to think about it.
- Deskmats: since both deskmats use patterns, I don't think we should have any issues to make a small mat version.
Offline LevelSteam
« Reply #264 on: Mon, 31 December 2018, 01:52:07 »
Honestly I hope the modifiers do turn out closer to P3 than something like RO2.
Even *if* this set turned out similar to burgundy alphas + ceresia mods I don't necessarily think that's a bad thing, and there's still enough going on with the accents to really make it pop and set it apart from those other sets as a whole.
Offline Zambumon
    • Keyset projects
« Reply #265 on: Mon, 31 December 2018, 09:21:20 »
Small kit update:
- Render color tweaks
- Moved accents from Core to Jamonelties (beige Esc and Enter)
- Added accent splitbars (2.00, 2.25, 2.75) to Spacebars
Offline ninjacore
Re: [IC] GMK Jamón - Group Buy Coming Soon! [Small kit update]
« Reply #266 on: Mon, 31 December 2018, 09:26:32 »
Did it lower the core kit price to move the accents?
Offline Zambumon
    • Keyset projects
« Reply #267 on: Mon, 31 December 2018, 10:27:54 »
It just made more sense to me to move all the beige accents to Jamonelties.
Offline LevelSteam
« Reply #268 on: Mon, 31 December 2018, 11:11:30 »
Definitely prefered the more vibrant reds on the previous renders to the newer desaturated ones :(
Offline Zambumon
    • Keyset projects
« Reply #269 on: Mon, 31 December 2018, 11:49:38 »
The new ones are closer to both the GMK and RAL samples.
Offline holtenc
« Reply #270 on: Mon, 31 December 2018, 11:58:14 »
nice kit updates.
Offline LevelSteam
« Reply #271 on: Mon, 31 December 2018, 12:10:41 »
Now that I'm looking at it on a different (better calibrated) monitor I actually like the new colors more. I think that like Nautilus or Laser, this is going to be one of those sets I have to see irl to really appreciate it. In any case count me in for pretty much every kit haha  :thumb:
Offline Zambumon
    • Keyset projects
« Reply #272 on: Mon, 31 December 2018, 12:55:54 »
We should have samples of everything before the group buy starts anyways, I'll try to take some pics of them once I get them here and share them with you guys.
Offline dantambok
« Reply #273 on: Mon, 31 December 2018, 13:09:16 »
Awesome updates! In for sure. Also, where will this run? (I’m really hoping zF will be one if them) heh
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline ninjacore
« Reply #274 on: Mon, 31 December 2018, 13:32:29 »
So, no price change, but keys were removed?  I don't necessarily disagree with them being in with the novelties; just doesn't make sense to simply remove them if it doesn't change the price...
Offline Zambumon
    • Keyset projects
« Reply #275 on: Mon, 31 December 2018, 13:37:49 »
It does lower the price, but it's more meant to be so people can choose which accents they want (at least for most layouts)
Offline Zambumon
    • Keyset projects
« Reply #276 on: Mon, 31 December 2018, 13:38:31 »
Massdrop. I don't know if ZF will proxy the set in China, that's up to them I guess.
Offline ninjacore
« Reply #277 on: Mon, 31 December 2018, 13:56:37 »
Cool, like the change then
Offline catamscott
« Reply #278 on: Mon, 31 December 2018, 14:11:55 »
Small kit update:
updated render colors are looking excellent, now even more excited for this set
Offline Zambumon
    • Keyset projects
« Reply #279 on: Mon, 31 December 2018, 17:19:03 »
I'm still open for suggestions until January 6th.
Happy 2019, year of the pig  :D
Feliz ańo nuevo!
Offline RamenTechMech
« Reply #280 on: Mon, 31 December 2018, 17:30:12 »
Feliz ańo nuevo!
Happy New Year  ;D
Offline snelltrail
« Reply #281 on: Tue, 01 January 2019, 01:43:14 »
Small kit update:
Really liking these proposed updated kits! I appreciate you trying to squeeze the splitbars into the spacebars kit. I was planning on picking up the Jamónelties anyway, so moving the accents from the Core doesn't matter much to me.
Not sure whether I like the new colors as much, I really liked the vibrancy of the previous mods. But the set still looks amazing and I'll definitely be for most kits! :D
Offline Zambumon
    • Keyset projects
« Reply #282 on: Tue, 01 January 2019, 07:26:28 »
As I mentioned, it's not like these are new colors. All I did was some adjustments with the renders so they are more accurate with the real thing.
Offline snelltrail
« Reply #283 on: Wed, 02 January 2019, 05:41:32 »
Ah right, sorry, I managed to miss that it was only *render* color updates. Definitely nice to have more accurate renders; can't wait to get some Jamón!! :D
Offline Zambumon
    • Keyset projects
« Reply #284 on: Wed, 02 January 2019, 16:44:53 »
I managed to make some new renders with the new colors. Hopefully I should be able to update the OP later this week.
Offline LevelSteam
« Reply #285 on: Wed, 02 January 2019, 18:17:00 »
Love it!
Offline snelltrail
« Reply #286 on: Wed, 02 January 2019, 20:18:55 »
Oooof, these new renders look fantastic!!  :eek:
Offline gabbbe
« Reply #287 on: Wed, 02 January 2019, 20:28:29 »
I must say one thing: this is one of the best looking keycaps I ever seen but I’d really really love them if it had Icon Mods. Any chance to add?
Offline Zambumon
    • Keyset projects
« Reply #288 on: Wed, 02 January 2019, 20:29:20 »
None.
Offline Zambumon
    • Keyset projects
« Reply #290 on: Wed, 02 January 2019, 20:41:54 »
A Space Cadet set for R2 :)?
This set has little to do with Lisp. Stay tuned for Crimson Cadet instead.
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #291 on: Wed, 02 January 2019, 20:53:56 »
Offline gabbbe
« Reply #292 on: Wed, 02 January 2019, 21:25:52 »
None.
Anyway,it's an amazing keyset
Offline Zambumon
    • Keyset projects
« Reply #293 on: Wed, 02 January 2019, 21:36:40 »
Apologies for being so direct, but it saves us some time. I just don't have plans to add any extra kit to the set.
Offline gabbbe
« Reply #295 on: Wed, 02 January 2019, 22:22:58 »
No worries at all. The keyset is amazing as it is and I'll probably purchase one myself.
Offline Myth
« Reply #296 on: Wed, 02 January 2019, 22:41:51 »
I have never seen a set of keycaps so perfectly capture the essence of ham. Well done.
Offline Zambumon
    • Keyset projects
« Reply #297 on: Thu, 03 January 2019, 06:10:18 »
I've just received some GMK Jamón deskmat samples and they look fantastic, I really like the result and how the colors look like. Once I get samples from GMK, I'll try to take some pics to see how they look together. The hexagon red looks awesome and could be used with blue sets like Nautilus too.
The other one is also superb and looks fantastic with red keyboards.
Offline Zambumon
    • Keyset projects
« Reply #298 on: Sat, 05 January 2019, 16:23:16 »
Final hours to send your suggestions! Kits will be locked on January 6th and will be inmediatly sent to GMK for quoting.
Offline dyrdevil
« Reply #299 on: Sat, 05 January 2019, 18:49:39 »
As much as I'd love to see some accent colors in the core kit, I think the way you've done it is the best way to keep the cost down.
I'd rather have a lower entry price than accents so I'm crossing my fingers for you.  GL!
