Author Topic: Does XD75 keyboard fit GH60 Case?  (Read 4420 times)
Offline vatin
« on: Sat, 02 June 2018, 05:08:02 »
Hi,
I'm interested in getting an XD75 keyboard through Aliexpress (KPrepublic store) and I heard somewhere that it is compatible with GH60. Could you please confirm? I much prefer the look of the aluminum GH60 case than the aluminum bent case for the XD75. Do I need to buy an extra plate or anything else to make it fit GH60 case?
Thanks,
HHKB Professional Classic
Offline vatin
Re: Does XD75 keyboard fit GH60 Case?
« Reply #1 on: Sat, 02 June 2018, 05:38:03 »
Ok, I got my answer from reddit. It does not fit perfectly. https://www.reddit.com/r/MechanicalKeyboards/comments/7rbnd8/help_xd75_questions_and_show_tell/
I better go with the bent case designed for the XD75.
Offline Leslieann
« Reply #2 on: Sat, 02 June 2018, 06:00:05 »
Considering how the GH60 plate and pcb is mounted, you can pretty easily re-drill the necessary holes and add standoffs.
Edited to reflect new info.
« Last Edit: Sat, 02 June 2018, 06:02:38 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
