Author Topic: Best place to get Box Navy switches? Best novice PCB?  (Read 4093 times)
Offline Touch_It
« on: Wed, 06 June 2018, 12:53:13 »
Edit, I can't read.  Packs of 10, price is reasonable :D.
https://novelkeys.xyz/products/novelkeys-x-kailh-box-thick-clicks?variant=3747938205736
If I were to build my own board (I want a pcb) any recommendations? I'm a novice solderer, and would want to keep things on the cheap side.
« Last Edit: Wed, 06 June 2018, 12:58:07 by Touch_It »
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
Re: Best place to get Box Navy switches?
« Reply #1 on: Wed, 06 June 2018, 12:58:53 »
Is there a place to buy the switches that won't cost me my 1st borne child?  They sound like a modern switch I could really get behind, but damn if $3.40 a switch isn't ****ing expensive.  Not that I haven't spent that in the past, (I have), but we are talking about $360 for 105 key switches.
Hey man,
It isn't 3.40 PER switch its 3.40 for 10 switches
Offline sncbraxsc2
Re: Best place to get Box Navy switches? Best novice PCB?
« Reply #2 on: Wed, 06 June 2018, 12:59:49 »
ah you got it  :thumb:
Offline killyou
« Reply #3 on: Wed, 06 June 2018, 15:09:05 »
I wish BOX Navies were ~8-10g lighter :(
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
« Reply #4 on: Wed, 06 June 2018, 15:13:44 »
Box Jades?
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
Offline Kevadu
« Reply #5 on: Wed, 06 June 2018, 15:17:22 »
Problem with jades is that they feel unbalanced with the huge bump yet fairly light springs.  They make you bottom out hard.  I would like to see a switch with a clickbar thickness in between the original and the jade/navies.
Offline killyou
« Reply #6 on: Wed, 06 June 2018, 16:51:22 »
Box Jades?
They are horrible to a point that I consider them a broken design. They are like binary switch with only 2 states of operation, they feel close to a lighting switch. Certainly not my cup of tea. Something between BOX Pale Blue and BOX Navy would be best to be honest. Probably something with a tad lighter spring and a slightly thinner click bar. They went extreme and we need something in the middle. I bought my new Pok3r with MX Blues with an intention to install clicky BOX switches and the best ones currently are Pale Blues in terms of the operations in my opinion (just few grams too heavy to my liking - would prefer ~60-62g bottom out force - and I would prefer having slightly thicker click bar for deeper sound and bigger tactility but not as thick as BOX Navy). None of these BOX clicky switches are THAT good to make me want to desoler entire board, install holtites and put a new batch of switches in.
Offline clik_clak
« Reply #7 on: Wed, 06 June 2018, 17:36:02 »
Box Jades?
...Something between BOX Pale Blue and BOX Navy would be best to be honest...
So a Box Jade...
Offline Kevadu
« Reply #8 on: Wed, 06 June 2018, 17:52:33 »
Box Jades?
So a Box Jade...
It's like you didn't read anything he said except that one sentence.  I happen to agree with him and made the same point myself...
Offline godlikekitten
« Reply #9 on: Wed, 06 June 2018, 23:08:00 »
Honestly for cheap can't really go wrong with a DZ60.
Offline hilltopchill
« Reply #10 on: Fri, 08 June 2018, 20:44:04 »
If you're in Australia, dailyclack.com just pretty good. It's where I got my box jades.
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #11 on: Fri, 08 June 2018, 21:14:08 »
SPRiT makes custom box switch springs so you can spring swap to get your desired weight
Offline killyou
« Reply #12 on: Sat, 09 June 2018, 02:24:58 »
For the switch to work properly with a lighter spring it would need to have a thinner click bar because the force needed to overcome the click bar will be much greater than bottom out force and that will result with a switch similar to BOX Jades. Not as bad as BOX Jades but still.
« Reply #13 on: Sat, 09 June 2018, 02:55:56 »
Hmm.. that hasn't been my experience with lighter Box Navies.
