Author Topic: What is your favourite board ATM?  (Read 4620 times)
Offline jcoffin1981
« on: Sun, 10 June 2018, 05:12:02 »
I say "at the moment," because mine changes all the time.  I've been trying to increase my typing speed which I've increased from about 60 to 71 wpm.  I haven't bought a new board in about 2 years and there are so many new switches and boards that I am unfamiliar with. I'd like to know as I'm in the market for something new, and non-Cherry
_I will say with the disclaimer that of the boards I own, my fave changes frequently, so I'll list my current. I swap my board once a week and the novelty keeps things fresh.
1. Favorite board?
2. Paired with favorite switch?
3. A brief explanation
I'll go first
1. Pok3R
2. Lubed Cherry MX Brown
3. I like the small footprint, programability, and the lubed switches. Some say it is pointless to lube these as they have rather low tactility already, but I'm finding I'm liking less of a bump. Unfortunately I don't remember the lubricant I used.  When I get around to doing so I should really try a light linear switch, probably in a board that allows hot-swapping.  Also, the keycaps on these really are top notch.  Many swap them but I see no point, though I see lots of pretty keycaps.
Re: What is your favourite board ATM?
« Reply #1 on: Sun, 10 June 2018, 07:12:46 »
Currently liking my CP-SQ (1800ish) with first round Zealio housings and linear Gateron clear stems lightly lubed with Krytox thin.  Heavy springs to avoid bottoming out (120g springs in the middle section, 100g towards the edges) and Hyperfuse GMK caps.
This board has every key I need where I want it (see 'more' for layout) while still allowing the mouse to be closer than a fullsize, and being acrylic it has a distinct dull satisfying thud when I do bottom out.
Offline Leslieann
« Reply #2 on: Sun, 10 June 2018, 07:37:03 »
1. Filco MJ2
2. Hand wired Jailhouse blues, 60gram springs (at actuation), o-rings, thick pbt caps
3. I really like the VA68/Magicforce 68 layout (wish it had fkeys), however the Magicforce is cheap (though good for what it is), the Va68 is nice (have not tried one) but lacks a few things and is certainly not cheap. I've been giving serious though to getting the Va68 and installing an aftermarket pcb with programmability, but if I'm going to spend that much, I would almost prefer to just design and build my own keyboard from the ground up. I've bought 4 keyboards since the MJ (Model M, Magicforce 68, GH60 and a full Chinese custom) and none have been able to replace it so I'm hesitant to buy yet another that will just sit around.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline sebna
« Reply #3 on: Sun, 10 June 2018, 10:35:11 »
1. Topre RF 87U 45g uni
2. 45g uni
3. It is just pure sex to type on it. Every key stroke is so comfortable, precise and repeatable. In compare my Hyper-x alloy FPS TKL with cheery red feels quite flimsy and random in key presses. Great for gaming tough!
Offline ArchDill
« Reply #4 on: Sun, 10 June 2018, 10:39:09 »
1. Gray Revo RJ and GB PCB, Brass Plate, thin lubed Zealio's.
2. HHKB Pro 2, lubed Realforce silent sliders, 55g RF domes.
Offline zslane
« Reply #5 on: Sun, 10 June 2018, 11:23:14 »
1. Topre Realforce RGB
2. Silenced TMX
3. This is the only full-size keyboard with Topre switches that can take all my MX-based keycap sets, so it wins by default. I've had to perform two customizations myself: adding silencing rings and painting the case white. Example:
197785-0
Offline sebna
« Reply #6 on: Sun, 10 June 2018, 12:09:24 »
2. Silenced TMX
Ohh wow... that is a beauty :) Well done.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #7 on: Sun, 10 June 2018, 12:15:15 »
2. Silenced TMX
Ohwww, dat SA SC just looks so good :D .
Offline fracno
« Reply #8 on: Sun, 10 June 2018, 13:19:37 »
At the moment I have three boards, and they're all so different from each other that I tend to bounce back and forth on which is my favorite. I'd have to say that purely based on feel, my HHKB is probably my favorite.
Offline Blue_Moon
« Reply #9 on: Wed, 13 June 2018, 17:06:26 »
same here: hhkb. but i dislike the cylindrical keycaps because i type with my wrists straight. a split keyboard would solve that problem, but it's a no-win situation because i also like to be able to reach any key with my left hand only (for when i'm using the mouse heavily)
Offline ag36
« Reply #10 on: Wed, 13 June 2018, 19:26:46 »
Model M SSK but I also really like the keytouch and sound of my alps64 with matias click and aekii keycaps.
Favourite switch is buckling spring but I can't decide if I prefer model F or M.
Fantastic bottoming outs and great sound and heavy keycaps.
« Last Edit: Wed, 13 June 2018, 19:30:49 by ag36 »
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline TheNamesTy45
« Reply #11 on: Wed, 13 June 2018, 22:45:08 »
1) Current favorite board is my Tina-A with a brass plate, DZ60 USB-C PCB, and GMK Muted keycaps.
2) Current favorite: Tie between Hako True and Silent MX Reds in Zealios housing with lube. From what I've felt though, Halo Trues will likely overtake these as my favorite. I like pink switches.
3)  HHKB is my favorite layout because it is compact, aesthetically pleasing to me, and easy to reach all necessary functions. The Hako is a nice switch, but now that I have some Halo Trues, in hand, I really wish I was able to use them on this build because they definitely feel more tactile and consistent. In the future, I'll either be updating this to True Royals (Hako true stem and spring in Box Royal housing, makes it very tactile), or Halo Trues in Zealios housing and 67g spring for increased tactility until Panda R2 happens.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #12 on: Wed, 13 June 2018, 23:32:06 »
Dell AT101 with linear black alps mode, USB teensy
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #13 on: Wed, 13 June 2018, 23:47:25 »
my mira
Offline jcoffin1981
« Reply #14 on: Tue, 19 June 2018, 03:58:47 »
I read the forums and there are so many switches that I have never heard of, including box and a half-bajillion others.  My next board may be a hot swap board so I can try all these new ones and not be committed.  I have not even tried Alps or Matias yet.  I am behind the times.  However, I am very happy with my current daily driver, the lubed Pok3r.
Offline Sup
« Reply #15 on: Tue, 19 June 2018, 04:52:12 »
Currently love my KBD75 Lubed Gateron yellow with geniune cherry stabs and JTK storm trooper key caps.
current
Coming soon
Offline dgneo
  • Supervillain
« Reply #16 on: Tue, 19 June 2018, 05:02:24 »
TGR Jane
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #17 on: Tue, 19 June 2018, 05:48:15 »
Filco with silent reds
Offline lasernasaur
« Reply #18 on: Wed, 20 June 2018, 03:15:13 »
Since its the only keyboard i have at the moment. I'm really liking my MK Disco with KBtalking Browns. I have two kits waiting on switches.
Offline Riverman
« Reply #19 on: Wed, 20 June 2018, 18:11:00 »
My current favorite is a Realforce RGB.  I love the way it types almost as much as the Type Heaven I have at work, but I have Mac specific keycaps on the RGB, so that puts it over the top.
