Author Topic: Modification Pok3r RGB / LE for shorter height  (Read 3380 times)
Offline coccosoids
  • A?
« on: Wed, 13 June 2018, 13:27:52 »
Is it possible to mod the Pok3r RGB / LE to make it shorter?
What I mean by that - are there any known modifications possible of these boards that will cut down on the total height of the front row of keys, back row of keys respectively? IE: bring the front height of ~30mm down to ~20mm, ~25mm?!
Links to the two boards:
Pok3r RGB LE
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=3625
Pok3r RGB
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=3527
Offline ag36
Re: Modification Pok3r RGB / LE for shorter height
« Reply #1 on: Wed, 13 June 2018, 14:30:14 »
You mean make the keyboard lower?
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline coccosoids
  • A?
« Reply #2 on: Wed, 13 June 2018, 14:35:56 »
That's exactly what I mean.
Offline RehnMan
« Reply #3 on: Wed, 13 June 2018, 14:53:59 »
Im not positive on this, but are you sure that the case is actually higher on the LE? Are you sure it isnt just that its a high profile case so it appears higher? The height of the top of the keycaps is probably relatively close to the same height off the desk.
Just venturing a guess. Good luck on your quest.
Offline ag36
« Reply #4 on: Wed, 13 June 2018, 16:24:35 »
I'd say go get a low profile case and install some cherry or dsa profile keycaps, if that's still not enough, buy a higher chair or cut a opening on your desk to make the keyboard lower.
Offline xondat
  • i'm not a star
« Reply #5 on: Wed, 13 June 2018, 16:32:18 »
There aren't any options in the tray 60% case market for specifically lowering the height of the switches in boards. I'm presuming you mean the height of the switches relative to the desk.
The only thing possible is by just having a case designed to be shorter (or with it in mind). You aren't able to modify anything in the PCB/plate/switches portion.
As ag36 mentioned, going from the stock caps (OEM) to Cherry profile will lower the typing surface a little bit, but it obviously won't move the switches down.
A low profile case also won't move the switches down on purpose (it could move them higher/lower though, there just isn't documentation on it), it'd just make the front wall height (that you'd essentially need to "overcome" anyway) a little bit shorter.
Offline coccosoids
  • A?
« Reply #6 on: Fri, 15 June 2018, 16:35:48 »
No more ideas?! No power recommendations for low profile mechanical boards?
Offline ag36
« Reply #7 on: Fri, 15 June 2018, 17:51:39 »
Getting a low profile keyboard is perhaps easier, why you're pursuing low height?
Offline coccosoids
  • A?
« Reply #8 on: Sat, 16 June 2018, 07:46:45 »
What I mean by lower profile is actually low height... and the reason is ergonomics. I cannot even fathom why boards of +30mm front row keys exist.
Offline ag36
« Reply #9 on: Sat, 16 June 2018, 07:58:04 »
I always had the thoughts of lowering my keyboard but I have about 30+ keyboards so that's not very viable to mod my keyboards, personally I think you need to look for a lower table or have a cutout on your table for your keyboard to sit low because mx switches are already pretty tall and low profile switches are not common yet.
« Last Edit: Sat, 16 June 2018, 08:07:02 by ag36 »
Offline killyou
« Reply #10 on: Sat, 16 June 2018, 13:41:59 »
Maybe wait for new Coolermaster keyboards. They will have a lower profile.
Offline yearn
« Reply #11 on: Sat, 16 June 2018, 14:12:52 »
It sounds to me like you have a VERY EXPENSIVE desk/chair that is positioned too high to your liking and you're trying to bandaid fix the problem haha.
I would suggest you to get yourself a cherry profile keyset (GMK, OG cherry ds, etc) which should help reduce the height a bit but other than that... detach the PCB from the case and just use your keyboard bare-case??? Should be okay if you put a spongy bottom piece of plastic or something underneath the PCB.
Offline jcoffin1981
« Reply #12 on: Sat, 16 June 2018, 21:49:09 »
I think you mean the chair is not positioned high enough.  I cannot mount the keyboard high enough. I sometimes sit on a book so the keyboard is at
a more comfortable height.
