Author Topic: Trimmed the "eyebrow" on my model F XT  (Read 2752 times)
Offline ag36
« on: Thu, 14 June 2018, 11:42:48 »
While curing paints on my xt's case some major accident happened I had to start over so I decided to change the look a little bit while working on it. I might do some work on the "ear" too at later point. Now waiting for the XT-USB converter to arrive.
Model M*5, SSK*4, M13 black*1, Model F XT*1, AT*1 F107*1, Unicomp*1, 3278 *1, Leopold FC750R*2, 980M*2 FC980C*1 Filco majestouch 2 TKL*1, Cooler Master MasterKeys S PBT*1, Uniqey Q100*2, Ducky pocket*1, KBD75*2, KBD19X*2, HHKB pro 2*1, Type-S*1 Topre Realforce RGB*1, 108 all 30g*1, numpad*1, 87U*1 Dell AT101W*2, Alps64*2, V80 matias quiet click*2, Quiet liner *1, WYSE ASCII *1
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
Re: Trimmed the "eyebrow" on my model F XT
« Reply #1 on: Thu, 14 June 2018, 11:52:01 »
Are the "ears" the leg/incline adjuster knobs?
« Last Edit: Thu, 14 June 2018, 12:13:29 by Zuology »
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
Offline ag36
« Reply #2 on: Thu, 14 June 2018, 11:53:53 »
Are the "ears" the leg/include adjuster knobs?
Yes, I am thinking of trimming it short.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #3 on: Thu, 14 June 2018, 11:57:29 »
I've always thought making the "ears" completely flat would be a good look for an F.
« Reply #4 on: Thu, 14 June 2018, 12:46:55 »
I kind of like the pencil tray but the ears can definitely go.
- D Trump 2026-10-24
Offline ag36
« Reply #5 on: Thu, 14 June 2018, 20:03:51 »
I think I'll get rid of the riser feet too on my next restoration, lot of work to fill it. :)
I've polished the matte coat with polishing paste, need to prep it better next time for better result.
Offline ag36
« Reply #6 on: Wed, 20 June 2018, 13:51:02 »
I modded my XT a bit further, maybe too much. Unfortunately the filler I used shrunken after most work were done(after a day of curing after several refilling and sanding), too tired to rework therefore it will be as it is for now.
« Last Edit: Wed, 20 June 2018, 13:53:20 by ag36 »
« Reply #7 on: Wed, 20 June 2018, 15:35:18 »
I was thinking you were going to pull the feet, snip the ears, then smooth out that part of the foot so you still had the circle showing in the case.  But this approach works too.
I think it looks good.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #8 on: Wed, 20 June 2018, 15:43:45 »
This is hot, and makes me want one really badly
