Author Topic: [IC] GMK Carbon R2  (Read 246413 times)
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
[IC] GMK Carbon R2
« on: Thu, 05 July 2018, 14:48:21 »
KITS ARE LOCKED!
I am open only for changes which do fix some major issues if there are any.
Dear fellow geeks,
i welcome you to the interest check for GMK Carbon Round 2 which will probably happen on Massdrop in Q4 of this Year (german fiscal year format). So we got some time and i want to use it for getting useful and constructive feedback for the upcomming drop.
GMK Carbon Round 1 owners will be able to get some addons since its using still the same custom colors. Tho not all kits will be compatible with GMK Carbon Round 1. The reason: I am very passionate about this hobby and i am in mad love with Cherry profile and i decided to focus in this round onto vintage Cherry profile. Most of you heard probably about the row 0 and row 5 which you will find on some vintage Cherry boards but also in some current GMK Groupbuys. For example recent Triumph Adler Groupbuy which i joined in a heart beat after it went online.
However most of groupbuys do utilze only rows 1,2,3 and 4. This is because row 5 is missing 1.25u key which is crucial for most modern layouts and making a new mold for it is actually an expensive investment. In general any key mold is expensive and please dont mix it with legend molds. So in this round i want to take the chance and introduce 1.25u key for row 5, which will make Cherry profile complete from my enthusiastic point of view. I hope this fruits and i hope if the mold gets build it will be used extensively in all upcoming GMK keyset projects. Also it may motivate keyset designer to rerun their keysets which i would love to see.
Anyway let me show you how a full Cherry profile looks like from the side:
Keep in mind i am using modern row notation. Afaik in cherry dicumentation the rows are called (from left to right): F, E, D, C, B, A
So this side view displays also how the base sets for round 2 will be. Being honest i can say setting up the full cherry profile kits was quite challenging since i had to rethink all the established kit designs. The additional rows 0 and 5 do requiring more keys in order to cover some important basic layouts.
GMK Carbon round 2 will probably drop in November or December of 2018
So enough said and i dont like to write much. Here are the kits for Round 2.
Base kits
Upgrade for Round 1 GMK Carbon - DISCARDED  :'( :'( :'(
Extension kits
Novelty kits
Kits are not final and are subject to change. Base kits are almost complete and if i dont discover some major flaw they will get only minor changes.
If you dont see the kit you desire dont worry here is my ToDo list with missing kits:
- Definitely Spacebar kit (need some confirmations in order to make it) done
- Definitely International kit (NORDEUK) done
- Definitely Dvorak and Colemak kit. done
- Definitely a kit with some usefull extra keys like vertical function keys. discarded
- Definitely a kit with icon bottom row ala Yuri. Considering also OS specific keys like for win or macos partially done and partially discarded
- Probably Upgrade kit for round 1 to Vintage rows. done
- Probably 40% kit done
- Probably beige mods with og icons like Bone base kit and some sugar keys like in alpha extensions (see the bee caps lock key in Beezarre alphas) done
- Probably any idea i get...
If you want to provide any constructive and usefull feedback/suggestion then please respond below. I will be thankfull.
Please keep in mind i read every response and consider every made suggestion but i am not obliged to make every suggestion reality.
Thank you for your attention.
« Last Edit: Mon, 29 October 2018, 16:28:33 by T0mb3ry »
Offline T0mb3ry
    • Flickr
Re: [IC] GMK Carbon R2
« Reply #1 on: Thu, 05 July 2018, 14:48:38 »
Banderole style for Carbon base and Bone kits is the same as of deskmats.
Novelkeys x T0mb3ry Deskmats
Some nice renders by Oblotzky:
« Last Edit: Tue, 23 October 2018, 17:26:16 by T0mb3ry »
Offline T0mb3ry
    • Flickr
« Reply #2 on: Thu, 05 July 2018, 14:48:51 »
Reserved.
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #3 on: Thu, 05 July 2018, 14:51:09 »
Nah
Offline xondat
  • i'm not a star
« Reply #4 on: Thu, 05 July 2018, 14:51:57 »
If R0/5 full coverage, yes.
Otherwise no.
Offline dimo
« Reply #5 on: Thu, 05 July 2018, 14:52:32 »
I like the orange/gray alphas
Offline T0mb3ry
    • Flickr
« Reply #6 on: Thu, 05 July 2018, 14:55:37 »
Thats Carbonski alphas which i am not introducing because it will intersect with already running skidata ic.
Otherwise no.
As you can see its full coverage ;)
Offline wodan
« Reply #7 on: Thu, 05 July 2018, 14:56:16 »
Moister than an oyster!!!
Offline Poesjuh
[IC] GMK Carbon R2
« Reply #8 on: Thu, 05 July 2018, 14:56:51 »
LET’S GO BOOOISSSSS
@T0mb3ry
Would an accent kit with the orange caps be possible? So just the arrows, enter and escape.
I’m aware these are part of the base however when you buy the Bone kit you won’t get these.
« Last Edit: Thu, 05 July 2018, 15:01:49 by Poesjuh »
Offline dimo
« Reply #9 on: Thu, 05 July 2018, 14:56:59 »
Oh, I meant those as two separate entities (i like the gray alphas, and orange alphas)
Offline avid
« Reply #10 on: Thu, 05 July 2018, 15:00:28 »
Love this, the grey alphas will be amazing.
Is there any ETA when this is going to be ran? After space cadet i assume?
Offline Vigrith
« Reply #11 on: Thu, 05 July 2018, 15:05:06 »
R0 R5.
Offline Hokabuki
« Reply #12 on: Thu, 05 July 2018, 15:11:40 »
Really like the R1 1u backspace in base and bones base. Any reason the base is text and the bones is icon?
Offline T0mb3ry
    • Flickr
« Reply #13 on: Thu, 05 July 2018, 15:25:58 »
Added banderole and deskmats styles.
You are welcome buddy  ^-^
Hope to meet you again if Mechanicon happens again this autumn ;)
As i wrote in the beginning, somewhere in Q4.
Is in consideration. Probably part of the kit with vertical function keys which i forgot to mention.
Yes the reason is quite simple. Designwise its better to use only icon style on high contrast (beige/gray) and text + icon on lower contrasts(orange/gray). Ofcourse i am trying also to provide more choices and reach out to people with different taste.
Offline pentawater
« Reply #14 on: Thu, 05 July 2018, 15:30:45 »
Definitely getting bone
Offline oh_chesteroni
« Reply #15 on: Thu, 05 July 2018, 15:32:47 »
Don't have any constructive feedback as the kits you've posted are perfect for my needs. I am interested in a 40% kit however, and will be following your progress on that.
Looking forward to the GB!
Offline neon_tom
« Reply #16 on: Thu, 05 July 2018, 15:36:40 »
+1 for proper Row 0/5 support. Also interested in a 40s/Planck kit.
Offline wangledorf
  • Formerly pewing
« Reply #17 on: Thu, 05 July 2018, 15:37:43 »
Very interested. I'm a big fan of R0/R5 support and appreciate there being plenty of options for novelties that aren't just R1 so I can cover my ergonomic layouts.
Offline Vadurr
  • Valar Morghulis
« Reply #18 on: Thu, 05 July 2018, 15:42:58 »
Definitely in for a bones base kit :)
Edit: Any chance we can get 6mm thick 36x18 mousepads as well?! I need this!!!
Edit2: Any chance for full icon mods for the bones base as well? Love it regardless.
« Last Edit: Thu, 05 July 2018, 15:48:42 by Vadurr »
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #19 on: Thu, 05 July 2018, 15:47:31 »
Very interested. Any idea of price yet? Will this also be on MassDrop?
Would be interested in Apple legend keys. Or maybe an OS compatibility kit?
Offline KaosJ
« Reply #20 on: Thu, 05 July 2018, 15:52:38 »
FINALLY IS HAPPENING  :D
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #21 on: Thu, 05 July 2018, 15:58:58 »
very interested in bone and boneyard.
Offline KaosJ
« Reply #22 on: Thu, 05 July 2018, 16:00:36 »
BTW hyped for R0-R5 and deskpad, gj Tomb3ry  :thumb:
What about EU proxy this time?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #23 on: Thu, 05 July 2018, 16:01:15 »
Interested in Boneyard as well, but as has been mentioned to you, it would be grand if you continue to support R1 buyers by splitting new keys into a key that allows for R0/R5 support for users of the R1 set.
« Last Edit: Thu, 05 July 2018, 16:03:56 by LightningXI »
Offline T0mb3ry
    • Flickr
« Reply #24 on: Thu, 05 July 2018, 16:01:33 »
Please check the last lines in my first post. This will give you some answers. Also people asking for planck kit , its already there look for ergoplanck.
Offline T0mb3ry
    • Flickr
« Reply #25 on: Thu, 05 July 2018, 16:04:10 »
Interested in Boneyard as well, but as has been mentioned to you, it would be grand if you could support R1 buyers by splitting new keys into a key that allows for R0/R5 support for users of the R1 set.
We already discussed this in slack. As you have seen such kit will be enormous due to the two base sets i am offering. Anyway the idea is not from the table and i will still look into it ;)
Offline Yeoh
« Reply #26 on: Thu, 05 July 2018, 16:07:16 »
lol already?
Like there isnt a long enough lineup at GMK for sets, and the market isnt fully saturated already?
Offline oldcat
  • 65% is Life
« Reply #27 on: Thu, 05 July 2018, 16:13:40 »
ALL IN.
Offline smurkcity12
« Reply #28 on: Thu, 05 July 2018, 16:14:07 »
Very excited about the new ergodox kit! It was my first set I put on my ergodox and looking forward to the update.
Offline oldcat
  • 65% is Life
« Reply #29 on: Thu, 05 July 2018, 16:15:07 »
Let's get this dropped soon.
ALL IN ALL KITS.
Offline enrique.aliaga
« Reply #30 on: Thu, 05 July 2018, 16:19:12 »
Interested if it doesn’t happen at the same time as GMK Skidata. Yay!
Offline Chimera
« Reply #31 on: Thu, 05 July 2018, 16:22:51 »
SA isn't for me, but GMK is. I'm in for R2.
Edit: would want base, novelties, and warning signs
« Last Edit: Thu, 05 July 2018, 16:38:38 by Chimera »
Offline manzel
« Reply #32 on: Thu, 05 July 2018, 16:33:01 »
Damn, my poor wallet!
Offline duynguyenle
  • Personal text? What personal text???
« Reply #33 on: Thu, 05 July 2018, 16:36:37 »
R0 and R5 with full coverage is probably an instant buy for me. Any rough ideas of pricing in terms of making up the cost of the new moulds?
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline The_judge_168
« Reply #34 on: Thu, 05 July 2018, 16:46:00 »
Greys look great, will be in for a set
Offline T0mb3ry
    • Flickr
« Reply #35 on: Thu, 05 July 2018, 16:49:21 »
So far no info on that. But guess it will be affordable if done on a big scale. I hope for this.
Offline kwerdenker
    • thinkkwer.eu
« Reply #36 on: Thu, 05 July 2018, 16:53:59 »
Finally the chance to get my white whale of keysets! Love the possibility of full R0/R5 profile
Offline konstantin
  • Formerly constexpr
« Reply #37 on: Thu, 05 July 2018, 17:03:22 »
Let's work toward that big scale. In for bone.
Offline pvd
« Reply #38 on: Thu, 05 July 2018, 17:18:06 »
Ergoplanck kit looking benjamin beefy
Offline neon_tom
« Reply #39 on: Thu, 05 July 2018, 18:22:56 »
Wait, why icon mods for bone and standard mods for Carbon?
Offline PaultheSloth
  • JW Double Black
« Reply #40 on: Thu, 05 July 2018, 18:39:53 »
Will we see the standard R4 bottom row as an option for those that may prefer R1 to 4?
Polaris|Leaf60|QXP|DC60|Planck|SKB60|Tokyo60|UT-47|AnnePro
Offline whitty
  • Formerly dsw_408
« Reply #41 on: Thu, 05 July 2018, 19:12:30 »
Any chance for Hiragana alphas?
Offline wholypantalones
  • text and icon mods plz.
« Reply #42 on: Thu, 05 July 2018, 19:24:50 »
Goin down on some bones.
Offline a_ak57
« Reply #43 on: Thu, 05 July 2018, 19:26:27 »
Oh FFS, I spend a bunch of money on SA Carbon R2 and now you have to throw out a fully kitted R0/R5 GMK version?
Offline hineybush
  • student of error
« Reply #44 on: Thu, 05 July 2018, 19:35:44 »
My only suggestion (made it in Slack as well) is to change the Num/Scroll Lock legends to the ones from TA:
At least on the bone set.
Offline lemur
  • personal text
« Reply #45 on: Thu, 05 July 2018, 19:42:34 »
please no!
keyboards
Offline hineybush
  • student of error
« Reply #46 on: Thu, 05 July 2018, 19:49:35 »
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #47 on: Thu, 05 July 2018, 19:56:47 »
No no no no. Please no!!!! I'm so sick of the weeb alphas already...
« Reply #48 on: Thu, 05 July 2018, 19:59:25 »
how do you delete someone else's post
Offline THRILLHOIAF
« Reply #49 on: Thu, 05 July 2018, 20:18:21 »
a kit that replaces all alphas with the salty novelty?
