Author Topic: [IC] GMK Carbon R2  (Read 249646 times)
Offline Atredl
Re: [IC] GMK Carbon R2
« Reply #400 on: Mon, 06 August 2018, 09:37:01 »
Ok it seems like you can use any notation for periodic table as long you provide some format description for it. But indeed there is only one unified standard notation which is used for current Carbon Element novelty.
However the standard notation does not work well with cherry profile alignments. In this case i want to suggest slightly different notation format. Since that novelty is truly for people who has some knowledge in chemistry, i think it will be easy for them to recognize the notation format.
I知 a fan of the decimal mass. I also usually round it to 12 but I like the accuracy of including more numbers. As long as it値l look clean on a keycap, my vote is for the longer number.
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #401 on: Mon, 06 August 2018, 10:04:20 »
If you don't use 12.0107 u ア 0.0008 u then i'm not buying it
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #402 on: Mon, 06 August 2018, 12:24:05 »
Maybe there could be a special right SHIFT keycap just for you.
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
« Reply #403 on: Mon, 06 August 2018, 14:17:01 »
hineybush was pretty much clear he wants a 12.0107u key  :p
Offline hineybush
  • student of error
« Reply #404 on: Mon, 06 August 2018, 14:25:15 »
Offline dvorcol
« Reply #405 on: Mon, 06 August 2018, 16:43:21 »
Sorry, I missed the U.  But looking at it anyway, ENTER is a great size if you wanted that legend.
Offline T0mb3ry
    • Flickr
« Reply #406 on: Mon, 06 August 2018, 17:00:33 »
In case for Carbon periodic table notation i want to keep atomic mass as decimal notation for a while. Some renders will show later if its bussy or not. If yes i will simplify it.
I like this actually but i got already graphene enter for novelty. I would like to keep the periodic notation on the C key. Imo it gives one elegant and handsome touch ;)
Offline dvorcol
« Reply #407 on: Wed, 08 August 2018, 23:46:50 »
Then, since the CAPS LOCK is often used for other purposes, how about a 1.75U periodic table C keycap?
Offline dvorcol
« Reply #408 on: Wed, 08 August 2018, 23:53:26 »
hineybush, were you really requesting a huge spacebar at first?  From Wikipedia: "The unified atomic mass unit or dalton (symbol: u, or Da) is a standard unit of mass that quantifies mass on an atomic or molecular scale (atomic mass). One unified atomic mass unit is approximately the mass of one nucleon (either a single proton or neutron) and is numerically equivalent to 1 g/mol."
Offline Atredl
« Reply #409 on: Wed, 08 August 2018, 23:56:08 »
Offline dvorcol
« Reply #410 on: Thu, 09 August 2018, 00:09:34 »
Just voicing ideas, since that is one of the purposes of an [IC].  I love the 1U C and am using it on my SA Carbon keyboard.  But since there are graphene keycaps for many different sizes/rows, I was thinking there could be a novelty C in addition to the base alpha C.
« Last Edit: Thu, 09 August 2018, 16:10:44 by dvorcol »
Offline OracleKev
« Reply #411 on: Thu, 09 August 2018, 01:01:14 »
Kinda like this.  A lot of space to play with~
Offline Water lee
« Reply #412 on: Thu, 09 August 2018, 08:14:29 »
more pic
make it better!
Offline hineybush
  • student of error
« Reply #413 on: Thu, 09 August 2018, 12:09:15 »
it was all a joke, the u was copied directly from wikipedia or something lol. i didn't mean i wanted a 12ish-unit spacebar
Offline T0mb3ry
    • Flickr
« Reply #414 on: Fri, 10 August 2018, 13:42:55 »
Update
I could get a view on approximate pricing for GMK Carbon base set.
If we consider the very generous coverage of the base set and the vintage row factor, which will require new molds (exactly atleast two molds for each shot), the price is justified in my opinion. Ofcourse i will not be able to share it with you and the pricing is also not set in stone yet.
Anyway i decided to keep vintage rows.
Otherwise i got some updates for some kits.
Beezare and Boneyard alphas
- Added accent F Row keys for classic color schema.
Novelties
- Redesigned Carbon periodic table key in order to match Cherry style.
Offline Marutks
« Reply #415 on: Fri, 10 August 2018, 14:13:44 »
when is this GB going to start?
Offline T0mb3ry
    • Flickr
« Reply #416 on: Fri, 10 August 2018, 14:30:28 »
Most probably November or December.
Offline online
« Reply #417 on: Fri, 10 August 2018, 14:45:31 »
Is the grey mod use the same grey as GMK Oblivion?
Offline T0mb3ry
    • Flickr
« Reply #418 on: Fri, 10 August 2018, 14:50:18 »
Carbon and Oblivion do share same base color for mods. So if you got GMK Oblivion you can purchase Boneyard alphas and mix it with Oblivion mods in order to achieve monotone set but with mods legends in oblivion colors ;)
Offline online
« Reply #419 on: Fri, 10 August 2018, 14:54:51 »
awesome. count me in!
Offline T0mb3ry
    • Flickr
« Reply #420 on: Fri, 10 August 2018, 15:15:42 »
Tho keep in mind this combo will not work on layouts with numpads like 100% or 1800. The reason for this is that all the alpha extensions (beezare and boneyard alphas) are designed to be combined with Carbon or Bone base sets and because of this they are using row 5 bottom row on numpad alphas.
Offline dvorcol
« Reply #421 on: Fri, 10 August 2018, 16:51:05 »
Because of R5, is the profile of the numpad ENTER different from the numpad "+"?  I ask because these two vertical keys have the same profile in SA.  But are they different in GMK even if the bottom row is R4?
Offline T0mb3ry
    • Flickr
« Reply #422 on: Fri, 10 August 2018, 17:14:04 »
Exactly. The numpad enter and "+" keys (both 2u vertical) are different compared to SA profile. And there is more to it.
- In SA profile those keys has the same shape.
- In Cherry profile they are different. Also there is a difference between numpad enters on cherry profile, depending on the bottom row. There is an vintage (row 4 to row 5) numpad enter and there is an 'modern' (row 4 to row 4) numpad enter. That explains why kits like Round 1 Upgrade kit or Xtra 4.0 kit include their specific numpad enter keys.
Offline dvorcol
« Reply #423 on: Fri, 10 August 2018, 20:29:17 »
Thanks for the detailed explanation.  In most layout renders, these 2U vertical keycaps have two different row labels so I am never sure what profile they actually have.  Same with the vertical keycaps in ErgoDox kits.
Oh, one more question: In SA profile, are these vertical 2U keycaps R3?
Offline T0mb3ry
    • Flickr
« Reply #424 on: Sat, 11 August 2018, 02:12:27 »
Yes, in SA Profile the vertical numpad keys are 2U Row 3 keys.
Offline thelaughingman
  • Simultaneously the most starry-eyed idealist and t
« Reply #425 on: Sat, 11 August 2018, 04:33:04 »
Update
Novelties
thank you sweet lord!  :thumb:
Offline silversung
« Reply #426 on: Sat, 11 August 2018, 09:15:16 »
Perfect timing to put some money together, and the vintage row stays! It's like my dream GB.
Question is, which set do I go for? Preferably all of them, I think...
Offline polarsolar
« Reply #427 on: Sat, 11 August 2018, 10:45:15 »
I used to be a chemist, so this set is a must-buy.  :p  You could say the decision is elementary.  Or maybe that the keyset is guaranteed to get a reaction.  (No?)
Love the new carbon periodic table novelty.  Is there going to be a R2 version in the DC kit?
Offline coffeeshopcoder
« Reply #428 on: Sat, 11 August 2018, 13:11:05 »
This is awesome!!! Now I need to get those boneyard alphas as well
Sent from my Nexus 6P using Tapatalk
Offline Cas
« Reply #429 on: Sun, 12 August 2018, 03:56:45 »
Have you decided if there will be os keys, win and Mac?
Offline oldcat
  • 65% is Life
« Reply #430 on: Sun, 12 August 2018, 12:30:26 »
all kits, all kits
Offline T0mb3ry
    • Flickr
« Reply #431 on: Sun, 12 August 2018, 12:33:30 »
Carbon has already too many kits for an GMK keyset, so i discarded that idea.
In SP SA Carbon R2 i offered those keys for DC Kit too. I do not promise but i'll look into it.
Offline T0mb3ry
    • Flickr
« Reply #432 on: Mon, 13 August 2018, 12:13:39 »
Update
DC kit
 - Added Carbon periodic table novelty.
« Reply #433 on: Tue, 14 August 2018, 13:36:21 »
Would you consider adding a Mac command opt keys to the bone icon extension ? Or perhaps even going full micons (assuming mito gives his thumbs up) for the bone icon extension ?
Offline T0mb3ry
    • Flickr
« Reply #434 on: Tue, 14 August 2018, 14:24:38 »
Update
Bone base kit
 - Added orange accent keys.
Ivory mods
 - Removed exotic keys like windowed keys etc. in order to bring it on pair with modifiers offered in other kits. If i do not offer a kit for exotic keys (like windowed keys) for base sets then there is no sense to offer it in ivory mods since it makes it only more expensive.
If i would treat MAC OS in special way then i need to treat other OS in the same way. Say i need then to add other OS specific keys for XY Operating Systems. The kits are already enormous and i dont want to add any niche keys.
Regarding Micons, i do have already to many kits for a GMK set and i dont have any plans right now for more kits.
Offline Poesjuh
« Reply #435 on: Tue, 14 August 2018, 14:26:08 »
Update
Bone base kit
Ivory mods
WOOOOEEEEEEHHH Orange accents! Let's GOOOOOOOOOOOOO.
ps; orange arrows no? :P
Offline T0mb3ry
    • Flickr
« Reply #436 on: Tue, 14 August 2018, 14:31:59 »
Ooooooh maybe? I'll look into it, becuase Carbon base has accent arrows too.
Offline Poesjuh
« Reply #437 on: Tue, 14 August 2018, 15:21:46 »
I know I know. I値l forgive you if you don稚 add it ;) I知 already really excited because of the R0-5, the accent keys make it even better now!
Sent from my iPad using Tapatalk
Offline T0mb3ry
    • Flickr
« Reply #438 on: Tue, 14 August 2018, 16:08:48 »
Update
Bone base kit
 - Added orange accent arrows.
Offline Poesjuh
« Reply #439 on: Tue, 14 August 2018, 16:11:41 »
Update
Bone base kit
Offline T0mb3ry
    • Flickr
« Reply #440 on: Tue, 14 August 2018, 16:22:36 »
Btw i think the gray accent function keys (f1-f4 and f9-f12) in Bone base kit are absolete. They are available in Boneyard alphas. Carbon base kit has different accent function keys available but it cant be really compared with the Bone base kit, because both are using different color schemas. Anyway i'll leave those accent keys in bone base kit for time being and i will decide later if they should stay there. Right now Bone base kit has one key more than Carbon base kit.
« Reply #441 on: Tue, 14 August 2018, 18:43:36 »
I don't like orange accent keys in Bone base, so now it's down to just Boneyard + Ivory for me :)
Offline fouras
« Reply #442 on: Wed, 15 August 2018, 02:38:32 »
This might have been deliberate, but you're missing a scooped 5 cap for the numpad in all applicable kits and barred Fs and Js in the Beezarre and Boneyard kits.
Offline T0mb3ry
    • Flickr
« Reply #443 on: Wed, 15 August 2018, 04:43:07 »
Good catch. I will add these missing keys in the next update.
Offline polarsolar
« Reply #444 on: Wed, 15 August 2018, 09:05:31 »
DC kit
Great, thanks!   :thumb:
Offline T0mb3ry
    • Flickr
« Reply #445 on: Wed, 15 August 2018, 10:07:25 »
Update
Carbon base kit
 - Added scooped homing numpad key.
Bone base kit
 - Removed for classic color scheme obsolete accent function keys. They have been moved to Boneyard alphas in previous update.
Beezarre alphas
 - Added bared homing keys for alphas and scooped homing key for numpad.
Boneyard alphas
Rolling bones
 - Added scooped homing key for numpad.
Offline petamva
« Reply #446 on: Wed, 15 August 2018, 10:33:07 »
Carbon has many allotropes such as diamond, graphene etc. I 'd like to see some of those in the novelties kit. If you asked me i would add a R0 or R1 kit (like warning signs) with the first ten elements (H, He, Li, Be, B, C etc) but t0mbr3y knows best.
Offline petamva
« Reply #447 on: Wed, 15 August 2018, 10:43:40 »
Oops just noticed graphene is already in the novelties kit. Nice!
Offline fouras
« Reply #448 on: Wed, 15 August 2018, 12:23:24 »
For the space kit, could you add another three 1u caps so ortho users not buying the ergoplanck kit don't need two copies?
And, I think a R5 Fn cap is missing from the ivory mods kit. There's one in both base kits but not it.
Boneyard alphas
Unfortunately, there's two scooped Fs and Js now.
Offline T0mb3ry
    • Flickr
« Reply #449 on: Wed, 15 August 2018, 12:42:27 »
Thats possible. Will add in the next update.
Dang thats right. That key is missing too.
Can you mark which keys are doubled? Right now i see only F and J keys scooped showed together with alphas and barred F and J (note the bar) keys showed on the bottom.
