Author Topic: Happy Hacking Pro 2 Copying And Pasting Issue  (Read 1941 times)
Offline misterfriendly
« on: Fri, 06 July 2018, 11:09:15 »
Hi,
Anyone have this issue with copying and pasting with this keyboard? When I copy something from the web, it doesn't paste. Only copying something from notepad pastes on notepad. Copying text from notepad cuts the text as well. What is up!
Edit: I just found out accidentally CTRL+X actually copies. So since CTRL+X copies, why is CTRL+C copying and cutting text?
Edit: Sorry I just found out what the problem is. So I basically messed up when I cleaned out my keyboard and put the keys on the wrong spot. Basically, X and C are incorrectly placed.
FML
« Last Edit: Fri, 06 July 2018, 12:03:21 by misterfriendly »
Offline HotRoderX
Re: Happy Hacking Pro 2 Copying And Pasting Issue
« Reply #1 on: Fri, 06 July 2018, 12:02:58 »
would be a issue in the OS. The keyboard doesn't have anything to do with shortcut's like this.
« Reply #2 on: Fri, 06 July 2018, 12:04:18 »
lol, actually it's my own stupid mistake. I misplaced the keys when cleaning them out. Basically switched them.
Offline fluxrez
« Reply #3 on: Fri, 06 July 2018, 13:06:18 »
Lol,. Nice fix!
Offline hikashi1988
« Reply #4 on: Sat, 07 July 2018, 03:42:47 »
do touch typing then even wrong key placement shouldnt be bothering you.  ;)
