Author Topic: [IC] grid 600, a 60% chassis w/ interchangeable pieces PROTOTYPE!  (Read 87497 times)
Offline spyruf
Re: [IC] grid 600, a 60% chassis w/ interchangeable pieces PROTOTYPE!lnow
« Reply #250 on: Fri, 31 May 2019, 01:27:02 »
Does anyone know how to get in contact with zfrontier / how long a response typically takes? I need to change my shipping address. I’ve tried their email and Instagram account already.
Your best bet would be to raise a ticket through the support system they have. Login to your account and find teh support button on the bottom right corner.
I've had a reply by this method usually within a day. Emailing Alex, I've had much less success.
Thanks! Found the green support button in the bottom left.
Offline easy_rider
« Reply #251 on: Mon, 17 June 2019, 09:42:44 »
If someone wants to sell their black Grid600, send me a message! got mine  :)
« Last Edit: Tue, 03 September 2019, 16:48:00 by easy_rider »
Offline Howser
« Reply #252 on: Wed, 17 July 2019, 03:45:44 »
i vaguely remember seeing a post how someone replaced the tritium vials with something more visible during the day.
has anyone seen this as well and remember where it was?
thanks!
Offline lakeboredom
« Reply #253 on: Wed, 24 July 2019, 03:08:17 »
Anyone wanna trade their Classic Module for my Neon?
Offline coffeeshopcoder
« Reply #254 on: Sun, 28 July 2019, 00:52:51 »
PM’d
Offline PancakeMSTR
« Reply #255 on: Wed, 31 July 2019, 15:53:36 »
Does anyone happen to know what size screws the grid uses to bolt the PCB to the case?
Offline thearctican
« Reply #256 on: Thu, 01 August 2019, 08:06:46 »
They're M2 screws.
Offline easy_rider
« Reply #257 on: Tue, 03 September 2019, 16:47:32 »
Does anybody have problems with the grid600 and a macbook?
Mine works fine on a windows PC with a usb-c/usb-a cable, but won't work with a usb-c/usb-c cable on a macbook. At all. Does not appear in HID device list. Works fine if plugged straight into the PCB (a DZ60RGB).
Edit: it was the PCB. Changed to a DZ60rev3 non hotswap, works fine.
« Last Edit: Wed, 09 October 2019, 03:21:04 by easy_rider »
Offline _swagfrog
« Reply #258 on: Mon, 07 October 2019, 20:50:18 »
Will there ever be another round for this?
Offline Funkzilla
« Reply #259 on: Sat, 23 November 2019, 22:42:55 »
God, let there be another round for this??? I can begin the initial funding with my right kidney.  ;D ;D ;D
Offline DoCallMeKing
« Reply #260 on: Thu, 14 May 2020, 21:33:17 »
If anyone has a kit for sale, please let me know.
Also, I’m looking to buy a flash and neon module if anyone has one of them to sell.
Thanks a lot!
Offline smallermeesk
« Reply #261 on: Fri, 15 May 2020, 01:02:08 »
Truly hope a second run of this happens some day. Amazing design
Offline Havattack
« Reply #262 on: Fri, 02 October 2020, 23:33:15 »
I second the motion. I want one of these BAD.
Offline menuhin
« Reply #263 on: Sat, 03 October 2020, 06:14:09 »
Some examples of Grid 600 looks great.
My wish instead is a Grid 750:
- a 75% version of Grid 600
- various modules to fit at the top like the Grid 600
- some modules are function, e.g. like the LED panel of the Cybertruck / Cyberboard keyboard, or a bigger LCD panel, like those in Apple MacBook Pro, linked to the controller of the keyboard, e.g. to display layer information or time.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline Havattack
« Reply #264 on: Sat, 10 October 2020, 11:09:58 »
I 3rd the motion! I'd do things for one of these... bad things.
Also, i emailed asking about the possibility of another round, and was told they are working on a new version, a 65% so, a "Grid 650" I guess? I'm excited.
 I think 60% HHKB is the best looking layout (something about having that 1st row being shorter then the rest, is very appealing to me) but 65% and TKL for that matter, look almost as good, and are a lot more functional for me.
Offline TheNeonKnight
« Reply #265 on: Mon, 16 November 2020, 02:14:49 »
Thick Bezels as all keyboards should have, I NEED IT.
