Author Topic: [IC] grid 600, a 60% chassis w/ interchangeable pieces PROTOTYPE!  (Read 86911 times)
Offline gridishere
Here's the prototype!
201072-0201074-1201076-2
201084-3201080-4201082-5
201078-6201086-7
201088-8
The fine grit bead-blasting results in a very smooth finish ;) The "PEAKS" looks absolutely fantastic! And I am very satisfied with that!
As you can see, I also have a prototype for the "PRESS". PCB still needs more work, but it's a fun little project and it will certainly have ALPS support for those who love ALPS!
Don't for get to cast your vote in the poll VOTE HERE
Hi guys,
It's been a while :) The prototype took longer than I expected, but they just arrived! I will take some photos later today. Let's wait and see!
In the mean time, I have created a Google form where you can vote for the top pieces you prefer!
VOTE HERE
I also did more renders with GMK Violet Tendencies, enjoy!
200999-10
201001-11
Hi buddy, grid is here.
199835-12
199837-13
Last week I put a rendering of grid 600, a keyboard chassis for GH60 enthusiasts, on reddit.(
https://www.reddit.com/r/MechanicalKeyboards/comments/8waqh3/ic_grid_600_a_chassis_with_interchangeable_pieces/ )
After collecting some feedbacks and suggestions, I assume it is the right time for some updates.
grid 600 Specs:
   1. Keyboard chassis based on GH60
   2. Supports tray-mount PCB, not compatible with IKBC Poker II and GK64.
   3. Has a battery compartment (96x50x3 mm)
   4. 5.5° fixed angle
   5. Aluminum parts will be bead-blasted with fine grit.
   6. Interchangeable cover modules
Cover Modules:
   1. Type 01 "CLASSIC" : A regular, "Model F"-inspired flat top.
199839-14199851-15
   2. Type 02 "NEON" : Type 01 with 3 self-luminous tritium vials. (Red, Green, Blue)
199837-16
   3. Type 03 "PEAKS" : Form inspired by mountains.
199841-17199849-18
   4. Type 04 "FLASH" : Flat top with programmable RGB lighting.
199843-19
   5. Type 05 "PRESS" : With 4 extra programmable Keys. (Left)
199845-20
   6. Type 06 "PAPER": With a 2inch E-ink Paper. (Raspberry Pi Zero would fit in)
199847-21
Thanks to u/CubbyNINJA for the micropad idea.
Thanks to u/3NJV2 for the 8 bit graphics concept, unfortunately that won't happen but hope the E-ink paper isn't that bad.
Ideas of green cover modules with GMK Terminal by TheKey.Company comes for u/postollagenovese.
I am grateful to all your comments.
« Last Edit: Tue, 31 July 2018, 00:24:25 by gridishere »
Offline xondat
  • i'm not a star
Re: [IC] grid 600, a chassis w/ interchangeable pieces for GH60 PCBs
« Reply #1 on: Wed, 11 July 2018, 11:23:45 »
Looks interesting, any idea on price?
Offline fcoury
« Reply #2 on: Wed, 11 July 2018, 11:40:56 »
I think it's a great concept for sure. I am assuming it will be compatible with the standard 60% not listed as incompatible like dz60 or zeal60 right?
Offline gridishere
« Reply #3 on: Wed, 11 July 2018, 12:09:50 »
Pricing is not available at the moment. I hope to keep the pricing in an affordable range, sub $150 for Type 01 Classic.
Offline gridishere
« Reply #4 on: Wed, 11 July 2018, 12:10:44 »
As long as they have the same screw mounts, yes :)
Offline beekey
« Reply #5 on: Wed, 11 July 2018, 12:44:12 »
Wow, this look nice. Great idea!
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #6 on: Wed, 11 July 2018, 12:51:19 »
Price goal sounds appealing. Any colors in mind to be offered?
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline gridishere
« Reply #7 on: Thu, 12 July 2018, 02:35:37 »
A prototype has been ordered, I am trying different colors on cover modules. Will see how that turn out :)
Offline _ODIN_
« Reply #8 on: Thu, 12 July 2018, 04:14:03 »
interested
Offline SteffeMK
« Reply #9 on: Thu, 12 July 2018, 04:53:02 »
The 02 neon looks really nice, got any approximate price on that version?
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #10 on: Thu, 12 July 2018, 07:52:17 »
That's a lot of versions... I'm assuming not all will make it to production?
Sent from my LG-H990 using Tapatalk
Offline sheepish.alpaca
« Reply #11 on: Fri, 13 July 2018, 02:12:09 »
I'm interested in the Peaks version - would fit well with both Laser and Violet Tendencies, unless I'm mistaken.
Will need a price though - I've been rather hard on my wallet lately.  :-[
Offline gridishere
« Reply #12 on: Mon, 16 July 2018, 07:34:41 »
Expecting a prototype this week :) Hyped!
Offline beekey
« Reply #13 on: Mon, 16 July 2018, 10:46:11 »
Type 01 or 02 would be nice. Cool ideas. I hope this becomes reality and ist affordable.
Offline glubazoid
« Reply #14 on: Mon, 16 July 2018, 23:45:32 »
This is exciting! Love that top bezel
Offline teobeo94
« Reply #15 on: Thu, 19 July 2018, 11:51:21 »
A white color will be great if possible!
Offline bball2
« Reply #16 on: Thu, 19 July 2018, 14:19:16 »
Would probably be a bit more expensive, but blockers integrated into the top of the case are so much nicer than individual recessed ones.
Offline gridishere
« Reply #17 on: Mon, 30 July 2018, 02:13:27 »
Yes, there will be a white one!
Offline gridishere
Updates! Also, prototype just arrive and I will take some pictures later today!
Offline gridishere
Re: [IC] grid 600, a 60% chassis w/ interchangeable pieces PROTOTYPE!
« Reply #19 on: Tue, 31 July 2018, 00:25:14 »
Updated photos for the prototype, tell me what you think :)
Offline slxdegrees
  • Nerds With Keebs
« Reply #20 on: Tue, 31 July 2018, 00:47:21 »
Will the PCB support Kailh hotswap sockets?
Offline wowremy
« Reply #21 on: Tue, 31 July 2018, 04:21:15 »
This is the sexiest keyboard ive seen since CA66. Maybe im a sucker for those rounded sides.
Offline Meowsaur
  • I don't like that.
« Reply #22 on: Tue, 31 July 2018, 19:56:35 »
Immediately drawn to the peaks & their interchangeable nature.
Would look fantastic in gunmetal grey and/or white pearl (I'm a fan of mute colours).
How much does the prototype weigh?
Offline gridishere
« Reply #23 on: Tue, 31 July 2018, 22:31:13 »
If you are mentioning the small PCB for the "PRESS", no. But since this is a chassis design, you will be able to use hot swappable 60% PCB on to it.
I don't currently have plans for making the PCB for the "PRESS" hot swappable because it will be mx/alps dual support and will not have a plate to secure the switches. However, if there are enough interest, I will offer extra PCBs.
Offline gridishere
« Reply #24 on: Tue, 31 July 2018, 22:31:35 »
Thank you!!
Offline gridishere
« Reply #25 on: Tue, 31 July 2018, 22:37:20 »
Thank you :)! I don't have a proper weight to weigh it, but will do that soon.
Offline Corgiattackkk
« Reply #26 on: Tue, 31 July 2018, 22:40:01 »
The prototype looks so sleek! Interested in purchase for white with reasonable price point  ;)
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #27 on: Tue, 31 July 2018, 22:56:59 »
that overwatch menu background lookin ass top piece is sweet.
really interested in this one, very unique :thumb:
Offline gutsack
« Reply #28 on: Wed, 01 August 2018, 03:14:58 »
Wow, prototype looks terrific.
Offline Zeroblade
    • Twitter
« Reply #29 on: Wed, 01 August 2018, 11:47:45 »
That e-ink paper panel... Very neat idea.
Offline gridishere
« Reply #30 on: Wed, 01 August 2018, 22:31:41 »
The idea came from a reddit user :) all credits to him! However, the e-ink paper module may not be available for now as I will need to run more test on it.
Offline coffeeshopcoder
« Reply #31 on: Wed, 01 August 2018, 23:54:43 »
This was  .. meh - gimmicky ... at first.. now looking at the prototype, I have to say, this is an InstaBuy for me... Hopefully this wont be a  limited production run....
Will I be able to buy multiple top modules ? Like multiple colors and different modules ?
Offline ThomasTH
« Reply #32 on: Thu, 02 August 2018, 00:25:33 »
I am also in if its possible to buy different tops in different colors.
Offline gridishere
« Reply #33 on: Thu, 02 August 2018, 00:33:46 »
No, this won't be a limited run :) and yes, you will be able to have different tops in different colors for sure! And I am planning to offer 3-4 colors for the top piece
Offline gridishere
« Reply #34 on: Thu, 02 August 2018, 00:34:42 »
Yes, you will be able to do that!
Offline ErgoMacros
« Reply #35 on: Thu, 02 August 2018, 01:11:51 »
Liking a lot of things about this.
Looks like the e-paper version will be it's own USB device, so the host OS CPU will control it?
(or will the keyboard controller be able to address it directly?)
Hope this is a resounding, wonderful success!
Today's quote: '...“but then the customer successfully broke that.”
Offline Draic
« Reply #36 on: Thu, 02 August 2018, 11:25:35 »
Can I use USB-C PCBs? Will there be no problems with USB-C to C?
Offline petamva
« Reply #37 on: Thu, 02 August 2018, 14:17:56 »
This looks pretty interesting... Weight? Pcb compatibility?
Offline Jkush463
« Reply #38 on: Thu, 02 August 2018, 18:52:32 »
this is great would love to get one when the time comes for the GB!
Offline Combonaut
« Reply #39 on: Fri, 03 August 2018, 00:48:27 »
These look amazing!
Would be very interested in peaks and an RBG strip!
Some of the pics show a rose gold champagne colour, if that was available, it would be an instant buy for me.
Love your work.
Offline s1in8er
    • kevldesign
« Reply #40 on: Fri, 03 August 2018, 10:33:10 »
The prototype is stunning, really love the peaks and its blue (green?) color.
Btw, i am a bit curious about how you manage to build the surface of the chassis's side.
Is it likes the pic 1 or 2 below.
201325-0201327-1
Offline gridishere
« Reply #41 on: Sat, 04 August 2018, 00:09:41 »
E-paper may not make it's appearance in the first launch I am afraid :( But I will put more work onto it and make it happen some time soon. It will be stellar to control it via the keyboard!
Offline gridishere
« Reply #42 on: Sat, 04 August 2018, 00:13:29 »
Hi Draic,
Sure yes you can use Type-C PCBs! It will have a PCB daughter board and internal adapter cables, so mini/micro/c should all work.
Offline gridishere
« Reply #43 on: Sat, 04 August 2018, 00:28:21 »
This is not a heavy board as it has many cutouts to make room for the components for the top module pieces, weighting ~1.7kg with the bottom chassis + the PEAKS and without PCB, switches and keycaps on.
However, it will have custom rubber feet to secure it on the desktop. And will certainly explore more materials for the top piece in the future if things go well! Some might add heft and some might add functionality.
Most 60% PCBs will work! GH60, XD60, DZ60 all work fine! And I believe with some modifications, XD75RE will also work. It also has a battery compartment, so it should also support some bluetooth 60% PCBs.
Offline gridishere
« Reply #44 on: Sat, 04 August 2018, 00:30:09 »
It's happening soon! Looking forward to have it open for GB next Monday :)
Offline gridishere
« Reply #45 on: Sat, 04 August 2018, 00:34:15 »
These look amazing!
Love your work.
Thank you! Yes I will offer rose gold for the top pieces
Offline parityb1t
  • 60% or less \m/
« Reply #46 on: Sat, 04 August 2018, 05:28:22 »
Whats the final estimate price for classic?
Alps64 w/ Orange Alps | SatanGH60 Gartistotles
Offline Combonaut
« Reply #47 on: Sat, 04 August 2018, 06:17:54 »
These look amazing!
Love your work.
That's awesome, can't wait. I assume the base colours will be black and white?
Offline Aerizu
  • Professional Lurker
« Reply #48 on: Sat, 04 August 2018, 07:08:07 »
Looks interesting ;) Any information on layout support?
Offline gridishere
« Reply #49 on: Sat, 04 August 2018, 07:34:36 »
This will not come with a PCB, so you can have any layout as long as it's on a 60% PCB. I will also have blockers for WKL(1u*2) and HHKB(1.5u*2 and 2.5u*1) available.
