Author Topic: [IC] grid 600, a 60% chassis w/ interchangeable pieces PROTOTYPE!  (Read 86912 times)
Offline gridishere
Re: [IC] grid 600, a 60% chassis w/ interchangeable pieces PROTOTYPE!
« Reply #50 on: Sat, 04 August 2018, 07:51:26 »
Whats the final estimate price for classic?
The final and detailed pricing will be released soon. However, I am sad to say after factoring all the costs, it will be higher than what I originally estimated.
Offline gridishere
« Reply #51 on: Sat, 04 August 2018, 07:52:00 »
These look amazing!
Would be very interested in peaks and an RBG strip!
Some of the pics show a rose gold champagne colour, if that was available, it would be an instant buy for me.
Love your work.
Thank you! Yes I will offer rose gold for the top pieces
That's awesome, can't wait. I assume the base colours will be black and white?
Yes Black or White for the case
Offline Aerizu
  • Professional Lurker
« Reply #52 on: Sat, 04 August 2018, 08:00:24 »
Looks interesting ;) Any information on layout support?
This will not come with a PCB, so you can have any layout as long as it's on a 60% PCB. I will also have blockers for WKL(1u*2) and HHKB(1.5u*2 and 2.5u*1) available.
Oops, my bad. I didn't see that it was a tray-mount case. Thanks for the info!
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #53 on: Sat, 04 August 2018, 08:24:34 »
How much higher are we looking at here?
Offline oldcat
  • 65% is Life
« Reply #54 on: Mon, 06 August 2018, 22:12:43 »
very nice, very nice
Offline slxdegrees
  • Nerds With Keebs
« Reply #55 on: Tue, 07 August 2018, 08:07:25 »
Oh, just realized there are no plates... Hmm that's quite a dealbreaker, and not quite sure how it escaped mention this entire thread... :eek: https://en.zfrontier.com/products/grid600
« Last Edit: Tue, 07 August 2018, 08:11:47 by slxdegrees »
Offline DasGnome
« Reply #56 on: Tue, 07 August 2018, 08:13:23 »
It's tray mount. You have to source your own plate + pcb.
Offline slxdegrees
  • Nerds With Keebs
« Reply #57 on: Tue, 07 August 2018, 08:14:30 »
Oh, my bad then. And thanks for clearing that up!  :)
« Last Edit: Tue, 07 August 2018, 08:16:37 by slxdegrees »
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #58 on: Tue, 07 August 2018, 09:27:16 »
Do we have to hand-wire the module if we choose the "PRESS" option?
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline jebbra
  • jebbra.net
« Reply #59 on: Tue, 07 August 2018, 11:04:35 »
I'm sorry if I'm late but why the white top part isn't even an option  :'( an all-white Grid600 will be ultra neat!
Offline gridishere
« Reply #60 on: Wed, 08 August 2018, 23:29:48 »
NO, you don't need to hand wire it. PCB and cable are provided, all you need is to plug it into the hub.
Offline wowremy
« Reply #61 on: Thu, 09 August 2018, 20:51:51 »
Is there a photo of the purple ano we can expect?
edit: found it on the extra modules page on ZF.
« Last Edit: Fri, 24 August 2018, 15:05:08 by wowremy »
Offline coffeeshopcoder
« Reply #62 on: Fri, 10 August 2018, 12:19:50 »
will the main housing and the modules be available in the same colors ? or is the main housing black/darkgrey/while and the modules purple/green/rose gold ?
Offline slxdegrees
  • Nerds With Keebs
« Reply #63 on: Fri, 10 August 2018, 12:43:43 »
Gb is live on zfrontier. Check main post for link.
« Reply #64 on: Fri, 10 August 2018, 14:50:43 »
Oh wow . I did not realize. Thanks !!! A pity that the e-ink display module did not make it !!!
Sent from my Nexus 6P using Tapatalk
« Reply #65 on: Fri, 10 August 2018, 22:36:12 »
Simple question - how does the plate fit in the case ?
Another person already asked this, and got an answer that its a standard 60% plate can be used and its tray mount. Thats great, my question is how exactly does it fit ?
As in, does one lower the pcb and plat directly from the top ? the bottom chassis seems to be a single piece ?
Also is the left and right side of the chassis hollow ?
Offline Darknight00z
« Reply #66 on: Thu, 23 August 2018, 10:15:15 »
Love this case, but unfortunately can't afford this at the moment. Will there be a r2 planned?
Offline gutsack
« Reply #67 on: Thu, 23 August 2018, 23:03:52 »
Finally placed an order. Went with Flash.
Offline slxdegrees
  • Nerds With Keebs
« Reply #68 on: Sun, 26 August 2018, 00:54:15 »
Uh I can't for the life of me figure out how the modules are changed. Does anyone here know?
Offline gridishere
« Reply #69 on: Thu, 30 August 2018, 21:44:48 »
The switches are secured by the plate and the plate is secured by the switches too :) The 4 sides of the plate should be flush with the PCB, so you could simply put the assembled PCB and Plate into the chassis and then secure the PCB from moving by screws.
And no, the left and right sides of the chassis are solid.
Hope this answers your question.
Offline gridishere
« Reply #70 on: Thu, 30 August 2018, 21:48:57 »
The modules are secured by screws drilling from the bottom of the chassis.
To change them, you will need to unscrew (and unplug the internal connection for FLASH or PRESS) and screw them back in.
« Reply #71 on: Thu, 30 August 2018, 22:35:30 »
Perfect ! thank you !
I got in for a white powder coated chassis with a black classic and a purple 'peaks' modules.
Looking forward to this !!!
Offline esavage
« Reply #72 on: Fri, 31 August 2018, 22:02:38 »
lightbar version of this looks awesome. Definite pickup for me
Offline sneaky101
« Reply #73 on: Sun, 02 September 2018, 02:36:09 »
Bought the Press module! Love the design.  Question: does the Press PCB support backlighting?
Offline OkKarma
« Reply #74 on: Sun, 02 September 2018, 05:10:59 »
What is the ETA on production and delivery?
Offline slxdegrees
  • Nerds With Keebs
« Reply #75 on: Sun, 02 September 2018, 05:15:35 »
Dec 2018
Offline gridishere
« Reply #76 on: Tue, 04 September 2018, 06:53:41 »
Sure, will have RGB support and you dont need to solder the LEDs :). Updates soon!
Offline OkKarma
« Reply #77 on: Tue, 18 September 2018, 11:39:25 »
Any update?
Offline glubazoid
« Reply #78 on: Fri, 19 October 2018, 00:55:51 »
Any updates?
« Reply #79 on: Fri, 19 October 2018, 14:13:55 »
On the zfrontier updates page it says "Order submitted. On schedule." from Oct 9th
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #80 on: Fri, 19 October 2018, 15:14:15 »
R2 Please  ^-^
« Reply #81 on: Tue, 27 November 2018, 17:34:29 »
Any updates?
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #82 on: Sat, 01 December 2018, 15:59:44 »
Id be curious to know how many of these cases were ordered? Does anyone know?
Offline glubazoid
« Reply #83 on: Thu, 06 December 2018, 00:58:51 »
Are we still on time for a Dec. shipping date?
Offline DukeEsquire
« Reply #84 on: Thu, 06 December 2018, 01:25:36 »
I'm interested in changing my black keyboard with the white one instead. Is there any way to do that?
Offline Jkush463
« Reply #85 on: Thu, 06 December 2018, 02:11:17 »
jeez a little late for a major change no? lol that something you should have sorted out long ago i feel but message ZF.
Offline LevelSteam
« Reply #86 on: Thu, 06 December 2018, 07:41:11 »
Hope this runs again at some point. I really regret not grabbing one at the time....
« Last Edit: Mon, 10 December 2018, 21:26:01 by LevelSteam »
Offline RETURNISO
« Reply #87 on: Sun, 09 December 2018, 19:45:00 »
Hope this runs again at some point. I really regret not gravving one at the time....
Same. I really, really hope it will run again! Looks super crisp what he is doing with it  :eek:
Check this update on https://www.zfrontier.com/post/detail/11040
« Reply #88 on: Mon, 10 December 2018, 15:31:21 »
Finally an update!!
I hope we can receive the boards before CNY!
Offline gutsack
« Reply #89 on: Fri, 14 December 2018, 16:28:59 »
Had momentary shock the other day when I received a shipping notice from zFrontier that claimed it contained both my Leaf and grid in the same shipment, which I didn't think was possible. Package arrived today and, of course, it contained only the Leaf. Makes sense, but :'(
(Edit: typo)
Offline PancakeMSTR
« Reply #90 on: Sat, 15 December 2018, 18:44:15 »
So what's the status on the grid? Getting slightly anxious from lack of updates.
Offline rdg
« Reply #91 on: Sun, 16 December 2018, 15:21:56 »
They posted an update on keebtalk Dec 5th
https://www.keebtalk.com/t/gb-grid-600-group-buy-is-here-updates/3156/42
There is an update, please check:
https://www.gridishere.com/updates/module4-flash-module-5-press-updates-and-more/
Thank you~
The shipping will happen between Dec 2018 and Jan 2019. We are pushing our vendor but quality is the first concern.
Offline lakeboredom
« Reply #92 on: Thu, 27 December 2018, 03:14:36 »
Are we ever going to be refunded for the Neon modules in US orders?
Offline 2ndRoad805
« Reply #93 on: Fri, 28 December 2018, 00:14:35 »
Any word on an r2?
« Reply #94 on: Fri, 28 December 2018, 08:04:45 »
Any word on an r2?
lol.
This current run is behind schedule already :(
Offline PancakeMSTR
« Reply #95 on: Fri, 28 December 2018, 11:40:53 »
I'm increasingly worried that the thing won't ever ship, let alone that we'll get refunds.
Offline lakeboredom
« Reply #96 on: Fri, 28 December 2018, 13:21:57 »
Lol youre talking to someone still waiting for his Elemento Fr87. I trust Zfrontier.
« Reply #97 on: Fri, 28 December 2018, 14:13:43 »
I can't tell if that is sarcastic or not. :O
Offline lakeboredom
« Reply #98 on: Fri, 28 December 2018, 14:31:57 »
Neither can I tbh ;p
Offline Jkush463
« Reply #99 on: Fri, 28 December 2018, 16:48:23 »
gonna go ahead and guess well never see refunds, ZF is a jokee
