Author Topic: [GB] ALF DC60 (100% shipped)  (Read 164703 times)
Offline driftingbunnies
Re: [GB] ALF DC60
« Reply #100 on: Sun, 15 July 2018, 14:01:48 »
Would an XD75 fit in this case? Similar issues with other 60% cases?
Offline DocNoc
Re: [GB] ALF DC60
« Reply #101 on: Sun, 15 July 2018, 15:21:05 »
Do you have any more pics of the cases    uwu
« Last Edit: Fri, 20 July 2018, 15:11:50 by DocNoc »
Offline rickard.von.essen
Re: [GB] ALF DC60
« Reply #102 on: Sun, 15 July 2018, 15:32:37 »
Any more info on the PCB? I assume it supports split space bar? What MCU does it have? Does is support Alps? etc, etc..
Offline DocNoc
Re: [GB] ALF DC60
« Reply #103 on: Sun, 15 July 2018, 15:51:11 »
PM'd about gb google doc
Offline oldcat
  • 65% is Life
Re: [GB] ALF DC60
« Reply #104 on: Sun, 15 July 2018, 16:37:12 »
Damn can't even decide on which color. I want to get the Everest White but can't think of a keyset to put it on!
Xda oblique maybe good... but that keyset won’t ship till Nov
Offline asury
  • /u/adsury/
Re: [GB] ALF DC60
« Reply #105 on: Sun, 15 July 2018, 18:22:18 »
Black and White only will looks stunning IMO, like a stormtrooper theme:
GMK Monochrome - still IC
GMK originative / JTK WoB
or just a simple Blank Gateron/PBT
Grey Duck Sidewinder/GMK Hyperfuse Origins/MX Black retooled | Sage M60-A/GMK Camping/Holy Sky | LFK68/DSA Granite Alps/SKCM Orange Alps
Offline ilouis_07
  • Never Forget Your Origin
    • ILUMKB
Re: [GB] ALF DC60
« Reply #106 on: Mon, 16 July 2018, 01:16:45 »
i think so.
Offline oldcat
  • 65% is Life
Re: [GB] ALF DC60
« Reply #107 on: Mon, 16 July 2018, 01:17:39 »
Is it possible to add a brass plate as an option?
Should be able to buy one from kbdfans I think. I bought a 60% brass plate there
There are also some very nice brass plates on keyclack and mekanisk, much higher quality than the kbdfans.
Will check them out. I haven't received mine from kbdfans yet. But I am indeed looking for something higher quality.
Keep in mind that for US buyers, 1Up prices include shipping!
I’m curious as to which brass plate provided by 1up supports arrow clusters? I cannot seem to figure out. Any experience?
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #108 on: Mon, 16 July 2018, 01:38:27 »
replied pm. Thanks:)
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #109 on: Mon, 16 July 2018, 01:46:43 »
1)PCB can support split spacebar. 2)qmk fireware 3)cant support alps 4)etc etc etc... :D
Offline glubazoid
Re: [GB] ALF DC60
« Reply #110 on: Mon, 16 July 2018, 01:49:45 »
Long time lurker on this site but this case seems too god to pass by- I can't decide whether to get this or wait for the Deluxe version!
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #111 on: Mon, 16 July 2018, 02:18:03 »
model you check in photo.
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
Re: [GB] ALF DC60
« Reply #112 on: Mon, 16 July 2018, 02:38:16 »
That was super helpful! Would you mind sharing some of the possible split spacebar layout which the plate supports? Essentially, I'm just trying to see if I could pair the type A plate from this GB with a different 60% PCB that also supports split spacebar layout (such as YD60 or DZ60).
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #113 on: Mon, 16 July 2018, 02:39:59 »
If I may ask, what's the measurement of the battery slot?  I got a battery which size is 6mm x 36mm. Do you think it will fit?
here we go:D
115mm x 65mm
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #114 on: Mon, 16 July 2018, 03:04:40 »
updates for plate issue:we will mod 2 parts for current plate type B
1) last row cant support split spacebar for type B
2) enter key can support ISO for type B
« Last Edit: Mon, 16 July 2018, 09:08:16 by ilouis_07 »
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #115 on: Mon, 16 July 2018, 03:06:45 »
i already updated this issue to alf designer. we will mod it soon.
« Last Edit: Mon, 16 July 2018, 09:04:59 by ilouis_07 »
Offline Choppersuey
Re: [GB] ALF DC60
« Reply #116 on: Mon, 16 July 2018, 05:10:36 »
Do you think you could add a fixed plate for a cleaner look? I’m going for the same layout as in the prototype picture. I think it would be much nicer than a swiss cheese plate.
Offline wixxzblu
Re: [GB] ALF DC60
« Reply #117 on: Mon, 16 July 2018, 05:57:35 »
updates for plate issue:we will mod 2 parts for current plates.
1) last row cant support split spacebar for type B and Type C
2) enter key cant support ISO for type B and Type C
final goal: All the plates can support split spacebar and iso at same time.
Please DONT change plate C, i dont want ISO support or split space bar. As Choppersuey said, please keep it 'fixed' layout.
Make Plate B the universal plate and keep plate C more standard ANSI.
Offline otanishock
  • ファーストラブ
Re: [GB] ALF DC60
« Reply #118 on: Mon, 16 July 2018, 06:19:24 »
If that's the case then what's the difference between them all??
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #119 on: Mon, 16 July 2018, 09:02:30 »
OK good idea! Thanks
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #120 on: Mon, 16 July 2018, 09:05:49 »
ok:)
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #121 on: Mon, 16 July 2018, 09:11:05 »
i think it is a good point that we mod type B plate into universal plate. we forgot to do this during IC period, i should apologize for that:(
Offline wixxzblu
Re: [GB] ALF DC60
« Reply #122 on: Mon, 16 July 2018, 09:13:27 »
ye sounds very good to me.  :thumb:
Plate A = 2u shift
Plate B = Universal
Plate C = ANSI
Offline onefivenine
    • Project Keyboard LLC
Re: [GB] ALF DC60
« Reply #123 on: Mon, 16 July 2018, 10:33:46 »
Would this case work with the GK64 RGB PCB. Looking for a PCB with hotswap and possibly brass mounts.
https://kbdfans.cn/products/gk64-rgb-60-64keys-hot-swap-pcb
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #124 on: Mon, 16 July 2018, 12:48:07 »
nope cant fit.
Offline wixxzblu
Re: [GB] ALF DC60
« Reply #125 on: Mon, 16 July 2018, 13:10:20 »
Take a look at the hotswap pcb on the TR60 GB.
Offline SantiGo
Re: [GB] ALF DC60
« Reply #126 on: Mon, 16 July 2018, 14:10:02 »
go that whait my invoice ___))
Offline onefivenine
Re: [GB] ALF DC60
« Reply #127 on: Mon, 16 July 2018, 15:17:53 »
GB Ended July 10  :(
Offline otanishock
  • ファーストラブ
Re: [GB] ALF DC60
« Reply #128 on: Mon, 16 July 2018, 16:36:47 »
By any chance you'd offer that same Everest White finish to other color?
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #129 on: Mon, 16 July 2018, 21:07:34 »
because anodize cannot make white color, and MAO finish a bit greyish. So we used new craft to create prefect white. For other colors, i think it is good so far:)
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #130 on: Mon, 16 July 2018, 21:24:17 »
hmmm..this early morning i talked to ALF, how about we make a universal 1.5mm thinkness brass plate for all? so it won't affect current alum plate buyers. So far there are no much options for brass plate in the market. We can create one with high quality:
1) 1.5mm thickness brass plate to give strong and stable support.
2) polishing after cnc.
3)Surface passivation treatment to prevent oxidization.(can last at least half of year)
4)of course universal layout with iso and split spacebar and etc.....
ps:we should do this kind of works during IC period. But our purpose is for a better product, Consumer satisfaction and A AWESOME KEYBOARD.
Offline Mearaz
Re: [GB] ALF DC60
« Reply #131 on: Mon, 16 July 2018, 22:51:33 »
Can I change my plate to the brass plate if i have already send in my order?
Offline JubJubCity
Re: [GB] ALF DC60
« Reply #132 on: Mon, 16 July 2018, 23:45:38 »
i am also interesting in changing my plate to brass
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #133 on: Tue, 17 July 2018, 00:06:26 »
Changing is ok but let's wait alf finished CAD first and give me the quota also the moq for brass plate.
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #134 on: Tue, 17 July 2018, 00:09:14 »
Brass plate sample. Not sample but you guys can see the finish. Also the thickness
What we gonna offer is 1.5mm thickness brass plate:D
Offline kimwonsik
Re: [GB] ALF DC60
« Reply #135 on: Tue, 17 July 2018, 00:26:42 »
That's fantastic !!
Offline DePulse
Re: [GB] ALF DC60
« Reply #136 on: Tue, 17 July 2018, 00:34:54 »
I might just probably join the basic with brass plate than wait for the deluxe.. I just need to have this asap  :eek:
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #137 on: Tue, 17 July 2018, 01:47:12 »
You guys can check your orders now. AT OP last part.
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #138 on: Tue, 17 July 2018, 04:37:25 »
hmm, this is the brass plate layout:p
Offline wixxzblu
Re: [GB] ALF DC60
« Reply #139 on: Tue, 17 July 2018, 04:39:18 »
thats great! you should email all the gb participants and ask them if they want change plate or order an extra brass plate.
Re: [GB] ALF DC60
« Reply #140 on: Tue, 17 July 2018, 04:39:23 »
That image looks a bit broken.
Sent from my SM-G935F using Tapatalk
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #141 on: Tue, 17 July 2018, 04:53:25 »
Quota haven't updated from factory side, 1.3mm brass plate we don't want, we want 1.5mm thickness one.
Offline ilouis_07
    • ILUMKB
Re: [GB] ALF DC60
« Reply #142 on: Tue, 17 July 2018, 04:55:18 »
Click the image first then will be ok:)from my phone view a bit broken also.
Re: [GB] ALF DC60
« Reply #143 on: Tue, 17 July 2018, 05:04:46 »
Only tried my phone, but there clicking and zooming didn't help. I'll check my computer when I get back home.
Offline MC_kb
Re: [GB] ALF DC60
« Reply #144 on: Tue, 17 July 2018, 09:39:53 »
It's the first time I buy a keeb through a GB ! Thanks a lot for making this possible guys.  ;D ;D
Edit : Holy sh*it my brain didn't click ; I'd be totally down for a brass plate. If it came to MOQ, I'd like to change my ordered plate for a brass plate too.
« Last Edit: Tue, 17 July 2018, 10:48:19 by MC_kb »
Offline speedemonv12
Re: [GB] ALF DC60
« Reply #145 on: Tue, 17 July 2018, 09:41:48 »
I mean, this is just becoming a fantastic deal. White case, brass plate, highly customizable PCB. Incredibly well done guys. Also at an affordable price!
Offline oldcat
  • 65% is Life
Re: [GB] ALF DC60
« Reply #146 on: Tue, 17 July 2018, 11:58:48 »
Looks like white is the only option. See another prototype pic from Alf. Took with a cellphone with low light, white balance is likely off a bit, and not a whole lot of detail. High quality pics forthcoming soon.
Offline autobot
Re: [GB] ALF DC60
« Reply #147 on: Tue, 17 July 2018, 13:14:31 »
Dumb question - would this fit an Anne Pro / POK3R PCB?
I’m thinking Purple Case + RGB 60% + Laser Blocknet & Kobe  :)
Offline oldcat
  • 65% is Life
Re: [GB] ALF DC60
« Reply #148 on: Tue, 17 July 2018, 13:43:26 »
Someone please sell me a set of Laser :/ Darn missed that.
Offline DocNoc
Re: [GB] ALF DC60
« Reply #149 on: Tue, 17 July 2018, 14:02:11 »
PM'd
