Author Topic: [IC] Collide39 - Not Quite 30% or 40% Keyboard w/ a Macro Twist!  (Read 7568 times)
Offline SpaceCatDesign
  • www.SpaceC.at
    • SpaceCat Design
Hey everyone!
SpaceCat Design is working with Maple Computing on a new and exciting project...at least we think so! :-)
Here are some renders of the keyboard in question, no point in not getting right to it, eh?
https://imgur.com/a/cdODwbk
As you can see from the renders, many layouts are supported. Essentially it's a small profile keyboard with a macro (or artisan) area on the right. Our intent is to ship with PCB case/plate combination. We are also working with some well-known vendors to get cases made out of various materials.
MSRP looks to be about $60 for a fully on-board, soldered keyboard (with PCB case, of course). You would just supply and solder your own switches/stabs. It would use QMK most likely.
So, basically this is an interest check to get some feedback on things before we go any further. The form itself is here:
https://goo.gl/forms/nCyQRYeg1oeA3nIK2
Thank you so much, as always. <3
Offline dimo
Re: [IC] Collide39 - Not Quite 30% or 40% Keyboard w/ a Macro Twist!
« Reply #1 on: Fri, 13 July 2018, 13:31:20 »
i love it (:
  • www.SpaceC.at
    • SpaceCat Design
« Reply #2 on: Fri, 13 July 2018, 13:41:34 »
Offline ZROGST
« Reply #3 on: Sun, 15 July 2018, 16:42:32 »
I love small boards and think it’s an area with plenty of innovation left to mine. Consider two units sold to me if it goes to GB.
Offline Rubbermilitia
« Reply #4 on: Thu, 19 July 2018, 06:44:04 »
I can't say no to cheap innovative DIY kits like this. I like the macro pad to the right, very cool. I'm likely in.... The only thing is that ~40% boards with PCB cases are usually half that price...
Offline Ephemeral
« Reply #5 on: Thu, 19 July 2018, 08:07:45 »
This is a neat little board! Definitely in.  :thumb:
Collection:
E6.5 (Lubed 50g MX Blacks) | Preonic (55g MX Clears) | CA66 (Zealios V2 65g) | budget96 (MX Red) | Infinity 60% (Zealios 78g) | Phantom TKL (Gateron Black) | MiniVan (Zealios 78g) | Helix (?)
[Incoming: Polaris (?) |  KBDFans 8X Mk II (v2 Tealios)]
Offline MikeTheTiger
« Reply #6 on: Sat, 11 August 2018, 17:48:36 »
Wow...beautiful!!
"all the numbers or none of them cmon man" -Kokaloo
Offline axcoping@gmail.com
« Reply #7 on: Fri, 17 August 2018, 21:23:35 »
looks excellent!
Offline digid3ar
« Reply #8 on: Thu, 23 August 2018, 20:47:21 »
just after buying from u a lets split, man now i have to build another keeb  :eek:
« Reply #9 on: Sun, 26 August 2018, 23:04:20 »
Hello. Any updates?
« Reply #10 on: Sun, 02 September 2018, 17:47:54 »
where we at on this beauty?
Hey everyone!
Where you at on this beauty?
