Author Topic: Which switch in Zealios compete with Cherry MX Browns?  (Read 1709 times)
Offline Pavilions
« on: Tue, 17 July 2018, 12:18:58 »
Which switch has almost the same force as a Cherry MX Brown or a Gateron Brown?
I want to try Zealios, but I want them at the same range as Cherry and Gaterom browns. :D
Offline Cocopah
  • Lurker Extraordinaire
Re: Which switch in Zealios compete with Cherry MX Browns?
« Reply #1 on: Tue, 17 July 2018, 12:23:08 »
Closest would be 62g zealios. I believe bottom out weight on an mx brown is 60g.
Offline Pavilions
« Reply #2 on: Tue, 17 July 2018, 12:59:37 »
did you try it? if yes, what is it like compared to Cherry MX brown or Gateron Brown?
Offline Leslieann
« Reply #3 on: Tue, 17 July 2018, 18:07:21 »
The click will feel the same.
What is different is the spring force curve. Cherry springs tend to remain relatively flat all through travel while the 62gram spring will start softer and end stiffer, meeting somewhere in the middle.
If you just mash keys, it won't matter much, but if you touch type it can feel quite different.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
