Author Topic: [IC] 4XRGB Switch LED Kit (to be offered with the Think6.5V2 GB)  (Read 19478 times)
Offline oldcat
  • 65% is Life
Not long ago, 3XRGB light kit was designed by some keyboard enthusiasts to spice up the customized keyboard game, especially for the novelty keycaps compatible with backlighting. The designers use spectacular skills to attach 2*1206 SMD LED to the surface of the switch combined with the one regular switch LED to create the magical 3XLED backlight. This is, however, quite cumbersome, and not quite as accessible to most users.
Based on the community's instructions and feedback, we have created 4XRGB light kit. The 4XRGB is installed between the PCB and the plate, the 4 SMD LEDs emit the lights, which shines through any transparent switches (e.g., Tealios), and the effects on box switches (with creamy bottom) are also great.
Here are some pictures and videos of the actual products, and how they look on novelty keycaps. This 4XRGB will no doubt take your keyboard game to the next level.
Most of the PCBs are compatible. Details of installation instructions will be provided to users. A minimal level of soldering skills are needed.
Original Designer and Manufacturer: Scott Wei
Update: Scott designed and made some but the demand is not high. Now Demo S has made an improved version if more people will be interested. This will likely be available along with the Think6.5V2 GB.
See images and videos below, and let us know what you think and whether you will be interested in this offered to the broad community at a reasonable cost!
Video:* 1.mp4 (2222.1 kB - downloaded 535 times.)
Video:* 2.mp4 (2327 kB - downloaded 390 times.)
201974-2
201976-3
201978-4
201980-5
201982-6
201984-7
« Last Edit: Sat, 18 July 2020, 01:15:45 by oldcat »
Offline AaronR
Re: [IC] 4XRGB Switch LED Kit
« Reply #1 on: Wed, 15 August 2018, 00:33:17 »
looks good for an upgrade for a non RGB PCB. hope cost isn't too high for these. it be good to see how this is to be installed before buying also.
Offline PaultheSloth
  • JW Double Black
« Reply #2 on: Wed, 15 August 2018, 07:34:58 »
Looks good, definitely interested!
Polaris|Leaf60|QXP|DC60|Planck|SKB60|Tokyo60|UT-47|AnnePro
Offline oldcat
  • 65% is Life
« Reply #3 on: Thu, 16 August 2018, 22:18:30 »
Thanks! Hope there is enough interest
Offline draecas
« Reply #4 on: Sat, 18 August 2018, 10:49:14 »
I am definitely interested! Really curious about the specifics - price, and installation process, especially.
Offline bakageta
« Reply #5 on: Sun, 19 August 2018, 17:00:35 »
Definitely interested. I also wouldn't mind a variant design that only has 2 LEDs in the top left, leaving the bottom and right empty to be lit by the next switch. Then throw a 4 LED board in lower right switch, and you've got even lighting with half the power draw.
Offline scud80
« Reply #6 on: Sun, 19 August 2018, 22:48:08 »
i'd be interested in this if it will be compatible with pcbs made by keeb.io (at least the ones that have led support)
Offline odd
« Reply #7 on: Tue, 21 August 2018, 13:57:11 »
im for sure down to purchase some of these
Offline oldcat
  • 65% is Life
« Reply #8 on: Thu, 23 August 2018, 12:16:33 »
Offline oldcat
  • 65% is Life
« Reply #9 on: Fri, 31 August 2018, 16:05:50 »
So far not many have signed up. If we can't get 50 to sign up I guess we will just leave it. It sold hundreds instantly in a recent Chinese GB!
Offline Acuitii
Re: [IC] 4XRGB Switch LED Kit (IC link updated)
« Reply #10 on: Mon, 24 September 2018, 21:22:02 »
I'd be down to purchase some of these, signing up rn!
weeb guy
Offline oldcat
  • 65% is Life
« Reply #11 on: Tue, 25 September 2018, 15:43:55 »
I love these, they literally sold out hundreds in the China GB, but only 10 signed up on GH, I am baffled - maybe I didn't describe clearly what this does?
Offline Darknight00z
« Reply #12 on: Mon, 04 February 2019, 15:06:56 »
interested!
Offline Tefrem34
« Reply #13 on: Sun, 17 February 2019, 00:59:27 »
This is a great concept and awesome that is modular. I would love to get a hold of these!!
Offline thornkin
« Reply #14 on: Tue, 19 February 2019, 11:17:50 »
How is the color controlled on these?  Would it be controllable by firmware or is it fixed?
Sent from my Mediatek MTK8173 Chromebook using Tapatalk
Offline mxgian99
« Reply #15 on: Thu, 11 April 2019, 10:36:46 »
so we have a vendor in the US that started selling these, so are they now generally available?
edited to add vendor: https://spacecat.design/
but they are not cheap $7 for one.
« Last Edit: Thu, 11 April 2019, 18:10:40 by mxgian99 »
Offline thornkin
« Reply #16 on: Thu, 11 April 2019, 10:56:39 »
Which vendor?
Offline iaman
« Reply #17 on: Thu, 11 April 2019, 11:10:36 »
Would be super interested in seeing what the build process is like (and getting a comparison of power draw) for installing a significant number of these into a board; e.g what it's like to modify an entire 60% and what QMK/VIA support is like for this kind of thing.
Offline mxgian99
« Reply #18 on: Thu, 11 April 2019, 18:12:00 »
what i've been told, these are treated like 1 LED on a WS6812B strip.  so it would be controllable like those.
i dont think you could build a full board with these, besides the cost, there is a limit to the number of RGB LEDs that you can drive from the USB bus.  i think it's in the 25-30 range.  but thats assuming these draw as much as a RGB LED, thats still TBD.
« Last Edit: Thu, 11 April 2019, 18:13:33 by mxgian99 »
Offline oldcat
  • 65% is Life
Re: [IC] 4XRGB Switch LED Kit (on hold)
« Reply #19 on: Thu, 11 April 2019, 18:14:02 »
Which vendor?
There are some discussions in the ALF discord, Scott the designer is in there.
And I integrated 4XRGB to the PCB for Think6.5, to save the trouble (or joy) in the modding.
Offline oldcat
  • 65% is Life
« Reply #20 on: Sun, 19 April 2020, 19:39:03 »
This may revive with Demo S working on an improved design to make it easy to solder.
Offline oldcat
  • 65% is Life
Re: [IC] 4XRGB Switch LED Kit (updated)
« Reply #21 on: Mon, 15 June 2020, 23:05:30 »
This will be provided during the Think6.5v2 GB to avoid the hefty shipping costs.
Offline AvoidingYou
« Reply #22 on: Thu, 18 June 2020, 19:28:43 »
would very much like to have
Offline Jotylr
« Reply #23 on: Thu, 16 July 2020, 15:56:19 »
Oldcat, is this still going to happen? I really hope so and I would like to buy a couple for my SpaceCV and Think6.5 V2. I'm sure you can gain some traction on the Think discord channel with these.
Offline oldcat
  • 65% is Life
« Reply #24 on: Fri, 17 July 2020, 17:50:01 »
Currently in discussion with Demo S to see if he would like to have it available for purchase during the Think65v2 GB. This will definitely save shipping!
And we have actually optimized both CyberVoyager and Think65V2 PCB to allow easy soldering of the 4XRGB LEDs on the ESC key. Will try to make it happen.
Offline villagepillage
« Reply #25 on: Fri, 17 July 2020, 22:17:23 »
+1 for me
TGR 910
Offline swtech
« Reply #26 on: Fri, 17 July 2020, 23:58:59 »
Interested
Offline woyaodapian
« Reply #27 on: Sat, 18 July 2020, 00:44:18 »
Please make this available as extras on think6.5 GB. Thanks in advance!
Offline oldcat
  • 65% is Life
« Reply #28 on: Sat, 18 July 2020, 01:15:24 »
I made a quick tutorial on installing a 4XRGB kit on Think6.5V2. Suffice to say that 4XRGB kit an be installed in many PCBs using various methods, but we have made a conscious effort to make it super easy for you to install it. This is also my absolutely favorite mod to any keyboard build.
First step:
Take a 4XRGB kit (with some wires, which will be provided with the kit in the upcoming GB), and fix it to a flat surface. What I did was to stick it on a plastic surface with a double sided adhesive.
Apply some solder on the pads (the pads will be optimized in the new version DemoS developed, what I am showcasing here is an old version of 4XRGB kit), and solder the 3 wires to the pads.
Note that the 3 pads are G, I, and V.
Second, stick the kit to the PCB. I use double sided adhesive, applied to the bottom of the kit, which sticks to the PCB. Note that I use a switch to guide it, so that later the switch can fit in the switch slot but not collide with the kit.
Third, insert the wires through the hole on the PCB to the back of the PCB.
Fourth, clip the wires to the right length, and solder them to the G.O.V holes, note that you match G wire to G, I wire to O, and V wire to V. I use different colors of wires, but if you might use single color if you can tell them apart as you solder the respective wires to the correct holes.
Fifth, this all is done correctly, when you connect the USB cable, the 4 RGB LEDs on the kit should light up.
This is how it looks like when you put a switch on. Use some transparent or translucent switches for maximum RGB effects.
Lastly, tune your VIA light effects settings to achieve the result you like for the 4XRGB ESC Mod, here is mine.
Offline Asbrodeus
Re: [IC] 4XRGB Switch LED Kit (to be offered with the Think6.5V2 GB)
« Reply #29 on: Sat, 18 July 2020, 08:42:15 »
Very cool. I'd love to see a variant for the wasd/arrow cluster
Sent from my Pixel 3a using Tapatalk
Offline oldcat
  • 65% is Life
« Reply #30 on: Sat, 18 July 2020, 19:19:14 »
Interesting, I believe you can solder them on WASD as well. Just need 4 kits :)
Offline Asbrodeus
« Reply #31 on: Sat, 18 July 2020, 19:34:35 »
Would they overlap at all or would they be able to fit together?
Offline soloplayer
« Reply #32 on: Sat, 18 July 2020, 21:16:26 »
so if i want to install 2 or more kit, should i solder all of them into the GOV hole ?
Offline oldcat
  • 65% is Life
« Reply #33 on: Sat, 18 July 2020, 22:13:27 »
Think6.5v2 with 4XRGB + Think artisan:
Offline Shiro
« Reply #34 on: Sun, 19 July 2020, 16:45:02 »
looking forward to this.
Offline Smithsonian
« Reply #35 on: Thu, 24 June 2021, 11:54:31 »
Is it just me or does this kit not fit in the caseof the think 6.5 V2? I installed mine between the pcb and the plate but, even with the corner cut out, it still hits the case.
« Last Edit: Thu, 24 June 2021, 12:00:32 by Smithsonian »
Offline Assthetic
« Reply #36 on: Mon, 05 July 2021, 11:44:55 »
Straight up does not fit. It juts out past the PCB, and the corner of the RGB kit rests on the corner of the bottom case. You can still close the case in this configuration, but everything is tilted.
I've also tried filing down the RGB kit, but by the time the kit is filed down far enough to fit, we've already filed through one of the traces on the kit.
These kits are absolutely useless if you want to use them at the Escape position on a Think V2
