Author Topic: [IC] Topre Realforce keyboards replacing rusted plate by Stainless steel  (Read 39757 times)
Offline Desprado
  • Customizing electrostatic capacity keyboards
Hello  GeekHack
I am Des , fan of Electrostatic capacity keyboards.   I used Realforce 87u and Leopold 980C very often . But I found the plate under the keycaps is really easy to rust .  it is nasty and bother my mood when typing on it
Now  I got a solution ,and plese see the pictures below .
As you can see from the picture I got solution for replace keycaps with MX slide as well.  Please let me know if you like , and tell me what keyboards you are using and rusted ,   and I will offer solution plate for all topre keyboards .
The prototype is not perfect. but all screws exactly match , only some flaw mark which will easily solved in next producing. and balanced big keys are very nice .
I am Des_KB , welcome to follow .  Regards .
Customizing electrostatic capacity keyboards.  Unibody 660C & 980C.
Offline nanook_the_great
  • Give me all your left shift
Re: [IC] Topre Realforce keyboards replacing rusted plate by Stainless steel
« Reply #1 on: Wed, 22 August 2018, 10:36:16 »
I have a realforce 87u, and I would be interested in a plate like this.
Offline nmur
  • ಠ_ಠ
« Reply #2 on: Wed, 22 August 2018, 10:43:17 »
nice job
my realforce 86U plate was very rusty when i got it, so i sanded it down and painted it over, but this would be a better solution if it fits well
Offline scriptfans
« Reply #3 on: Wed, 22 August 2018, 10:47:01 »
Awesome! I have realforce 87u/104u, leopold fc980c, and hhkb!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #4 on: Wed, 22 August 2018, 12:45:03 »
I would be interested in 87u and 86u plates.
Offline Desprado
« Reply #5 on: Wed, 22 August 2018, 17:28:10 »
nice job
nice job
I want to paint the rusty plate at the first . But replace by brand new copy with better material at last .  it fits perfectly .
Offline Desprado
« Reply #6 on: Wed, 22 August 2018, 17:33:44 »
Thank you for support . I have 87u ,  same layout with 86u ?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #7 on: Wed, 22 August 2018, 17:48:10 »
No, the 86u has a symmetrical bottom row and 7u spacebar (although it uses the same 6u stabilizers as 87u)
Offline Desprado
« Reply #8 on: Thu, 23 August 2018, 08:52:04 »
Understood , thanks.
Offline GeneriksGiraffe
  • Living the Rubber Life
« Reply #9 on: Thu, 23 August 2018, 23:22:08 »
I would be totally interested.
SOMEONE PLEASE SELL/TRADE ME AN HHKB PRO 1
Offline richard912
« Reply #10 on: Fri, 24 August 2018, 04:36:06 »
Totally interested too
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #11 on: Fri, 24 August 2018, 06:01:42 »
Will you do other materials? Aluminum, polycarbonate, brass, other plastics and metals?!
Sent from my mobile using Tapatalk
Offline moitorpsychoo
« Reply #12 on: Fri, 24 August 2018, 06:02:50 »
Poly and other plastics are no go, since the plate needs to be bent.
Offline Desprado
« Reply #13 on: Fri, 24 August 2018, 06:51:54 »
Will  open  GB   shortly .
Offline Desprado
« Reply #14 on: Fri, 24 August 2018, 06:53:02 »
Correct .
Offline Desprado
« Reply #15 on: Fri, 24 August 2018, 07:16:24 »
Will have option for Aluminium and brass  with different surface treatment .
Offline dallman5
« Reply #16 on: Fri, 24 August 2018, 08:16:02 »
I’d really like to try out a poly/plastic plate too to see if you could mimic the HHKB feeling, but you’re right the bends make it difficult. However, the bends are only really necessary if you’re using the stock case, so for people using aftermarket cases such as the Norbaforce it might be fun to experiment with these materials.
LF: OG Cherry APL (lasered), Artisans
Current collection:
Norbatouch (Galaxy Blue) | Mira SE (Lunar Grey, WKL) | HHKB Pro 1 (KB300BN) | Noxary X60 (Grey, HHKB) | KBDFans 5 Degree (Silver) | AEK64 (Grey) | Norbaforce (Tactical Black, WKL)) | Realforce 86U (White) | TGR 910 RE (Polycarbonate) | LZ-SQ (Black) | LZ-CLS (Grey, WKL) | Duck Orion v1 (Silver, WK)) | Nissho KB106DE | HHKB Pro 1 (KB300B) | LZ CLS-S (Blue, Poker) | Realforce 87U 10th Anniversary) | Realforce 104UK | TGR Alice (Grey on Pink) | Singa (Blue, WKL)  | Quantrik QXP (Blue Grey, WKL) | LZ-GH v2 (Black, WK) | KMAC Happy (Red, Poker)) | IBM Model M SSK (APL) | TGR 910 SE (Pink on Blue) | GSKT-00 (Silver, Poker) | OTD Koala (Silver, WKL) | Realforce R2 PFU Edition (Ivory) | IBM 3279 Beamspring (APL) | TGR Tris (Blue) | LZ-GH v2 (Blue, WKL)) | TGR Jane v2 (Blue-grey, WKL) | LZ-MP (Shine Grey, WKL)  | TGR x Singa Unikorn (Purple) | Justsystems x Realforce 108UG) | IBM Model F Unsaver (APL) | TGR Jane V2 CE (Multicolor, WKL) | Realforce 87U (Blank Black) | Lin Montage (Light Blue, WKL) | GSKT-00 AEK R2 (Grey, HHKB) | Leopold FC660C (Blank Black) | Duck Viper v3 (Grey on Black) | Rama Works M6-C RWxRW | LZ-GH v1 (Black, WKL) | Gok 7v (Grey) | biso x beaming Kei (SS, HHKB) | zacheadams x bisoromi little z | Matrix Noah (Silver/Grey, WKL) | Lin Whale (Pink, WKL) | TGR Alice (Polycarbonate) | Rama Kara (Noct) | Lin Whale75 (Burgundy, F13) | Realforce 89 (Ivory) | Hand Engineering Haus (Bluegrey) | Haytco CAKE60_R1 (Pantone 4167C) | LZ-XE (Grey, WKL) | Noxary X60 V2 (Grey, WK) | Daji Ochocuatro (Grey, WKL) | HHKB Hybird Type-S 25th Anniversary (Snow) | LZ-REs (Grey, WKL) | Matrix 8xv 3.0 (Blue-Black/Deep Grey, WKL) | Realforce 23UB | Biso RS60 (Black, WK) | TGR x MXF Koala (Grey/Black, WKL)
Italics = Incoming, Black = Gone
Offline dario
  • obsessive–compulsive hardware slut
« Reply #17 on: Fri, 24 August 2018, 08:23:25 »
Correct me if I'm wrong, but aren't Topre boards infamous for cracking switch housing if you try to remove it from the original plate?
"Cracking" may be wrong term, but they do get somewhat damaged, even if they still work.
« Last Edit: Fri, 24 August 2018, 08:25:08 by dario »
Offline dallman5
« Reply #18 on: Fri, 24 August 2018, 08:42:19 »
"Cracking" is maybe wrong term, but they do get somewhat damaged, even if they still work.
If you do it the right way you should have no issues. What I found to work for me was pushing from the top of the housing with my thumb and pushing in the tab on the side with a flathead screwdriver (although I’m sure something like a spudger would work better) from a nearly perpendicular angle to the plate, and then repeating for the other side. It doesn’t take too much force to get the housing to release from the plate.
In my experience, it’s how you push that tab that could lead to cracking the housing. One of the first ones I did I cracked because I pushed the screwdriver into the housing too parallel to the plate which if you slip leaves you pushing straight through the wall of the housing. If you push the tab with something at more of a perpendicular angle to the plate though there’s much less risk of this, and I’ve yet to crack a housing with this technique (knock on wood).
So I guess what I’m trying to say is that removing the housings is absolutely doable but you need the right technique to mitigate the risk of breaking them.
Current collection:
Offline dario
« Reply #19 on: Fri, 24 August 2018, 08:52:49 »
Alright, I'm glad somebody came up with a proper technique to remove them. If you could record a video doing that it would be great.
Anyway, I'm in for a FC660C brass plate that can be installed into Norbauer's Heavy 6 housing. But only if bass is properly sealed against patina. I don't know what method they use for that, and if anodization is applicable.
Offline E.E.L. Ambiense
  • Acrylic Heretic
« Reply #20 on: Fri, 24 August 2018, 14:36:45 »
This is awesome!  So your 980C is now using Costar stabs along with the MX sliders?  Nice!  Depending on price, I'm totally in for a 980C plate.
Case modder by trade; mech-deck'r for fun!
Offline dario
« Reply #21 on: Sat, 25 August 2018, 07:10:13 »
I have been doing a little bit of research trying to find out what would be the perfect finish for a brass plate against corrosion/patina and it seems that PVD coating is universally recommended as the best solution (although in the same time probably the most expensive one). You can't anodize brass, but PVD is better anyway.
Offline Desprado
« Reply #22 on: Sat, 25 August 2018, 10:31:58 »
Thank you for your information  :thumb:
Offline Stresemann
« Reply #23 on: Sat, 01 September 2018, 23:51:52 »
I would definitely be in for RF87u.
Offline duck pauper
« Reply #24 on: Tue, 04 September 2018, 18:54:53 »
I would buy one. I would also buy other materials like brass.
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #25 on: Tue, 04 September 2018, 19:12:59 »
Brass...
Offline Hawkfriend
  • K E Y B O R T S
« Reply #26 on: Wed, 05 September 2018, 18:15:30 »
Definitely in
Offline chakku
    • airi.su
« Reply #27 on: Mon, 10 September 2018, 19:32:52 »
Definitely interested in jumping on this for an 87U
Offline tanvir175
« Reply #28 on: Fri, 05 October 2018, 15:59:31 »
Interested for 86u. Here are pictures for mine: https://imgur.com/a/ihyrRqI
Would also possibly be interested in one for FC660C and would love different options for plates (alu, poly)
« Last Edit: Fri, 05 October 2018, 16:18:40 by tanvir175 »
Offline Gobluebro
« Reply #29 on: Tue, 09 October 2018, 12:29:58 »
Interested. Does this add anything to typing sounds?
Offline dario
« Reply #30 on: Tue, 09 October 2018, 13:19:40 »
Is this thing still on?
If it is, I hope you'll make a brass plate for Realforce R2 too. It's the new kid on the block.
Offline Desprado
« Reply #31 on: Sat, 13 October 2018, 02:02:59 »
Sure it is on ,    I will open GB shortly .
Offline Desprado
« Reply #32 on: Sat, 13 October 2018, 02:06:32 »
Nope , just same with original .  may reduce the sound if use some soft material
Offline Wetherbee
« Reply #33 on: Sat, 13 October 2018, 04:13:42 »
I would like 86U plate option.
Offline dario
« Reply #34 on: Sat, 13 October 2018, 08:48:21 »
You know what, lately I've been trying to build high-quality ALPS board, and soon enough I realized the market for ALPS is so scarce that it doesn't even have any kind of policarbonate, brass or stainless steel options when it comes to plates.
The only thing that was available for a short period of time is an aluminium plate for ALPS over zfrontier, but it isn't available anymore.
So it occured to me to find the factory and do it myself.
I'm thinking about making a plate for TEX aluminium TKL keyboard that seems to be the most popular choice for ALPS keyboards nowdays.
Since you trying to make basically the same thing as I do, maybe we should form some kind of partnership. You find the factory where it can be done, and I'll start an IC to see if there is enough interest for something like this, and if there is I'll make all CAD drawings needed.
The end result would be lower prices from the factory both for you and me (I guess), since we're making higher demand in total.
Offline phearboner
« Reply #35 on: Tue, 16 October 2018, 18:22:59 »
In for an 87u and 86u version, let me know when / if the group buy starts
Offline djaeyun
« Reply #36 on: Sun, 21 October 2018, 00:39:16 »
Definitely in for my 87U! Great idea.
Offline Dead Encryption
  • Dead...
    • Twitch Channel
« Reply #37 on: Sat, 27 October 2018, 18:40:23 »
I would totally be in for this, but I would like to see if I could get one with standard 7u stabilizer cutouts for my 86u RealForce. I PMed as well, hope to hear from you soon.
Offline mkarlsson
« Reply #38 on: Sun, 28 October 2018, 10:05:12 »
Maybe the LFKeyboards pcb and plate for Alps can help you, I believe they are Filco/Phantom compatible so it should work with TEX cases, have a look here if interested:
https://www.lfkeyboards.com/plates-cases.html
Offline dario
« Reply #39 on: Tue, 30 October 2018, 07:20:50 »
Yes, they are compatible with TEX cases, but all of LFKeyboards PCBs are out of stock long time now, same thing with their plates. Besides, what they were selling was 1.5 aluminium plates, I would probably opt for brass or stainless steel with PVD coating. Also, from what I was reading before, ideal thickness for the ALPS plate shoud be about 1.1 mm.
Offline mkarlsson
« Reply #40 on: Tue, 30 October 2018, 08:43:07 »
Offline gabetjh
« Reply #41 on: Thu, 22 November 2018, 00:09:22 »
i just purchased the 980C. have been observing alot of rusting issues and would like to buy a replacement plate in case it happens in the future.
so can i verify that the materials available are alum and brass with different surface finishes? the original plate is steel yes?
what is the cutting process used? CNC? i actually do happen to have a CNC machine at my workplace and have aluminium plates too. do you happen to have the autocad file?
Offline dario
« Reply #42 on: Mon, 26 November 2018, 09:42:15 »
I am currently working on a 980C titanium plate, so I can sell you one of those later on. If you're interested and patient enough.
Offline Pennywise359
« Reply #43 on: Tue, 04 December 2018, 15:57:10 »
Is this still happening?
Offline SK0P1
« Reply #44 on: Sat, 15 December 2018, 10:31:06 »
Same question, hopefully this happens!
Offline tanvir175
« Reply #45 on: Sat, 15 December 2018, 14:07:21 »
From what I've heard. No. He's fully focusing on the topre-mx sliders and has abandoned this project, for now. Won't share/sell the plate file either. Shame because I really needed this for my 86u. The plate is rusted all over.
Offline SK0P1
« Reply #46 on: Sat, 15 December 2018, 18:02:48 »
Oh, I also need to replace my rusting 86u plate  :(
Offline tanvir175
« Reply #47 on: Sun, 16 December 2018, 13:59:50 »
Yeah, I'm pretty disappointed. Was really looking for to this since an IC was made. If this wasn't such a cock tease, I wouldn't have really cared much.
Offline phinix
« Reply #48 on: Sat, 12 January 2019, 10:06:22 »
I wonder if you could also make one with standard bottom row.
I did couple of mods on 87u and 88u to make bottom row standard, as the pcb still registers keys after it. Of course CNCd would be perfect compared to those I made in hand...
Offline thelaughingman
  • Simultaneously the most starry-eyed idealist and t
« Reply #49 on: Sat, 12 January 2019, 22:53:58 »
don't need standard bottom row plate as 6u spacebar adapter is available now :)
