Author Topic: Glossy SA Keycaps?  (Read 5321 times)
Offline Rubbermilitia
Glossy SA Keycaps?
« on: Fri, 24 August 2018, 10:18:41 »
Is SP the only company to make glossy SA keycaps? I think the feel of the glossy caps is much more satisfying than the semi-matte finish on Maxkeys, for example. I bought the maxkeys SA WoB set because the image on kbdfans made them look really shiny but they are NOT glossy like SP caps... Am I the only person that prefers the glossy finish? Are there others out there?
Offline zslane
Re: Glossy SA Keycaps?
« Reply #1 on: Fri, 24 August 2018, 11:57:23 »
I'm not aware of any SA set produced by SP that utilizes their glossy finish. All the ones you see out there are their semi-matte finish (I think it should be called semi-gloss, but whatever). If they appear glossy it is because they've been worn down a bit and become glossy over time (ABS plastic is like that). Maxkeys and SP use the same finish molds, so their SA keycaps look and feel pretty much identical.
Note: SP has made SA keycaps in the past using their matte molds, but they are quite rare (Commando is the only set that immediately comes to mind).
« Reply #2 on: Fri, 24 August 2018, 13:27:51 »
I'm comparing my SP chocolate with Maxkeys WoB set and the feel and look of the SP keys are noticeably smoother and shinier. then again, I did get the SP caps used, so maybe that's why?
I wonder why SA manufacturers never use full gloss finish...I think it looks great.
Are there really no gloss SA sets? I thought Round 6 and modern selectric looked really glossy
Offline zslane
« Reply #3 on: Fri, 24 August 2018, 13:32:08 »
The primary reason you don't see SA sets using the glossy finish is because SP doesn't have glossy finish molds for all the necessary keycap sizes and row profiles.
« Reply #4 on: Fri, 24 August 2018, 13:42:48 »
Ah ok. Thanks for the info. Guess I'll have to work on wearing down my WoB set for that sexy shine ;)
