Author Topic: [GB] Doro67 (99% shipped by 80ultraman)  (Read 169887 times)
Offline Gghi
Re: [GB] Doro67 - Integrated 4mm Plate 65% Keyboard
« Reply #50 on: Mon, 10 September 2018, 11:55:53 »
is Brass Bottom Slab better than aluminium one?
They are the same but heavier. Other than that they should be the same.
Offline Gghi
« Reply #51 on: Mon, 10 September 2018, 11:56:25 »
Love this...
Thanks!!
Offline beekey
« Reply #52 on: Mon, 10 September 2018, 12:09:52 »
The split space support is only 2.75,1.25,2.2.25, right? No 2.25,1.25,2.2.75 split possible?
Yes, 2.75 / 1.25 / 2.25. I think this makes more sense.
I tried 2.75 / 1.25 / 2.25 with the BananaSplit and switched after one week to 2.25,1.25,2.2.75. For me much more comfortable, as I use the 2.25 as the Mac Cmd and the 1.25 as layer toggle with my left thumb.
Offline Gghi
« Reply #53 on: Mon, 10 September 2018, 12:25:13 »
Definitely make sense. but for me, I use my left thumb hit the spacebar, so I wanna that better a bit larger and right-er.
However, we have passed that IC phase. Let's just accept the spacebar the way it is.
Offline oldcat
  • 65% is Life
« Reply #54 on: Mon, 10 September 2018, 12:41:39 »
Just adding weights. Some love heavier boards I guess.
Offline Rubbermilitia
« Reply #55 on: Mon, 10 September 2018, 12:46:47 »
Are most people going for blocker or no blocker? Just curious. I went blocker cause its easier to find caps for.
Offline Gghi
« Reply #56 on: Mon, 10 September 2018, 13:00:21 »
LOL .. only 4.2% of people went non-blocker
Offline dario
  • obsessive–compulsive hardware slut
« Reply #57 on: Mon, 10 September 2018, 13:18:09 »
Doro with GMK caps side profile:
Just a little detail I noticed. First prototype had camfered edges. Second prototype had rounded edges (if I'm not mistaken).
Now the final product has camfered edges again. I'm just curious to know was this intentional and is it because of production restrictions or is it because you think it looks better?
« Last Edit: Mon, 10 September 2018, 13:24:44 by dario »
Offline Gghi
« Reply #58 on: Mon, 10 September 2018, 13:42:54 »
I dont see your point. The first and the second both have chamfered edges, the difference are the bezel and how much of the chamfered. The final product will have the same look with the second prototype(the ones in the pic).
Offline oldcat
  • 65% is Life
« Reply #59 on: Mon, 10 September 2018, 17:12:39 »
Here is the current distribution of orders for different layouts.
203255-0
Offline Marutks
« Reply #60 on: Tue, 11 September 2018, 08:06:03 »
I can't decide which color to order.    Which color would look best with dev/tty keycaps ?
https://www.massdrop.com/buy/massdrop-x-matt3o-devtty-custom-keycap-set
Offline lovetree
« Reply #61 on: Tue, 11 September 2018, 08:17:43 »
Black +1
Offline OracleKev
« Reply #62 on: Tue, 11 September 2018, 08:55:11 »
If RGB PCB is chosen, is the RGB shown anywhere?
Offline Gghi
« Reply #63 on: Tue, 11 September 2018, 09:17:19 »
It's in-switch, per-key RGB, so the top side. :D
Offline OracleKev
« Reply #64 on: Tue, 11 September 2018, 09:22:23 »
Ah, in-switch RGB.  Are LEDs soldered on the PCB or soldered in holes (thus level with PCB surface).  In another words, am I restricted to use only RGB switches?
Offline Gghi
« Reply #65 on: Tue, 11 September 2018, 09:25:43 »
You can use any MX-like switches. the leds are soldered in holes. :)
Offline OracleKev
« Reply #66 on: Tue, 11 September 2018, 09:39:30 »
Awesome!
Offline dario
« Reply #67 on: Tue, 11 September 2018, 11:40:06 »
Everest white, obviously.
But you can take red as a cheaper alternative (and use red accents on dev titty).
« Last Edit: Tue, 11 September 2018, 11:43:01 by dario »
Offline PoochZag
« Reply #68 on: Tue, 11 September 2018, 12:18:58 »
I think the pink and the grey/green are muted enough to go with a lot of different things.  I'm a big 9009 fan though so maybe that's where its coming from
TX-CP, TX60, Campine Mk. III, Mira SE
Offline Gghi
« Reply #69 on: Tue, 11 September 2018, 12:31:05 »
google sheet has been updated. contact me if you wanna change your order or anything.
https://docs.google.com/spreadsheets/d/1Gvtz7gh2hRnw0u1vduaLifWRRc_tG3sOpt0f2FL6FFo/edit?usp=sharing
Offline oldcat
  • 65% is Life
« Reply #70 on: Tue, 11 September 2018, 15:40:18 »
Offline Gghi
« Reply #71 on: Tue, 11 September 2018, 22:49:35 »
The switches on the GB page are very basic. if you wanna more premium switches, just PM me and talk about other options.
Offline oldcat
  • 65% is Life
« Reply #72 on: Tue, 11 September 2018, 23:59:04 »
Please, I want some Holy Pandas!
Offline Poblopuablo
« Reply #73 on: Wed, 12 September 2018, 00:56:55 »
Are the pcb's north or south facing LEDs?
I imagine the rgb is north facing.... How about multilayout PCB?
Offline OracleKev
« Reply #74 on: Wed, 12 September 2018, 01:02:33 »
In the Features section
3. QMK PCB, with options for RGB LED PCB or Regular (Compatible) PCB, both PCBs designed to have switches facing south.
Offline PoochZag
« Reply #75 on: Wed, 12 September 2018, 08:50:22 »
I asked this in the IC thread and both PCBs are south facing.  Which is good for those of us who like cherry profile :)
Offline Gghi
« Reply #76 on: Wed, 12 September 2018, 10:56:18 »
weight (including pcb, switches and caps):
    3.1lb / 1.4kg for alu case
    4.6lb / 2.1kg if update to brass bottom slab.
« Last Edit: Wed, 12 September 2018, 10:59:11 by Gghi »
Offline oldcat
  • 65% is Life
« Reply #77 on: Wed, 12 September 2018, 15:05:25 »
Yeah, I recall seeing the post about north facing cap hitting the switch casing.
Offline Poblopuablo
« Reply #78 on: Wed, 12 September 2018, 17:43:33 »
So how would shine through caps look on here?
If the led is sounth facing, then lighting for the legends on the caps would be way off. :/
Offline OracleKev
« Reply #79 on: Wed, 12 September 2018, 22:38:14 »
Many consider shine through keycaps tacky.  Background lighting behind your favorite GMK or SA is preferred.  For those, south facing or north facing don't matter.
« Reply #80 on: Thu, 13 September 2018, 02:35:59 »
You're stating preference as if it were fact. Yes, north-facing LEDs are better for shine through, which some people like, but this doesn't seem like the kind of board you would be using shine-through caps with anyway, considering it doesn't have a diffuser or acrylic bottom for backlighting either.
Offline OracleKev
« Reply #81 on: Thu, 13 September 2018, 02:50:17 »
Wut, I don't know what you're picking on.
Anyway, south facing LED is fine.  north facing LED would interfere with Cherry height keycaps.
Offline Gghi
« Reply #82 on: Thu, 13 September 2018, 11:19:28 »
I didn't know that north-facing switches may crack Cherry profile caps before. I choose south-facing simply because it's more nature and can help me reduce the overall height maybe 1mm.
Offline Marutks
« Reply #83 on: Thu, 13 September 2018, 17:57:06 »
Cherry profile caps may have shorter travel distance on north-facing switches.
Usually home row keys. It happens for almost all switches.
Offline e2o
« Reply #84 on: Thu, 13 September 2018, 22:25:19 »
Hey! Can someone outline the possible downside(s) of getting the plate in “multi-blocker” (config 2) if I’m most likely going to use the default layout, but wouldn’t mind the split space bar as an option? Would there be less stability in the switches in those areas? Would I have to use non-standard stabs if using the default layout with it? Any other concerns? Thanks for helping out a noob...
Offline oldcat
  • 65% is Life
« Reply #85 on: Fri, 14 September 2018, 00:09:00 »
Every mm counts!
Offline Marutks
« Reply #86 on: Fri, 14 September 2018, 06:30:56 »
I wouldnt expect to have any stability issues.  Not with 4mm plate.
standard stabs should be fine
Offline PoochZag
« Reply #87 on: Fri, 14 September 2018, 06:56:10 »
It's not that they crack keycaps, but R3 and R4 of cherry profile caps will actually hit the housing on north facing switches just before it would normally bottom out.  This creates a different sound and feel and can be bothersome to those of us who are easily bothered :)  I am glad you went with south, I am super excited for the Doro!
Offline Gghi
« Reply #88 on: Fri, 14 September 2018, 10:20:11 »
Hi, the default layout is using the most common stabs and keycaps. the layout 2 support multiple layouts, like split backspace/spacebar, or 7u space bar, all of them are less common but easy to find.
Offline Gghi
« Reply #89 on: Fri, 14 September 2018, 10:22:43 »
Every mm counts!
True. Did everything I can to lower the case. ;D
Offline Marutks
« Reply #90 on: Fri, 14 September 2018, 10:34:50 »
It is very annoying.  I would never buy any keeb with north-facing switches.
Offline Gghi
« Reply #91 on: Fri, 14 September 2018, 11:28:52 »
Yea, great i went south.
Offline e2o
« Reply #92 on: Fri, 14 September 2018, 11:47:17 »
Thanks. And just to be absolutely sure, the multi-blocker #2 option will accommodate the default layout, correct?
Offline Gghi
« Reply #93 on: Fri, 14 September 2018, 12:10:13 »
Yes, that's correct!!
Offline mushubanane
« Reply #94 on: Fri, 14 September 2018, 12:35:33 »
All in for a classy black :thumb:
Offline Gghi
« Reply #95 on: Fri, 14 September 2018, 14:48:20 »
Thank you for joining!!
Offline Darknight00z
Re: [GB] Doro67 - Integrated 4mm Plate 65% Keyboard (last week!)
« Reply #96 on: Fri, 14 September 2018, 15:54:05 »
I wonder if I should get the Doro67 and purchase an extra pcb from rama koyu so I can get hotswap. hmm
Offline Macflag
« Reply #97 on: Fri, 14 September 2018, 16:17:18 »
What’s the timeline for order shipment?
Offline Gghi
« Reply #98 on: Fri, 14 September 2018, 17:06:13 »
you shouldn't. These two PCBs are not compatible (due to daughter-board design and bottom-row stabs direction).
Offline Gghi
« Reply #99 on: Fri, 14 September 2018, 17:08:17 »
1.5 to 2 months after collected all payments. That will be around mid/ end Nov.
