Author Topic: [GB] h87a LIVE NOW  (Read 155478 times)
Offline donut_sauce
Re: [GB] h87a: QMK-powered a87 PCB
« Reply #100 on: Tue, 11 December 2018, 07:07:42 »
:fingerscrossed: i am in first batch, so i can build over christmas
My goal is to have em all out by next Friday (21st) at the latest.
If we are traveling for the holidays can we get our shipping delayed? If so should we pm? Email?
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #101 on: Tue, 11 December 2018, 07:26:35 »
Email yep. Hineybushkeyboards@gmail.com with your order number or email address.
Offline hineybush
  • student of error
« Reply #102 on: Thu, 13 December 2018, 00:25:12 »
Almost all of the single orders are packed. I'll be working on the rest of the non-vendor/proxy orders in the next 2-3 days with a goal of getting them all to the post office by Friday. The vendor/proxy orders will be sent out by mid next week.
Offline forevermadrigal
« Reply #103 on: Thu, 13 December 2018, 06:12:54 »
Omg I got a tracking. One step closer to end game. Thanks hiney :thumb:
Offline hineybush
  • student of error
« Reply #104 on: Thu, 13 December 2018, 08:10:28 »
*Saturday
 ;D
Offline hineybush
  • student of error
« Reply #105 on: Mon, 17 December 2018, 17:13:18 »
dropped the first batch off today. can only fit so many in my car.
will do the same over the next few days
Offline hineybush
  • student of error
« Reply #106 on: Wed, 19 December 2018, 19:49:23 »
last batch of multi-PCB orders out tomorrow. not sure if i will be able to get the vendor ones out before i go home for the holiday, but i will attempt
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #107 on: Wed, 19 December 2018, 20:47:26 »
looking good!  :thumb:
-Dana
Offline wholypantalones
  • text and icon mods plz.
« Reply #108 on: Thu, 20 December 2018, 05:50:05 »
My order has been sitting in pre-shipment since Sunday, glad to see that they are going out.  :thumb:
Offline hineybush
  • student of error
« Reply #109 on: Thu, 20 December 2018, 15:39:30 »
Looks like people will start receiving these today. I've redone my site and added a project page for the h87a, with default keymaps, links to .hex files, and other relevant info.
https://hineybush.com/h87a-project/
Offline DasGnome
« Reply #110 on: Thu, 20 December 2018, 16:54:32 »
Got mine today! Woohoo! except I have to wait for my titanium plate too :(
Offline kolashnikov
« Reply #111 on: Wed, 26 December 2018, 21:04:12 »
Just built a Keycult No. 1 with one of these PCBs tonight. I noticed that right shift is really sticky compared to the other stabilized keys. There's resistance on the way down and it doesn't spring back like normal. Is there something tricky about the stabilizers in that position? Maybe I gummed up them up with too much/thick lube. I'm using the clear Zeal stabs.
Offline hineybush
  • student of error
« Reply #112 on: Wed, 26 December 2018, 21:14:37 »
I think I know why.. The right shift and spacebar stabs are bi-directional (the stab wires can be in either north or south-facing direction) which makes the footprints slightly oblong. My best guess is the stab is loose in the mounts right now. You'd be able to fix this by loosening the stab screws slightly, pushing/pulling the stab in the wire/clip end's direction, and re-tightening the screws.
Offline kolashnikov
« Reply #113 on: Thu, 27 December 2018, 05:08:11 »
Thanks, I thought that was related. I loosened and retightened in the correct spot and it works great now. When I was building, I noticed the screws in that stab kept sliding towards the middle of the oblong slot once I tightened them down. The tension from being screwed down in the wrong place must have deformed the stab housings enough to squeeze on the sliders.
Thanks for putting this project together.
Offline hineybush
  • student of error
« Reply #114 on: Thu, 03 January 2019, 20:02:20 »
A few extras available here https://hineybush.com/shop/h87a
Offline futurecrime
  • Get Zooted
« Reply #115 on: Fri, 04 January 2019, 06:46:36 »
Rad. Gripped one.
Offline Captainbuttmonkey
« Reply #116 on: Fri, 04 January 2019, 11:08:22 »
Just wanted to ask if EU proxy ones are on the way? Cheers
Offline hineybush
  • student of error
« Reply #117 on: Fri, 04 January 2019, 11:39:35 »
Shipping em tomorrow.
« Reply #118 on: Fri, 04 January 2019, 12:03:40 »
Sweet, thanks =]
Offline Allo
« Reply #119 on: Thu, 10 January 2019, 00:34:25 »
Anyone know how to enable the caps lock LED?
Offline hineybush
  • student of error
« Reply #120 on: Thu, 10 January 2019, 00:40:03 »
I've been meaning to add that to the project page on my site, check it out in the next few days.
To connect the caps lock LED, locate the jumper pads (three next to each other, would be either J1 or J2) and bridge the center pad to the pad with a dot next to it, or to the opposite pad to add it to the standard led backlight.
Note that I may have those pads backwards, I won't be able to check until tomorrow.
Offline Allo
« Reply #121 on: Sat, 12 January 2019, 16:10:20 »
Could you show a picture as an example? I don't really understand the instructions
Offline hineybush
  • student of error
« Reply #122 on: Sat, 12 January 2019, 16:13:33 »
Connect these two
Offline Allo
« Reply #123 on: Mon, 14 January 2019, 12:21:09 »
Connect these two
One more dumb question, will just a blob of solder work for this?
Offline hineybush
  • student of error
« Reply #124 on: Mon, 14 January 2019, 12:24:17 »
Connect these two
Yep! Should be okay. I'd recommend using a small bit of wire without insulation or a diode/LED leg, but they aren't necessary.
Offline PoochZag
« Reply #125 on: Mon, 14 January 2019, 17:50:10 »
I purchased one of the extras and got my tracking info several day ago, but it still hasn't been received by USPS. Just wanted to make sure this is expected?  Thanks
TX-CP, TX60, Campine Mk. III, Mira SE
Offline hineybush
  • student of error
« Reply #126 on: Mon, 14 January 2019, 21:27:58 »
Hey, yeah! I printed out all of the labels once they were sold. Took me a couple days to get the packing in order, they'll be dropped off to USPS tomorrow.
Offline PoochZag
« Reply #127 on: Tue, 15 January 2019, 08:45:29 »
Great thanks for the update!
Offline Krelbit
  • Switchmod.net
    • Switchmod
« Reply #128 on: Sat, 19 January 2019, 22:30:59 »
Offline pr0ximity
« Reply #129 on: Sun, 20 January 2019, 06:59:56 »
Did I hear right that there might be a thinner version in the works?
Offline hineybush
  • student of error
« Reply #130 on: Sun, 20 January 2019, 10:14:00 »
yea. will be an option for the next gb (prob next month ish)
also https://novelkeys.xyz/products/h87a-pcb-by-hineybush
Offline pr0ximity
« Reply #131 on: Sun, 20 January 2019, 10:19:11 »
Yusssss, that was my only real critique: it's not quite flexible enough for my taste to be used with a half-plate. Amazing quality though, very happy with mine.
Sent from my ONEPLUS A3000 using Tapatalk
Offline Ensaum
« Reply #132 on: Mon, 21 January 2019, 13:59:32 »
Can you clarify what you mean by "thinner?" I'd really like to buy one of these to put in a nerd tkl case, but the usb connector needs to be on the bottom side of the pcb to fit. This is literally the only thing stopping me from ordering one right now.
Offline hineybush
  • student of error
« Reply #133 on: Mon, 21 January 2019, 14:02:57 »
Thinner meaning 1.2mm thick, vs the "normal" thickness of 1.6mm which most PCBs use. I have no plans to make a bottom-USB version publicly available atm, sorry to disappoint.
Offline Ensaum
« Reply #134 on: Mon, 21 January 2019, 14:14:18 »
..I have no plans to make a bottom-USB version publicly available atm, sorry to disappoint.
That's unfortunate. I've been trying to figure out a way to make a B.87 style build ever since winkeyless closed down :/
Offline SBN
« Reply #135 on: Sat, 09 February 2019, 10:52:22 »
Any update on the EU proxy orders? Did MyKeyboard receive them?
Offline dorf
  • divine creator
« Reply #136 on: Sat, 09 February 2019, 10:54:31 »
Last I heard was that they are stuck at customs.
Offline hineybush
  • student of error
« Reply #137 on: Sun, 10 February 2019, 23:04:53 »
Found a problem with the 1u winkey LEDs. There's a short due to the trace crossing over the VCC pad.
To fix: Cut the trace at the red line with an xacto/utility knife. Using wire/something conductive, bridge the LED pad to the center (circle) pad.
Also: expect a new round of these in 2-3 weeks (beginning of March I think). Estimated ship is beginning/mid May.
Code: [Select]
Group buys:
H87 round 2  ~$45 for 1.6mm, ~$50 for 1.2mm and alps (based on estimated order numbers)
    h87a 1.6mm (regular) and 1.2mm (thinboi) versions. h87a 1.6mm will be red, 1.2mm will be matte black
    h87alps - 1.6mm thick only. will be matte black.
« Last Edit: Sun, 10 February 2019, 23:06:27 by hineybush »
Offline Jaxxstatic
  • Haptic Recon
« Reply #138 on: Tue, 26 February 2019, 12:28:24 »
Hineybush.com is down.
Offline hineybush
  • student of error
« Reply #139 on: Tue, 26 February 2019, 12:30:31 »
Working on switching over to Shopify, hung up on squarespace not giving it up in the DNS lol
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #140 on: Tue, 26 February 2019, 12:35:50 »
Whats the appeal of the thin PCB?
Offline hineybush
  • student of error
« Reply #141 on: Tue, 26 February 2019, 12:37:00 »
More flex, it's designed to be used with poly or half plates.
Offline Jaxxstatic
  • Haptic Recon
« Reply #142 on: Tue, 26 February 2019, 12:38:07 »
Dagnabit, you're quick! I'm redoing my whole personal project to match these PCBs instead of a custom one because of the amount of support you've shown with your products and your good communication with other creators.
Offline theillumedpanda
  • Don't point that gun at me - I'm an unpaid intern!
« Reply #143 on: Thu, 28 February 2019, 02:12:49 »
I'm a bit out of the loop, but neither the Alps PCB nor the thinner MX PCB GB has started yet, am I correct?
Offline hineybush
  • student of error
« Reply #144 on: Thu, 28 February 2019, 09:42:53 »
Correct, should be like 2 ish weeks or so
Offline hineybush
  • student of error
« Reply #145 on: Mon, 04 March 2019, 09:58:34 »
The new PCB design stuff is done. I plan to have pricing by the end of this week, and the next GB round will likely start this upcoming Monday (Mar. 11, 2019). It will run for ~3.5 weeks, ending Mar. 29, 2019. No proxies are set up at the moment, but I will be reaching out to vendors to see if any are interested in taking up some stock.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #146 on: Mon, 04 March 2019, 09:59:14 »
Hey that's on my birthday. Nice! What are the new features and specs?
Offline hineybush
  • student of error
« Reply #147 on: Mon, 04 March 2019, 10:07:23 »
Differences from previous version:
  • Fixed WKL winkey LED issue
  • Changed RGB LEDs (2020 vs. 3535 on the old)
  • Improved/redone routing
  • Small tweaks etc. that don't really affect anything
  • QMK will be the exact same as the first round
This time around I'll have three versions:
Normal (1.6mm, same as last round) which will be red
Thin (1.2mm, will add more flex etc) which will be matte black
Alps-only (1.6mm thick) which will have alps-only compatibility (WKL, ANSI, and AEK) - need to add bigass enter at this time. This one will be gloss black
Offline futurecrime
  • Get Zooted
« Reply #148 on: Mon, 04 March 2019, 10:45:24 »
This is amazing. You're amazing. I'm gonna buy your new stuff so hard. God I love a good PCB.
Offline kolashnikov
« Reply #149 on: Mon, 04 March 2019, 10:54:08 »
In for a flexy boi
Any meaningful difference between the types of LEDs? Wondering what motivation you had to change it.
