Author Topic: [GB] h87a LIVE NOW  (Read 155500 times)
Offline TastyChance
Re: [GB] h87a - Round 2 Shipping
« Reply #250 on: Tue, 23 July 2019, 12:33:23 »
All gone? Sucks to be euro...
They were gone incredibly fast lol didn't matter US or Euro tbh
Offline cspirou
« Reply #251 on: Tue, 23 July 2019, 13:02:27 »
I was actually logged on when it went live. Decided to wait since I didn't think it would go so fast.
« Reply #252 on: Tue, 23 July 2019, 13:48:30 »
Same. But I didn't have the dough anyway.
These will go later on NovelKeys, won't they?
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #253 on: Tue, 23 July 2019, 13:48:39 »
Yep!
Offline mgsickler
« Reply #254 on: Wed, 24 July 2019, 09:56:34 »
Offline mgsickler
« Reply #256 on: Wed, 24 July 2019, 10:42:39 »
« Last Edit: Wed, 24 July 2019, 10:44:10 by mgsickler »
Offline TastyChance
« Reply #257 on: Wed, 24 July 2019, 12:22:50 »
I'm sure it's already been asked but when are we going to see a USB C hiney board? I need an excuse to own this many USB C cables 😂
Offline cspirou
« Reply #258 on: Thu, 25 July 2019, 14:59:49 »
...and hotswap
Offline packman86
  • Morning Coffee
« Reply #259 on: Thu, 25 July 2019, 15:16:20 »
...and hotswap
Hotswap adds an unnecessary amount of complexity to the PCB, and the people who would be buying this PCB would probably prefer to solder their finely tuned switches onto it anyway.
« Last Edit: Thu, 25 July 2019, 15:19:52 by packman86 »
Keyboard Collection:
TGR Jane V2 | TGR Jane V2 CE | TGR Alice | TGR Dolice | TGR 910 | TGR x Singa UNIKORN 60 | Matrix 8XV 2.0 Korea Version | Matrix 8XV 2.0add | LZ CLS s h x | Duck Jetfire | TX-CP | QXP | Noxary X65 | RAMA M60-A | Model F62 "Kishsaver" | Daji OC 2XL FnF Black
Offline hineybush
  • student of error
« Reply #260 on: Thu, 25 July 2019, 15:49:23 »
...and hotswap
Hotswap is v possible in the future, we'll see
USB C may happen too, depends on if new stuff in the market dictates the necessity
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #261 on: Thu, 25 July 2019, 16:20:38 »
...and hotswap
Support for Via Configurator would be awesome...
« Reply #262 on: Thu, 25 July 2019, 17:04:28 »
Can you add support for beamspring switches?
Offline hineybush
  • student of error
« Reply #263 on: Thu, 25 July 2019, 17:34:11 »
...and hotswap
Working on it with Wilba...
Offline hineybush
  • student of error
« Reply #264 on: Thu, 25 July 2019, 17:50:45 »
The current h87a/thin/alps supports beamspring switches.
Offline beamingrobot
  • もうけい
    • monokei
« Reply #265 on: Thu, 25 July 2019, 18:05:05 »
how about topre, can we get topre support too thanks
http://monokei.co
Jane v2 | Jane v2 CE | Police | EXENT | KFE | KFE CE | Singa R1 | Jaguar | HHKB | Custom G80-3000 | Dalco 959mini | Haus | Kei | Hiro | Hidari | Tomo | Neko | Prophet | MXSS | TKL One | RS
« Reply #266 on: Sun, 28 July 2019, 06:07:07 »
This groupbuy has made me one happy boy.
Offline hineybush
  • student of error
« Reply #267 on: Sun, 28 July 2019, 14:19:07 »
Great pic, thanks! Looks like the right shift key stab mounts may be slightly on the outer limit of width based on the wire, would it make sense to narrow the distance between them a bit?
« Last Edit: Sun, 28 July 2019, 14:20:41 by hineybush »
« Reply #268 on: Sun, 28 July 2019, 14:46:29 »
Yes. They are literally just a touch too wide. I ended up taking a razor to the stab mounts to make it fit just right. I also ended up bending a wire from an apple bus spacebar because I only had one right shift large enough. It might make sense to make them the same spacing as the others. I know some wires have a reverse bend and alot of boards use a shorter spacing on the right shift.
Offline hineybush
  • student of error
« Reply #269 on: Sun, 28 July 2019, 14:50:29 »
OOf good to know thank you!
Offline hineybush
  • student of error
« Reply #270 on: Tue, 30 July 2019, 13:27:12 »
I just have to send out the Australian proxy orders, will do that tomorrow!
I plan to do two buys VERY soon: h88ce (for Jane V2 CE and associated new designs - thin (1.2mm) only) and another h87a round (normal and thinboi) without RGB underglow LEDs populated in the aim to make the PCBs a bit cheaper (maybe $3-5 per).
I will include some small updates to these as well- likely adjusting the spacebar stab mounting to north-facing ONLY, port positions for daughterboard connection and RGB strip(s), and other small improvements like routing.
Offline henz
  • What?
« Reply #271 on: Mon, 12 August 2019, 14:49:11 »
the pcb looks nice, just wondering how i get it into a programmable state?
« Reply #272 on: Mon, 12 August 2019, 14:51:20 »
There are two holes on the back that say reset above them. Bridge it with tweezers!
Offline packman86
  • Morning Coffee
« Reply #273 on: Mon, 12 August 2019, 14:54:14 »
fn + R when you plug it in also triggers dfu(?) mode.
Offline henz
  • What?
« Reply #274 on: Mon, 12 August 2019, 15:56:05 »
i made a little mod :D
i wont be using QMK, have my own little fork of TMK.
Offline henz
  • What?
« Reply #275 on: Mon, 12 August 2019, 16:35:22 »
ok, that did not work, it was a live reset :( have to figure out something else tomorrow.
Offline Mr_BeastQuake
    • Reddit
« Reply #276 on: Tue, 13 August 2019, 11:19:40 »
PCB without underglow LEDs is something I'd be interested in. When make thiccboi for the thick boys?
Offline hineybush
  • student of error
Re: [GB] h87a - Round 3 pre-orders soon!
« Reply #277 on: Sun, 20 October 2019, 22:12:28 »
I am planning to open pre-orders in the next week or two. Trying to nail down the final color for the 1.6mm version - either gloss green (likely lighter than the proto pictured below), matte black (like round 1) or black FR4 + clear solder mask (see below):
https://www.strawpoll.me/18822462
Example of the black core + clear solder mask:
New features for h87a 1.7:
Redesigned/more robust snap-off parts (USB port, stab anchors around the spacebar area)
JST-SH 4-pin footprints
  One for the USB port (daugtherboards can be directly connected now, no cable soldering)
  One for an RGB daughterboard (in the area between the navkeys and arrows, or anywhere you'd like really)
A bypass to allow the RGB out from the MCU to be directly connected to the RGB daughterboard, instead of to the underglow (the first RGB LED would have to be removed in this instance)
Removal of the dedicated Reset pads, they are now incorporated into the 6-pin SPI header as the two pins exist there already
Improved ground plane via stitching to avoid needing to jump ground pads when the USB port is removed on previous versions
I plan to order the 1.2mm-thickness thinbois soon after these - likely 2-3 weeks after.
« Last Edit: Sun, 20 October 2019, 22:17:09 by hineybush »
Offline ThePanduuh
  • Discord @thepanduuh
« Reply #278 on: Sun, 20 October 2019, 22:19:34 »
my $0.02, the black pcb with clear solder traces looks miles cleaner and more professional than green pcb.
I have some keyboards, mostly resin.
I like CAD. Making things is fun. [W] Projects
Offline ConfuseBill
« Reply #279 on: Sun, 20 October 2019, 22:43:35 »
Wow, Black FR4 with Clear Solder Trace looks cool.
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #280 on: Sun, 20 October 2019, 22:45:54 »
+1 for the black/clear option
Offline Solotov
« Reply #281 on: Sun, 20 October 2019, 22:49:23 »
Hi guys, I'm completely a newbie in Alps world, and currently planning to do a TKL Alps build with DCS Yuri keycaps from Drop.
Saw the info that DCS would need MX stabs. H87a would work well for my case, right? And what about plate? Where can I buy a plate for this build?
Flex is love, flex is life.
Offline hineybush
  • student of error
« Reply #282 on: Sun, 20 October 2019, 23:20:23 »
Hey! The currently available h87alps version (1.0) doesn't support Cherry PCB mount stabs but the next version will. As far as plate goes, you'd need one with plate mount MX stab holes. It depends on the case, but some cases have publically available plate files that you can download. If you find a plate file and need it edited drop me a line.
Offline Solotov
« Reply #283 on: Mon, 21 October 2019, 00:57:07 »
Thanks for the answer, Hiney! That means the incoming round 3 pcb will work for me, right? Then, I'll definitely grab one, and vote for the black color  ;)
Offline hineybush
  • student of error
« Reply #284 on: Mon, 21 October 2019, 01:19:59 »
that update was strictly for the h87a, the MX version. the alps one is separate and will be ready in about a month for a buy.
Offline LifeZ
  • LifeZone
« Reply #285 on: Mon, 21 October 2019, 02:37:39 »
Looks good!!
LZ Limited
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #286 on: Mon, 21 October 2019, 07:17:26 »
Black and clear solder mask looks nice!
Although I kind of wish yellow PCBs were a thing.
Offline Lbibass
« Reply #287 on: Mon, 21 October 2019, 08:53:21 »
The black with clear solder mask will look pretty dope. Def interested in that colorway.
Offline Henrythewound
« Reply #288 on: Mon, 21 October 2019, 10:56:46 »
Is the purpose of these boards mostly to provide a versatile quality TKL PCB for people with really high end cases? I have not gotten past to part of this hobby where everything comes a s a kit (case, plate, PCB all together). What are people doing for a plate to go along with this? Does that depend on their case? I don't know how standardized this layout is.
Offline yicaoyimu
« Reply #289 on: Mon, 21 October 2019, 11:20:06 »
It's meant to be a replacement PCB for cases that are compatible (listed here). Or for those that want QMK.
Offline hineybush
  • student of error
« Reply #290 on: Mon, 21 October 2019, 11:22:09 »
This is for people who need a PCB for an older kit with a "bad" PCB, or they want more programmability. I sell FR4 plates for a few boards currently, but a lot of the time plates can be reused or their files can be found around the community for someone to have their own cut. A lot of newer TKLs are being designed around the PCB as well
« Reply #291 on: Mon, 21 October 2019, 11:29:06 »
Thanks to you both, makes total sense now
Offline jakereps
« Reply #292 on: Mon, 21 October 2019, 20:08:04 »
That Black FR4 and Clear looks so sick, granted it’s a PCB so similar to colored switches it’s not super important as it’s mostly out of sight, but definitely a +1.
Offline TastyChance
« Reply #293 on: Mon, 21 October 2019, 20:28:03 »
I'm running out of my extras this couldnt be better timed.
Offline infamousvincci
« Reply #294 on: Fri, 01 November 2019, 10:01:07 »
Did this GB started already?
Sent from my GM1915 using Tapatalk
Offline hineybush
  • student of error
« Reply #295 on: Fri, 01 November 2019, 10:02:39 »
Nope but i'll be putting some units up for pre order later today
« Reply #296 on: Fri, 01 November 2019, 10:30:38 »
Oh okay. Can i purchase one? Or how do i purchase one?
Offline hineybush
  • student of error
« Reply #297 on: Fri, 01 November 2019, 10:39:32 »
Yep, once I put them in stock they'll be available to pre order. I'm not doing a group buy, I'm going to be ordering a large amount tonight to have ready to ship in about 5 weeks. This will cut a month ish off of the total time needed to wait.
« Reply #298 on: Fri, 01 November 2019, 10:44:11 »
Nice! Is there a discord server that we can go to for the notice when its up? Or ur gonna post it here?
Offline hineybush
  • student of error
« Reply #299 on: Fri, 01 November 2019, 10:45:15 »
discord.hiney.cc
I will also post here
