Author Topic: [GB] Modern Dasher D60 (firmware is updated)  (Read 122145 times)
Offline Chaselicious17
Re: [GB] Modern Dasher D60 (firmware is updated)
« Reply #200 on: Sat, 26 January 2019, 21:11:30 »
So I got the thing built but something when haywire with my pcb and about 4 keys don't work at all and a "column" of keys malfunction when pressed. I'll just order a different 60% pcb and use that. All in all the board looks and feels incredible, I just can't wait to get to use it :D
Offline mxgian99
« Reply #201 on: Sat, 26 January 2019, 21:52:26 »
Sometimes people want to try different layouts. The top-mounted plate and matching PCB are great but you want to try new layouts. I tried to buy another top-mounted plate from Triangle lab. Ramiel arranged it so I can use the DZ60 PCB with it. I had to buy it on Taobao https://item.taobao.com/item.htm?id=586248649082. I tried but my order was declared invalid and I was refunded. This is the 4th time I try to buy stuff from Taobao but no success yet :( If there is enough interest we should try to buy it as a group? I don't speak Chinese unfortunately and I'm not trying Taobao again.
i thought you have to use a proxy to buy from taobao?  i think superbuy is one of them?
Offline mxgian99
« Reply #202 on: Sat, 26 January 2019, 21:53:53 »
i would double check the soldering you did on the daughterboard.   is this the hotswap PCB or your own tray mount one?  if you take the PCB out of the case and plug directly into the PCB does it still do the same thing?
« Reply #203 on: Sat, 26 January 2019, 23:40:17 »
Unfortunately that isn't the issue. I just tried plugging directly into the pcb after taking it out and the same keys weren't working whereas the others still are. It's random like 6, N, S all don't work. I'm chalking up to a pcb issue for now, thanks for the advice!
« Reply #204 on: Sat, 26 January 2019, 23:42:35 »
It's the hotswap pcb from TriangleLabs, I forgot to add
Offline Sshimosawa
« Reply #205 on: Sun, 27 January 2019, 04:28:19 »
hi, so i'm a little confused.  this supports EITHER the top mount plate and hotswap PCB OR a bottom mount plate + PCB--which is pretty much any generic GH60 style 60% keyboard.
if you bought the PCB and matching plate, you do not need to use the standoffs at all.  the plate actually screws into the top of the case from the underside.  if you line up the plate on the underside of the top you should see how it bolts in.  this pictures shows it, see how the plate is bolted around the edges to the underside of the top.
https://i.imgur.com/cFcs762.jpg
What he said. Top mount is the way to go.....
Offline mxgian99
« Reply #206 on: Sun, 27 January 2019, 08:47:19 »
sorry if i missed this, but is that even with no switches mounted?
« Reply #207 on: Sun, 27 January 2019, 10:35:12 »
Yea so like I took the switches off the pcb and plate. Then I just put a single switch on the problem keys and plugged the pcb in. The problem keys weren't working but the ones that were working continued to work.
Offline mxgian99
« Reply #208 on: Sun, 27 January 2019, 14:56:02 »
ah ok, so my guess would be the hotswap sockets are not soldered in all the way.  i would test to see if the pads are sending signals correctly (you can do this by connecting the pads with a set of tweezers), that way you would know the PCB underneath is fine but that the hotswap sockets need to be addressed.  and then i would try adding some solder to the hotswap sockets to get them seated in the pads.  but i know that's a bit of work/know-how so if thats too much, i hope ramiel gets you a new PCB soon!
« Reply #209 on: Sun, 27 January 2019, 15:37:30 »
I'll try the tweezers thing! If it's a hotswap socket issue and not a pcb issue then I can probably figure it out, otherwise Ill snag another 60% pcb.
Offline vodan
« Reply #210 on: Tue, 02 July 2019, 01:40:01 »
still kicking myself for missing out on this.
hoping there will be enough demands for a new round...
Offline Neodeus
« Reply #211 on: Wed, 03 July 2019, 07:16:11 »
I'll add +1 to demand. I would love to have one o' these.
Offline jmg123
« Reply #212 on: Sat, 28 September 2019, 09:00:15 »
I bought one of these second hand on Mechmarket, and got a stainless steel iso plate for it cut at laserboost, fits really well and makes it even more heavy!  If anyone else wants to get a new plate in the future, these are the settings I used in  http://builder.swillkb.com.  to generate the plate:
Plate layout: <Add yours from kle here>
Switch Type:MX
Stabilizer Type: Cherry Only
Case type: None
Edge Padding:5.838mm
Plate Corners:2mm
Custom Polygon:
   cut polygon:circle
   diameter: 2.5mm
   shapes relative to:[0,0]
   circle centres: [51.874,50.507];[-51.874,50.507];[51.874,-50.507];[-51.874,-50.507];[121.874,50.507];[-121.874,50.507];[121.874,-50.507];[-121.874,-50.507]
Add polygon:rounded rectangle
   radius: 3.2
   width: 75.266
   height: 10
   shapes relative to: [0,0]
   rounded rectangle centres: [-50.562,y];[-50.562,-y];[50.562,y];[50.562,-y]
   radius: 3.2
   width: 10
   height: 68.927
   rounded rectangle centres:[[-x,0];[x,0]
Offline singabore
« Reply #213 on: Thu, 17 October 2019, 15:34:34 »
Hey guys, I accidentally busted up the pcb end of the daughter board adaptor. Is there anyway to replace it?
Sent from my SM-N950U using Tapatalk
Offline mxgian99
« Reply #214 on: Thu, 17 October 2019, 16:15:23 »
is that the end that connects to the PCB?  it looks like the other side is ok, so could you just cut that end off a good cable and strip the wires to connect it to the daugherboard?
or do you think you need a replacement daughter board?
Offline singabore
« Reply #215 on: Thu, 17 October 2019, 16:48:57 »
No the end that connects to the PCB is completely busted. I need to find a replacement and solder it onto the wires that connect to the daughterboard
Offline mxgian99
« Reply #216 on: Thu, 17 October 2019, 17:12:18 »
Not sure I follow 100% but can you just cut apart a new usb cable with the right end to fit your pcb and solder that to the daughter board?   You would then connect 4 wires from usb cable to 4 holes on daughter board.
Offline singabore
« Reply #217 on: Thu, 17 October 2019, 17:13:27 »
Ohh I see what you mean. I didnt think about that. Thanks
Offline singabore
« Reply #218 on: Thu, 17 October 2019, 18:48:32 »
Where can I buy a new connector?
Offline singabore
« Reply #219 on: Fri, 18 October 2019, 12:54:47 »
Also does anyone know how I can get in contact with ramiel?
Offline jiezhou
  • https://jiekb.com
    • JIEZHOU
« Reply #220 on: Fri, 18 October 2019, 13:27:50 »
You could try to PM OP Ramiel or foxlab senter to get an extra daughter board kit.
Offline vodan
« Reply #221 on: Sun, 24 November 2019, 22:34:46 »
Switch Type:MX
Case type: None
Plate Corners:2mm
Custom Polygon:
   cut polygon:circle
   diameter: 2.5mm
   radius: 3.2
   width: 75.266
   height: 10
   radius: 3.2
   width: 10
   height: 68.927
this is a godsend! thank you!
Offline ChutneyRiggins
« Reply #222 on: Wed, 15 January 2020, 14:49:08 »
Is there any chance that this kit gets another production run?
Offline singabore
« Reply #223 on: Fri, 31 January 2020, 14:07:04 »
I have a scuffed d60 that I'm trying to sell if anyone is interested. PM me for more pictures
Offline Skfocmwla18(!
« Reply #224 on: Sat, 25 January 2025, 22:14:14 »
This should be resurrected in a larger size with a ‘cross’ arrow layout to give those of us wanting a ‘Lumon’ vibe a chance!
Offline Punkypj
« Reply #225 on: Fri, 07 February 2025, 17:12:23 »
This 👆
Offline Ouskambou
« Reply #226 on: Tue, 25 February 2025, 08:26:51 »
I'd buy one too
Offline reidweb
« Reply #227 on: Tue, 25 February 2025, 10:42:21 »
Also interested
Offline jd
  • 60%
« Reply #228 on: Sat, 01 March 2025, 12:17:05 »
I would be 100% in even if this was resurrected as-is! This keyboard is such a beast.
Offline kajahtaa
« Reply #229 on: Sat, 01 March 2025, 13:02:50 »
yep. regret selling mine.
my first GB board. Would love to get a R2 in MX HHKB layout.
Even if only 30 are cut like first time. hehe.
