Author Topic: [IC] Stemshaver - a tool to fix BOX switches  (Read 76459 times)
Offline Fantaku
Re: [IC] Stemshaver - a tool to fix BOX switches
« Reply #200 on: Sat, 12 December 2020, 08:22:32 »
I know I'm super late to the party... But I could really use something like this, is there still any chance on getting my hands on something somewhere?
Offline Ella
  • Why is it called an oven
« Reply #201 on: Sat, 08 May 2021, 16:06:56 »
Were these ever sold, and is it possible to buy one now? I have some very tight MX Clears that I want to make less tight.
Offline dyrdevil
« Reply #202 on: Sat, 08 May 2021, 23:52:21 »
+1. still looking for one.
Offline Kavik
« Reply #203 on: Sun, 09 May 2021, 01:17:20 »
I ended up getting the Cruciformer (https://rudbeardesign.myshopify.com/products/cruciformer). It's currently out of stock, but you may be able to get in contact with the maker to ask about it. I may have done something wrong, but it actually cut my box switches a little too much, so some types of keycaps are loose instead of too tight, but at least it exists unlike the item in this thread.
Offline Ella
« Reply #204 on: Sun, 09 May 2021, 01:52:30 »
Thanks, I'll check it out
Sent from my M2007J20CG using Tapatalk
Offline ReverbSlush
  • 16/52 RNG score
« Reply #205 on: Tue, 11 May 2021, 06:23:57 »
I have one... just shoot me a PM  (I'm in the US, if that matters to you).
