Author Topic: [IC] Stemshaver - a tool to fix BOX switches  (Read 75356 times)
Offline lutchbu
« on: Wed, 31 October 2018, 18:48:53 »
Hi geekhack!
Two weeks ago I posted on reddit about a little piece of brass I machined to fix the old stemmed BOX switches I have. I also made a v2 out of steel.
Reddit post v1: https://www.reddit.com/r/MechanicalKeyboards/comments/9p2ay5/i_present_to_you_the_stemshaver/
Reddit post v2: https://www.reddit.com/r/MechanicalKeyboards/comments/9p97bd/stemshaver_v2_adventures_in_metal/
Imgur album: https://imgur.com/a/zgmJw6z
This got some attention and lots of people told me they'd be interested in buying one, so here we are...
IC Form: https://docs.google.com/forms/d/e/1FAIpQLSdqCEiw2psQEP_6m0DztjzyczzvGgwjO_JBK3t7tdOsohNagw/viewform
If there are any questions, feel free to get in touch but it's the first time I'm doing something like this, so please be gentle. ;)
frequently asked questions
Price
Material costs are low. I don't know for sure but probably under 0.5 USD. The expensive part is my time and the machining. It took me about an hour to make the first one.
To explain my current manufacturing steps a bit:
  • cutting stock to length
  • milling the slots
  • grinding the bevels and deburring
  • fine tuning the distance between the cutting edges to 1.25mm by hand sanding the inside faces of the tool The new version does not require this anymore.
Current estimate: 10-18 USD depending on order quantity
Shipping
I'm in the EU and I plan to ship worldwide if we get that far. The tool is small, this should keep the shipping costs fairly low. Current estimate is 8-10 USD tracked and insured up to ~40 USD. No promises though.
Durability
It turns out there are lots of you with several hundred switches they'd like to fix. This rises the reasonable question if the tool will hold up/stay sharp for that many switches, especially the brass version.
I don't think the sharpness will be a problem. Even if the shaver blunts it could easily be resharpened with some fine grit sandpaper and a flat surface. However, I am a bit concerned about the cutting edges bending apart. While the tool wouldn't become unusable, it would become less effective, requiring multiple applications per stem or application at an angle, which in turn would require more care by the user. The new version should not have this problem.
BUT, to be honest I don't know and this is all speculation on my part.
Testers report minimal to no wear after testing the stemshaver on up to 200 switches.
How to use it
Ideally, you push it on the stem in the right orientation, pull it off and you're done. I would recommend testing the fit every few switches and adjusting the tool or your technique accordingly to produce the desired tightness.
Short video of me using the tool:
UPDATE 2
New version:
In this version the sides of the x-axis are closed. This should prevent the prongs from deforming but is a bit more difficult to machine.
I also made prototypes of the regular and deluxe version.
Regular:
Deluxe:
more pictures here: https://imgur.com/a/wnLvcYB
The next step is to send a few stemshavers out for testing.
UPDATE 3
OVERVIEW
testresults, i've been takling to a cnc shop and decided to drop the artisan idea
TESTRESULTS
  • design: Material will be steel and the stemshaver does not need a bevel. No bevel would cut costs by ~25% but means that there might be a slightly higher force required to operate
  • function: Prototypes produced the desired results but had to be applied a second time rotated 180°. This is due to my milling setup and should not be an issue with the ones produced by the cnc shop.
  • durability: Prototypes were tested on up to 200 switches with minimal to no wear observed
PRICE
Current estimate is 10-18 USD for the regular version, depending on quantity.
and now?
I'm not quite sure how to proceed from here to be honest. Ideally, I would want to send out a batch of prototypes made by the cnc shop to test them out. However I do not have the means to finance a small prototype run.
So... any advice?
Changelog:
2018-11-01: added FAQ
2018-11-11: added Update 2, updated FAQ
2019-03-21: added Update 3, updated FAQ
« Last Edit: Thu, 21 March 2019, 11:07:32 by lutchbu »
Offline cijanzen
Re: [IC] Stemshaver - a tool to fix BOX switches
« Reply #1 on: Wed, 31 October 2018, 18:49:36 »
Want one!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Wed, 31 October 2018, 18:58:04 »
I'd be interested as well. Gotta make use of allll of these switches I have lying around in the corner of shame.
Offline pixelpusher
« Reply #3 on: Wed, 31 October 2018, 19:21:34 »
About 1000 switches that need fixing.  I’d take one or two
Offline ReverbSlush
  • 16/52 RNG score
« Reply #4 on: Wed, 31 October 2018, 19:26:58 »
IN.  I need to fix my switches.  stuck using PBT on a super nice board right now.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #5 on: Wed, 31 October 2018, 19:29:59 »
I'm interested, but I have questions before filling out the form.
1. Can you do a render of sorts of your deluxe tool idea? It can be potato, I'm just having trouble visualizing what you mean.
2. About how long does it take you to mill one, what's the likelihood of mistakes and do-overs, and what is the per-tool metal cost? I want to know a little more before suggesting a price.
3. I have around 700 of the first-gen box switches to shave. Do you think brass would stay sharp through that many?
Thanks for running this! It'll be a life saver.
Offline abrahamstechnology
« Reply #6 on: Wed, 31 October 2018, 20:55:12 »
Interested as heck!!!!
Offline Starius
« Reply #7 on: Wed, 31 October 2018, 21:07:58 »
I'm definitely interested as well.
I have a lot of unused Box switches stocked up.
I had been considering trying to sell them, but if this tool works - I would rather try this first rather than completely offloading my stock.
Offline euphxenos
« Reply #8 on: Wed, 31 October 2018, 21:50:19 »
I'm interested.  I don't think we know enough about your time and costs to be able to suggest a price for you.
Offline ExuDeCandomble
« Reply #9 on: Wed, 31 October 2018, 21:52:08 »
Registering my interest in this thing!
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #10 on: Wed, 31 October 2018, 21:56:55 »
IC filled out. would love to have my SA on Navies again.
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
« Reply #11 on: Wed, 31 October 2018, 23:23:02 »
If you're looking for people to do some early testing for feedback, I've got about 700 Jades to test on.
Offline Mcnos
    • GMK Fuyu
« Reply #12 on: Wed, 31 October 2018, 23:37:15 »
Interested. Even though I'm not that into box anymore. There's not much that's unique
Offline sevenseacat
« Reply #13 on: Thu, 01 November 2018, 00:55:52 »
If you like clicky switches, there isn't much to compare them with...
Offline Eggplant
« Reply #14 on: Thu, 01 November 2018, 01:00:57 »
I'm very interested!
Offline portbaron
« Reply #15 on: Thu, 01 November 2018, 01:27:36 »
I'll try it
| LIVING THE 1800 LIFE |
Offline _ODIN_
« Reply #16 on: Thu, 01 November 2018, 03:08:00 »
I am in
Gesendet von meinem H8416 mit Tapatalk
Offline Kerasan
« Reply #17 on: Thu, 01 November 2018, 04:00:46 »
PVD Coating pls  :)) :)) :))
KMK Labs.
Offline funderburker
« Reply #18 on: Thu, 01 November 2018, 04:08:13 »
This is really cool, would definitely think of buying one if I had a lot of Box switches.
Keyboard design by Skepur
Offline Darknight00z
« Reply #19 on: Thu, 01 November 2018, 10:19:03 »
In for one
Offline realxmlforce
« Reply #20 on: Thu, 01 November 2018, 12:34:22 »
In for one too. And some thing to protect the stem shaver from corrosion would be nice. I guess that is what the pvd coating demand is for?
Gesendet von meinem Xperia Z5 mit Tapatalk
  • ʘ_ಠ
« Reply #21 on: Thu, 01 November 2018, 14:03:00 »
What's the coating about? Like what you see on some knives, where it's coated except for the cutting edge?
Offline macken
« Reply #22 on: Thu, 01 November 2018, 16:32:01 »
This will come in handy. Interested!
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #23 on: Thu, 01 November 2018, 16:50:28 »
Interested
Offline voight-kampff
« Reply #24 on: Thu, 01 November 2018, 17:02:07 »
Personally I can live withoult a coating. It should work, should shave the stems.
It is a tool used for let's say for a year. Then all the box stems will be the new ones, and the old ones will be shawed.
Offline Acereconkeys
  • Happiness = life - expectations
« Reply #25 on: Thu, 01 November 2018, 17:13:40 »
Interested. Seems like a useful tool to have.
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline Starston3
« Reply #26 on: Thu, 01 November 2018, 17:20:26 »
Yep... sign me up.
Offline pixelpusher
« Reply #27 on: Thu, 01 November 2018, 17:37:35 »
Since every time I see this topic I misread it as either “steamshaver” or “steambeaver”, can we call it that?   Maybe the stem beaver? Thx
Offline cijanzen
« Reply #28 on: Thu, 01 November 2018, 18:58:48 »
Heh, I like Stem Beaver. +1
Offline Zuology
  • Why does this rabbit-hole have so many side-quests
« Reply #29 on: Thu, 01 November 2018, 19:02:38 »
How about calling it the Boxcutter? Wordplay/pun requirement satisfied without bordering on lewd, conveys what it does.
75%: Scarlet Bandana (TBD) | Singa75 Polycarb (TBD) | SKB75 (TBD) | YMD75 (Box Navy) | XD84 (Outemu Ice) | Plum84 (BKE Redux Heavy)
TKL: ALF X1.1 SE (TBD) | LZ Iron White (TBD) | Fox Labs Orange (TBD) | Alu WASDv2 (Cherry Green) | MechkeyAlpha MA87 (Kailh Box Burnt Orange) | Archon RE:AL Superior EX (Nopre 65g)
Full+: Clueboard Double 1800 (Vint Clears) | IBM Model M | IBM Model F XT
« Reply #30 on: Thu, 01 November 2018, 19:03:00 »
I too love the name stem beaver.
Offline cijanzen
« Reply #31 on: Thu, 01 November 2018, 19:04:26 »
Beavers aren’t lewd. They’re literally animals that chew down trees. But I do like box cutter as well.
« Reply #32 on: Thu, 01 November 2018, 19:22:45 »
Damn... Boxcutter is good...
Offline lutchbu
« Reply #33 on: Thu, 01 November 2018, 19:26:58 »
Hi, I just updated the 1. post addressing frequently asked questions and comments
I don't have render at the moment, just an idea in my head. ;) I'll try to make some prototypes soon.
KMK Labs.
Please keep in mind that every manufacturing step added will drive up cost. I could oil the steel version but that would be a mess.
I like both names. :) Maybe we'll get a rebrand for the GB.
Offline GigaFlop
« Reply #34 on: Thu, 01 November 2018, 19:47:54 »
I marked myself as down for this. I'm on a Tada68 with old Box Jades, and one of my low value caps is cracked. I've got a set of Mitolet on the way, and am scared :(
Oh god why did my wallet get so thin
Offline onefivenine
    • Project Keyboard LLC
« Reply #35 on: Thu, 01 November 2018, 19:54:17 »
Shoot I’ll use this on mx clears
Offline Zuology
« Reply #36 on: Thu, 01 November 2018, 20:15:34 »
My mind is just dirty and went to the lewd side (shave + beaver + box/stem), so I tried to temper it for non-sick-f*cks by adding "bordering on" :D
Offline pixelpusher
« Reply #37 on: Thu, 01 November 2018, 21:15:58 »
Box beaver.  There.  Super lude, super awesome.
« Reply #38 on: Fri, 02 November 2018, 16:12:38 »
(deleted)
« Last Edit: Fri, 02 November 2018, 18:49:43 by abrahamstechnology »
Offline lendflat
« Reply #39 on: Fri, 02 November 2018, 16:14:19 »
Can you explain how this tool actually works??
« Reply #40 on: Fri, 02 November 2018, 16:35:51 »
OG box stems have little ridges on the side that can break caps, this cuts them off
Offline bluesclera
« Reply #41 on: Fri, 02 November 2018, 16:40:33 »
thanks, was wondering also.
Offline dario
  • obsessive–compulsive hardware slut
« Reply #42 on: Sat, 03 November 2018, 02:58:00 »
Hey OP, what do you think would your tool work with Nexus ALPS to MX stem equally well? Turns out, they need some shaving too.
« Reply #43 on: Sat, 03 November 2018, 05:28:06 »
"Box cutter" sounds good and with just the right amount of pun.  :thumb:
Offline Starius
« Reply #44 on: Sat, 03 November 2018, 07:43:15 »
I'm fond of that one myself. ;)
Offline azeria
« Reply #45 on: Sat, 03 November 2018, 12:26:38 »
so down
Offline azharkh
« Reply #46 on: Sat, 03 November 2018, 19:53:35 »
in 100%.
Offline PikaJoyce
« Reply #47 on: Sat, 03 November 2018, 21:11:32 »
I'd be interested in getting one of these for future box switches I may end up getting :)
« Reply #48 on: Sat, 03 November 2018, 22:29:57 »
I was going to sell my Box Jades because it wasn't worth risking caps, but if I can pick up a Boxcutter, depending on the price, that would be awesome!
Offline BigBlackThock
« Reply #49 on: Sat, 03 November 2018, 22:48:13 »
I keep hearing people refer to OG and first generation box switches as if this is no longer an issue. I have been told the exact opposite by several people. Do I need this if I buy new box switches or not?
