Author Topic: [IC] VE.A 2nd  (Read 276984 times)
Offline severin
Re: [IC] VE.A 2nd
« Reply #300 on: Tue, 14 May 2019, 15:55:51 »
Looks great, would be in
Offline horribleatcalculus
Re: [IC] VE.A 2nd
« Reply #301 on: Tue, 14 May 2019, 16:51:55 »
Fantastic, made an account just to plant my stake of support.
Offline adramalech
Re: [IC] VE.A 2nd
« Reply #302 on: Tue, 14 May 2019, 18:23:36 »
Just created an account to show my support also. That keyboard looks amazing!
Offline aphoid
Re: [IC] VE.A 2nd
« Reply #303 on: Tue, 14 May 2019, 18:27:28 »
Interested.
Offline PainMaster
  • Formerly cjakma
  • IBM(PainMaster)
Re: [IC] VE.A 2nd
« Reply #304 on: Tue, 14 May 2019, 19:35:27 »
Thanks(?) to your many requests,
We're working on a sample of VE.A 2nd's PCB
We're still seeing some modifications.
First, all SATA + USB mini-connectors were changed to USB - C.
And, PCB patterns are being organized.
This is not a finished product.
It's about 90% complete.
Will there be blocker options on this board?
We are testing to deal with any situations that
could damage the circuit,
cause abnormal operation,
or cause over-voltage conditions.
Although we have prepared the over-voltage blocking option,
which is the reference for USB-C,
it will be accurate if we test it a little more.
The software should still use bootmapper.
SaiB-CP Black - Kailh Bronze (Non Click / 58g) - Finish
Light Saver v1 Black - Cherry Wyze Black (Linear / 64g)
Light Saver v2 Gray - Cherry 1501 Black (Linear / 64g)
Light Saver v3 Silver - Cherry 8200 White (Non Click / 64g)
Light Saver Acryl (Duck96 base) - Gateron Yellow (Linear / 62g) - Season 1 Fin.
Octagon v1 Black - Cherry 1501 Black (Linear / 64g) / TX-1800 v1 Red/Black - Cherry Wyze Black (Linear / 58g)
VE.A Test Housing- Cherry 8113 White (Non Click / 58g)
TC-V3 , LZ*ASRH Black, VE.A 2nd
... etc.
Offline bisoromi
  • Formerly Duwang
  • owo
Re: [IC] VE.A 2nd
« Reply #305 on: Tue, 14 May 2019, 19:46:52 »
C:
(credits to Kokaloo)
Offline yicaoyimu
Re: [IC] VE.A 2nd
« Reply #306 on: Tue, 14 May 2019, 19:47:57 »
I'm not a big fan of the two extra columns to the left. I would also like to have a sperator between left arrow and the modifier key next to it.
Offline JediJesseS
Re: [IC] VE.A 2nd
« Reply #307 on: Tue, 14 May 2019, 21:06:41 »
USB-C is amazing! Sold on this board.
Offline ImBZppl
Re: [IC] VE.A 2nd
« Reply #308 on: Tue, 14 May 2019, 21:52:10 »
This will be the last one then I'm out I swear.  ;D
Offline LithiumLion
Re: [IC] VE.A 2nd
« Reply #309 on: Tue, 14 May 2019, 22:43:44 »
Registed for this I would be in! I always wanted a VE.A
Offline AlcoholEnthusiast
Re: [IC] VE.A 2nd
« Reply #310 on: Tue, 14 May 2019, 23:08:07 »
Glad to see USB-C as an option. Is that for powering the board or for connecting the two sides?
Offline Sorachi.Ace
  • Formerly CaptRobo
  • Co-owner of SodieCaps artisan keycaps
Re: [IC] VE.A 2nd
« Reply #311 on: Tue, 14 May 2019, 23:16:10 »
Both.
Offline DillonHightower
  • Formerly DillonHighsmith
Re: [IC] VE.A 2nd
« Reply #312 on: Tue, 14 May 2019, 23:34:50 »
Whooo!! Glad to see this get some life, and take off a little. Such a gem that went under the radar for so long. I bet if this hit massdrop in the current market. it would sell 10 fold what it did originally..
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
Re: [IC] VE.A 2nd
« Reply #313 on: Tue, 14 May 2019, 23:46:22 »
Hello yes i would like one
Offline Don Cardenio
Re: [IC] VE.A 2nd
« Reply #314 on: Tue, 14 May 2019, 23:55:19 »
This is what will fill the holes in my life. Can't wait.
Offline oHimari
Re: [IC] VE.A 2nd
« Reply #315 on: Wed, 15 May 2019, 10:37:09 »
Now I'm definitely getting one.
Offline macintacos
Re: [IC] VE.A 2nd
« Reply #316 on: Wed, 15 May 2019, 16:29:05 »
Good news that VE.A 2 is going to get type-c support for all connectors. I guess it's for the better, losing the iconic SATA connector.
What about software, still going to be using bootmapper? Would hope that we could change that too. Not sure who is the creator of bootmapper and since winkeyless have closed, if possible, maybe change the way on how to configure the board to some of the newer and latest way. QMK? etc.
This will be unpopular opinion but qmk blows ass for new users and is not friendly whatsoever.. boot mapper works 99% of all users without needing a programming degree in order to get the damn thing working. I have no idea why anyone prefers qmk over any of the more simple interface is out there.
Personally, I like QMK; I've never really had a problem getting it set up, and the interface is plenty user friendly for my needs? I've only recently started modding boards and it really wasn't difficult to get started. Documentation is great too.
Anywho, very happy that this is coming!
Offline rkarp
    • hypertext.dev
Re: [IC] VE.A 2nd
« Reply #317 on: Wed, 15 May 2019, 20:36:32 »
In on this...
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] VE.A 2nd
« Reply #318 on: Thu, 16 May 2019, 03:36:44 »
Personally, taking away those columns takes away a good part of the charm for these keyboards.
A separator I can agree with.
And as previously mentioned, hopefully a revision to the acrylic diffuser lines and the badge/logo as well so it looks more elegant.
« Last Edit: Fri, 12 July 2019, 01:20:15 by LightningXI »
Offline jil_jil32
  • Tokyo Press <3
Re: [IC] VE.A 2nd
« Reply #319 on: Thu, 16 May 2019, 07:28:21 »
Bookmarked.
Offline rawrjau
  • Stop making nice things so I can stop spending
Re: [IC] VE.A 2nd
« Reply #320 on: Thu, 16 May 2019, 15:48:02 »
In from the start! I discovered VE:A after it was gone and this is definitely the endgame
Offline IOVERCALLHISTIOCYTES
Re: [IC] VE.A 2nd
« Reply #321 on: Sat, 18 May 2019, 07:56:51 »
Tenting kits? Wrist rests?
Re: [IC] VE.A 2nd
« Reply #322 on: Sat, 18 May 2019, 10:43:34 »
I'm totally in for this one! Endgame material right here.
E6-V2 [Tealios] | RAMA M60-A [Zealios] | QXP [Healios]
Offline hejog
Re: [IC] VE.A 2nd
« Reply #323 on: Sat, 18 May 2019, 13:29:15 »
just created an account after far too long of being a lurker to reiterate my interest!
Offline soso
Re: [IC] VE.A 2nd
« Reply #324 on: Sat, 18 May 2019, 16:30:05 »
I'd also like info on this.
Offline nastrovje
Re: [IC] VE.A 2nd
« Reply #325 on: Sat, 18 May 2019, 16:58:16 »
created an account 3 years ago to post in this thread. still interested.
pls change the extreme logo.
Offline rmendis
  • Artisan addict
Re: [IC] VE.A 2nd
« Reply #326 on: Sun, 19 May 2019, 16:52:02 »
It would be unbalanced without the left columns.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [IC] VE.A 2nd
« Reply #327 on: Mon, 20 May 2019, 09:43:15 »
I love my current VE.A, R2 is looking to be even better. I would probably be in for this and start using my R1 at work so I can enjoy that ergo life in two places without lugging my keyboard around.
Offline RDaneelOlivaw
  • Don't Panic.
Re: [IC] VE.A 2nd
« Reply #328 on: Mon, 20 May 2019, 12:09:13 »
I'm loving the update!! Very excited that progress is being made.
Regarding the firmware, I am torn, I like qmk for it's power, but it is so annoying how hard it is to use. Bootmapper I think will work just fine.
He felt that his whole life was some kind of dream and he sometimes wondered whose it was and whether they were enjoying it.
Offline radam
Re: [IC] VE.A 2nd
« Reply #329 on: Mon, 20 May 2019, 14:37:21 »
I’m interested in this but downloading an executable off Dropbox to program makes me real nervous. Would bootmapper client be the only way?
Edit:
I'm confused. If the layout is available in QMK you can just go to https://config.qmk.fm and pick the layout and configure. Click "compile" and download the firmware and then flash with dfu-programmer command line tool or qmk toolbox.
It doesn't seem like you have to manually build the firmware if you don't want to.
« Last Edit: Mon, 20 May 2019, 14:56:24 by radam »
Offline Rejeckted
  • Fe, Fi, Fo, Fum... I smell Kraft dinnah
Re: [IC] VE.A 2nd
« Reply #330 on: Mon, 20 May 2019, 23:16:32 »
I would definitely be on board for this.
« Last Edit: Thu, 30 May 2019, 02:43:44 by Rejeckted »
Offline Twist3d
Re: [IC] VE.A 2nd
« Reply #331 on: Tue, 21 May 2019, 01:05:10 »
Can't wait to see the final details.
Offline rampantandroid
Re: [IC] VE.A 2nd
« Reply #332 on: Mon, 27 May 2019, 00:06:20 »
I'd have interest in this.
Someone apparently went up to the great philosopher Wittgenstein and said "What a lot of morons people back in the Middle Ages must have been to have looked, every morning, at the dawn and to have thought what they were seeing was the Sun going around the Earth, when every school kid knows that the Earth goes around the Sun", to which Wittgenstein replied "Yeah, but I wonder what it would have looked like if the Sun had been going around the Earth?"
Offline CallMeMaybe
Re: [IC] VE.A 2nd
« Reply #333 on: Mon, 27 May 2019, 08:50:20 »
Beyond down for a board, been waiting for this since missing R1.
The USB C is def a big and my wallet is more than ready.
Offline silas
Re: [IC] VE.A 2nd
« Reply #334 on: Mon, 27 May 2019, 19:02:08 »
Would be in for one if it can handle peak 150wpm (600-800 key presses) without dropping input or rolling over. See that it is an issue from V1 as well as other single-controller split keyboards that I own. (my deltasplit and quefrency boards don't have the issue)
Offline Skull_Angel
Re: [IC] VE.A 2nd
« Reply #335 on: Wed, 29 May 2019, 19:42:48 »
Check your debounce settings. Iirc, the default setting isn't optimal and can cause these issues.
Edit: The info in this thread might be relevant to you if you're really interested in keyboard performance; https://geekhack.org/index.php?topic=42385.0
« Last Edit: Wed, 29 May 2019, 19:52:33 by Skull_Angel »
Offline japancakes
Re: [IC] VE.A 2nd
« Reply #336 on: Thu, 30 May 2019, 02:34:06 »
In 100%.
Only thing I hope changes are the shifting lines around the acrylic diffuser in the front/back, the -=-=-=- look.
It looks busy and "gamer" compared to the original which is not what you generally desire with a $400+ keyboard. V2 already looks different with the tenting, logo, etc.
Offline FatOldGuy
  • SA4Lyfe
Re: [IC] VE.A 2nd
« Reply #337 on: Thu, 30 May 2019, 21:42:01 »
I'd be 100% down with this. Sign me up
Offline foo4542
Re: [IC] VE.A 2nd
« Reply #338 on: Wed, 05 June 2019, 03:15:39 »
Offline Yazzin123
Re: [IC] VE.A 2nd
« Reply #339 on: Wed, 05 June 2019, 07:06:35 »
100% in on this one
Offline MrTq
Re: [IC] VE.A 2nd
« Reply #340 on: Wed, 05 June 2019, 07:15:17 »
waiting here...
Offline heyitsqi
Re: [IC] VE.A 2nd
« Reply #341 on: Wed, 05 June 2019, 12:44:52 »
Glad to see USB-C finally put in. The last item on my checklist would be QMK.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: [IC] VE.A 2nd
« Reply #342 on: Wed, 05 June 2019, 13:00:40 »
Re: QMK, just use the configurator. Yes, it's not quite as easy as Bootmapper, but nowadays it's pretty close. Winkeyless.kr doesn't even operate anymore outside of Korea.
Thanks for the update, these are good changes. Is there any chance of a plate material other than stainless steel? I think aluminum might be more suitable for most people nowadays.
It would also be nice to see some more detail on the tenting system (not sure if that's been posted already).
Re: [IC] VE.A 2nd
« Reply #343 on: Wed, 05 June 2019, 13:10:53 »
Tenting details haven't been posted yet. I watch this more carefully than I do oncoming traffic
Re: [IC] VE.A 2nd
« Reply #344 on: Wed, 05 June 2019, 21:40:39 »
Im with you man. I need an  board for my carbon build, I have chosen this. And well It cant come soon enough. been holding out from other good buys not knowing when to expect anything from this.. Hopefully soon!
Offline japancakes
Re: [IC] VE.A 2nd
« Reply #345 on: Fri, 28 June 2019, 10:53:38 »
yeet my wallet off a cliff
Offline juusu
Re: [IC] VE.A 2nd
« Reply #346 on: Sun, 30 June 2019, 03:34:26 »
I Hate to be that guy, but ... any chance of ISO layout support?
Offline bit-shifter
Re: [IC] VE.A 2nd
« Reply #347 on: Sun, 30 June 2019, 03:57:40 »
ISO is supported, see the OP!
Cheers!
Offline urbantheii
Re: [IC] VE.A 2nd
« Reply #348 on: Sun, 30 June 2019, 12:25:48 »
When can I throw my money at it?
Offline strigif0rm3s
Re: [IC] VE.A 2nd
« Reply #349 on: Wed, 10 July 2019, 15:17:45 »
omg im in! when is this happening?!?!?
