Author Topic: [IC] VE.A 2nd  (Read 276975 times)
Offline Vigrith
Re: [IC] VE.A 2nd
« Reply #50 on: Mon, 26 November 2018, 13:42:31 »
Anyhow, how do you know it is the SATA cable that is causing the lag and replacing the SATA connector to something else will fix it? Why do you think using USB-C will eliminate the lag that you experience?
I personally don't know enough about the matter to be able to answer this but it's widely accepted as fact from the other owners I've spoken to who know a lot more than I do - surely someone can chime in considering the amount comments that have already been made against.
Offline litster
  • rare caps?! THAT'S A SMILIN
Re: [IC] VE.A 2nd
« Reply #51 on: Mon, 26 November 2018, 13:46:44 »
PS: plenty of cable makers within the hobby make USB-C cables nowadays so that argument is moot point.
I didn't really argue that you can't or shouldn't get a custom USB-C.  In fact I was arguing the opposite with armpit that the cable for VE.A should be custom length but he has a requirement that he wants to use one of his handful of 6 feet long USB-C cables for the keyboard.
Offline litster
Re: [IC] VE.A 2nd
« Reply #52 on: Mon, 26 November 2018, 13:51:49 »
OK.  This is basically hearsay and somehow it is believed to be fact.  This is how fake news come to be.
There is no prove so far that I can see any lag is due to using a SATA connection between the two halves.  If it is because of the SATA connection, then it would happen only (or most of the time) on the right half and not the left half.   You can use the left half of the keyboard without connecting the right half.  Hitting the Q key for example doesn't require the SATA cable so there should be no lag typing on the left half.
Offline ampt
Re: [IC] VE.A 2nd
« Reply #53 on: Mon, 26 November 2018, 13:56:15 »
Resorting to name calling so soon? Tsk tsk
In regards to my "requirement" I'm simply stating that USB C cables are becoming more and more common. It's less that I have to be able to use one of my existing cables and more that I can. How many times have you been unable to use something because you either lost or forgot to pack the cable? If you answer never then I'd count you among the few rather than the majority. Who has spare SATA cables lying around as opposed to USB C? You yourself claim that while you only have a couple of USB Devices, you already have 2 cables available.
Offline litster
Re: [IC] VE.A 2nd
« Reply #54 on: Mon, 26 November 2018, 14:01:11 »
Sorry, not name calling.  Just that it came to mind when I try to pronounce your handle.  How do you say your name?
In any case while would you need to use a 6 feet USB-C cables for VE.A?
Offline breusch91
Re: [IC] VE.A 2nd
« Reply #55 on: Mon, 26 November 2018, 14:26:33 »
I'm sure it's been stated already but it's very sad to see that the waited for this lead to no seemingly good changes. Uglier logo (imo), no usb-c, and worst of all still SATA between the halves?? Common. All this time to revamp and hear the complaints about the old one but they appear to have fallen on deaf ears.
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
Re: [IC] VE.A 2nd
« Reply #56 on: Mon, 26 November 2018, 15:00:17 »
Excited for more
Offline trizkut
Re: [IC] VE.A 2nd
« Reply #57 on: Mon, 26 November 2018, 15:06:35 »
Have 2 VE.As, and have experienced none of the supposed issues with lag from the connector at higher wpms.  This is actually the first I've heard of it.
I think the new logo is fine; SATA is fine too if that's what you choose to go with.  :thumb:
Offline litster
Re: [IC] VE.A 2nd
« Reply #58 on: Mon, 26 November 2018, 15:11:47 »
+1
The only problem I have experienced is the keyboard going in and out of connected state with my PC when I used a low quality mini USB cable by accident.  Never had any problem with a good quality mini USB cable.
Offline clik_clak
Re: [IC] VE.A 2nd
« Reply #59 on: Mon, 26 November 2018, 15:13:58 »
I'm glad there's people like this that can give their own opinions based on their own used instead of all the people that watched 1 youtube review and decide the board is trash because of the connector.
Thank you.
Offline Vigrith
Re: [IC] VE.A 2nd
« Reply #60 on: Mon, 26 November 2018, 15:19:53 »
Thank you.
I've used a VE.A extensively too and the keystroke lag was fairly noticeable, though I do type abnormally fast I still think it's something they should work on - as said I don't know if it's a physical limitation with the type of cable used, I'm not an electrician and I definitely know very little about the subject, maybe it's their implementation of it rather than a problem with the connection; regardless, even if it is an on and off problem, or only a problem for some, I still think it should be addressed especially given the fact that USB-C is becoming so prevalent and is so handy. Or just go with TRRS, we know that one works just fine.
Offline litster
Re: [IC] VE.A 2nd
« Reply #61 on: Mon, 26 November 2018, 15:30:31 »
You mean electrical engineer, not electrician.
the lag may be something to do with the firmware design, or your cable, or your computer's OS, USB driver, USB controller, USB hub, USB cable, or other USB devices you have on your computer.  There has been no prove that SATA is the cause of the lag you have experienced non any prove that USB-C connectors would fix it.  The SATA cable there is just for wiring up the two halves of the keyboard.  The keyboard is not using the SATA protocol and would not use USB protocol if the SATA connectors are replaced with any kind USB connectors.
However using USB-C connectors would introduce a usability problem.  On the left half there would be one mini USB connector and one USB-C connector, and another USB-C connector of the right half.  Someone might ask, "why can't I use the right half of the keyboard when I plug in a USB-C cable to it and connect it to my PC?  It is a USB connector so it should work.  Trash!"
Offline ampt
Re: [IC] VE.A 2nd
« Reply #62 on: Mon, 26 November 2018, 15:36:06 »
By that same logic someone might plug the VE.A into their motherboard and ask why it doesn't work.  :rolleyes:
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: [IC] VE.A 2nd
« Reply #63 on: Mon, 26 November 2018, 15:36:24 »
Your name really get autocorrected by my phone when I type it in tho.
Offline litster
Re: [IC] VE.A 2nd
« Reply #64 on: Mon, 26 November 2018, 15:40:45 »
True, but you would have to way more cray cray to make the leap that a keyboard would by connecting it to your PC's SATA port.
Offline Vigrith
Re: [IC] VE.A 2nd
« Reply #65 on: Mon, 26 November 2018, 15:56:13 »
I used electrician the same way one some times uses the term rocket scientist to refer to someone with x or y sciencey expertise. The unit I used is a friend's and we used it on both of our home PCs as well as my office one with the issue prevalent in all 3 so it's actually not a one and done type of situation where no experimentation took place. It also doesn't have exceedingly heavy switches or anything that could be giving off a wrongful impression of the keystrokes being delayed.
That said, as of when I wrote my previous posts I was wrongfully taking SATA being the culprit as factual when I should've considered that the discussions I took part in/saw happen (which took place prior to the video clik_clak mentioned) may also involve scientifically unproven opinions all around (since I honestly can't remember, was a year and a half ago or something). I shouldn't dismiss the fact it may be something else, and as per someone on Slack I was also pointed to this post which I'd forgotten about which seemingly solves the issue via an option on bootmapper - https://geekhack.org/index.php?topic=82509.msg2524712#msg2524712
I'm still adamant in that I believe the issue should be officially addressed in so that the prospect buyers feel reassured but I understand and appreciate the scepticism.
Offline PainMaster
  • Formerly cjakma
  • IBM(PainMaster)
Re: [IC] VE.A 2nd
« Reply #66 on: Mon, 26 November 2018, 16:27:17 »
Will the SATA connection be changed? The SATA connection has latency issues and typing above ~100wpm would cause problems.
Also, would you consider changing the logo? The way the v1 did it was far more attractive. See below.
Hi LightningXI, can you prove it by youtube?
Because we've never experienced that issue before.
If you prove it on video,
After watching the operation status of the keyboard, RGB, LED, etc. of the video,  We are trying to consider a lot of things.
SaiB-CP Black - Kailh Bronze (Non Click / 58g) - Finish
Light Saver v1 Black - Cherry Wyze Black (Linear / 64g)
Light Saver v2 Gray - Cherry 1501 Black (Linear / 64g)
Light Saver v3 Silver - Cherry 8200 White (Non Click / 64g)
Light Saver Acryl (Duck96 base) - Gateron Yellow (Linear / 62g) - Season 1 Fin.
Octagon v1 Black - Cherry 1501 Black (Linear / 64g) / TX-1800 v1 Red/Black - Cherry Wyze Black (Linear / 58g)
VE.A Test Housing- Cherry 8113 White (Non Click / 58g)
TC-V3 , LZ*ASRH Black, VE.A 2nd
... etc.
Offline forevermadrigal
Re: [IC] VE.A 2nd
« Reply #67 on: Mon, 26 November 2018, 23:59:19 »
Would like to see more than just STS for a plate.
Offline Rubbermilitia
Re: [IC] VE.A 2nd
« Reply #68 on: Tue, 27 November 2018, 00:11:37 »
After the gigantic ****storm which took over this thread, I really hope someone attempts this and posts their results. We have clearly gotten the runner's attention, and destroyed his IC, lets at least follow up with the proof they are requesting...
And if anyone is going to post a video proving this, please also test if the debounce fix posted by Vigrith works or not. If it does, then this entire lag argument is moot....
Offline dantambok
Re: [IC] VE.A 2nd
« Reply #69 on: Tue, 27 November 2018, 00:17:45 »
about the SATA, maybe it would not be a problem for everyone since some people type slower ( i do 70ish WPM lol)
BUT i think a big problem is the durability/life span of of SATA ports. They are rated to like 50 to 100 plug unplug cycles?
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] VE.A 2nd
« Reply #70 on: Tue, 27 November 2018, 00:23:00 »
I'd be willing to show something on video, but I actually have sold my own VE.A. some time ago. I've asked the buyer for help and see if it's possible to prove it on video. I apologize for that inconvenience.
Perhaps the much more concerning aspect for me is that a SATA connector is not durable. The number of cycles it can sustain for insertion and removal is pretty low relative to other connector types. While I understand that there's ease in using the v1 PCB for the v2, I strongly believe that you will garner a much more positive response by considering a USB C to USB C data transfer as well as aesthetic changes as they are being proposed. There is sufficient evidence that interested parties would prefer these features.
In any case, I will advocate for somebody to attempt a video-based experiment on the functionality of the v1, as I do not own one anymore. I'd gladly do it if I were to be able to borrow one as well.
« Last Edit: Tue, 27 November 2018, 00:29:14 by LightningXI »
Offline Tree_
Re: [IC] VE.A 2nd
« Reply #71 on: Tue, 27 November 2018, 00:32:03 »
+1 for no SATA.
I actually don't mind the new logo and badge.
I should probably put a point against my comment: I'm not actually against SATA because of the possibility that it effects the board when used at high WPM or because of the potential for port failure after a high number of re-connections - I just think it aesthetically looks bad compared to a USB cable. Sure you can get round SATA connectors, but it's rare to come across nice custom SATA's.
Offline actualglacier
  • ¯\_(ツ)_/¯
Re: [IC] VE.A 2nd
« Reply #72 on: Tue, 27 November 2018, 01:17:38 »
That logo, ouch : (
actualglacier on youtube
Offline kokugatsu
Re: [IC] VE.A 2nd
« Reply #73 on: Tue, 27 November 2018, 02:16:37 »
Really hyped for this, though I prefer the old logo and a departure from SATA. It’s just way harder to find a replacement connector, with seemingly no benefits.
Offline typischt
Re: [IC] VE.A 2nd
« Reply #74 on: Tue, 27 November 2018, 02:26:29 »
I was really confused at first, but there is another thread in the Keyboards section:
https://geekhack.org/index.php?topic=98322.0
According to this, the logo is changeable and there is a „less colorful“ logo variant that will be (might be?) available.
Aaaand it has already been edited in in the OP of this thread, so that‘s that. ;D
Really hyped for this board, was also waiting for quite some time now. SATA doesn‘t bother me that much if there are no problems with it, tho the argument that it has less „plug-in/out cycles“ does sound a bit concerning.
But I might be in either way.
« Last Edit: Tue, 27 November 2018, 02:33:07 by typischt »
Offline PainMaster
  • Formerly cjakma
  • IBM(PainMaster)
Re: [IC] VE.A 2nd
« Reply #75 on: Tue, 27 November 2018, 05:25:52 »
In personal opinion.
about the 'latency issue' is a suspected situation of low power.
There are many different specifications for 'USB'.
For example,
USB 2.0 support 5V 500mA ~ Max 2A (2000mA).
USB 3.1 support 5V Max 5A (5000mA) & 12V & 20V.
Between USB 2.0 and USB-C (3.1),
There is a huge difference in the amount of power available.
most of Laptop USB 2.0 has 5V 500mA,
But, USB-C (for example, Mac)  has 5V 45w is Max (about 9A, standard is 5A).
If you plug the KBD (full LED, full RGB status) into a hub that low (or None) power, KBD controller may be out of power and cause abnormalities.
« Last Edit: Tue, 27 November 2018, 05:34:25 by PainMaster »
... etc.
Offline kawasaki161
Re: [IC] VE.A 2nd
« Reply #76 on: Tue, 27 November 2018, 06:01:21 »
Had it plugged directly into a USB port (tested both 2.0 and 3.0, both type a) all LEDs off, still had lag.  :thumb:
The lag has nothing to do with sata but with the implementation of VUSB that BMC uses, as well as suboptimal i2c connection between the halves. There still was very noticeable input latency on the master half.
I don't get it tbh, how did this work during design? "Let's pick a controller whose main purpose is talking to the PC via USB, oh yea this one that has no native USB support makes way more sense than the ones that do offer that functionality"  :))
« Last Edit: Tue, 27 November 2018, 06:07:26 by kawasaki161 »
Offline PainMaster
  • Formerly cjakma
  • IBM(PainMaster)
Re: [IC] VE.A 2nd
« Reply #77 on: Tue, 27 November 2018, 07:06:09 »
..... I'm not sure what you mean.;;
... etc.
Offline tchalikias
Re: [IC] VE.A 2nd
« Reply #78 on: Tue, 27 November 2018, 07:56:33 »
I'm in, provided that SATA is replaced with USB. I don't believe the cable is responsible for the lag, obviously,  it's just a couple piece of wire,  but sata ports are incredibly flimsy.
Offline nguyenhimself
Re: [IC] VE.A 2nd
« Reply #79 on: Tue, 27 November 2018, 08:45:52 »
I think it's clear from this thread that the IC starter is not very motivated to change the SATA connector to USB.
I like retro computing as much as most people here, but this dedication to SATA of all things is just something else.
Also, I saw the logo update, and I still find it extremely cringey. Do people really enjoy seeing all those visible holes on their expensive keyboards? Paging r/trypophobia
This is by far the worst R2 I've ever seen. All the complaints from R1 were ignored, with extra new stuffs that nobody asked for or wanted.
« Last Edit: Tue, 27 November 2018, 08:53:09 by nguyenhimself »
Offline clik_clak
Re: [IC] VE.A 2nd
« Reply #80 on: Tue, 27 November 2018, 09:44:29 »
Then don't buy it, simple as that. Let your wallet do your talking for you.
He's not going to have any problems selling the ones he does though.
Offline fireworm
Re: [IC] VE.A 2nd
« Reply #81 on: Tue, 27 November 2018, 10:01:58 »
QMK or implement a few missing features in BMC.
USB-C or TRRS between halves
USB-C main connector
It's not clear, what are the layout options? I'd really like bottom left to be 1.25, 1.25, 1.25, 2.25, 1.25 (or 1).
Is it possible to lose the F-row for a 65% plus Macro keys?
Offline MajorKoos
  • 1 life please. Extra large.
Re: [IC] VE.A 2nd
« Reply #82 on: Tue, 27 November 2018, 10:22:43 »
I have 3 VE.As from R1, and I've had 2 SATA cables fail on me (with a 3rd starting to give issues).
SATA cables are typically solid core wire and not meant to be moved around or bent too much.
At least it's the cable which fails and not the plug on the PCB.
What makes this better than R1?
I'm struggling to find anything which would make me consider getting one, and that's a shame because Korean ergos are my "thing".
Offline urbantheii
Re: [IC] VE.A 2nd
« Reply #83 on: Tue, 27 November 2018, 10:52:00 »
Is it just the cables that are failing or the ports? I don't know much about this issue, but I really don't mind having to swap in a new SATA cable as long as the integrity of the port is fine.
Offline schoolbus
Re: [IC] VE.A 2nd
« Reply #84 on: Tue, 27 November 2018, 11:01:04 »
the off-brand VE.A uses mini-usb to connect the halves and it appears to work well. I also haven't noticed any latency issues with it and I would say I type reasonably fast.
Even if SATA is acceptable, it's still annoying to have to use yet another different cable for just this board, rather than it conforming with the trend of almost all the other split keyboards.
Why don't we just use the old-school ipod charger cable to connect the halves?
Offline kawasaki161
Re: [IC] VE.A 2nd
« Reply #85 on: Tue, 27 November 2018, 11:04:41 »
same tbh
Offline AuthenticDanger
Re: [IC] VE.A 2nd
« Reply #86 on: Tue, 27 November 2018, 11:07:26 »
Firewire!  :))
F Keys belong on the left.
Re: [IC] VE.A 2nd
« Reply #87 on: Tue, 27 November 2018, 11:20:04 »
So you're saying we should ONLY say positive things in IC threads? Are you so against criticism?
Can't you stop thinking in black and white and understand that I'm posting here because I really want to get a VE.A ever since OP teased R2 on the VE.A thread since last year or so?
I'm just seriously annoyed at how there is seemingly zero worthy improvement to this kit after all this time, and now some people are dismissing criticism as 'fake news' of all things. Ugh.
« Last Edit: Tue, 27 November 2018, 11:23:13 by nguyenhimself »
Re: [IC] VE.A 2nd
« Reply #88 on: Tue, 27 November 2018, 11:27:53 »
100% agree that an IC is to check for interest and give feedback. Just because some people might buy this doesn't mean that it's good design or well thought out.
Offline redbanshee
  • actually Dade Murphy
Re: [IC] VE.A 2nd
« Reply #89 on: Tue, 27 November 2018, 11:36:16 »
smh
lmao, geekhack, destroyer of interest checks and the majestic land of the "deal breaker", with the occasional "try hard" and the ever popular "doesnt match the render" guy for good measure
can we please get 4 handed Goro from mortal kombat to test the theoretical "lag" that apparently is produced when typing 200wmp on VE.A v1
give me a break lol
Offline litster
Re: [IC] VE.A 2nd
« Reply #90 on: Tue, 27 November 2018, 11:43:12 »
You think it is okay to repeat unsubstantiated rumor that SATA connection is causing typing lag?  Or can you show prove that it is true?
Offline kawasaki161
Re: [IC] VE.A 2nd
« Reply #91 on: Tue, 27 November 2018, 11:47:16 »
The whole thing has pretty noticable inputlag regardless of how quickly you type, easily 30ms higher than any other board I have. If you want proof, sorry I sold it because of that reason about one and a half years ago.
Offline ampt
Re: [IC] VE.A 2nd
« Reply #92 on: Tue, 27 November 2018, 11:50:43 »
Lets just ignore the lag thing since everyone seems to be agreed that the firmware fix seems to work. I still have yet to see any good counters to the following:
SATA connectors have a very low lifespan rating.
SATA cables are harder to find in custom sleeves.
SATA cables don't flex very well, making them harder to move and position.
Or, put another way, why should we use SATA over the myriad of other options; USB C, TRRS, Mini USB? The only real reason to use SATA here is because the first one had SATA, so we don't have to redesign the PCB. That said, it seems like there are pretty substantial things being done to the case itself, leading me to think that this is less about cost savings. Either way, we're pretty stuck in the dark unless OP wants to chime in on their preference for SATA.
Offline redbanshee
Re: [IC] VE.A 2nd
« Reply #93 on: Tue, 27 November 2018, 12:02:15 »
I own one, I have been gaming on the ve.1 v1 for a very long time, never has it once lagged in any game or effected my performance on FPS's at all. I have never ever noticed lag with my ve.a.
build album here for proof: https://imgur.com/a/lR64b
Offline clik_clak
Re: [IC] VE.A 2nd
« Reply #94 on: Tue, 27 November 2018, 12:03:13 »
It is fake news until you can prove it's not. Go ahead and show all this magical proof that its the SATA cable that's causing the lag. Once you can do that, you may have a valid point.
I've already pointed out that people have experienced similar lag with other pcb's with similar firmware/hardware...and those aren't even split boards. Hell, how can we even say its the keyboard itself? Maybe the people experiencing lag are using a motherboard with a certain USB controller that has issues with the firmware? Maybe they're plugging into s USB hub that's causing lag. Maybe there's 20 other causes for the lag that haven't been considered to anyone.
You can be as negative as you want. Don't expect everyone to agree with you, and if you have such huge complaints, there's nothing stopping you from designing your own board with all the fixes you would like to see made. I'm 100% positive you'd have no problems selling these in mass if you can get everything made...Just like this seller is going to have no problem all of these ones as well.
Offline litster
Re: [IC] VE.A 2nd
« Reply #95 on: Tue, 27 November 2018, 12:18:35 »
Well said.
Offline litster
Re: [IC] VE.A 2nd
« Reply #96 on: Tue, 27 November 2018, 12:26:09 »
Not arguing there aren't any better solution than SATA for connector durability.  only arguing there has been no prove that SATA is causing lag.  I can imagine there are plenty of reasons why SATA was chosen and why it is staying as it is.  OP said they are looking into other options.  Whatever else options they investigate, I am sure people including myself will find flaws with them.
Offline Vigrith
Re: [IC] VE.A 2nd
« Reply #97 on: Tue, 27 November 2018, 12:27:10 »
I think discrediting other people's experience(s) because you didn't encounter the same problem is a little naive though, that said if the bootmapper option fixes it reliably (which should be extensively tested by the person running the buy rather than prospect buyers, imo) then it's not really as big a deal - still silly to use SATA, I think pointing out people calling it a "deal breaker" when it obviously has a bunch of challenges that shouldn't be a thing with a board of this quality/price is hardly warranted.
He doesn't need everyone to agree with him, the fact not everyone does doesn't invalidate the fact some do/have experienced the same issue or other problems in general with the SATA cable. I don't understand the political correctness to this extent, you're defending something/someone that doesn't need defending - the idea being pitched is a new VE.A, people are giving input (good and bad) regarding the design and decisions made, just as they do in every other IC which is the whole point. The fact some people seem to think the IC is being "ruined" is ridiculous and worrying.
Just because there'll be enough people buying this revision as it stands doesn't mean sales and/or customer satisfaction wouldn't be higher if the concerns people who WANT to buy one have were addressed. Discrediting critical feedback is exactly what you do not want to do, thankfully OP realises that as per his latest posts.
« Last Edit: Tue, 27 November 2018, 12:29:26 by Vigrith »
  • sleever supreme
  • greyhat co-leader
Re: [IC] VE.A 2nd
« Reply #98 on: Tue, 27 November 2018, 12:36:28 »
My man fought the last boss of kb-kustoms to get there.
https://geekhack.org/index.php?topic=79183.msg2042517#msg2042517
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] VE.A 2nd
« Reply #99 on: Tue, 27 November 2018, 12:40:35 »
Speaking specifically on this -- I do not have my own VE.A anymore as of the past month, but I experienced this specifically -- when typing a word like "sole" it would type as "soel" -- the right hand side would lag behind the left when typing. I wish I did have the keyboard to test it out for people. I am personally more concerned about the longevity of a SATA connector given the fewer number of insertion cycles it can handle on a basis of mechanical stress.
