Author Topic: .  (Read 3580 times)
Offline novantix
« on: Sun, 09 December 2018, 16:01:54 »
« Last Edit: Wed, 14 August 2019, 16:53:42 by novantix »
Offline Jaxxstatic
  • Haptic Recon
Re: I found the pipe key on the HHKB pro 2 UK ISO layout
« Reply #1 on: Sun, 09 December 2018, 16:19:18 »
Oh snap! Congratulations! I'm glad you got it working, but that combo is annoying
« Reply #2 on: Sun, 09 December 2018, 20:08:38 »
Serves you right for not using ANSI layout :p
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #3 on: Wed, 19 December 2018, 07:19:10 »
Use Switch Hitter to see what key codes are being sent. What keyboard layout are you using on your computer?
