Author Topic: [GB] Titanium Plate  (Read 80125 times)
Re: [GB] Titanium Plate
« Reply #50 on: Mon, 17 December 2018, 21:47:41 »
What is the expected price for e.g.. 3mm plate over 1.5mm?
Just remember that cherry switches won't click into a plate over 1.5mm thick. "Thicker" plate designs (5mm) have been milled to depth where the switches click in.
And it's important that they clip in if you have a tray mounted board.  When they don't clip in, the plate can/will slide down the switches and there's not much you can do about it other than add some supports in between the plate and PCB that are exactly the right thickness.
which i may add is a giant pain the ass
Offline xantiema
« Reply #51 on: Tue, 18 December 2018, 07:01:56 »
That is good to know  :thumb:
I really want to join, but still don't know which 65% I will buy  :eek:
Offline DGX_Shin
« Reply #52 on: Tue, 18 December 2018, 09:52:40 »
We know :). With thicker plate we will cnc a step down to 1.5mm :)
Sent from my INE-LX2 using Tapatalk
Offline DGX_Shin
« Reply #53 on: Tue, 18 December 2018, 09:53:30 »
We understand and have knowledge about that. Thank :)
Offline DGX_Shin
« Reply #54 on: Tue, 18 December 2018, 09:55:20 »
Yes indeed! We try fulfill your request and if there are any risk of slide / unstable we will notice it for yoh before we run :)
Offline DGX_Shin
« Reply #55 on: Tue, 18 December 2018, 09:57:06 »
I have no idea about that but we will open GB for our 65% with in-built blueooth :). It may around mid of Feb :)
Offline booleanjulien
« Reply #56 on: Tue, 18 December 2018, 10:07:30 »
What technique is used to create this holographic anodization on the titanium?
https://imgur.com/a/1bKjLxZ
Offline DGX_Shin
« Reply #57 on: Tue, 18 December 2018, 10:14:09 »
In fact i dont know and i don't want to try to make a "holographic" like this :).
Offline xantiema
« Reply #58 on: Tue, 18 December 2018, 11:00:02 »
65% PCB with inbuilt BlueTooth also with titanium plates? Maybe I should wait for that group buy
Offline DGX_Shin
« Reply #59 on: Tue, 18 December 2018, 11:04:24 »
Ah... Don't misunderstand we dont decide yet which will release with the 65 pcb...
Offline cucgach
« Reply #60 on: Wed, 19 December 2018, 07:44:40 »
Wow.. good luck with the Gb!
Current: Filco TKL Majestouch | TX60 antique brass | NIU40 silver | H360 burgundy | tr.mk wooden 60 | Imperial Hue 60 | Tofu 65 silver | Tofu WKL navy | Gergo Kit: black PCB | Space65 gray/silver | VN66 Black
Future: none
Past: TinaC HHKB gray | TX84Se titan gray | Leopold 660M white | GSX96 R2 purple | Rama M60-A lake | 0.01 Z70 silver | E7-V1 MAO | Rama M6-A | TMO50 green/poly | HB85 black/gray | TX108se titan gray | Typewriter68 ceramic white | Think6.5 frost poly
Offline DGX_Shin
« Reply #61 on: Wed, 19 December 2018, 07:46:02 »
Thanks - Cám ơn :)
Offline peterpans01
« Reply #62 on: Sat, 22 December 2018, 06:54:42 »
Bump, just a little more to reach MOQ.
Have a nice day :D
Offline _ODIN_
« Reply #63 on: Sat, 22 December 2018, 10:25:27 »
How can you add engraving to your plate?
Gesendet von meinem H8416 mit Tapatalk
Offline finalarcadia
« Reply #64 on: Sat, 22 December 2018, 14:19:26 »
Anyway you can get files from Wei of Kbdfans for kbd67 ? The 5 mm plate would be nice.
Sent from my Pixel 3 using Tapatalk
Offline DGX_Shin
« Reply #65 on: Sat, 22 December 2018, 14:36:06 »
CNC with 0.2mm countersink
Sent from my SM-N950N using Tapatalk
Offline DGX_Shin
« Reply #66 on: Sat, 22 December 2018, 14:37:14 »
I afriad not :).
Offline Lansky
  • Realest motherthocker
« Reply #67 on: Sat, 22 December 2018, 15:37:55 »
Would it be possible to make a plate for a Realforce 87U?
Offline DGX_Shin
« Reply #68 on: Sat, 22 December 2018, 15:43:55 »
I afraid not. I dont have any idea about topre -..-'
Offline _ODIN_
« Reply #69 on: Sat, 22 December 2018, 16:17:45 »
Filled out the form :)
Offline KaosJ
« Reply #70 on: Sun, 23 December 2018, 06:05:50 »
But that one is pretty af
Offline DGX_Shin
« Reply #71 on: Sun, 23 December 2018, 06:08:07 »
I think we may make it on aluminium... Not sure, our artist said that he mau try :). Anyway, we try many way to staify most mechincal keyboard lover :)
Offline DGX_Shin
« Reply #72 on: Thu, 27 December 2018, 11:37:33 »
Update: It's 13 / 34 Order. Hope that we can reach MOQ 2 :).
Offline DasGnome
« Reply #73 on: Thu, 27 December 2018, 12:19:14 »
Hopefully people starting paying to get MOQ 1, so we can for sure get this GB going. lol
What happens at MOQ 2? :)
Offline DGX_Shin
« Reply #74 on: Thu, 27 December 2018, 12:32:49 »
Dear,
 MOQ for discount, not for running :). The GB will run for sure whether it reach MOQ or not.
Offline KaosJ
« Reply #75 on: Thu, 27 December 2018, 13:17:34 »
Dear,
What is the current MOQ?
do i have to send the file before 28 to join the GB?
Offline DGX_Shin
« Reply #76 on: Thu, 27 December 2018, 17:04:42 »
Dear,
Need last 6 confirm for first MOQ.
GB is still open till end of 28
« Reply #77 on: Sat, 29 December 2018, 10:57:20 »
I squeezed in at the last second into this group buy, and am still finalizing my specification. Having not worked with any specialized software for designing plates before, DGX_Shin has been extremely helpful in working with to make my idea a reality- a bent titanium TKL open case:
I will be using this kbfans 8x PCB. I'm posting this here because I still have a chance to make changes to this, and I have a few questions that maybe some of you could help me with.
1. Is it absolutely necessary to have screw holes in the plate? Is there some kind of shim I could screw in from underneath to make sure the PCB is supported / has even distance?
2. Do you think the switch-top opening support look ugly on an open case design, since you'll be able to see the holes? Does it change the sound?
Any suggestions are appreciated. This isn't dependent on changes to this design, but I'm also looking to find any information on how to create a custom fitted underglow diffuser.
Offline DGX_Shin
« Reply #78 on: Sat, 29 December 2018, 17:38:39 »
You need 4 screw holes at for angle because you may need put a frosted mica below your pcb.
2. I strongly suggest to remove OT support.
« Reply #79 on: Sat, 29 December 2018, 18:33:22 »
I have also asked /r/MechanicalKeyboards on Reddit, and they said I could mount the acrylic directly to the PCB. I think this is what I will do.
I have already sent you an email with the final changes :) Thank you!
Offline DGX_Shin
« Reply #80 on: Sat, 29 December 2018, 20:04:29 »
Ukie dukie :)
Offline JDragon
« Reply #81 on: Sun, 30 December 2018, 11:04:20 »
I just realized I forgot to hit submit on my order after posting about it earlier... :(
Any way to still enter?
Offline DGX_Shin
« Reply #82 on: Sun, 30 December 2018, 11:19:41 »
Dear,
I'm so sorry about this but GB have already close.
Offline DGX_Shin
« Reply #83 on: Sun, 06 January 2019, 20:58:37 »
Dear all,
First of all i'm sorry for late update :).
1. We reach over MOQ1 so i will refund or it will includes into shipping cost :).
2. Your plates is on the progress but shipping time MAY delay 1 week (we have a some personal issue so please padron us)
3. To guy who choose below 1.5mm, our supplier is no longer get 1.1 and 1.2mm foil so i have emailed you guy to confirm a some solutions. Please reply me when you get my email.
Offline DGX_Shin
« Reply #84 on: Sun, 13 January 2019, 04:45:32 »
Update:
1. Finish cutting
2. On stamp logo and brushing surface. After clean the surface we will anodizing it.
Regard,
Tâm Huỳnh.
Offline fer.real
« Reply #85 on: Sun, 13 January 2019, 06:14:02 »
Update:
1. Finish cutting
Regard,
Tâm Huỳnh.
Looking good!  It's exciting to see the progress.
Offline dangboy
  • yes
« Reply #86 on: Sun, 13 January 2019, 11:20:24 »
thanks for the update+pics, oooo I can see my plate in there!
Offline foxmancore
« Reply #87 on: Sun, 13 January 2019, 19:05:40 »
looks great :)
Offline dubious
  • 쏘쿨
« Reply #88 on: Thu, 17 January 2019, 15:15:32 »
I think you mentioned somewhere that this is a one time deal, but hopefully you will consider running this again. I think there's enough community interest in plate materials to warrant another GB. I would definitely pick up one or two plates.
Offline DGX_Shin
« Reply #89 on: Thu, 17 January 2019, 16:19:19 »
Dear,
I didn’t mention that this is one time gb. I said we have no plan to run another GB yet ^^.
Offline azulyf
« Reply #90 on: Thu, 17 January 2019, 16:47:16 »
The plates look really nice. Wonder will those raw plates be shipped first?
Offline dubious
  • 쏘쿨
« Reply #91 on: Thu, 17 January 2019, 17:51:53 »
Dear,
Rad!
Offline TeeAreEffedUp
« Reply #92 on: Fri, 18 January 2019, 18:40:31 »
Update:
1. Finish cutting
Regard,
Tâm Huỳnh.
Hey, I'm pretty sure I see my plate in that big ol stack! Glad to see they're coming along so nicely.
Offline DasGnome
« Reply #93 on: Mon, 21 January 2019, 11:59:16 »
Any updates?
Offline DGX_Shin
« Reply #94 on: Mon, 21 January 2019, 19:06:20 »
Any updates?
Not yet dear :).
Offline obeisa
« Reply #95 on: Thu, 31 January 2019, 14:28:00 »
Can we get an update on this? Thanks.
Offline DGX_Shin
« Reply #96 on: Fri, 01 February 2019, 19:57:38 »
Dear,
First of all I'm so sorry about delay.
I didn't mention about Year End (includes Lunar Year End) so i had gave a wrong estimate timeline. I'm really sorry about that.
We have done engraving and next step we will clean a surface again. But this week, Vietnam is celebrating Lunar Year End and Shipping service will close in this week. Feel sad :(.
After the celebrating week we will start to ship and finish this GB in Feb. Please pardon me (just me not my team) for my mistake.
Regard,
Tâm Huỳnh.
Offline DasGnome
« Reply #97 on: Thu, 14 February 2019, 19:52:57 »
Any updates?
Offline obeisa
« Reply #98 on: Tue, 19 February 2019, 23:24:19 »
Can we get an update please?
Offline jizzaztartist
« Reply #99 on: Thu, 21 February 2019, 15:29:20 »
Out of curiosity, does anyone know where the plate files for the TiAmo/Titanium TKL keyboard that was run some time ago might be found? I would like to get a Titanium plate for it at some point in the future.
