Author Topic: [GB] New Cherry PCB Mount stabilizer (Screw mounted)  (Read 87770 times)
Offline sennin32
    • Doyu Studio
« on: Wed, 26 December 2018, 21:46:04 »
[Update Mar 31 '19]
We are sorry about following info:
We keep asking for update every week, but 1 month pass.
We still have no accurate deliver time.
Will send mails about cancellation tomorrow.
You can also tell us what's your order number if you want to cancel it via PM or sy_yang@doyustudio.com
For people who want to wait for it.
We'll keep asking for update of delivery, but I can't promise the time line now.
Once we got delivery time, we'll update ASAP.
[end of update Mar 31 '19]
Hi,
Guys!
Cherry changed their stabilizer design.
Here's the change(didnt get sample yet, pic below come from representative of Cherry) :
https://imgur.com/a/6WQVsZ2
Major change is they're going to use screw mount now.
They don't use thread insert.
It has to mount by self tapping screws.
The package will include:
60/TKL pack :
1. stabilizer stem *12
2. stabilizer house *12
3. 2u wire *6
4. 3u wire *2
5. 6.25u wire *1
6. 7u wire *1
7. screw *12
8. washer *12
full pack:
1. stabilizer stem *18
2. stabilizer house *18
3. 2u wire *9
4. 3u wire *2
5. 6.25u wire *1
6. 7u wire *1
7. screw *18
8. washer *18
Leading time is 8 weeks after GB ends.
GB time will be 2018/12/27~2019/1/12
Price :4.5/6.5
Shipping fee : auto calculate, start from $4.5 with registered mail
Group Buy link(Work after 2018/12/27 12:00) :
shopkey.doyustudio.com/001kbasnp
Happy New Year!
« Last Edit: Sun, 31 March 2019, 03:21:05 by sennin32 »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] New Cherry PCB Mount stabilizer (Screw mounted)
« Reply #1 on: Thu, 27 December 2018, 05:51:19 »
Approved! GL with the GB and happy holidays :)
Offline Lisinge
« Reply #2 on: Thu, 27 December 2018, 05:55:10 »
I don't get it. How does these differ from the screw-in stabs that cherry/gmk has been making for a while now?
Offline ChrisSwires
« Reply #3 on: Thu, 27 December 2018, 05:57:49 »
As above and as I asked on Reddit, how are these different from gmk stabilisers bar the branding.
If it's a GB for gmk stabilisers at a lower price (and your price is lower than I've seen before), then that's absolutely fine, it's just potentially a bit misleading. This does not appear to be anything new.
Sent from my Pixel 3 using Tapatalk
Offline stoic-lemon
« Reply #4 on: Thu, 27 December 2018, 06:03:49 »
I'm glad I'm not the only one who is confused. I wonder if their choice of self-tapping screws was down to performance or cost to manufacture.
Offline ChrisSwires
« Reply #5 on: Thu, 27 December 2018, 06:14:06 »
On the 'self tapping screws' comment, gmk stabilisers also have this, in as much as the screw hole isn't threaded, unlike zeal/epbt. I presume that's what that comment alludes to.
Cherry, gmk and zeal attached (in that order).
Offline Lisinge
« Reply #6 on: Thu, 27 December 2018, 06:17:17 »
I've always heard that "GMK screw-in stabilizers" are still manufactured by cherry, just sold through GMK.
Offline ChrisSwires
« Reply #7 on: Thu, 27 December 2018, 06:18:55 »
That's also what I've heard, gmk are simply the brand, they're cherry stabilisers. Bar the screw portion they're identical to cherry.
Offline rondg
« Reply #8 on: Thu, 27 December 2018, 06:25:14 »
These are cheaper though
Offline ChrisSwires
« Reply #9 on: Thu, 27 December 2018, 06:31:00 »
As I said earlier, down for cheap gmk stabs for sure, I'd just like clarification if they're actually new, because that's a very big deal if they are given cherry hasn't changed its stab lineup for like. I have no idea how long.
Offline OmegaSupreme
  • For Cybertron!!!
« Reply #10 on: Thu, 27 December 2018, 08:42:49 »
Just an FYI, GMK stabilizers are manufactured by Cherry.
| TX-CP | Dolphin V3x 2 | Dolphin Padx 2 | Unicorn X Legend | Jane V2 | Jane V2 CE |
Offline futurecrime
  • Get Zooted
« Reply #11 on: Thu, 27 December 2018, 09:31:37 »
Joining the 'awaiting clarification' party.
Offline kustom3
  • bonjour
« Reply #12 on: Thu, 27 December 2018, 11:35:56 »
FWIW my GMK stabs that came in a GMK bag with my M65-A are like the Cherry ones on your picture (one screw hole + 1 "mount" hole).
Offline Captainbuttmonkey
« Reply #13 on: Thu, 27 December 2018, 12:01:13 »
I've always thought cherry and gmk stabs are the same thing and people just use the names interchangeably? You can get them in screw in and standard mount?
Offline DasGnome
« Reply #14 on: Thu, 27 December 2018, 12:22:36 »
Yeah, these aren't new. GMK stabilizers are Cherry stabilizers. I think you've been out of the loop for the last year or so, Sennin...
That said, the price is really good; I'm guessing it's because we are cutting out GMK as the middleman.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #15 on: Thu, 27 December 2018, 20:58:28 »
Cheaper is good -- in fact, I know that the pricing in bulk is just about as cheap as this, so I think these are legit and pretty much the same Cherry/GMK screw-in stabilizers we are used to seeing.
Offline sennin32
    • Doyu Studio
« Reply #16 on: Wed, 02 January 2019, 08:39:05 »
I'll check the sample when possible.
Cause GMK stabs should threaded?
But the info that representative show me is not threaded, have to use self tapped screws.
And info I got is part number 6091539 change mold.
Maybe they just replace the part with what GMK is using cause the screw thing is the only difference I can tell.
I'm not sure the quotation of GMK.
What I heard is pretty expensive. (Higher than the price here for several hundreds set of 60%)
But I'm not the one who contact them, so not sure about that.
happy new year every body!
Offline sJ1N
« Reply #17 on: Wed, 02 January 2019, 09:38:12 »
new or not i joined for the price  :)
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #18 on: Wed, 02 January 2019, 10:42:59 »
From what I know, GMK and Cherry stabs are the same.
The difference is that the "new" Cherry stabs offered in this GB will have a new wire diameter of 1.52 instead of 1.54. I'm guessing this will be the new standard for both GMK and Cherry stabs offered in the future from now on.
Offline MTXjunkie
« Reply #19 on: Wed, 02 January 2019, 10:44:53 »
Do we know how the smaller dimension is a pro/con?  Sorry if that’s a noob question. Doesn’t seem like 2 hundredths of a difference would be a huge difference, but I’m not a material scientist or engineer.
Sent from my iPhone using Tapatalk Pro
Offline Eszett
« Reply #20 on: Wed, 02 January 2019, 13:30:56 »
You can buy these screw-in stabs since years, what's all the fuzz about? Or do I miss some feature?
Offline MTXjunkie
« Reply #21 on: Wed, 02 January 2019, 13:39:35 »
We’re paying $4.50 or $6.50 (depending on 60% or 104 option) for what would usually cost at least twice that.
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #22 on: Wed, 02 January 2019, 20:32:03 »
beside the price... why is this a 2019 new model? :)
Offline koduh
« Reply #23 on: Wed, 02 January 2019, 22:38:23 »
Would be great to have the option to throw an extra 6.25u stab in there. To make better use of the kits. But I understand that complicates kit creation.
Offline otanishock
  • ファーストラブ
« Reply #24 on: Wed, 02 January 2019, 23:49:37 »
Supposedly new wire diameter of 1.52 instead of 1.54. Don't think it will make that much of a difference, if any. Just the crazy kickass price that draws the attention here.
Offline sennin32
    • Doyu Studio
« Reply #25 on: Mon, 07 January 2019, 09:07:27 »
Hi,
We get a suggestion to add washers in the pack on Reddit.
Contacted washer venders last week.
It's not expensive item, so we'll add it into the kit.
Offline funderburker
« Reply #26 on: Mon, 07 January 2019, 09:39:28 »
So GB is still up for about five days right? Could cop these for the price for sure.
Keyboard design by Skepur
Offline MTXjunkie
« Reply #27 on: Mon, 07 January 2019, 09:54:22 »
Hi,
Even better. I bought my own bag on Amazon a week or so ago, but you can’t ever have too many
Offline trg1234
« Reply #28 on: Mon, 07 January 2019, 16:51:53 »
Can anyone attest to how legit this is. I'm pretty interested because of the really low prices, but I am not sure whether its legitimate or not.
« Reply #29 on: Mon, 07 January 2019, 17:08:26 »
Why would they build an entire storefront website just to scam?
« Reply #30 on: Mon, 07 January 2019, 17:15:27 »
Sennins legit.
Offline japanesehorrorwriter
« Reply #31 on: Tue, 08 January 2019, 03:40:41 »
+1 Sennin = legit
Offline rockydbull
« Reply #32 on: Wed, 09 January 2019, 09:47:31 »
Genuine Cherry stabs are very cheap in bulk. I bought 100 2u stabs from a USA electronic parts vendor for like 25 bucks. I have no doubt he can get them even cheaper.
Offline sennin32
    • Doyu Studio
« Reply #33 on: Thu, 10 January 2019, 03:38:20 »
Hi, guys:
I went to check the sample of stabilizer.
And found they reduce the distance shown below :
(this is plate stab, but I don't have pcb stab file, so I use this pic to show it)
Old cherry is around 2.67~2.69mm.
New one reduce to 2.3mm.
I can tell the difference between with eye.
And did a quick measuring, might have little measuring error.
And here's GMK vs old cherry:
Seems they have the same dimension.
I haven't measure GMK's.
Don't have one in my hand, somebody will mail me one this week, I might able to check it next week.
The change make wires more solid, older one is looser.
But representative has only few samples.
I have no chance to feel how it type.
Not able to tell if the modify makes the stab better now.
The other thing I confirm is that they indeed have no female thread.
« Last Edit: Thu, 10 January 2019, 03:40:30 by sennin32 »
Offline ChrisSwires
« Reply #34 on: Thu, 10 January 2019, 03:40:27 »
Hi, guys:
Ok, now that, is more interesting. Hmmmmm! I'll probably get in in that case, new is new, apologies if I came across skeptical above. It's because I always am haha!
Thanks for the update.
Offline sennin32
    • Doyu Studio
« Reply #35 on: Thu, 10 January 2019, 03:51:09 »
100 2u stabs for 25 is very cheap for retail @@.
Even cheaper for some sellers' cost as I know.
Offline Hyperdimension
« Reply #36 on: Thu, 10 January 2019, 08:31:26 »
Why can't I view my cart on the website? The CSS doesn't load. I want to know how much shipping will be
Offline rockydbull
« Reply #37 on: Thu, 10 January 2019, 09:03:04 »
https://www.mouser.com/ProductDetail/540-G99-0742
Offline Eszett
« Reply #38 on: Thu, 10 January 2019, 09:21:08 »
Right, that's approx. 15 cent a 2u stab, if 100 are ordered.
Offline mushubanane
« Reply #39 on: Thu, 10 January 2019, 10:13:55 »
Joining in for three sets!
« Reply #40 on: Fri, 11 January 2019, 13:47:24 »
Joined for two sets!
Offline Rumblehotep
« Reply #41 on: Fri, 11 January 2019, 22:18:37 »
Wew caught this just in time, in for one of each
Offline kmfmppl
« Reply #42 on: Sat, 12 January 2019, 05:36:23 »
Joined for three sets  :thumb:
Offline oh_chesteroni
« Reply #43 on: Sat, 12 January 2019, 12:26:29 »
Joined for 4 or 5. Can't remember.
Offline dallman5
« Reply #44 on: Sat, 12 January 2019, 12:28:00 »
Just bought enough to last me a lifetime  :thumb:
LF: OG Cherry APL (lasered), Artisans
Current collection:
Norbatouch (Galaxy Blue) | Mira SE (Lunar Grey, WKL) | HHKB Pro 1 (KB300BN) | Noxary X60 (Grey, HHKB) | KBDFans 5 Degree (Silver) | AEK64 (Grey) | Norbaforce (Tactical Black, WKL)) | Realforce 86U (White) | TGR 910 RE (Polycarbonate) | LZ-SQ (Black) | LZ-CLS (Grey, WKL) | Duck Orion v1 (Silver, WK)) | Nissho KB106DE | HHKB Pro 1 (KB300B) | LZ CLS-S (Blue, Poker) | Realforce 87U 10th Anniversary) | Realforce 104UK | TGR Alice (Grey on Pink) | Singa (Blue, WKL)  | Quantrik QXP (Blue Grey, WKL) | LZ-GH v2 (Black, WK) | KMAC Happy (Red, Poker)) | IBM Model M SSK (APL) | TGR 910 SE (Pink on Blue) | GSKT-00 (Silver, Poker) | OTD Koala (Silver, WKL) | Realforce R2 PFU Edition (Ivory) | IBM 3279 Beamspring (APL) | TGR Tris (Blue) | LZ-GH v2 (Blue, WKL)) | TGR Jane v2 (Blue-grey, WKL) | LZ-MP (Shine Grey, WKL)  | TGR x Singa Unikorn (Purple) | Justsystems x Realforce 108UG) | IBM Model F Unsaver (APL) | TGR Jane V2 CE (Multicolor, WKL) | Realforce 87U (Blank Black) | Lin Montage (Light Blue, WKL) | GSKT-00 AEK R2 (Grey, HHKB) | Leopold FC660C (Blank Black) | Duck Viper v3 (Grey on Black) | Rama Works M6-C RWxRW | LZ-GH v1 (Black, WKL) | Gok 7v (Grey) | biso x beaming Kei (SS, HHKB) | zacheadams x bisoromi little z | Matrix Noah (Silver/Grey, WKL) | Lin Whale (Pink, WKL) | TGR Alice (Polycarbonate) | Rama Kara (Noct) | Lin Whale75 (Burgundy, F13) | Realforce 89 (Ivory) | Hand Engineering Haus (Bluegrey) | Haytco CAKE60_R1 (Pantone 4167C) | LZ-XE (Grey, WKL) | Noxary X60 V2 (Grey, WK) | Daji Ochocuatro (Grey, WKL) | HHKB Hybird Type-S 25th Anniversary (Snow) | LZ-REs (Grey, WKL) | Matrix 8xv 3.0 (Blue-Black/Deep Grey, WKL) | Realforce 23UB | Biso RS60 (Black, WK) | TGR x MXF Koala (Grey/Black, WKL)
Italics = Incoming, Black = Gone
Offline MTXjunkie
« Reply #45 on: Sat, 12 January 2019, 12:29:52 »
Hahaha!  You guys make me feel better for the 7 or so I ordered . Sad part is I already have 3 boards on order so....
Offline Ashardalon
  • Ashkeebs
    • Ashkeebs Lubing Service & Shop
« Reply #46 on: Sun, 13 January 2019, 12:37:40 »
Joined for 4! Far too good of a price to pass up, should cover all of my boards this year.
Offline Justin_aka_OsP_SSJ4
  • Chellow... it's me...
    • My Twitch
« Reply #47 on: Sun, 13 January 2019, 18:03:18 »
I stupidly forgot about this... the "ill order when I get home from work" never works. I just put an order in for 3 sets since the link still works. I hope its ok.
DC60 w/ DZ60 PCB & Steel plate w/ 3mm neoprene foam - 68g Chellows Lubed w/ 3204 - Find me on twitch/twitter Osprey_SSJ4
Offline 5inn3d-
« Reply #48 on: Sun, 13 January 2019, 20:58:48 »
is it possible to still order? I tried yesterday and the transaction got declined
    • My Twitch
« Reply #49 on: Sun, 13 January 2019, 23:48:57 »
Weird that it stopped you? My paypal went through and I got a confirmation email. Maybe there was a cancellation or something?
Or maybe they havent caught my order yet and will cancel it after all.
