Author Topic: [GB] SPACE65 (100% shipped, Completed)  (Read 309588 times)
Offline SlamMakanen
Re: [GB] SPACE65 (Shipping in progress)
« Reply #350 on: Sat, 13 July 2019, 01:36:16 »
I can't seem to put the board into bootloader mode to install a custom layout. I unplug it, hold the escape key then connect the USB cable but it just seems to turn on as normal and the QMK toolbox doesn't pick it up as an available HID.
Anyone able to offer some advice?
I don't have mine to confirm yet, but reset should be Fn (key next to left arrow) + Esc.
Odd. It appeared to work briefly as QMK toolbox picked it up but Windows then did its "installing device drivers etc" then toolbox lost it. Since then I've not been able to get it to work again.
I think you need to do it while plugged in, rather than while plugging in.
That's what I did after your suggestion. It's as if it wiped the escape binding once windows installed the drivers for the board or something.
I'll try again later today
Offline SlamMakanen
« Reply #351 on: Sat, 13 July 2019, 02:46:13 »
This is all very odd. I connected the keyboard to my macbook and it picked-up it was available to flash there. I tried with my hex file (created from config.qmk.fm) and it errored with "see --debug=51 or greater for more information". After that the board was stuck in bootloader mode (even after being disconnected and reconnected). I had to load the default hex file back into it to get the board working again but now it won't go back into bootloader mode and the macbook doesn't pick it up either.
I've never gotten along with QMK :(
Offline SlamMakanen
« Reply #352 on: Sat, 13 July 2019, 04:20:28 »
Ok I've figured out the bootloader mode issue you may all want to keep in mind.
It appears that the firmware pre-loaded on the pcb uses the mod+esc to enter bootloader mode but if you load the default firmware from git it changes it to holding escape during connecting your keyboard.
Now I just need to build a hex file that actually works....
Offline mudcakehoney
« Reply #353 on: Sat, 13 July 2019, 06:55:24 »
If anyone is looking to sell their board please let me know
Offline Vadurr
  • Valar Morghulis
« Reply #354 on: Sun, 14 July 2019, 11:27:10 »
Looking to buy a gray space65 :)
« Last Edit: Mon, 15 July 2019, 15:54:19 by Vadurr »
Offline krisst
« Reply #355 on: Mon, 15 July 2019, 08:33:11 »
Any plans for R2?
Offline tskiller
« Reply #356 on: Mon, 15 July 2019, 12:03:10 »
Are we able to buy an extra PCB? Forgot to order one to go with the grass plate.
Offline cucgach
« Reply #357 on: Mon, 15 July 2019, 15:08:51 »
Just want to share my top gray bot silver space65.. the waiting is worth it  :thumb:
222690-0
222692-1
222694-2
222696-3
222698-4
222700-5
Current: Filco TKL Majestouch | TX60 antique brass | NIU40 silver | H360 burgundy | tr.mk wooden 60 | Imperial Hue 60 | Tofu 65 silver | Tofu WKL navy | Gergo Kit: black PCB | Space65 gray/silver | VN66 Black
Future: none
Past: TinaC HHKB gray | TX84Se titan gray | Leopold 660M white | GSX96 R2 purple | Rama M60-A lake | 0.01 Z70 silver | E7-V1 MAO | Rama M6-A | TMO50 green/poly | HB85 black/gray | TX108se titan gray | Typewriter68 ceramic white | Think6.5 frost poly
Offline linkian209
« Reply #358 on: Mon, 15 July 2019, 22:15:28 »
I just finished her up. I have GMK Red Samurai (until GMK Bentō shows up) with Massdrop x Invyr Holy Pandas. Very fun experience in my dry tests.
Offline moonux
« Reply #359 on: Tue, 16 July 2019, 01:31:56 »
Finished my silver Space65 build. I like the monochrome look on it.
Sent from my SM-G975U1 using Tapatalk
Offline HOBI3CAT
  • FraktalKaps.com
    • Fraktal Kaps Website
« Reply #360 on: Tue, 16 July 2019, 08:14:34 »
All these gorgeous pics, and I'm still waiting on a tracking number.....  :'(
Eat, Sleep, Resin, Repeat.
Offline Ensaum
« Reply #361 on: Tue, 16 July 2019, 10:54:34 »
Is there supposed to be an acrylic blocker for the side led? Mine just has an open hole in the side of the case.
Offline eyedrop
« Reply #362 on: Tue, 16 July 2019, 11:54:19 »
linkian209, did you use the CF plate with the holy pandas?
Offline MudkipMao
« Reply #363 on: Tue, 16 July 2019, 13:23:44 »
Not sure about him, but oldcat, the liason for the groupbuy heavily recommended using CF with holy pandas :]
Offline redjarojam
    • Instagram
« Reply #364 on: Tue, 16 July 2019, 14:45:07 »
Anyone with a brass plate having an issue getting their case closed tight? I keep getting a gap on top and bottom of my board. Carbon plate closes up just fine.
Offline hokietux
« Reply #365 on: Tue, 16 July 2019, 15:51:24 »
Got my Space65 yesterday! Was super excited... so excited, in fact, that I soldered all my switches on without testing the PCB. Turns out my `\`, up, and down keys don't function (not even with tweezers on the PCB). I have a second PCB which does appear to work, but all of my switches (and thus my plate) are now on the first PCB. Re-flashing the firmware doesn't fit, and I can't reset the EEPROM without getting this error:
Code: [Select]
>>> dfu-programmer atmega32u4 flash --force --eeprom /Applications/QMK Toolbox.app/Contents/Resources/reset.eep
    0%                            100%  Programming 0x80 bytes...
    [ X  ERROR
    Memory write error, use debug for more info.
Soooo I guess what I'm saying is make sure everyone checks their PCBs before you start soldering, because I just got totally hosed.
Offline AlcoholEnthusiast
« Reply #366 on: Tue, 16 July 2019, 16:14:37 »
Offline eskimojo
    • KeycapLendar
« Reply #367 on: Tue, 16 July 2019, 16:22:45 »
Code: [Select]
    [ X  ERROR
Sorry to hear this. Not sure what's caused the issues with the keys, but I've been informed the eeprom issue may be due to QMK Toolbox - apparently you should try being on version 0.0.9?
Relevant GitHub issue
« Last Edit: Tue, 16 July 2019, 16:25:36 by eskimojo14 »
Offline merlin64
    • MechMerlin
« Reply #368 on: Tue, 16 July 2019, 16:51:19 »
Hey all, if you find anything wonky with the firmware please feel free to reach out to me, and I'll try my best to get it worked out. When I got this into QMK, there really wasn't anything to test with.
Offline Vadurr
  • Valar Morghulis
« Reply #369 on: Tue, 16 July 2019, 18:05:46 »
Anyone with a gray kit want to sell me their spot? :)
Offline 8six753o9
« Reply #370 on: Tue, 16 July 2019, 19:39:27 »
Thanks for porting it over to QMK.  I just built a hex file using config.qmk.fm and so far so good.   :thumb:
Offline SlamMakanen
« Reply #371 on: Wed, 17 July 2019, 00:50:43 »
Odd as the hex files generated from there wouldn’t flash for me. Had to create one the old fashioned way (with help!)
Sent from my iPad using Tapatalk
Offline Sorachi.Ace
  • Formerly CaptRobo
  • Co-owner of SodieCaps artisan keycaps
« Reply #372 on: Wed, 17 July 2019, 07:30:29 »
Looking to buy a spot gb, any color :)
Offline eyedrop
« Reply #373 on: Wed, 17 July 2019, 08:36:47 »
Thanks as always for porting it to QMK.  If you need an actual PCB to test or troubleshoot, let me know.  I can send you mine.   :thumb:
Offline hokietux
« Reply #374 on: Thu, 18 July 2019, 08:03:12 »
Code: [Select]
    [ X  ERROR
Okay, I've solved the problem thanks to some input from some folks on Discord.
For anyone else that experiences this, if you are using screw-in stabs, the screws will short on the backspace key, which will prevent the pipe, up, and down keys from functioning. Here is a picture that highlights the issue:
If you have a thin plastic or rubber washer, that should work, as would kapton or electrical tape. Once I resolved this short, my three keys started functioning again.
Offline Visionaire
« Reply #375 on: Thu, 18 July 2019, 08:16:16 »
Really solid. Infill loooks great.
Offline moonux
« Reply #376 on: Thu, 18 July 2019, 08:28:40 »
Thanks! If you do the infill, make sure you do the bottom as well, it looks great. Too bad it's rarely seen
Offline thornkin
« Reply #377 on: Fri, 19 July 2019, 01:58:09 »
Wow. That mono one look amazing!
How does one go about doing the infill?
Offline LDawgR6
« Reply #378 on: Fri, 19 July 2019, 04:41:42 »
I am. Seems like the brass plate is just a hair too thick. After screwing the brass plate in, I can feel the brass plate is slightly higher than the top plate (especially in the corners) by running my fingers across the edges where the brass plate meets the top plate. When I screw the top and bottom plates together with the brass plate installed, there is definitely a slight gap between the top and bottom plates.
Offline moonux
« Reply #379 on: Fri, 19 July 2019, 07:46:42 »
Check out Jae's video of his Space65 build on the Top Clack YouTube channel. He shows the technique in detail!
Offline baphotmet
« Reply #380 on: Fri, 19 July 2019, 22:16:56 »
Got my Space65 yesterday, but the plate should be brass instead of carbon.
Where should i seek for help?
https://imgur.com/leCPhtg
https://imgur.com/pCXRzQk
Offline eyedrop
« Reply #381 on: Sat, 20 July 2019, 00:00:32 »
I would think wechat is probably fastest.  Check the OP.  Good luck!
Offline baphotmet
« Reply #382 on: Sat, 20 July 2019, 23:32:55 »
Thank you for mentioning it, but i have already used QQ to contact him, still no response.
Offline Ensaum
« Reply #383 on: Sun, 21 July 2019, 00:13:44 »
It may take a bit for him to get back to you because of his vpn going in and out. I reached out to him there for a missing piece and it took abut 2 days but he did email me back.
Offline Aatlatlatla
« Reply #384 on: Sun, 21 July 2019, 01:15:02 »
Anyone willing to sell an extra pcb?
Offline Anikiandy
« Reply #385 on: Mon, 22 July 2019, 00:22:28 »
Has anyone had any luck with the brass plate? Mine also doesn’t sit flush with it. Along the edges there is a ridge in a few places maybe from the machining? Since the ridges are on the back side of the plate I was planning on taking a grinder or file to them tomorrow to knock them off. Not sure if the plate is too thick overall or if the ridges will solve it.
Offline Anikiandy
« Reply #386 on: Mon, 22 July 2019, 20:53:37 »
Update: the plate is not brass. I ground the ridge down and then the brass dipped coating chipped away and now it’s all peely looking. Maybe it’s copper underneath? I can’t tell
Offline eskimojo
    • KeycapLendar
« Reply #387 on: Tue, 23 July 2019, 02:31:54 »
The plate is PVD coated brass. The coating you see is PVD, then you have the raw brass underneath.
Offline Vadurr
  • Valar Morghulis
« Reply #388 on: Tue, 23 July 2019, 17:09:41 »
« Last Edit: Wed, 24 July 2019, 02:05:15 by Vadurr »
Offline Sorachi.Ace
  • Formerly CaptRobo
« Reply #389 on: Tue, 23 July 2019, 17:31:47 »
I just got a silver with black badges, carbon and alu plate space65. I'd be open to swap plates, badges or a complete kb swap if anyone is interested.
Offline mrpetrov
« Reply #390 on: Tue, 23 July 2019, 19:23:19 »
222967-0
My red Space 65 in a red Tesla Model 3. Seemed thematically congruent: space65, mars geomap, red tesla, stairway to heaven on tunes.
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #391 on: Wed, 24 July 2019, 17:03:33 »
My brass plate doesn't fit either. I'm hoping there's a less invasive way to fixing this if anyone has any solutions.
Offline Subaeru
« Reply #392 on: Thu, 25 July 2019, 02:46:45 »
If anyone has a black space65 they would want to sell me please lmk :)
Subaeru 🐇
Offline SlamMakanen
« Reply #393 on: Thu, 25 July 2019, 03:32:08 »
Those looking for any for sale should check out mechnarket as I've seen as few for sale
Offline Vadurr
  • Valar Morghulis
« Reply #394 on: Sat, 27 July 2019, 01:31:03 »
My brass plate also does not fit :(
Also, is no-one applying the rubber feet on due to screw location?
Offline eskimojo
    • KeycapLendar
« Reply #395 on: Sat, 27 July 2019, 13:26:59 »
Quite a few people have holepunched/cut their feet to allow access to screws, from what I've seen.
Offline booleanjulien
« Reply #396 on: Sun, 28 July 2019, 11:29:52 »
Did anyone get a brass plate that DID fit? Seems like they're all not the right size so far.
Offline eskimojo
    • KeycapLendar
« Reply #397 on: Sun, 28 July 2019, 15:59:32 »
I did my build with cf in the end due to preferable sound, but my brass plate fitted fine when i tried it out.
Offline fcnchuck
« Reply #398 on: Sun, 28 July 2019, 18:30:41 »
First build - How do you change the LED settings on the side of the board? (Color, type, etc.)
Offline Anikiandy
« Reply #399 on: Sun, 28 July 2019, 18:42:35 »
It’s very subtle. since it’s a sandwich plate when you fully install it and then screw the case together it seems ok except if you look at the side you can see the brass plate showing through the seam
