Author Topic: [GB] ALF x Scott - G60 Retro Multi-mount Dual-mode Keyboard (Pending Shipment)  (Read 316142 times)
Re: [GB] ALF x Scott — G60 - 60% Retro Multi-mount Dual-mode Keyboard (Extended)
« Reply #150 on: Wed, 06 February 2019, 21:43:52 »
Happy Chinese New Year!  Gong Xi Fa Cai!
happy new year :)
Offline Dawn
Re: [GB] ALF x Scott - G60 Retro Multi-mount Dual-mode Keyboard (Extended to 2/15)
« Reply #151 on: Thu, 07 February 2019, 18:25:56 »
Just joined the group buy. I fell in love with the Pink and I love HHKB :) (plus I need a new home board)
Offline oldcat
  • 65% is Life
« Reply #152 on: Fri, 08 February 2019, 10:44:53 »
The HHKB is dope!
Offline oldcat
  • 65% is Life
« Reply #153 on: Fri, 08 February 2019, 21:09:43 »
Just confirming I was able to connect even 20 meters apart from the computer (using a pc plate in my case). Took my laptop for a meeting earlier today in another building and restarted the laptop, auto-connected to BIOI G60 BLE. Dang, that was amazing.
Also, using Bluetooth has practically no lag at all. The VIA configurator was awesome too, IMO every customized keyboard should adopt the VIA software.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #154 on: Sat, 09 February 2019, 17:43:19 »
+1 I wish we just had a standardized system for everything.
Offline crd
  • Discord: crd#7617
« Reply #155 on: Sat, 09 February 2019, 21:45:47 »
I have faith that VIA will get there :)
Offline kitimon
« Reply #156 on: Mon, 11 February 2019, 03:38:26 »
Hey, I submitted a form but haven't paid the invoice yet, and I would like to change my mind for some of the options on the board. Would it be possible to delete my current choices so I can submit a new form? Thanks.
Offline voight-kampff
« Reply #157 on: Mon, 11 February 2019, 08:03:22 »
Sorry but I have the same problem. I would also like to know what to do in this case.
Thanks
Sent from my MIX using Tapatalk
Offline tanega
« Reply #158 on: Mon, 11 February 2019, 15:58:37 »
I think drop a pm to scott on the discord channel.
Offline nasp
« Reply #159 on: Mon, 11 February 2019, 20:16:02 »
Say one was to use this PCB in another case, would you be able to charge it with the main USB connector on the PCB, or does charging the battery only work when plugged into the other connector that is attached to the daughterboard? Or perhaps both connectors on the PCB charge the battery?
Offline oldcat
  • 65% is Life
« Reply #160 on: Tue, 12 February 2019, 00:38:44 »
Any connector should charge the battery
Scott, correct me if I am wrong.
This PCB priced @ $42 is a steal.
Offline oldcat
  • 65% is Life
« Reply #161 on: Tue, 12 February 2019, 00:40:24 »
Yeah just submit a new form or/and PM Scott. I think he is traveling these 2 days with his GF. Should be back online shortly.
Offline scottwei
« Reply #162 on: Tue, 12 February 2019, 08:45:43 »
Yes, the battery is charged by the USB port of the PCB, there is a Li-Po battery charging management chip on board. It can be used on other case but you have to find your way to install battery.
Offline scottwei
« Reply #163 on: Tue, 12 February 2019, 08:49:22 »
Just leave me a personal message at GH or the discord,  and I’m sorry I have to process it later, as Oldcat said I’m on a unexpected travel these days.
Offline djhyro
« Reply #164 on: Tue, 12 February 2019, 12:58:07 »
Is there an option to add an extra upper case of a different configuration?
Offline oldcat
  • 65% is Life
« Reply #165 on: Tue, 12 February 2019, 13:27:10 »
Haven't thought about this -- maybe send Scott a PM (or a discord message)?
Offline lakeboredom
« Reply #166 on: Tue, 12 February 2019, 22:00:12 »
I know this case supports different pcb, but will the pcb fit in standard gh60 cases?
« Last Edit: Wed, 13 February 2019, 00:41:29 by lakeboredom »
Offline Dawn
« Reply #167 on: Wed, 13 February 2019, 16:04:02 »
Tempted to get a red one now and take an old honeywell terminal and SA honeywell and have a fun project in a few months.
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #168 on: Wed, 13 February 2019, 16:18:27 »
Yes!
Offline RETURNISO
« Reply #169 on: Wed, 13 February 2019, 16:19:04 »
Yees!!
Offline lakeboredom
« Reply #170 on: Wed, 13 February 2019, 17:12:04 »
Yes!
Thank you. Is this the best option for bluetooth 60 with arrowkeys? seems like it..
Offline RETURNISO
« Reply #171 on: Wed, 13 February 2019, 17:19:28 »
Yes!
Yes atm this is properly your best bet for a gh60 compat Bluetooth PCB with arrow keys + VIA configurable  :cool:
Offline F2F4
« Reply #172 on: Wed, 13 February 2019, 18:36:30 »
Could I not get a dz60 to make this split spacebar?
Offline RETURNISO
« Reply #173 on: Wed, 13 February 2019, 19:01:37 »
Yes, but it would only work if you source your own plate that supports split spacebar, furthermore you would be limited to the tray mount option. But it's possible!  :thumb:
Offline nasp
« Reply #174 on: Wed, 13 February 2019, 19:05:55 »
This will be a good keyboard to actually see the difference between top and tray mount, granted everything else is kept the same. I'm looking forward to it.
Offline Lyle88
« Reply #175 on: Wed, 13 February 2019, 19:16:27 »
Just filled out the form last night. Should I expect a confirmation email?
Offline F2F4
« Reply #176 on: Wed, 13 February 2019, 19:46:26 »
https://kbdfans.cn/products/dz60-cnc-aluminum-plate?variant=2208864567309
So will this plate + DZ60 work for a splitted spacebar layout in your case?
Offline scottwei
« Reply #177 on: Wed, 13 February 2019, 21:15:01 »
Works with tray mount, if you need a top mounted plate, I can provide a custom plate in carbon fiber or PC
Offline scottwei
« Reply #178 on: Wed, 13 February 2019, 21:17:53 »
Thank you so much for supporting G60, Due to some personal reasons I can’t process the invoices these days, the invoice email might comes a little bit later.
Offline oldcat
  • 65% is Life
« Reply #179 on: Wed, 13 February 2019, 21:44:16 »
Scott is traveling in Macau right now. He said he will be back in 30 hours will send an invoice soon.
Edit: see Scott's message above.
« Last Edit: Wed, 13 February 2019, 21:46:10 by oldcat »
Offline Lyle88
« Reply #180 on: Wed, 13 February 2019, 22:14:14 »
Cool thanks
Offline Rayndalf
« Reply #181 on: Wed, 13 February 2019, 23:50:19 »
Any idea if the case (with HHKB blockers) could fit a boardwalk PCB?
Offline lakeboredom
« Reply #182 on: Thu, 14 February 2019, 01:41:05 »
Yes!
So helpful thankyou. Thanks for making me look up VIA configurator geeze. Gonna have to put in rgb leds now.
Offline nasp
« Reply #183 on: Thu, 14 February 2019, 01:48:53 »
Yes it should be able to since it accepts tray mount
Offline lakeboredom
« Reply #184 on: Thu, 14 February 2019, 02:10:55 »
Yes!
I should not get this plate though, correct? This will be my first 60%, I'm sure it's obvious to experienced builders, but the pic made it look like the plate is for case mount only and I'll need a DZ60 plate to use the pcb in my grid as a traymount?
Offline crd
  • Discord: crd#7617
« Reply #185 on: Thu, 14 February 2019, 09:34:52 »
If you're planning to tray mount your own PCB then you may use whichever universal GH60 compatible plate you want. The plates on offer in this GB are specifically for mounting to the top half of the case. Tray mount means that your PCB is secured to the bottom half of the case on threaded standoff posts.
Offline Rayndalf
« Reply #186 on: Thu, 14 February 2019, 11:48:53 »
If I get the carbon fiber plate do I get to select a color?
Offline RETURNISO
« Reply #187 on: Thu, 14 February 2019, 12:16:20 »
Just black for CF.
Offline Rayndalf
« Reply #188 on: Thu, 14 February 2019, 12:19:14 »
Good. I hate making choices (especially when I don't have something in mind I'm trying to match) and this it my first real custom, but I love the lines of the G80 series and this thing is just adorable
I still can't decide between NCR grey and Everest white (beige) but I'm leaning toward NCR because I have OG beige boards, but no industrial grey ones
« Last Edit: Thu, 14 February 2019, 12:21:51 by Rayndalf »
Offline RETURNISO
« Reply #189 on: Thu, 14 February 2019, 12:43:34 »
Haha, yes the g60 is tough in choices, Black CF looks dope with so many choices. So all safe there.
Yeah the g80 series is just a clean classic design. I really look forward to the g60! Talk about a perfect first custom choice ;)
Everest White is WHITE and not beige, so if it can help you make a choice, go with the NCR White, which should be a more toned down white/grey to match the old "beige"
« Last Edit: Thu, 14 February 2019, 12:54:53 by RETURNISO »
Offline Rayndalf
« Reply #190 on: Thu, 14 February 2019, 13:03:00 »
Yeah, I went with NCR grey. It'll be harder to match keysets to than silver, but the two tone look from the side looks so sharp that I'll just have to track down something retro
Offline anfledd
Offline RETURNISO
« Reply #192 on: Thu, 14 February 2019, 13:32:53 »
It do look sharp! A nice choice 👌
Offline RETURNISO
« Reply #193 on: Thu, 14 February 2019, 13:43:17 »
Anybody know if this PCB would work?
https://kbdfans.cn/collections/60/products/dz60rgb-hot-swap-custom-keyboard-pcb
The layout works with the universal plate option, but I don't know if the kalih hotswaps sockets could interfere with the hight tolerance between the PCB and the traymounts. But your properly OK. I think OP mentioned he would change traymounts screw to m2.5 to have a little more space in there for HS PCBs.
Let's see when OP comes back from CNY, hopefully he can explain it more in detail  ^-^
Offline anfledd
« Reply #194 on: Thu, 14 February 2019, 14:01:15 »
Well, I'm in for No Blocker/White/White/Carbon Fiber, I can figure out the PCB situation later.
Offline RETURNISO
« Reply #195 on: Thu, 14 February 2019, 14:10:01 »
Nice! A recommendation would be to get a extra plate as they are pretty ( REALLY ) cheap in this GB, + The g60 PCB. You will be happy in the long run ;)
« Last Edit: Thu, 14 February 2019, 14:12:48 by RETURNISO »
Offline Rayndalf
« Reply #196 on: Thu, 14 February 2019, 14:48:02 »
How long does it typically take to get confirmation after filling out the form? I'd really hate to miss something obvious and fail to place my order
Offline anfledd
« Reply #197 on: Thu, 14 February 2019, 14:52:33 »
Good call, I probably could use just a regular back up plate, whenever @scottwei is back I will need to update the invoice.
Offline RETURNISO
« Reply #198 on: Thu, 14 February 2019, 14:53:58 »
OP is out of town ( CNY )
If you filled out the form you are good  :thumb:
« Last Edit: Thu, 14 February 2019, 14:57:32 by RETURNISO »
Offline RETURNISO
« Reply #199 on: Thu, 14 February 2019, 14:59:15 »
Just PM him here or on discord :)
