Author Topic: GAF  (Read 1612880 times)
Offline bgnu-thun
Re: GAF - Keep it Grimey Giveaway Contest
« Reply #400 on: Fri, 25 January 2019, 17:52:55 »
When I was a little kid my cat caught a poor little mouse and was trotting around with the mouse in its jaws. Wanting to save the mouse I grabbed the tail that was hanging out and tried to pull the mouse out of the cats mouth. The cat wasn't happy with that at all and pulled back, starting a tug of war.. Maybe you can see where this goes?
It didn't take long before the cat was in effect victorious - the poor little mouse's tail popped right off.. The cat ran off with its mostly complete mouse and I ran around screaming like an idiot because the tail had spiraled through the air and landed somewhere in my hair. That was pretty traumatising, and having mouse goo and tail in my hair was definitely a grimey time.
Offline Blurple33
« Reply #401 on: Fri, 25 January 2019, 18:03:47 »
Saw my friend vomit a piece of onion from his burger.  However, the onion was an unbroken, intact ring.
It raised a few questions while also being gross.
Offline forstsiven
« Reply #402 on: Fri, 25 January 2019, 18:18:46 »
When traveling through Turkey, I had to catch a ferry from, I believe, near-Bursa to Istanbul, which would take me across of the Sea of Marmara. I say, "I believe," because on the return leg I was feeling very ill and usually was passed out--aside from the times I had to run to the bathroom. A stomach bug + a love of spicy food is generally agreed upon to be a bad decision, but when you love spicy food, you forget such things.
While boarding the boat, I noticed dark storm clouds looming on the horizon. A stiff breeze, choppy waters, and suspiciously empty ferry clued me in that most thought it unwise to travel by boat. As we pulled out of the harbor, I could see even larger waves and a host of ships heading for safer waters. We were the only boat heading out towards open water.
The farther we got, the worse the waves became. It wasn't long before the entire ship was heaving and hawing with each wave. Up we went, then, a precipitous drop strong enough to remind one of a roller-coaster. My stomach and bowels also sent me another reminder. It was bathroom time, and I had to go immediately.
As I navigated to the bathroom, walking like the drunkest person on the planet, I contemplated with all seriousness whether the boat would sink. I had seen news prior that a ferry had sank in similar fashion while on the Adriatic. Once to the bathroom, I realized that the seas were so rough that the toilet had become a cross between a bidet and a geyser. Desiring to avoid being splashed by my own filth, I decided to spiderman my way above the toilet with one foot on the sink, another on the rail, and my back wedged up against the wall above the toilet.
From this lofty perch, I did my business and somehow avoided sullying myself. The same, however, couldn't be said for the toilet and the floor. The waves were simply too strong and no matter how quickly I tried to flush, there was spillage.
Making my way out of the bathroom, I found a long line of bleary-eyed, sea-sick Turks. I don't know whether it was the scene I left or the sheer motion in the ocean that caused it, but the first person into the bathroom behind me immediately puked, causing those behind him to cascade vomit.
While I'm not proud of what I did, it ended up being a bonding opportunity as my then ex-girlfriend (who had broken up with me a week before visiting) mended the fence. For that, I will always look upon that day as a time when my poop truly built a bridge over troubled waters.
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #403 on: Fri, 25 January 2019, 18:22:29 »
I was at the seattle meet and the room was hot since the AC wasn't bumpin.
Offline MajorclaM
« Reply #404 on: Fri, 25 January 2019, 18:38:34 »
Here goes my grimey story,
A few years ago I had face/jaw surgery to correct my bite and alleviate some jaw pain. Sounds rather trivial right? Nope. I had spent the year prior to the surgery in braces getting my teeth pushed and pulled into what would become my new bite. The last checkup before the surgery the PA gives us the talk, "this is going to be the worst thing ever, day 2 is a wall, if you make it past it you'll be past the worst, etc"
I have my surgery, make it out of recovery, and am wheeled up to my room. They had cut my upper jaw(maxilla) into 3 seperate pieces and cut my jaw (mandible) into four, all held together by plates and screws. All the trauma and cuts caused my sinuses to bleed despite blood vessels being cauterized and stapled shut. Now the fun thing about having your face rearranged is they rubber band your teeth together in the name of stability. I was unwittingly swallowing blood for several hours, I finally got nauseous and that blood came back up. Have you ever seen the Shining? You know the part where the elevators open and a deluge of blood comes crashing out? I felt like an anthropomorphic elevator that day. God bless the nurses that swooped in and changed my linens and got me a new gown.
Long story short, maxillofacial surgery is full of grime for weeks and weeks.
Thanks for the giveaway GAF!
Offline the_fascist
« Reply #405 on: Fri, 25 January 2019, 18:42:50 »
I sneezed once and the snot remained attached to my nose and rebounded into my mouth.  Never forget
Offline mbsurfer
Re: GAF - Keep it Grimey Giveaway Winner Announced
« Reply #406 on: Fri, 25 January 2019, 20:45:11 »
There we some really great stories in here, and I definitely gagged a few times. So happy to win! Thanks so much for the giveaway Kudos and Koala!!!
« Reply #407 on: Fri, 25 January 2019, 21:25:49 »
grats dude
Offline DeadlyPoison
« Reply #408 on: Sat, 26 January 2019, 04:16:59 »
Congratulations, very lucky.
Offline Kazemah
Re: GAF
« Reply #409 on: Thu, 20 August 2020, 09:45:01 »
I'm new to the forum, so I'm not sure if this is the place to post, but does anyone know what gofundme GAF is referring to in their new Insta story? Also! I'm pumped GAF as returned, I thought they were retired.
Offline ramnes
  • T fou, mec?
Re: GAF
« Reply #410 on: Sat, 22 August 2020, 01:15:47 »
Yeah I wondered that as well
Offline juntheboon
Re: GAF
« Reply #411 on: Sat, 22 August 2020, 01:17:12 »
The gofundme was a donation event that happened on the Inkeebriated twitch stream a couple weeks ago for an asbestos issue.
Offline Vlie
Re: GAF
« Reply #412 on: Sat, 22 August 2020, 15:12:27 »
i like fvccboi!!!
Offline shuangmu
Re: GAF
« Reply #413 on: Sun, 30 August 2020, 00:41:26 »
GAF <3
Offline mbsurfer
Re: GAF
« Reply #414 on: Mon, 31 August 2020, 16:03:38 »
Offline brianjking
  • always carry a towel.
    • @brianjking
Re: GAF
« Reply #415 on: Mon, 31 August 2020, 16:08:17 »
Same
Offline juntheboon
Re: GAF
« Reply #416 on: Sat, 12 September 2020, 22:07:04 »
I love GAF!!
eggplant eggplant eggplant
Re: GAF
« Reply #417 on: Thu, 17 September 2020, 01:51:03 »
Offline pendemon
Re: GAF
« Reply #418 on: Sun, 04 October 2020, 16:03:08 »
New putrid panda is dope AF!
Offline Dagdha
Re: GAF
« Reply #419 on: Sun, 04 October 2020, 16:08:13 »
Nothing is more classic than black and white.
« Last Edit: Sun, 04 October 2020, 16:12:49 by Dagdha »
Offline meiosis
  • Time
Re: GAF
« Reply #420 on: Sun, 04 October 2020, 20:19:30 »
It's my birthday in over 2 months! Hope RNG blesses me.
Keyboards:
Aripeko TKL
  • sleever supreme
  • greyhat co-leader
Re: GAF
« Reply #421 on: Mon, 05 October 2020, 11:15:07 »
my birthday is a few months after yours :cool:
Re: GAF
« Reply #422 on: Tue, 06 October 2020, 12:46:45 »
It was my birthday two months ago.  :cool:
Offline brianjking
    • @brianjking
Re: GAF
« Reply #423 on: Tue, 06 October 2020, 12:57:39 »
I too had a birthday two months ago. Happy Belated!
Re: GAF
« Reply #424 on: Wed, 07 October 2020, 13:11:14 »
Feliz cumpleanos from Chicago!
Offline juntheboon
Re: GAF
« Reply #425 on: Mon, 12 October 2020, 04:01:22 »
My birthday is in a little over two months
Offline kiwi99
  • that's a gnarly dookie
Re: GAF
« Reply #426 on: Mon, 02 November 2020, 01:06:53 »
I had a birthday this year!  :thumb:
Offline fatpolomanjr
Re: GAF
« Reply #427 on: Thu, 05 November 2020, 07:06:33 »
I've had a birthday at least once within the past 365 days.
Some guys keep on saying they believe in Jesus, and keep doing a lot of shameful things.
Current GH Classified Post (LF Arcade Floor, Garbield and CYM Otter and Keyng)
Offline rainb1ood
  • so pretty so plastic
Re: GAF
« Reply #428 on: Thu, 05 November 2020, 09:10:25 »
belated happy birthday to those that had birthday happened  this year
Offline rmendis
  • Artisan addict
Re: GAF
« Reply #429 on: Sun, 28 April 2024, 21:51:55 »
Kudos joined in remotely to one of the artisan panels at Keycon 2024 this past weekend.
Will post a VOD link when available, but in the meantime, here are a couple photos for proof of life... and new sculpt revisions to Grimace and Trash Panda. =)
307646-0307648-1
« Last Edit: Sun, 28 April 2024, 21:56:01 by rmendis »
Offline glack23
Re: GAF
« Reply #430 on: Sun, 28 April 2024, 21:56:16 »
Ohhhhhh new revision!
Sent from my Pixel 8 using Tapatalk
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: GAF
« Reply #431 on: Sun, 28 April 2024, 22:03:41 »
Super excited... And both a pleasant and happy surprise to see him back doing his art.
Will leave sub from Chicago to drop his macro of the keycap, but here are some quick snaps of the "Grimace v2.8" (a revision moving from v2 to v3) next to a Grimace v1 and v2 (Zipnotyzed and Omni-Klepto, respectively).The sculpt is evolving to a truly grimey form. The key was given away as part of a trivia award at the end of the panel/breakout session.
« Last Edit: Sun, 28 April 2024, 22:06:59 by LightningXI »
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: GAF
« Reply #432 on: Sun, 28 April 2024, 22:12:00 »
Oh snap, so there is still a chance I may one day win a GAF raffle!!!!!!!!!!!! Awesome to hear he's back!
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
Re: GAF
« Reply #433 on: Thu, 09 May 2024, 02:46:30 »
Amazing pics. thanks for sharing Lightning!
Offline Rhienfo
  • Why is everything I want here so expensive :(
Re: GAF
« Reply #434 on: Thu, 09 May 2024, 03:09:02 »
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
