Author Topic: Laser Cutting Polycarbonate?  (Read 4255 times)
Offline Ruskie
« on: Sat, 12 January 2019, 21:35:26 »
Has anyone had experience with cutting Lexan on a laser cutter? I would like to begin prototyping with better materials, as acrylic has proved to be quite fragile. Does Lexan polycarbonate emit any fumes when cut? Thanks everyone for your time!
Ive got myself a beefy boi
-Alf F62PE
-PCB Mount ZealV2 67g
-GMK KA1953 "OG Classic Retro"
8 pounds of clack
Online LightningXI
  • PPD
    • ArtisanMacro
Re: Laser Cutting Polycarbonate?
« Reply #1 on: Sat, 12 January 2019, 21:38:44 »
You might want to review this:
http://atxhackerspace.org/wiki/Laser_Cutter_Materials
If you cut polycarbonate with a laser, you risk damage to your laser, as well as a very inefficient cut... possibly a fire as well.
Offline Leslieann
« Reply #2 on: Sun, 13 January 2019, 00:36:41 »
Polycarbonate and Lexan are BAAAD for a laser. Lots of smoke and possible fire (smoke will fog the mirrors causing the laser to break them). I've seen these damage more than one laser.
Also, despite what the above link says, do burn or melt Teflon/PTFE. Ever. Seriously bad stuff.
Plexigalss is okay, but try Delrin/POM/Acetal (all quite similar).
Beware, black will cut but it will require quite a bit of power and/or multiple passes but the results are good.
And if you don't have one, install a vent to outside regardless of what you are cutting.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
