Author Topic: [IC] TGR Alice PCB (GB Live, Update: ARM MCU)  (Read 69874 times)
Offline onefivenine
    • Project Keyboard LLC
Re: [IC] TGR Alice PCB (Update: PCB Proto on the way | Acrylic board dropped)
« Reply #200 on: Mon, 04 March 2019, 05:30:12 »
rip, hopefully a new ic will pop up for the acrylic board for news to follow.
The 3D files are readily available. I have confidence that you guys can submit them and get it cut for you.
Try: https://www.formulor.de/
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #201 on: Mon, 04 March 2019, 12:38:49 »
Please do not try the files until this issue is closed. Thanks.
« Reply #202 on: Mon, 04 March 2019, 15:10:40 »
still need a pcb so we chill
Offline Darknight00z
« Reply #203 on: Mon, 04 March 2019, 16:43:06 »
Thanks for the heads up
Offline mikebmc
« Reply #204 on: Wed, 06 March 2019, 22:25:37 »
Is it too late to get in on this gb?
« Reply #205 on: Wed, 06 March 2019, 23:16:21 »
considering it hasn't started yet no
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #206 on: Thu, 07 March 2019, 01:50:51 »
So is this just pcbs now, since the acrylic case has been dropped? Or am I understanding this wrong?
Offline djmantis
« Reply #207 on: Thu, 07 March 2019, 09:55:21 »
The GB is now PCB only. However, Zambumon is working to open source and prototype an acrylic case. You would then be able to use these files to create your own case through a local or online laser cutting shop.
Offline H3NT4I
  • 気持ちいい
« Reply #208 on: Thu, 07 March 2019, 10:59:01 »
PCB hype
Offline onefivenine
« Reply #209 on: Thu, 07 March 2019, 13:12:38 »
Offline gabbbe
Re: [IC] TGR Alice PCB (Update: PCB Protos arrived)
« Reply #210 on: Thu, 07 March 2019, 13:14:41 »
Hyped
Offline ReDsNoTDeAd
    • RNDKBD
« Reply #211 on: Thu, 07 March 2019, 18:08:58 »
Thank you for the clarification. Did the original include a plate as well, or was it just PCB mounted?
Offline blizzara01
« Reply #212 on: Thu, 07 March 2019, 18:13:14 »
Integrated plate I believe
Offline onefivenine
Offline onefivenine
