Author Topic: Need help please, scroll wheel issue on 903  (Read 7653 times)
Offline typo
« on: Fri, 01 February 2019, 22:27:00 »
My scroll wheel on 903 works fine in every application. It has stopped working only in Microsoft mail. Anyone have any idea what is wrong or how to fix? Really do not want to reload OS for that! Thank you
Offline Leslieann
Re: Need help please, scroll wheel issue on 903
« Reply #1 on: Sat, 02 February 2019, 19:45:43 »
Since it's only in Mail, it's not the mouse that is the problem.
Could be the driver or the app, my bet is the app., unfortunately if you are on Win10, there's little you can do. You could uninstall the latest update, with some research you may be able to identify the exact one rather than just going at them most recent first. A reinstall will work until the OS downloads the update again.
My advice, install Thunderbird.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Nerd
  • Nerd (Aka Alex) Aka Garbage. Sister: @sintpinty
    • My Youtube channel!
« Reply #2 on: Tue, 26 March 2019, 09:55:14 »
It is probably your software.. I am having the same issue. I'll pass this along to those who need it.
"The world's nerdiest nerd that loves Youtube."
Consider subscribing to my channel, TanookiAlex. That would be greatly appreciated, thank you! Link is: Youtube.com/c/tanookialex.
                *  Subscriber Goal - 735/1000 *
