Author Topic: Any way to use a terminal model M?  (Read 2283 times)
Offline Dumbledas
« on: Thu, 14 February 2019, 00:07:31 »
The long story short is I accedentaly purchased a 1395666 model M keyboard and a separate ps/2 cable. Its only come to my attention that terminal keyboards wont work with modern computers. Are there any cheap ($30-$40) ways to make it work with modern computers?
If not, any tips on selling them?
Re: Any way to use a terminal model M?
« Reply #1 on: Thu, 14 February 2019, 03:52:04 »
Look for "Soarer's converter". It should auto-detect which type of IBM protocol the keyboard is using.
You could get a $5 Arduino Pro Micro, solder it up with connectors (or inside the keyboard) and download the firmware to it, or you could buy a ready-made one on eBay for a bit more.
« Reply #2 on: Thu, 14 February 2019, 06:17:10 »
Orihalcon is a member here and will probably give you a discount if you order it direct.
- D Trump 2026-10-24
