Author Topic: [IC] KAM Aquanaut (Updated 03/15/19)  (Read 88661 times)
Offline Surefoot
Re: [IC] KAM Aquanaut (Updated 03/15/19)
« Reply #150 on: Wed, 13 January 2021, 20:17:15 »
My understanding is that surface finish is more a product of the mold than the material and that KAM is just inherently shiny whereas KAT is not
That's it exactly. They both use the same material, the difference is KAM molds used to be shiny by default. Biip with KAM Wraith made them build new matte molds for KAM so i suppose that now there's the option for both.
That said I'd prefer that set in shiny finish, it will complement the colours quite well.
Offline MidnightSnek
« Reply #151 on: Tue, 02 February 2021, 11:35:41 »
I like it, but my only question is... why no 1.75 shift support? Most people are getting into 65s rn and that's the fundamental keycap to make that happen.
Offline iironforged
« Reply #152 on: Tue, 02 February 2021, 14:34:56 »
I made an account specifically to tell you how amazing this keycap set is and how stoked I am for the GB.
Offline kidpid
« Reply #153 on: Tue, 02 February 2021, 15:14:13 »
I hate to break it to you, but this project has been dead for over a year. The designer has been MIA since September '19, and it doesn't seem like reaching out to zfrontier got anywhere, either.
Offline eljudio42
« Reply #154 on: Wed, 03 February 2021, 01:32:27 »
This is the first set i've been interested in, in this profile. How will the same level caps work on a keyboard that's on an angle and not flat? How does that feel?
Offline BullRage
« Reply #155 on: Mon, 05 April 2021, 16:25:23 »
Too bad, nothing happening with this great set.
I would totally buy it. Great colors, great no standard-arrangement.
OP should totally get back to it.
Offline BullRage
« Reply #156 on: Mon, 05 April 2021, 16:28:42 »
It feels good. I line it way better than sculptured keycaps. But as everything in GH it's personnel preference. So my advice is to get yourself a cheap set from Amazon and test it and send it back to them, if yo want.
Offline Extra Fox
  • quis qui sais
« Reply #157 on: Mon, 05 April 2021, 19:42:24 »
Filled out the IC form before I checked the date.
Ugh, necroposting.
A-a-ron
