Author Topic: Help on not clicky blue switches after using contact cleaner  (Read 2531 times)
Offline Ryzera
« on: Wed, 27 February 2019, 13:12:35 »
Well, I have a Outemu Blue Switch mechanical keyboard for like 5 months , I've used some contact cleaner to solve "double click" problems , but I've noticed that the "ESC"  and "E"  keys wasn't making the clicky sound as before , now they sound like brown switches , and have a mushy feeling , and the white part (the one that make the clicky sound) of the affected switches are moving slowly when I press the key , not making the sound , neither feeling of a blue switch.
There is any way to fix it without desoldering and opening the switch ?
Re: Help on not clicky blue switches after using contact cleaner
« Reply #1 on: Wed, 27 February 2019, 20:19:21 »
Welcome to Geekhack!
You could try soaking the switch in isopropyl alcohol. or even very hot water.
Worst case you could acquire a couple of replacement switches and, well, replace them.
