Author Topic: [IC] wilba.tech Thermal - PREORDER NOW  (Read 121902 times)
Offline hottrout
  • I'd Hit Dat Key
Re: [IC] wilba.tech Thermal
« Reply #200 on: Fri, 12 April 2019, 10:22:56 »
I can't wait on this GB.  Is there any way that it would be able to take ISO for UK keys?
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #201 on: Fri, 12 April 2019, 10:26:39 »
Most likely OP will release a ISO plate file ( Crossing ISO fingers ) The zeal60 PCB already supports ISO :)
Offline bukowski
« Reply #202 on: Mon, 15 April 2019, 12:01:08 »
If there is an ISO version supported, I will get this one. :)
Offline RETURNISO
« Reply #203 on: Mon, 15 April 2019, 15:09:26 »
Check my answer 1 nodge up 😀
Offline Uryftw
« Reply #204 on: Mon, 15 April 2019, 16:04:46 »
Stunning design. Might consider picking this up.
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #205 on: Mon, 15 April 2019, 20:11:35 »
I will release ISO plate files. The current plan is to make another custom PCB without ISO, however the case will be compatible with Zeal60 rev 4 which has ISO support and can have a JST SH connector added so it connects with the supplied daughterboard USB-C PCB and cable. The case should also be compatible with other 60% PCBs like HS60 if the daughterboard cable is soldered to the PCB.
EDIT: if you are wondering what the hell am I gonna do with the Thermal PCB after I replace it with a new PCB, you can either keep it in case you sell the Thermal, or sell it to a Keycult No. 1/60 owner  :D
« Last Edit: Mon, 15 April 2019, 20:14:51 by Wilba »
Offline RETURNISO
« Reply #206 on: Tue, 16 April 2019, 05:46:37 »
Shoot, this properly means no red zeal60 Rev 4, damn haha ^-^
Care to elaborate why you are removing ISO compat from a Thermal PCB? I thought you guys was all about flex  :p
Offline Wilba
    • wilba.tech
« Reply #207 on: Tue, 16 April 2019, 07:32:51 »
ISO has to go away before it can return, no?  ;D
Offline RETURNISO
« Reply #208 on: Tue, 16 April 2019, 07:39:14 »
Damnit, new avatar pic..  :p
Offline nostr
« Reply #209 on: Thu, 18 April 2019, 07:58:28 »
I can't wait for this, the red on black with GMK red samurai  :eek:
Also, would the plates be sold separately?
Offline Wilba
    • wilba.tech
« Reply #210 on: Thu, 18 April 2019, 08:59:16 »
My aim for this GB is to sell extra plates and PCBs, as well as let the user choose the case and plate color combination. So for example, you can buy the black with red plate, and get an extra silver plate should the red plate not match some keycaps you'd like to use.
Offline regionfree
« Reply #211 on: Thu, 18 April 2019, 09:04:20 »
Around when would this GB start?
Offline Wilba
    • wilba.tech
« Reply #212 on: Thu, 18 April 2019, 10:06:38 »
My aim is to start soon, hopefully next month.
Offline bukowski
« Reply #213 on: Thu, 18 April 2019, 13:16:34 »
Okay, maybe I was bluffing and the HHKB layout would do perfectly fine aswell. :-P
Offline RETURNISO
« Reply #214 on: Thu, 18 April 2019, 13:31:31 »
i'll pay a lot for a couple of reds Rev 4, if you can trough them in the new Thermal batch :p
Offline odd
« Reply #215 on: Sat, 20 April 2019, 05:18:11 »
I hope I don't miss this. I told myself "no more 60's" but this is too awesome to pass up.
Offline nostr
« Reply #216 on: Thu, 25 April 2019, 06:54:47 »
With the Project now going under RAMA instead of Zeal, will Zeal PCB's still work on the case?
Offline futurecrime
  • Get Zooted
« Reply #217 on: Thu, 25 April 2019, 10:02:13 »
Really lovely design Wilba. Can't wait to see this one in the wild.
Offline fireworm
« Reply #218 on: Thu, 25 April 2019, 13:02:16 »
... What's up with the leaf spring mount?
« Reply #219 on: Thu, 25 April 2019, 22:13:52 »
more info to come when the proto arrives
Offline Yonben
« Reply #220 on: Sun, 28 April 2019, 07:55:19 »
It looks very good, hopefully it will be at an affordable price :)
Offline lolafineday
« Reply #221 on: Sun, 28 April 2019, 07:57:40 »
My guess but I see it being around 500-600$
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #222 on: Sun, 28 April 2019, 08:25:04 »
LOL. No.
Offline lolafineday
« Reply #223 on: Sun, 28 April 2019, 12:09:45 »
LOL. No.
Oh god
Offline snelltrail
« Reply #224 on: Sun, 28 April 2019, 17:03:05 »
LOL. No.
Oh god
I think Zambumon was saying that it’ll be less than that, not more. I seem to remember Wilba saying somewhere that it would be less than the Xeno, which was 420. But that might be a bit different since it’s being produced by Rama now.
Offline frankh
« Reply #225 on: Mon, 29 April 2019, 04:20:07 »
We're not getting any blue case options, I get that. I still wonder how Striker (which I already bought) would look on - say - the red case. Zambumon? It might look "off" or it might look dope. I'm lacking the imagination for it.
Offline Zambumon
    • Keyset projects
« Reply #226 on: Mon, 29 April 2019, 04:48:49 »
My recommendation for Striker is to use the silver case with a red plate, that would be similar to what the second type of jerseys they had.
There are some renders of Striker with that color combination on the GB threas
Offline frankh
« Reply #227 on: Mon, 29 April 2019, 05:08:25 »
Offline nguyenhimself
« Reply #228 on: Mon, 29 April 2019, 08:08:40 »
LOL. No.
Oh god
Please no fancy packaging.
I:m sure YouTubers love that for their flexing videos, but man I really hate having to pay extra for, on top of an already costly kit, something that I'll only look at once & probably never again.
At least a TX bag is a thing you can keep using.
« Last Edit: Mon, 29 April 2019, 08:10:49 by nguyenhimself »
Offline Vigrith
« Reply #229 on: Mon, 29 April 2019, 08:45:26 »
Your opinion is entirely valid and I understand why/agree that the argument should be at least brought up, but I know for a fact a lot of people (not youtubers) feel very differently. Many have stated the m60 is the most fun they've had unboxing a board and whilst that's something that you only do once per purchase, it's still a relatively important process (especially for those who buy often). Additionally, neither of the keyboards Rama's ran thus far have really been super expensive, $350 for the M60 (which sold a huge number of units) was a really good price for what you got and I think that if anything the packaging offer adds to that rather than taking away from it.
« Last Edit: Mon, 29 April 2019, 09:57:51 by Vigrith »
Offline gotemall
« Reply #230 on: Wed, 08 May 2019, 17:17:15 »
ne hotswap avail?
If you used an M60-A PCB ;D
I actually have an m60-a pcb on order, are you confirming that it will work with this board?
Also, ANY Chance of you adding some extra colors for the Plate? Seems like availability of other colors (perhaps a Blue, Green,rose gold) would have been awesome with this board, as this would have allowed pairing with various sets of all colors, since the plate color stands out so much.
Offline mlnr
« Reply #231 on: Thu, 09 May 2019, 11:24:42 »
Who do I need to fellate to get a pre-anodized plate as an option?
Offline regionfree
« Reply #232 on: Thu, 09 May 2019, 11:33:03 »
I admire your dedication
Offline Zambumon
    • Keyset projects
« Reply #233 on: Sun, 12 May 2019, 05:03:03 »
Based on the OP, I think Wilba wants to limit the colors to red/silver/black and have red as the main theme for this batch of keyboards.
Offline orangesoh
« Reply #234 on: Sun, 12 May 2019, 09:21:27 »
Can't wait. When is the group buy, it says May... is it gonna be soon?
Offline pixelpusher
« Reply #235 on: Tue, 21 May 2019, 23:53:09 »
Hey, Mr. Render man.... Could you do a Honeywell set on a Silver case with red and also gray plate.  Thanks  :thumb:
Offline infinitykw
  • Amazed by the beauty of industrial design
    • zFrontier Profile
« Reply #236 on: Wed, 22 May 2019, 00:23:40 »
Is there an estimated date for GB?  Only a week left for May.  Thanks!
Offline Pwner
  • soon™
« Reply #237 on: Wed, 22 May 2019, 08:26:58 »
ne crispy chicken avail?
Offline Wilba
    • wilba.tech
« Reply #238 on: Wed, 22 May 2019, 09:51:35 »
please reconsider ION keyboards
Offline Freakenstein
« Reply #239 on: Sat, 25 May 2019, 12:15:13 »
"Pre-order launch date: May"
It's May 26th now
Offline Zambumon
    • Keyset projects
« Reply #240 on: Sat, 25 May 2019, 12:19:38 »
It's May 26th now
Better have a delayed order window than a delayed keyboard.
Offline nasp
« Reply #241 on: Sat, 25 May 2019, 12:48:22 »
So how did the leaf spring mount TM mechanism work out? Any details on it?
Any actual prototype images?
Offline Vigrith
« Reply #242 on: Sat, 25 May 2019, 14:02:10 »
It's May 26th now
Offline Xynerorias
  • Lubin' with glicerin
« Reply #243 on: Sat, 25 May 2019, 14:58:14 »
It's May 26th now
my man
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #244 on: Sat, 25 May 2019, 16:28:04 »
Interested based on cost.
Offline Gabbzan
« Reply #245 on: Sat, 25 May 2019, 17:09:01 »
kinda looks like heatsinks on the sides, pretty cool
Offline Zambumon
    • Keyset projects
« Reply #246 on: Sun, 26 May 2019, 04:32:27 »
That's the idea.
Offline nathanchere
« Reply #247 on: Mon, 27 May 2019, 04:22:45 »
Is there any chance this would be offered unfinished if we don't like the 4 colour choices and want to get it cerakoted locally?
Offline Wilba
    • wilba.tech
« Reply #248 on: Mon, 27 May 2019, 05:19:26 »
No... this would just add complexity to the manufacturing and fulfilment. Thermal will be produced by Foundry using Rama Works manufacturing with the same expectation of quality and presentation. Shipping raw, unfinished cases is not congruent to their style. Even if it was, anodization protects the surface, and manufacturers prefer not to ship unanodized parts. Whoever does the cerakote will know what to do with an anodized aluminium case.
Offline hyppialonso
« Reply #249 on: Mon, 27 May 2019, 10:16:13 »
Hope it would be an affordable price!
