Author Topic: [IC] wilba.tech Thermal - PREORDER NOW  (Read 121177 times)
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
Re: [IC] wilba.tech Thermal
« Reply #250 on: Wed, 29 May 2019, 09:18:26 »
I'm in, would also be looking to get/make an ISO plate.
Offline Xynerorias
  • Lubin' with glicerin
« Reply #251 on: Sun, 02 June 2019, 07:55:52 »
https://r.works/thermal
"Launching in May. Details to follow"
Welp...
But jokes aside, where are we on this ?
Offline regionfree
« Reply #252 on: Sun, 02 June 2019, 08:36:49 »
Welp...
i have a feeling it will get delayed, so as not to take a bite out of the initial rush for the U80. even if they're different form factors, they will be fighting for the same budget.
Offline crd
  • Discord: crd#7617
« Reply #253 on: Sun, 02 June 2019, 08:37:43 »
Last I heard, there are still some RAMA projects in the queue taking priority over the Thermal prototype. I have seen some very hype shots of the Thermal PCB so that’s moving along.
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #254 on: Sun, 02 June 2019, 09:00:19 »
Production samples of cases should be finished soon. Like, this week maybe soon. As I have joked on Discord, the manufacturers are too busy cranking out M60-A right now to task switch. My mum always told me, good things come to those who wait.
Production samples of PCB were delivered. The colors and artwork are perfect, but something is missing. Fab did an oopsie. If you can spot it, you win a prize. No "missing ISO" jokes, please.
Offline TuCZnak
« Reply #255 on: Sun, 02 June 2019, 09:21:04 »
There ain't no copper on those holes
Edit: or is it that the left holes in top row aren't connected? Dunno if they don't have traces on the other side though
« Last Edit: Sun, 02 June 2019, 09:31:27 by TuCZnak »
Offline Wilba
    • wilba.tech
« Reply #256 on: Sun, 02 June 2019, 09:40:40 »
No. Pads are plated with silver.
Offline Zambumon
  • discord.zambumon.com
    • Keyset projects
« Reply #257 on: Sun, 02 June 2019, 09:52:06 »
No gasket mount?
Offline Hadi
  • Formerly eqtri
« Reply #258 on: Sun, 02 June 2019, 10:27:30 »
Is one of the columns missing a via connecting it to a switch?
220317-0
EDIT: Looks like a couple of the column vias are missing. Were they too close to the pad or something?
« Last Edit: Sun, 02 June 2019, 10:38:59 by Hadi »
Offline fireworm
« Reply #259 on: Sun, 02 June 2019, 10:36:22 »
Installed the leds upside down?
Mirrored the mx switch holes?
Edit: Hmmm.... Nope....
« Last Edit: Sun, 02 June 2019, 10:43:54 by fireworm »
Offline Wilba
    • wilba.tech
« Reply #260 on: Sun, 02 June 2019, 10:53:26 »
Column tracks top side go through the pads, or sometimes through a via near the pad.
Offline Zambumon
    • Keyset projects
« Reply #261 on: Sun, 02 June 2019, 10:55:20 »
What could be the mistake? Isn't that Wilba's hand?
Offline fireworm
« Reply #262 on: Sun, 02 June 2019, 11:00:16 »
Diodes soldered upside down?
Offline Wilba
    • wilba.tech
« Reply #263 on: Sun, 02 June 2019, 11:01:47 »
No.
This is what it should look like:
Offline Hadi
  • Formerly eqtri
« Reply #264 on: Sun, 02 June 2019, 11:11:16 »
No.
Oh, the border is missing, right?
Offline Wilba
    • wilba.tech
« Reply #265 on: Sun, 02 June 2019, 11:13:47 »
No.
Yep :D
Offline Hadi
  • Formerly eqtri
« Reply #266 on: Sun, 02 June 2019, 11:20:25 »
No.
Yep :D
Amazing! Looks like they got the right effect on the stabilizer holes but completely disregarded it for the border.
Offline Zambumon
    • Keyset projects
« Reply #267 on: Sun, 02 June 2019, 11:22:09 »
No relief cuts?
Offline Wilba
    • wilba.tech
« Reply #268 on: Sun, 02 June 2019, 11:26:50 »
No relief cuts?
Do I look Korean to you?
Offline flippanteer
« Reply #269 on: Sun, 02 June 2019, 12:36:04 »
Current boards: FLX Virgo w/ NK Drys, E8.5 w/ NK Drys, LZ Physix w/ H1s,  Moon TKL w/ MX Zilents, HAD66 [Alice layout] w/ NK Creams, KBD75v1 w/ Zealios 67g v1
Purchased boards: Infinitum
Past boards: Trinity w/ Tealios v2, Lubrigante w/ Holy YOK Trash Pandas, Kumo w/ Novelkeys Cream, Diverge 2 w/ MX Browns, Planck w/ MOD-H, Anne Pro w/ MX Blue
Offline Zambumon
    • Keyset projects
Offline Hadi
  • Formerly eqtri
« Reply #271 on: Sun, 02 June 2019, 15:14:13 »
 Out of curiosity, what was the prize for guessing?
Offline Zambumon
    • Keyset projects
« Reply #272 on: Sun, 02 June 2019, 17:23:31 »
Internet points.
Offline Xynerorias
« Reply #273 on: Sun, 02 June 2019, 17:25:09 »
Internet points.
Hey it's not reddit
Sent from my ONE A2001 using Tapatalk
Offline Wilba
    • wilba.tech
« Reply #274 on: Sun, 02 June 2019, 21:10:21 »
A limited edition Rama Works X wilba.tech keycap  :p
Offline Hadi
  • Formerly eqtri
« Reply #275 on: Sun, 02 June 2019, 23:48:25 »
Oh hey, that's exciting! Thanks a ton to both of you.
Offline TuCZnak
« Reply #276 on: Mon, 03 June 2019, 10:53:32 »
Really? That's interesting, haven't seen that anywhere else. Are you not worried about corrosion?
Offline Freakenstein
« Reply #277 on: Mon, 03 June 2019, 14:19:39 »
Is there a new time line?When will the GB start
Just can't wait so many expectations
Offline Wilba
    • wilba.tech
« Reply #278 on: Mon, 03 June 2019, 21:07:36 »
No... Immersion Silver is an alternative to Electroless Nickel/Immersion Gold (ENIG) with the same kind of properties.
Offline EMC Labs
« Reply #279 on: Sun, 16 June 2019, 20:45:04 »
Interested if sub $350.
Offline taylortdhouse
« Reply #280 on: Mon, 17 June 2019, 03:54:02 »
Made an account to reply to this.  Rama already said it will be cheaper than the newly released U80 on Instagram in a comment I asked a couple weeks ago.  So expect sub $320 at the very least.
Offline ptiede
« Reply #281 on: Mon, 17 June 2019, 08:01:08 »
The u-80 is $420 though.
« Reply #282 on: Sat, 22 June 2019, 02:26:11 »
... you are correct, I don't know how I forgot that already.  I guess for some reason in my head I thought the U80 was around $350.  My bad
Offline Xynerorias
« Reply #283 on: Tue, 25 June 2019, 08:00:41 »
Any news? Is this still coming in June?
Offline hottrout
  • I'd Hit Dat Key
« Reply #284 on: Tue, 25 June 2019, 08:12:51 »
Can I just ask again if there is any way this will have a ISO option?
Also I would part with big money to see this design in a 100% layout or even a 75%.  100%, loose the top row but keep navigation and pgup/pgdw and numpad.  Would look extra wide and very cool.
« Last Edit: Tue, 25 June 2019, 08:34:10 by hottrout »
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Wilba
    • wilba.tech
« Reply #285 on: Tue, 25 June 2019, 09:04:19 »
Prototypes were received and built. I am in the process of evaluating the prototypes and making some small tweaks. We will take some good photos soon. June launch is not possible, now... some things need to be sorted out which will take more than four days.
Offline Pwner
  • soon™
« Reply #286 on: Tue, 25 June 2019, 09:05:21 »
It will take a little effort but it will be possible.  The plate file will be available and the case is designed to allow other pcbs, you would just need to wire the daughterboard up.
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #287 on: Tue, 25 June 2019, 09:40:17 »
Sounds doable! I think this is what I'll end up doing. Think Wilba and co. have knocked it out of the park on this one. Totally getting that brutalist vibe off it.
Curious, what's the daughterboard for? Integrated USB-C?
Offline Wilba
    • wilba.tech
« Reply #288 on: Tue, 25 June 2019, 10:00:27 »
Zeal60 rev 4 is Thermal compatible and has ISO support.
Mekanisk is running WT60-D MEKANISK now, which has ISO support.
https://mekanisk.co/collections/fjell-classic/products/unannounced-product
It is also 60% tray compatible.
Note: when I say compatible, it means you have to solder a JST connector to the PCB so you can connect the daughterboard USB-C, the on-board USB-C on those PCBs is not used in Thermal. I can add this connector to Thermal orders.
Offline hottrout
  • I'd Hit Dat Key
« Reply #289 on: Wed, 26 June 2019, 04:41:12 »
This is excellent news.  Please add to the orders for sure.  I am going in on this one.  I would still love to see a 100% KB render using this design.  The proportions would make it look really cool.
Systems -
  Keyboards -
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #290 on: Wed, 26 June 2019, 06:24:33 »
Yes you can start the GB now 👍 😁
221773-0
Beautiful PCB mate
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #291 on: Wed, 26 June 2019, 06:53:47 »
Beautiful PCB mate
Seems quite an elegant PCB, I'm def gonna pick one up if I go for this board. Shows you can do ISO/ANSI in a PCB properly and still have per-key RGB for those that want that!
Offline Xynerorias
« Reply #292 on: Thu, 27 June 2019, 14:52:42 »
Hey I was so hyped about this board I forgot about the PCB. It says it's solderable, but does it mean it's hotswap but you can also solder it or just plain solder type pcb?
Offline Yeoh
« Reply #293 on: Thu, 27 June 2019, 17:58:34 »
Solderable probably means solderable.
If it was hotswap, it would say hotswap.
One or the other, cant have both.
Offline Xynerorias
« Reply #294 on: Thu, 27 June 2019, 18:15:30 »
Yea that's what I thought, just wanted confirmation, it seemed weird even to me to have a pcb that's both hotswap and regular. I dunno, it was the "able" in solderable that kinda bugged me for some reason, for me it's either a regular pcb or a hotswap one (what I mean is I never use the term/word solderable for a pcb, that's why I found it weird for some reason).
Offline Xynerorias
« Reply #295 on: Wed, 17 July 2019, 08:11:52 »
How we looking now chief? Are the protos good? You got some pictures for us?
Offline Wilba
    • wilba.tech
« Reply #296 on: Wed, 17 July 2019, 08:19:40 »
Prototypes are good. Leaf spring mount works. We are getting things ready for a pre-order launch ASAP.
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
« Reply #297 on: Wed, 17 July 2019, 08:21:22 »
Exciting! Will keep a wilba shaped space in bank account next month then…
Offline Wilba
    • wilba.tech
« Reply #298 on: Wed, 17 July 2019, 10:25:56 »
Wilba is vaguely shaped like the Loch Ness Monster.
Offline elpepe21
« Reply #299 on: Wed, 17 July 2019, 10:45:09 »
three fiddy
