Author Topic: [IC] Melody65 - Product Page LIVE! Sales Start 26th of Oct at 10AM EST  (Read 296759 times)
Offline BahaMech
  • Contact Me on Discord - dionsalekian#8349
Re: [IC] Melody65 Update
« Reply #100 on: Wed, 11 March 2020, 05:23:05 »
will there be an option for an alu bottom or is it only acrylic?
Acrylic bottom, with a founders edition full brass bottom (very limited quantities)
Offline Twigler
« Reply #101 on: Sun, 29 March 2020, 23:27:35 »
Is a full polycarbonate/acrylic case happening for this? Would love one
Offline Vaudevi77ain
« Reply #102 on: Mon, 30 March 2020, 00:36:05 »
Following. Would love to see pink/rose gold options for the case!
Offline doralikesmath
« Reply #103 on: Mon, 30 March 2020, 12:50:13 »
Looking to see  new renders. Following.
Offline BahaMech
« Reply #104 on: Mon, 30 March 2020, 23:20:19 »
Most likely
Offline BahaMech
« Reply #105 on: Mon, 30 March 2020, 23:21:29 »
We have already decided on the colours and unfortunately, there will be no pink. There will be E white, black, gray silver, and a dark purple
Offline BahaMech
« Reply #106 on: Mon, 30 March 2020, 23:22:47 »
The case and PCB had finished being made few days ago, and now we are waiting for Wei (KBDfans) to receive it so we can get some photos.
Offline FluffyUnicronz
« Reply #107 on: Tue, 31 March 2020, 19:59:39 »
Glad to hear everything still progressing! I've been checking daily for info on this board.
Offline BahaMech
« Reply #108 on: Wed, 01 April 2020, 05:34:35 »
I'm genuinely sorry about the wait, I've also been eagerly waiting for the sample too. But I'm afraid the delay is out of mine and KBDfans' hands, due to the current situation with the coronavirus.
Offline 28.8kbps
« Reply #109 on: Wed, 01 April 2020, 07:10:38 »
I signed up just to show my interest!
Offline BahaMech
Re: [IC] Melody65 Update (PCB sample finished)
« Reply #110 on: Sun, 12 April 2020, 08:27:01 »
bump
(update in original post)
Offline Tobiplayer3
« Reply #111 on: Sun, 12 April 2020, 10:07:17 »
I am also interested!
Will there be a hotswap version for ISO layout?
« Last Edit: Sun, 12 April 2020, 10:08:51 by Tobiplayer3 »
Offline BahaMech
« Reply #112 on: Sun, 12 April 2020, 22:01:48 »
Unfortunately hotswap ISO will not be happening, as we would have to make a new PCB and the MOQ will definitely not be met.
Sorry
Offline BahaMech
Re: [IC] Melody65 Update (Final sample progress photos)
« Reply #113 on: Fri, 24 April 2020, 08:00:29 »
bump
Offline CrazyAssMonkey
« Reply #114 on: Fri, 24 April 2020, 08:06:41 »
Looking good, how much is the weight of the board? I am assuming the brass bottom adds a considerable amount of heft.
Offline BahaMech
« Reply #115 on: Fri, 24 April 2020, 08:16:34 »
About the brass bottom, its going to be in very limited quantities (only a few of them). And it adds about 4kg to the case
« Reply #116 on: Fri, 24 April 2020, 08:34:02 »
O_o 4kg? 4kg??????????????
Jeeeeez how would one go about getting that tank?
Offline BahaMech
« Reply #117 on: Fri, 24 April 2020, 08:41:11 »
Brass bottom case is going to be around $100 USD extra. I am not 100% sure as it is going to be very very limited, so it might cost more than that.
« Reply #118 on: Fri, 24 April 2020, 08:50:31 »
Hmmmmm.... I am considering it but we shall see. I'll have to beat back the competition with a broom or something.
Offline BMLN
« Reply #119 on: Fri, 24 April 2020, 10:27:21 »
Sorry
Would Underglow and backlight ISO be possible with soldering? Whole kit would be perfect for me then
also, yes pls  ;D
« Last Edit: Fri, 24 April 2020, 10:29:49 by BMLN »
Offline BahaMech
« Reply #120 on: Fri, 24 April 2020, 20:35:56 »
Sorry
also, yes pls  ;D
Something i forgot to add was that hot-swap with underglow is not possible for us. But ISO and underglow is possible (non-hotswap PCB), but there will be no per-key RGB SMD's however, you would have the ability to add your own 2 pin LED's
Offline baobaozi
« Reply #121 on: Sat, 25 April 2020, 03:15:53 »
Keen!
Offline zakatak
  • no cash
« Reply #122 on: Sat, 25 April 2020, 07:09:41 »
Is the logo for the engraving finalized?
Sent from my POCOPHONE F1 using Tapatalk
Offline BahaMech
« Reply #123 on: Sat, 25 April 2020, 08:42:20 »
Yep this was our final logo. People didnt really like our first one, so we wanted to do something more subtle
Offline Roddin
« Reply #124 on: Sat, 25 April 2020, 09:20:14 »
looks gorgeous. definitely has my vote.
Offline MMMike
« Reply #125 on: Sat, 25 April 2020, 11:18:10 »
Soo, take my money? Who's gonna handle the GB/order?
Offline BahaMech
« Reply #126 on: Sat, 25 April 2020, 20:42:42 »
KBDfans is going to handle the orders, manufacturing, and sending the items out
Offline Fertan
« Reply #127 on: Sun, 26 April 2020, 12:37:26 »
Hi !
I'm considering my first DIY keyboard and and i'm very interested in the melody65 but I'm a fully noob. I would like an iso french layout, is it possible with this kit ? I saw in this thread that the hotswappable option is not possible for an iso layout, does it means i have to solder the switches on it ? Also about the led's mounting (on switches and underglow) if someone could explain me how to it or indicate a thread that explain it for a very similar product it could be great.
With experience of the first melody productions, how much time between order and delivery should I expect ?
Offline baobaozi
« Reply #128 on: Sun, 26 April 2020, 17:02:44 »
Sorry
also, yes pls  ;D
So to confirm, hot swap is no underglow, but is per-key RGB?
Non-hot swap is underglow, but no per-key RGB, but you can add it yourself?
Does this apply to ANSI as well? Or only ISO?
« Last Edit: Sun, 26 April 2020, 17:15:45 by baobaozi »
Offline dzbro
« Reply #129 on: Sun, 26 April 2020, 17:59:13 »
Definitely want in on this.
Offline KaosJ
« Reply #130 on: Sun, 26 April 2020, 18:25:27 »
Wei said is around 5kg the FE (brass bottom, alu top). As far as i remember i quoted 4-4.5kg months ago so the 5kg of wei might be actually true  :eek:
The bottom is thicc af and the angle of 7 helps to make it heavy
« Last Edit: Sun, 26 April 2020, 18:27:36 by KaosJ »
Offline BahaMech
« Reply #131 on: Sun, 26 April 2020, 20:15:32 »
Sorry
also, yes pls  ;D
1. Yes, hotswap will not have underglow, but will have per key RGB
2. Non hotswap has underglow, but no per key RGB. You cant add RGB yourself but you can add static LED's, such as white, green, blue etc.
Hope that helps.
Offline BahaMech
« Reply #132 on: Sun, 26 April 2020, 20:36:50 »
Hi !
1. Yes you will have to solder the switches in if you want to have an ISO layout.
2. If your talking about the 2 pin LED's i was talking about earlier, You can find them here (https://kono.store/products/1-8mm-keyboard-leds-100-pack), and if you want to know how to do it, i'd recommend you watch this video (https://www.youtube.com/watch?v=oQj9y16OmlE) by TaeKeyboards.
I will get back to you soon with answers about your layout and expected delivery.
Hope that helps   :)
Offline scrps
« Reply #133 on: Sun, 26 April 2020, 21:02:09 »
well there goes the money i was saving for a pc
Offline Fertan
« Reply #134 on: Mon, 27 April 2020, 00:32:46 »
Hi !
Hope that helps   :)
Din't mind about the layout, I will go with ANSI, way easier to catch keycaps for this layout and I really want the hotswap' feature.
Offline BahaMech
« Reply #135 on: Mon, 27 April 2020, 00:56:41 »
Hi !
Hope that helps   :)
As i've said earlier, if you want hot-swap you're going to unfortunately miss out on underglow
Offline Fertan
« Reply #136 on: Mon, 27 April 2020, 01:37:35 »
Yep.
Offline Fertan
« Reply #137 on: Wed, 29 April 2020, 09:43:58 »
Hi ! Me again :)
I did'nt found any render/sample with the colors available for the kit, am I missing something ? Sorry if it's a dumb question :)
Offline BahaMech
« Reply #138 on: Wed, 29 April 2020, 19:16:27 »
Hi ! Me again :)
No, not a dumb question at all. There are no renders including each colour available for the case, because the colours are going to be the same ones as KBDfans uses and we do not have the exact colour codes. So if your interested, you could go onto the KBDfans website and look at some of their cases and you will see the colours (Black, e-white, gray, silver and purple).
I hope that helps
« Last Edit: Wed, 29 April 2020, 19:42:48 by idontwanttoshowmyname »
Offline Fertan
« Reply #139 on: Thu, 30 April 2020, 02:35:33 »
Thansk for your answer. I have an other one, is it possible to add underglow to the hotswap (ainsi layout) following this guide : https://gist.github.com/tusing/b9e58480d67a9f3e5932ba27096643c6
This is the last "noobish" question I have i promise.
Offline BahaMech
« Reply #140 on: Thu, 30 April 2020, 03:21:09 »
Sorry but im not 100% sure. But as i've said before, we wont be able to do a hotswap ansi layout.
Offline Fertan
« Reply #141 on: Thu, 30 April 2020, 04:34:06 »
Ok !
Offline Xdoc6
« Reply #142 on: Fri, 01 May 2020, 08:29:37 »
Any ideas on when kbd will announce details? Can’t find much on their discord and nothing on the website. Really want one of the fe full brass bottoms.
Offline BahaMech
« Reply #143 on: Fri, 01 May 2020, 21:10:59 »
Most of China is on holiday until the 5th of May. But they have told me that the brass sample's will be ready some time in may. So once they are ready we will be very close to starting a group buy page on their site.
Offline Oni74
« Reply #144 on: Fri, 01 May 2020, 23:11:40 »
I'm happy to see 65 percent version of this great design. I'm not sure if it has been asked already - will the PCB have ESD protection?
Sent from my ONEPLUS A6013 using Tapatalk
Offline BahaMech
« Reply #145 on: Sat, 02 May 2020, 01:30:44 »
Yep, the PCB has ESD protection
Offline baobaozi
« Reply #146 on: Wed, 06 May 2020, 08:42:15 »
any idea about how many are up for grabs?
Offline BahaMech
« Reply #147 on: Thu, 07 May 2020, 19:34:26 »
We arent sure yet. but it is going to be a limited number per colour option.
But overall there will be roughly 100 up for grabs.
« Last Edit: Fri, 07 August 2020, 22:51:33 by BahaMech »
Offline dzbro
« Reply #148 on: Thu, 07 May 2020, 19:42:03 »
I am soooooooooooooooooo juiced for this to go live.
Offline CrlaoSvloadr
« Reply #149 on: Thu, 07 May 2020, 23:45:33 »
Loving this! Definitely jumping on board after enjoying my 96 so much.
Just a quick question, the brass housing for the case isn't the same shape as the acrylic bottom?
I really did enjoy the multiple layers from the 96, and i'm glad to see it in the acrylic version of the 65! Sadly i'd definitely prefer a full aluminum housing with the same characteristics.
