Author Topic: [IC] Melody65 - Product Page LIVE! Sales Start 26th of Oct at 10AM EST  (Read 296763 times)
Offline BahaMech
  • Contact Me on Discord - dionsalekian#8349
Re: [IC] Melody65 Update (Final sample progress photos)
« Reply #150 on: Fri, 08 May 2020, 00:47:53 »
Loving this! Definitely jumping on board after enjoying my 96 so much.
Just a quick question, the brass housing for the case isn't the same shape as the acrylic bottom?
I really did enjoy the multiple layers from the 96, and i'm glad to see it in the acrylic version of the 65! Sadly i'd definitely prefer a full aluminum housing with the same characteristics.
Yeah, so the brass bottom is slightly different in desgin and is more simple. We are considering doing an aluminium bottom option using the same design as the acrylic one.
Offline KaosJ
« Reply #151 on: Mon, 11 May 2020, 04:05:08 »
Yes different bottom.
The brass one is flat with the top, example here: https://i.imgur.com/oA3HCjB.jpg
The Standard one is "angled" on the edges (similar to melody96 edges), example here: https://i.imgur.com/4LYaONu.jpg
Offline cohesive_glue
« Reply #152 on: Tue, 12 May 2020, 21:13:38 »
Nice looking case. Excited for it!
Offline baobaozi
« Reply #153 on: Thu, 14 May 2020, 07:11:49 »
Any updates by any chance?  ;D
Also, will there be extra PCBs available when it goes up?
Offline BahaMech
« Reply #154 on: Fri, 15 May 2020, 23:26:10 »
The brass pieces have been sent over to the factory to get finished off.
And extra PCB's can be available, we will decide these kinds of details once we are almost ready to create a GB page.
Offline BahaMech
Re: [IC] Melody65 Update (Final sample progress photos) + New Google Form
« Reply #155 on: Mon, 18 May 2020, 04:29:40 »
Bump.
New update and google form is at the bottom of the original post.
Offline baysic
« Reply #156 on: Thu, 21 May 2020, 22:52:04 »
Will it have VIA firmware support as well?
This is off topic but will there be any per key RGB update to Melody96 boards soon?
Offline NathanCVII
  • Weeb I am
« Reply #157 on: Sat, 23 May 2020, 03:41:02 »
Oooof, my wallet. Is this case also by YMDK like the Melody96? Or is it a separate project jkaos92 is involved in? Just curious.
« Last Edit: Sun, 24 May 2020, 06:05:11 by NathanCVII »
Offline BahaMech
« Reply #158 on: Mon, 25 May 2020, 03:30:36 »
Sorry for the late reply, but at the moment the PCB does not support VIA firmware. There is still a chance we can add it for the final PCB though.
And I'm not sure about the update to the Melody96. Jkao would have to answer that one
Offline BahaMech
« Reply #159 on: Mon, 25 May 2020, 03:32:01 »
This is a separate project with Jkaos and I.
All the designing was done by Jkaos as he knew how the melody96 was designed
Offline KaosJ
« Reply #160 on: Mon, 25 May 2020, 18:24:23 »
Yeah I did the keyboard, basically Dion asked me to reproduce and evolve the melody96 design into a 65% keeb (making the design more advanced while trying to keep it affordable)
Dion is the OP/GB leader, the guy who organized the whole thing. Regarding the producer, it will be KBDfans, not YMDK.
Offline Waff3less
« Reply #161 on: Mon, 25 May 2020, 19:08:40 »
broke but gonna definitley try to cram some money together for this
Offline Keyjus
« Reply #162 on: Wed, 03 June 2020, 17:22:46 »
Some pics with some keycaps eould be nice!
Offline BahaMech
« Reply #163 on: Wed, 03 June 2020, 19:40:51 »
We will definitely update the pictures when the brass samples done. It's just taking a while to process due to the high surface area of the brass bottom
« Last Edit: Wed, 03 June 2020, 19:44:07 by BahaMech »
Offline ecbob
« Reply #164 on: Thu, 11 June 2020, 01:14:44 »
Do you have any straight bird's eye view photos? Also is this unlimited or limited GB?
Offline Sabin
« Reply #165 on: Thu, 11 June 2020, 08:59:15 »
This looks very nice. I can't believe it's been on going for well over a year. Good luck and hope the process goes smoothly. I would definitely like to get a hot swap version with brass bottom.
Offline konstantin
  • Formerly constexpr
« Reply #166 on: Thu, 11 June 2020, 18:01:42 »
Adding VIA support to existing AVR-based boards is quite straightforward. I'll be contributing VIA support for Melody96 soon.
As for the new PCB, you don't need to do anything special other than support QMK if it's AVR-based.
« Last Edit: Thu, 11 June 2020, 18:05:34 by konstantin »
Offline BahaMech
« Reply #167 on: Fri, 12 June 2020, 23:31:42 »
There will be photos soon, but we've had some issues with processing the brass that have delayed the photos.
And the GB is going to be limited (every colour is going to have a limit)
Offline NathanCVII
  • Weeb I am
« Reply #168 on: Fri, 12 June 2020, 23:57:08 »
Is the brass bottom still going to be in limited quantities? If so, how many will be available?
Offline BahaMech
« Reply #169 on: Fri, 12 June 2020, 23:58:51 »
Yes its going to be limited to about 10-20. We haven't exactly decided yet
Offline ecbob
« Reply #170 on: Sat, 13 June 2020, 13:35:36 »
How many units for each color? (not brass)
Offline sedxr
« Reply #171 on: Sat, 13 June 2020, 17:33:00 »
Any updates?
Offline BahaMech
« Reply #172 on: Sun, 14 June 2020, 00:55:55 »
Any updates?
IMPORTANT
Wei (KBDfans), is getting a quote from a new factory for sandblasting the brass. Because we weren't happy with the brass.
And we are making another PCB sample which will support a 7U layout, and hopefully support VIA too.
Im genuinely sorry about the delay, I would love to get this GB up and running as soon as possible, but we want to make sure everything is perfect before the final production.
« Last Edit: Sun, 14 June 2020, 01:03:03 by BahaMech »
Offline BahaMech
« Reply #173 on: Sun, 14 June 2020, 00:56:59 »
Around 20 per colour
Offline BahaMech
Re: [IC] Melody65 Update - New Photos (15th June 2020)
« Reply #174 on: Mon, 15 June 2020, 07:55:14 »
Bump (new photos on originial post)
Click the "more" button to expand the post.
Offline Scucka
« Reply #175 on: Mon, 15 June 2020, 08:56:58 »
Is there an expected date for gb?
Offline BahaMech
« Reply #176 on: Mon, 15 June 2020, 18:37:04 »
Not really. But id like to say that it should be up in the next 3 months (we are still sorting out some things).
Offline BahaMech
Re: [IC] Melody65 Update - New Photos + Full Brass Bottom (16th June 2020)
« Reply #177 on: Tue, 16 June 2020, 03:10:16 »
bump. New photos for the brass bottom on the original post
(click the  "more" button to expand the post)
Offline scrps
« Reply #178 on: Wed, 17 June 2020, 08:08:18 »
wooooooahhhhhh that looks sick
Offline baysic
« Reply #179 on: Fri, 19 June 2020, 12:08:23 »
Just found out that the 96 just got VIA support, Great stuff. Thanks for the support.
Looking forward to the 65% and may be 75% in the future? hahaha
Offline Oni74
« Reply #180 on: Fri, 19 June 2020, 14:05:27 »
+1 for a 75% version. I'm done with 65% boards.
Offline KaosJ
« Reply #181 on: Tue, 07 July 2020, 07:45:32 »
A photo from Wei to show the underglow of the Standard version (acrylic bottom) of the keeb
Regarding the Brass-bottom (FE) is still being defined, so we are still not sure about the final coating, just the design is confirmed of it.
There will be also an alu versions and maybe MAYBE maybe a PC version (still thinking about it)
Offline scrps
« Reply #182 on: Tue, 07 July 2020, 14:10:12 »
damnnnnnnnnn
Offline BahaMech
Bump (Update at the bottom of original post)
Update on;
1. More issues
2. PCB Updates
3. An exciting announcement
4. RGB Photos
Offline scrps
Update on;
1. More issues
2. PCB Updates
4. RGB Photos
woah mr taeha types is building the melody65 and via support too. very nice
Offline scrps
any updates?
Offline BahaMech
any updates?
The new samples are still being made, and we are also planning on making new packaging. But the reason for the delay is because Wei (KBDfans) is very busy at the moment.
If you have any other questions feel free to ask.
I will also update the post whenever we have new updates.
Thanks
Offline darthcapn
Exciting. Loooking forward for the gb.. by any chance is it possible to increase the number lol 100 will sell out in under seconds. May be even remove the last s and make it a second.
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline typezero
This is really nice looking. Can't wait a GB to happen.
Offline BahaMech
Yeah, 100 is definitely too low, but we don't want to produce too many. We will definitely increase it to a more reasonable number though.
Offline darthcapn
And if you were to take a rough random aim at the gb month, what would it be? Also, I am scared because kbdfans always has 2k+ people waiting on keyboards those are in IC. This will be gone in under microseconds.
Sent from my SM-G988U using Tapatalk
Offline KaosJ
We need to talk to Wei about this but he isn't answering right now (probably busy), but we think it will be in the 200-500 range.
Offline scrps
pog more of a chance to get it
Offline darthcapn
We got any updates here?
Offline BahaMech
Re: [IC] Melody65 Update - It is Finally Finished! (29th of August 2020)
« Reply #194 on: Fri, 28 August 2020, 22:30:25 »
Bump (update in original post)
Click "more" to expand the post
Offline BahaMech
Just updated it. Check the original post to see whats been happening
Offline bakuretsu
« Reply #196 on: Fri, 28 August 2020, 22:44:51 »
Ooh, Taeha build stream let's go
« Last Edit: Sat, 29 August 2020, 03:12:58 by bakuretsu »
Offline typezero
« Reply #197 on: Sat, 29 August 2020, 03:08:12 »
Can't wait to see Taeha's opinion.
Offline scrps
« Reply #198 on: Thu, 03 September 2020, 14:47:51 »
alright so gb will be after taeha's stream right? do we have an estimated gb time?
Offline guy0naBuffal0
« Reply #199 on: Thu, 03 September 2020, 23:33:21 »
Do we know when it will be on Taeha? I looked today and it is not there, but maybe I mis-read this.
