Author Topic: [GB] JER mini Group Buy (All Shipped)  (Read 89481 times)
Offline 8six753o9
Re: [GB] JER mini Group Buy (All Shipped)
« Reply #150 on: Fri, 02 August 2019, 20:22:50 »
I got mine in today.  I love the yellow but...  :'(
I'm ok with the 2nd damage since I can't see it, but the first one is too visible  :'(
Offline DetectiveNio
« Reply #151 on: Fri, 02 August 2019, 20:29:05 »
Damn that's unfortunate. One of the only four in the world too. If I didn't have my e-yellow tofu. I'd try to trade with my gray with you
Offline moonux
« Reply #152 on: Fri, 02 August 2019, 21:35:23 »
Oh man, that's unfortunate. I hope that can get replaced.
Sent from my SM-G975U1 using Tapatalk
Offline 8six753o9
« Reply #153 on: Fri, 02 August 2019, 22:53:32 »
And the PCB isn't working.  Did anyone else have their PCB and plate stacked on top of each other during shipping?  I'm wondering if that caused an issue with my PCB.  It's being detected but I'm getting "Unknown USB Device (Device Descriptor Request Failed) in Windows.  :'(
« Reply #154 on: Fri, 02 August 2019, 22:59:19 »
Mine were bundled together but I think they were separated by 1 layer of the wrapping parchment IIRC. Mine shows ps2avr something.
If you're getting a failed request, it's most likely one of the diodes or capacitors got knocked off. So check the back of your PCB. I had the same error when I got a PCB from KBDfans and they had to ship me a replacement capacitor
Offline koenoe
    • My YouTube channel
« Reply #155 on: Sat, 03 August 2019, 05:00:44 »
Offline proboy84
« Reply #156 on: Sat, 03 August 2019, 07:57:08 »
Nice Board and table again  :thumb: :thumb:
Offline 8six753o9
« Reply #157 on: Sat, 03 August 2019, 12:55:06 »
Thanks for the feedback. I had something similar with my KBD67 and it looked like my USB port was messed up (pins looked bent and pushed in) so I replaced them with a new USB port and it works. The USB port on this PCB looks fine to me.  I check the capacitor and diodes and they all look intact. The only thing I questioned was these next to the USB port. Is there something that suppose to be there?  It’s on top of the PBC so I thought it’s suppose to be missing.
Offline dimo
« Reply #158 on: Sun, 04 August 2019, 14:08:50 »
I can't for the life of me screw in the plate, screws are not staying into the threads at all
anyone have this issue? I might be doing something wrong
Offline kimper
« Reply #159 on: Mon, 05 August 2019, 10:48:59 »
I am too.
2 of plate screws are not fit at hole.
Offline dimo
« Reply #160 on: Mon, 05 August 2019, 10:52:22 »
built but plate is still INSANELY loose. I can hear the screws popping out of the sockets when I turn it, and the tray just shifts places.
If anyone has a solution do lmk.
« Reply #161 on: Mon, 05 August 2019, 10:59:16 »
I'm getting the same thing for 2 of plate screws. I assume the holes' teeth is stripped.
Offline bthezebra
« Reply #162 on: Mon, 05 August 2019, 11:40:53 »
Haven't built mine yet but this is disheartening to hear hope a solution is provided :/
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #163 on: Mon, 05 August 2019, 16:04:24 »
Bigger screws.
Just big enough to tap your own thread.
Offline dimo
« Reply #164 on: Mon, 05 August 2019, 16:16:15 »
Bigger screws.
and not too big, so that it can make a new hole in the plate.
Offline thornkin
« Reply #165 on: Mon, 05 August 2019, 20:52:40 »
Anyone notice an issue with the plate engraving.  The group is JER PLANeT, right?  Not JER PLANT?
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
« Reply #166 on: Mon, 05 August 2019, 21:24:55 »
No, it's JER Plant. https://i.imgur.com/lv4KOBh.jpg
Sent from my LYA-L29 using Tapatalk
Offline thornkin
« Reply #167 on: Tue, 06 August 2019, 02:12:48 »
Interesting because the top post on this thread says JER Planet twice.  Perhaps they use both?
Laser ALT sporting red Sky Pandas
Offline slxdegrees
  • Nerds With Keebs
« Reply #168 on: Tue, 06 August 2019, 02:21:39 »
Afaik JER PLANT is their official name. Maybe they changed it from planet to plant recently.
« Last Edit: Tue, 06 August 2019, 02:23:21 by slxdegrees »
Offline slxdegrees
  • Nerds With Keebs
« Reply #169 on: Tue, 06 August 2019, 10:25:08 »
Hey guys, with regards to the plate screws not being able to tighten, I believe that the screws provided are too short. Clarified with the runner the exact specification of the screws used and found that it was supposed to be M2x6 instead of the M2x4 that was provided.
Offline MajorKoos
« Reply #170 on: Tue, 06 August 2019, 21:47:17 »
I ran into the same issue with the screw holes.
I tried some longer M2 screws and still didn't find any thread to grab onto in 4 of them.
I suspect issues with tapping those holes.
Other than that it's a great looking keyboard.
(I used the sale + vinegar trick to clean the finger prints off the weight)
223936-0
223938-1
Offline flying1911
    • Mechlovin' Studio
« Reply #171 on: Wed, 07 August 2019, 03:08:34 »
Received my blue one and I have to say I'm neither happy nor disappointed with the color. It's definitely not the sample's color, and I was really excited with the muted teal color shown a couple of comments back. It is more saturated than that, and it's splitting my opinions.  :-X :-X
Jane V2 | Jane CE | Jane V2 CE | Police | Kaze | KMAC 2 | BRG Haus | Sessantacinque | Ori CLS-2 FE | Dalco 959 Mini | Mechlovin' Unikorn | G81-3100 SAV | Model M SSK
Offline ReAvenger
  • Sydney
« Reply #172 on: Wed, 07 August 2019, 07:49:16 »
Not disappointed, just surprised they shipped it with these ano problems
223947-0223949-1
Offline MajorKoos
« Reply #173 on: Wed, 07 August 2019, 08:06:00 »
Yeah, those scuffs are pretty obvious.
So that's 2 of the 6 yellow keyboards (counting the order list) which ended up with major defects :(
I hope there is some sort of remedy available.
Offline nguyenhimself
« Reply #174 on: Wed, 07 August 2019, 10:49:48 »
Yikes.
With obvious defects like that going unnoticed, one has to wonder about their QC process (if any at all).
« Reply #175 on: Wed, 07 August 2019, 11:12:35 »
Yikes.
I think the e-yellow was last minute change so I assume there wasn't any or minimal since they had to rush it out along with the already done colors
Offline MajorKoos
« Reply #176 on: Wed, 07 August 2019, 19:39:07 »
I wasn't happy with Serkia so...
223988-0
Offline 8six753o9
« Reply #177 on: Wed, 07 August 2019, 20:35:44 »
Can anyone share the hex file with me?  I'm getting errors whenever I plug in my PCB and tried to contact Frosty about it.  His last message was to try to get it into bootloader mode which I was able to do, but he never gave me a file to flash.  The lase communication I had with him was back on Sunday so I'm still waiting on him for further instructions.  I thought maybe if I can find someone with a hex file I can try flashing it back to life.
Offline MajorKoos
« Reply #178 on: Wed, 07 August 2019, 21:26:38 »
Here's the latest firmware and a copy of the keymap for just in case.
You should be using Bootmapper Client Ver 0.10.0
Offline 8six753o9
« Reply #179 on: Wed, 07 August 2019, 22:01:22 »
Thank you so much, you're a lifesaver!  My PCB now works and I can finally build this.
Offline noahf
« Reply #180 on: Fri, 09 August 2019, 18:07:40 »
Looks like 3 of my 8 threads are ****ed.
Frosty what solution are you providing for this? Its pretty unacceptable that so many boards have this issue and no solution had been provided or offered.
Offline thornkin
« Reply #181 on: Sat, 10 August 2019, 18:44:58 »
I am about to put mine together. Any tips for the screw situation?
Offline MajorKoos
« Reply #182 on: Sun, 11 August 2019, 07:08:20 »
I just left those holes alone.  The rest seem to do well enough a job.
Offline slxdegrees
  • Nerds With Keebs
« Reply #183 on: Tue, 13 August 2019, 23:07:16 »
Any ideas what size LEDs to use for the indicator lights? Was thinking 1.8mm since the size of the hole cutout is pretty small. Anyone tried putting in the LEDs yet?
Offline dimo
« Reply #184 on: Tue, 13 August 2019, 23:39:11 »
At least like 5-6 of my threads are completely unusable. Some people just got lucky but that is definitely not a solution for everyone.
Offline dimo
« Reply #185 on: Tue, 13 August 2019, 23:39:54 »
« Last Edit: Tue, 13 August 2019, 23:44:45 by dimo »
« Reply #186 on: Tue, 13 August 2019, 23:44:01 »
Front page update:
"The author and EVE Studio apologize for all the imperfections and defects that happens. We will try to solve all the problems and let all users get a satisfield product. If you still have any other problem, please contact the author at 303669158@qq.com for help. In the worst case you still have not idea what to do please get contact with the author and you may send the keyboard to EVE Studio so that we could solve the problem by modification and redoing. Shipping cost is covered by the author and EVE Studio."
Offline dimo
« Reply #187 on: Tue, 13 August 2019, 23:45:20 »
Front page update:
ah thanks. will do
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #188 on: Wed, 14 August 2019, 00:02:10 »
I'm having the same problem others have mentioned. One of my bottom case screws just spins and doesn't latch onto threads.
Offline slxdegrees
  • Nerds With Keebs
« Reply #189 on: Wed, 14 August 2019, 00:14:02 »
Got longer screws and managed to get 7 of 8 screws to catch. With the provided screws I only managed to get 2 or 3 to screw in.
Offline macclack
    • Macclack
« Reply #190 on: Wed, 14 August 2019, 08:06:54 »
Do you mind sharing where you found the screws?
Offline slxdegrees
  • Nerds With Keebs
« Reply #191 on: Wed, 14 August 2019, 08:32:54 »
Just look for M2 x 6mm screws... You should be able to get them at your local hardware store.
Offline moonux
« Reply #192 on: Sat, 17 August 2019, 22:25:15 »
I finished my build a few days ago, decided to try some linear switches I had handy. I uploaded a sound test if anyone is curious:
« Last Edit: Sat, 17 August 2019, 23:18:57 by moonux »
Offline thornkin
« Reply #193 on: Sun, 18 August 2019, 03:30:06 »
This may be a dumb question, but I don't see the answer in the post.  How do I program this keyboard?  The GB listing just says, "General B-series programmable PCB."  What software do I use?
Offline slxdegrees
  • Nerds With Keebs
« Reply #194 on: Sun, 18 August 2019, 03:44:11 »
Bootmapper client
« Last Edit: Sun, 18 August 2019, 03:46:36 by slxdegrees »
Offline thornkin
« Reply #195 on: Sun, 18 August 2019, 03:55:20 »
Thanks for the bootmapper link.  That works great.
Has anyone tried larger screws?  Does that work?  If so, what size screws?  I think I'm lucky and only 2 of mine don't catch, but one is the corner which I'd really like to have tight.
Offline slxdegrees
  • Nerds With Keebs
« Reply #196 on: Sun, 18 August 2019, 05:12:02 »
Not bigger screws, but longer ones. Maybe try 6/7/8 mm ones.
Offline x9Memoriez
« Reply #197 on: Sun, 18 August 2019, 16:11:29 »
Hopefully mine is fine with the longer screws..
Anyone know the exact numbers on the weight of this thing? I haven't got mine in yet, and I don't have a scale.
« Last Edit: Sun, 18 August 2019, 16:21:22 by x9Memoriez »
Matrix 1.2OG | Constellation | Rukia | TMO50 | HHKB
Offline catamscott
« Reply #198 on: Sun, 18 August 2019, 17:07:13 »
unbuilt, mine comes in at 1488 grams (3lbs 4oz).
Offline Subaeru
« Reply #199 on: Wed, 21 August 2019, 20:00:29 »
sad I didn't get into this groupbuy; i might be on the lookout for one on mm lol. What usb connector does it use?
Subaeru 🐇
