Author Topic: [GB] JER mini Group Buy (All Shipped)  (Read 89235 times)
Offline frostylove
« on: Wed, 13 March 2019, 20:42:11 »
CHECK YOUR GB ORDER STATUS HERE
JER MINI screws and weight issues solutions
Problem 1: The JER mini weight has M3.5x6mm holes with thread inserts of M2.5x5mm holes. Removing the weight screws may cause the thread inserts to fall off in sucha a case it could be very hard to reinstall the weight.
Solution: Remove the thread Inserts. Purchase the M3.5x5mm phillips screws and lock the weight with a screwdriver. If you have not take the weight out of the keyboard, please avoid doing so. If you already did it, buy some M3.5x5mm screws in case you have any issue with the weight mounting.
Problem 2: The weight material is sandblasted on the surface of the brass, and the process property makes it easy to stick fingerprints and is not resistant to dirt.
Solution: Please avoid contact with oil. If any surface problem, please wash it with detergent that has good grease resistance, such as washing powder or laundry detergent. Then air-dry or blow-dry the weight after washing. Please do not wipe it after washing.
The author and EVE Studio apologize for all the imperfections and defects that happens. We will try to solve all the problems and let all users get a satisfield product. If you still have any other problem, please contact the author at 303669158@qq.com for help. In the worst case you still have not idea what to do please get contact with the author and you may send the keyboard to EVE Studio so that we could solve the problem by modification and redoing. Shipping cost is covered by the author and EVE Studio.
UPDATE:
07/24/2019 - All JER mini orders are shipped now. Please check the spreadsheet above for tracking number.
07/24/2019 - With 4 yellow samples not achieveing our expecting results, now all yellow boards are getting a free upgrade of Electrophoresis finishing instead of anodizing surface.
03/26/2019 - End of payment. Waiting for production complete
03/22/2019 - All invoiced, collecting payments
03/22/2019 - Invoicing now
03/20/2019 - Group Buy is closed now. Thanks everyone for joining! Invoicing soon
03/17/2019 - Add order details spreadsheet
03/15/2019 - Group Buy launched!
Before the GB details, I want to say THANK YOU ALL for your continued support and love to JER Planet!
JER mini is the 2nd keyboard designed by JER planet team.
Check out our previous here:
JER-A06
Limited edition JER mini Pale white
Finally, GB for the official version JER MINI! This time we have multiple color options for you to choose from. OEM is the same as JER-a06: EVE. As a very mature custom manufacturer from China, their previous works including Moon, MIRA, zero, Atom, Meteor, Kira. JER PLANT has been working with EVE for many years and will present perfect quality works to everyone.
Let's take a look at the protagonist: JER MINI
Currently we only have 3 samples in black, light blue and pink. (Pale White as a limited edition is only for reference here)
Other colors samples would be updated in the post once avaliable. You could change your color option before anodizing, feel free to PM me.
Carved Logo design is ready for color filling. We recommend using acrylic paint.
Color samples and laser engraving of brass counterweight pictures are only for reference. Due to the specificity of anodizing and display problems, there may be chromatic aberration. Everything is subject to the actual product. With years of experience, EVE will try to make the color as accurate as possible.
Specification
  • OEM: EVE
  • Layout: Unique 65% layout
  • Matierial: 6063 Aluminum
  • PCB: General B-series programmable PCB
  • Contents including: New exquisite packaging box, top housing, bottom housing, LED indicator strip, PCB, aluminum plate, gold-plated screws, brass weight.
Group Buy Details
  • GB period: 2019.3.13-2019.3.20
  • Estimate lead time: 4 months
  • JER mini Kit: $339 + Shipping + 5% PP fee
  • JER mini Color options: black, silver, light blue, pink, yellow, gray. All comes with light gray plate.
  • Color plate and additional PCB combo pack: $69, select your plate color from red, black, silver, light blue, pink, yellow, and gray.
  • Shipping: All orders would be shipped by SF express Global. $60 for NA, $75 for EU and Canada, $30 for Korea. For other countries shipping cost would be adjusted accordingly.
« Last Edit: Sat, 10 August 2019, 00:35:24 by frostylove »
Suhr Custom Standard Carve Top
Manson DL-1 Matt Bellamy Signature
Marshall JVM410H + 1960A
Lovepedal Kanji Enternity
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] JER mini Group Buy
« Reply #1 on: Fri, 15 March 2019, 05:12:00 »
Approved, GL w GB
Offline garbo
« Reply #2 on: Fri, 15 March 2019, 05:41:12 »
Cool to see more yellow anodisation. Do you have any samples for it? Looks like it would be a bit more neon/less pastel than Fox Lab's, based on the render.
Offline bthezebra
« Reply #3 on: Fri, 15 March 2019, 05:53:48 »
Very cool to see this board in a more open buy :))
Offline rmendis
  • Artisan addict
« Reply #4 on: Fri, 15 March 2019, 06:43:27 »
Would love to see a sample of the yellow. Will it be more a gold anno color, or flat yellow to match something like GMK Serika? Thanks!
Offline Morgan3Wheeler
« Reply #5 on: Fri, 15 March 2019, 06:57:36 »
Joined!
I can't wait
KMAC Happy red HHKB / KMAC Mini red / KMAC 2 86 / 45-ATS cerakote white / Matrix Noah avocado green / Matrix2.0 WKL yellow / Matrix2.0 WKL red / Matrix2.0 add WKL / Matrix Abel X RX-78 / Matrix Abel X Eva / Matrix1.2 OG WKL purple blue / Percent BOOSTER yellow /  Percent CANOE yellow / Percent Canoe2 casio / Percent SKOG mao / TGR 910 CE pink / TGR Jane CE WKL olive green/ TGR Jane V2 WKL blue gray/ TGR Jane V2 CE WKL / TGR Alice red / Keycult No. 2 Rev. 1 / EXENT65 black / GRAYCOD 67 mao / CA66 e-white / Think6.5 V2 LE / Think6.5 V2 robocop / Think6.5 V2 snow white / SPACE 65 R1 black / Typewriter68 e-white/ E6.5 pc / E7-V1 mao white/ E8.5 WKL e-white/ Voclano660 e-white / Moon by EVE WKL carbon / JER-Mini gray / JER80S NCR WKL geekhack / JER80S NCR WKL Korean / Dolumina65 black / Elephant S7 R2 e-white / Bear 65 ergo e-white, black, blue, pink, PC / Fox key65 e-white / Cyberboard purple / Saturn-60 moondust / Saturn-60 supernova / Infinitum / Rama M65a e-white / Rama Jules navy / Rama Zenith ouro / Rama U80-A Seq2 soya / Primus75 / 7V blue / / Cajal gray / Cajal e-white / SQUARE.X 6ea / Time 80 Reforged WKL e-white / J-01 rev1 Black / J-02 LE Poker e-white / OTD 356 Mini R1 red / LZ-CE red / LZ-CE gray / LZ-CLSms silver/ LZ-PhysiX gray / LZ-SQ SE titan gray / LZ-EX titan gray /  LZ-ST silver / LZ-FE WKL silver/ LZ-CLS WKL silver/ LZ-CLS WKL black / LZ-MP gray / LZ-MX SE titan gray / LZ-CP black-blue / LZ-CP red-red SE / LZ-RV gray / Light Pad silver / Light Pad gray / Octagon V2 gray / Orion V2 WKL silver-red / Orion V2.5 WKL gray / Dol Pad dolch / Dolinger 2017 dolch / Dolinger RE yellow/ Dolinger RE PC / Whale-Fe / Dolphin V3 dolch / Montage PC WKL / F1-8X WKL gray / F1-8X WKL navy / F1-8X WKL burgandy / AL.BOK WKL silver
Offline thearctican
« Reply #6 on: Fri, 15 March 2019, 07:37:43 »
Yeah! Got some hands on with a white one and these are AWESOME.
Offline hayt
« Reply #7 on: Fri, 15 March 2019, 07:40:20 »
Big fan of the A06, this looks like a really nice follow-up! GLWB
Offline BlankeyGotCaps
« Reply #8 on: Fri, 15 March 2019, 08:06:38 »
The Pale White Limited Edition. Where can I get one of them? Would match my setup flawlessly and really Love the way it looks.
Offline Jinnnxxu
  • U only live once
« Reply #9 on: Fri, 15 March 2019, 08:11:49 »
GL! Go Jer!
Ins: Jinnnxxu     Discord:Jinnnxxu#9644
Exclusive: E8V1 | E7V1 x14 | E7-VX | E6V2 x1 | E6V2 PE x7 | E6.5 x9 | E7SE x3 | E8.5 x5
Matrix: 1.0RE | 1.2RE | Abel | Abel+ | Cain | 2.0 x8 | 2.2 x8 | Abel-x x4 | M6 x2 | 1.2OG x15 | Project F x2 | 2.0AD x15 | Noah x3 | Mr. Hat x3 | 2.0VK x1
Rama: M60-A x4 | M65-A x2 | M6-A 88edition | M6-B | KOYU x3 | M60-A SEQ2 X4 | M6-C x2 | U80 x5 | M10-C | M6-C | M60 LNY x2 | M60 Olivia x2 | M65-B x5
FOX: Leaf 80 x4 | Leaf 60 x4 | Key65 x5      TGR:Jane V2 | 910RE | Jane V2 CE x2     Percent: Canoe x3 | Maze x2 | Skog lite | Canoe FE x2
Others: Mira SE x2 | Jermini | C225 x2 | INETT Cross x2 | Kira 80 | Kira 60 | Zephyr 65 R2 | Space 65 x2 | Volcano 660 x3 | INETT Square80 x4 | INETT Square68 x6 | FMJ 80 x2 | Keycult No.2 x1 | Thermal x2
Offline Jinnnxxu
  • U only live once
« Reply #10 on: Fri, 15 March 2019, 08:14:35 »
it's sold out already, just limited 10 of that! :'(
« Reply #11 on: Fri, 15 March 2019, 08:25:06 »
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!  :'(
Offline frostylove
« Reply #12 on: Fri, 15 March 2019, 10:04:16 »
Yellow sample pics would be updated later once available. They said it supposed to be kind of light and mellow yellow, pretty much like the GMK Serika. No gold tint at all.
Offline vicissitude
« Reply #13 on: Fri, 15 March 2019, 11:01:00 »
nice keeb.  :thumb:
Offline oldcat
  • 65% is Life
« Reply #14 on: Fri, 15 March 2019, 11:08:11 »
GLWS!
Offline Little4Real
« Reply #15 on: Fri, 15 March 2019, 13:10:59 »
I wish the GB was going on for more than a week (sighs)
Offline nu_types
  • Formerly Iredeus
« Reply #16 on: Fri, 15 March 2019, 14:48:03 »
Nice! I've been kicking myself for missing out on the original gb. I'm definitely in for this one.
« Last Edit: Fri, 15 March 2019, 15:37:24 by Iredeus »
Offline thearctican
« Reply #17 on: Fri, 15 March 2019, 15:33:42 »
Having built one of the white ones as a commission, I have to say that the quality and tolerances on this board are phenomenal. It has a great sound profile once it's all together, and it looks so very good in person. And the HEFT. Don't let the off-center weight fool you, this is a beefy board all around.
If you're on the fence about it, buy one. If you wish they came in other colors, buy one and cerakote it. I'll be trying my damnedest to move money around and enter the group buy myself.
Offline razor_blade
« Reply #18 on: Fri, 15 March 2019, 16:05:40 »
Entered; what a beautiful board! While QMK would move it into endgame territory, I can make do with bootmapper.
« Reply #19 on: Fri, 15 March 2019, 16:06:33 »
the back design on these is super cool, glwgb
Offline Depresso-the-clown
  • yee haw
    • lmao it's literally just an instagram page
« Reply #20 on: Fri, 15 March 2019, 16:20:47 »
This is bottom mount, or top mount? And no split backspace option?
:thumb:
« Reply #21 on: Fri, 15 March 2019, 16:24:03 »
looking at the render, bottom mount
Offline noahf
« Reply #22 on: Fri, 15 March 2019, 16:38:46 »
signed up! cant wait for that pink.
Offline omgkittiesyay
« Reply #23 on: Fri, 15 March 2019, 17:12:20 »
Super excited for this, only problem is how tough it will be to pick a color.
Offline MMKB
« Reply #24 on: Fri, 15 March 2019, 17:42:36 »
Nice job starting a larger GB. Just curious, what is the bar at the front under the spacebar?
Offline nu_types
  • Formerly Iredeus
« Reply #25 on: Fri, 15 March 2019, 21:03:44 »
I think that's just for aesthetics and has the LED indicators.
Offline frostylove
« Reply #26 on: Fri, 15 March 2019, 22:53:28 »
JUN just give me some ideas behind the little bar:
1 Aesthetic 2 Slightly curved as a tiny wrist rest 3 LED cover 4 touch type positioning 5 More DIY possibility
Offline thearctican
« Reply #27 on: Fri, 15 March 2019, 22:54:14 »
It is indeed bottom mount.
Offline rmendis
  • Artisan addict
« Reply #28 on: Fri, 15 March 2019, 23:38:53 »
Nice. Serika is not pale, but if it matches that, it would be great.
Offline catamscott
« Reply #29 on: Fri, 15 March 2019, 23:40:59 »
really, really love the design. there's something about the bottom lip and off-center weight that just looks so good. will have to make sure to get in on this :thumb:
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #30 on: Sat, 16 March 2019, 00:04:16 »
I'm in.
I love my JER-A06.
Offline oldcat
  • 65% is Life
« Reply #31 on: Sat, 16 March 2019, 00:30:52 »
Will these be e-coat or regular anodization?
Offline thornkin
« Reply #32 on: Sat, 16 March 2019, 00:59:01 »
Looks great. Happy to have found this. My wallet, maybe not so much...
Sent from my Mediatek MTK8173 Chromebook using Tapatalk
Offline whalematrontron
« Reply #33 on: Sat, 16 March 2019, 06:12:41 »
If only the white was still available :'(
Offline V. Vega
« Reply #34 on: Sat, 16 March 2019, 08:32:14 »
215422-0
Is this sample the light blue or is it gray?
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #35 on: Sat, 16 March 2019, 10:58:47 »
OK, here we go. Really wasn't planning on picking up another board, but this one's hard to pass up.
Offline frostylove
« Reply #36 on: Sat, 16 March 2019, 11:30:28 »
Light blue, here's another light blue sample pic.
Offline frostylove
« Reply #37 on: Sat, 16 March 2019, 11:32:14 »
Regular anodizing process, not hardcoat.
« Reply #38 on: Sat, 16 March 2019, 13:06:36 »
Do you have any images of the Silver vs dark grey? Would like to see the difference between those two if possible! Also I think I already know the answer but is this USB-C?
Offline method_
« Reply #39 on: Sat, 16 March 2019, 15:20:03 »
This design is super classy.
I'm in!
thock program.
Offline V. Vega
« Reply #40 on: Sat, 16 March 2019, 15:23:32 »
Thank you for clarifying and for the additional pic!
Offline thornkin
« Reply #41 on: Sat, 16 March 2019, 21:59:32 »
This says programmable. Is this qmk or boot mapper or...?
Sent from my SM-G950U using Tapatalk
Offline Visionaire
« Reply #42 on: Sat, 16 March 2019, 22:37:16 »
Hrm. Might have to jump on this.
Offline oldcat
  • 65% is Life
« Reply #43 on: Sat, 16 March 2019, 23:09:13 »
"General B-series programmable PCB"
Pretty sure its bootmapper
Offline DetectiveNio
« Reply #44 on: Sun, 17 March 2019, 01:09:09 »
Joined! excited for my first gb
Offline frostylove
« Reply #45 on: Sun, 17 March 2019, 11:39:59 »
Sample pics of other colors would be available later. JER mini is using miniUSB interface for connection.
Offline Waterrmelonn
« Reply #46 on: Mon, 18 March 2019, 00:57:31 »
What is the typing angle of the keyboard?
Offline frostylove
« Reply #47 on: Mon, 18 March 2019, 13:49:39 »
6 degree
Offline bthezebra
« Reply #48 on: Mon, 18 March 2019, 23:23:12 »
Probably a dumb question: can this be built without the plate to have a typing experience similar to the Jer A06?
Offline puddingfarmer
« Reply #49 on: Mon, 18 March 2019, 23:37:54 »
Could I get one without the JER logo?
