Author Topic: [GB] JER mini Group Buy (All Shipped)  (Read 89482 times)
Offline slxdegrees
  • Nerds With Keebs
    • Donate to Room To Read!
Re: [GB] JER mini Group Buy (All Shipped)
« Reply #200 on: Wed, 21 August 2019, 20:05:25 »
sad I didn't get into this groupbuy; i might be on the lookout for one on mm lol. What usb connector does it use?
USB mini
Sent from my LYA-L29 using Tapatalk
Offline nebluh
« Reply #201 on: Wed, 28 August 2019, 13:47:08 »
Thankfully my plate screws work well enough but the brass weight screws are almost entirely useless, any tips as to what I can do ?
also either it came that way or (more likely) in my rush to get this thing up and running i might have knocked off a piece of the pcb that now makes the insert key (top right most key) not function. how involved would it be for me to fix this?
https://i.imgur.com/RxVhiT6.jpg
« Last Edit: Wed, 28 August 2019, 14:40:02 by nebluh »
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #202 on: Wed, 28 August 2019, 15:29:41 »
It's just a diode so it's an easy fix.  The part is a couple of cents at most.
You could replace it with another surface mount diode or get creative with a through hole one.
Offline Jhambone9160
« Reply #203 on: Fri, 04 October 2019, 13:23:51 »
I epoxied my weight in. It's not going anywhere plus no more concerns of shorting the pcb out on the weight screws.
I had to do more work to this board aside from having to epoxy in the weight. I had to put new helicoils in the indicator light trim piece, plus i had to rethread every single plate screw with 2.5m hex bolts. Now my JER Mini is as solid as a rock. The tolerances on the machine work are fantastic and the finish is nice aside from one minor scratch but the quality of the threads and the use of helicoils is unacceptable. It could always be worse though. I gotta say, while the issues with this board are unacceptable, I was able to work around them and that work has made me like the board even more. I'll definitely purchase another plate and PCB if the JER Mini runs again.
Offline macclack
  • The rhythm of the game
    • Macclack
« Reply #204 on: Fri, 04 October 2019, 16:00:08 »
I have 1 plate screw that just spins endlessly but rethreading it is something I'm not familiar with how to do. Any tips?
Offline 8six753o9
« Reply #205 on: Fri, 04 October 2019, 16:06:06 »
You may need a longer screw.  A few people have been having problems with the plate screw being too short.  Try getting some m2 6mm screws.  I'm getting some tonight to see if they fit.
Offline MajorKoos
« Reply #206 on: Fri, 04 October 2019, 17:06:17 »
A spot of locktite?
https://www.loctiteproducts.com/en/products/specialty-products/specialty/loctite_threadlockerblue242.html
« Reply #207 on: Fri, 04 October 2019, 18:36:46 »
Teflon tape will work if you are lucky, or a longer bolt. I opted to use a larger bolt of a much harder metal. Carbon steel bolts cut through aluminum with ease.
Offline macclack
    • Macclack
« Reply #208 on: Sat, 05 October 2019, 09:22:17 »
I tried that but I think the hole is actually too wide. Maybe I'll try an m2.5 bolt
Offline bweebz
« Reply #209 on: Thu, 10 October 2019, 19:00:50 »
Hey Frosty,
Do you have any extra JER Mini PCBs? I accidentally spilled water on my JER and now the TAB and ESC buttons dont work :(. If you have any extras of the bar that lies at the bottom of the keyboard, I'm also interested in that.
Offline Morgan3Wheeler
« Reply #210 on: Fri, 11 October 2019, 04:31:59 »
Gray color
KMAC Happy red HHKB / KMAC Mini red / KMAC 2 86 / 45-ATS cerakote white / Matrix Noah avocado green / Matrix2.0 WKL yellow / Matrix2.0 WKL red / Matrix2.0 add WKL / Matrix Abel X RX-78 / Matrix Abel X Eva / Matrix1.2 OG WKL purple blue / Percent BOOSTER yellow /  Percent CANOE yellow / Percent Canoe2 casio / Percent SKOG mao / TGR 910 CE pink / TGR Jane CE WKL olive green/ TGR Jane V2 WKL blue gray/ TGR Jane V2 CE WKL / TGR Alice red / Keycult No. 2 Rev. 1 / EXENT65 black / GRAYCOD 67 mao / CA66 e-white / Think6.5 V2 LE / Think6.5 V2 robocop / Think6.5 V2 snow white / SPACE 65 R1 black / Typewriter68 e-white/ E6.5 pc / E7-V1 mao white/ E8.5 WKL e-white/ Voclano660 e-white / Moon by EVE WKL carbon / JER-Mini gray / JER80S NCR WKL geekhack / JER80S NCR WKL Korean / Dolumina65 black / Elephant S7 R2 e-white / Bear 65 ergo e-white, black, blue, pink, PC / Fox key65 e-white / Cyberboard purple / Saturn-60 moondust / Saturn-60 supernova / Infinitum / Rama M65a e-white / Rama Jules navy / Rama Zenith ouro / Rama U80-A Seq2 soya / Primus75 / 7V blue / / Cajal gray / Cajal e-white / SQUARE.X 6ea / Time 80 Reforged WKL e-white / J-01 rev1 Black / J-02 LE Poker e-white / OTD 356 Mini R1 red / LZ-CE red / LZ-CE gray / LZ-CLSms silver/ LZ-PhysiX gray / LZ-SQ SE titan gray / LZ-EX titan gray /  LZ-ST silver / LZ-FE WKL silver/ LZ-CLS WKL silver/ LZ-CLS WKL black / LZ-MP gray / LZ-MX SE titan gray / LZ-CP black-blue / LZ-CP red-red SE / LZ-RV gray / Light Pad silver / Light Pad gray / Octagon V2 gray / Orion V2 WKL silver-red / Orion V2.5 WKL gray / Dol Pad dolch / Dolinger 2017 dolch / Dolinger RE yellow/ Dolinger RE PC / Whale-Fe / Dolphin V3 dolch / Montage PC WKL / F1-8X WKL gray / F1-8X WKL navy / F1-8X WKL burgandy / AL.BOK WKL silver
Offline Hazy
« Reply #211 on: Wed, 29 January 2020, 22:02:20 »
Any chance that someone has the plate files for this?
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #212 on: Tue, 15 September 2020, 12:54:16 »
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #213 on: Wed, 16 September 2020, 10:08:13 »
I had emailed about a year ago for a plate file and received this. I don't have a program to open it and see it, myself, hopefully this helps.
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #214 on: Wed, 16 September 2020, 12:30:00 »
Dude you rock. Hard. This is exactly what was needed. Thanks so much!
« Last Edit: Wed, 16 September 2020, 12:34:03 by Kokaloo »
Offline Visionaire
« Reply #215 on: Thu, 04 February 2021, 23:18:33 »
If anyone has an extra PCB... I'm in need. :)
