Author Topic: Re-mapping Varmilo  (Read 6046 times)
Offline phinix
Re-mapping Varmilo
« on: Thu, 14 March 2019, 17:51:13 »
Can you re-map Varmilo keyboards?
Just wanted to know if there is a way to do it...
Offline Sup
Re: Re-mapping Varmilo
« Reply #1 on: Sat, 16 March 2019, 07:42:21 »
Quik answer nope. It's only with Dip switches. You can use Hasu's USB to USB converter it can make any keyboard re programmable but it can't read FN outputs from the keyboard.
current
Coming soon
Offline phinix
« Reply #2 on: Tue, 19 March 2019, 08:15:04 »
Thanks.
Right, with this converter I would not be able to use Fn key combinations...
Reason I asked is that now when I started using VArmilo VA69, which has Ins, Del, PgDn,PgUp - I noticed how much I miss Home and End keys.
I almost never use PgUp and PgDn, so wanted to re-program them to be Home and End.
« Reply #3 on: Tue, 19 March 2019, 08:35:25 »
You could use a software solution to swap those functions. That's what I do with the FC980M.
