Author Topic: [OTD] Updated Wiki  (Read 117955 times)
Offline notflipperdan420
  • dalla dalla
[OTD] Updated Wiki
« on: Sat, 16 March 2019, 17:44:01 »
Hi Geekhack.
It's been too long since the Deskthority OTD wiki has gone without an update.
With the growing interest in OTD boards within the community, I thought it'd be nice to make an updated wiki people can refer to and check years from now.
I'll be updating this thread every few days / weeks with a new board, so stay tuned.
  • 356L -2008
  • 356N -2008
  • 356CL -2009
  • 356CL DGE -2009
  • 356 Mini -2010
  • 356 Pad - 2010
  • 356N MK2 -2010
  • Koala -2011
  • 356 Mini MK2 -2012
  • 456GT -2012
  • 356.2 -2013
  • 360C -2013
356L *2 | 356CL Gunmetal *3 | 356CL Black | 356.2 | 356CL DGE SE | 356mini v1 Military | 356mini v1 Black *2 | 356mini v1 Red *2 | 356mini v2 Red | 356N MK2 Silver *2 | 356N MK2 Red | 456GT Pink *3 | 356 Pad *2 | Brass Koala | Koala WK Black | FE Whale WKL | Whale v1 WKL Gunmetal | HHKB Type-S |  G80-5000HAMUS | G80-1838HPU NIB | G81-3000SAT NIB
Current Rotation: HeoK Dolch, HHKB Type-S, 456GT Pink
  • dalla dalla
Re: [OTD] Updated Wiki
« Reply #1 on: Sat, 16 March 2019, 17:45:00 »
356L
The first in the OTD lineup is the 356L. Following in the footsteps of the DK Saver, it is one of the earliest Kustom keyboards to be made.
Made from German aluminum, the keyboard is a lot heavier than it looks, weighing in at approximately 1.5kg (3.3 Pounds) despite not being an angled case.
As the L in the name suggests, it is designed for use with Linear switches, but it's said that the 356L also goes well with MX Blues.
Being the oldest and first of the legendary OTD 356 series, it is one of the rarest and most sought after keyboards by collectors.
Groupbuy Date: March 13th, 2008
Layout: Winkey 87
Units Made: 60 (1 lost during shipping, so a total of 59 units).
Colors Available: Black
Matching Wrist Rest: Yes
Controller: Any controller from a USB type WK layout Cherry G80-3000 keyboard.
Types of Plates Available: Aluminum (Black)
Engraving: It's engraved as #/60 depending on which number you have on the backside of the case and on the plate above the arrow keys.
Connection Type: USB
215448-0
215450-1
215452-2
215454-3
215456-4
215458-5
215460-6
215462-7
215464-8
« Last Edit: Sat, 16 March 2019, 19:37:18 by notflipperdan420 »
  • dalla dalla
« Reply #2 on: Sat, 16 March 2019, 17:45:13 »
356N
Following the 356L is the 356N. The 356N wasn't limited in quantity like the previous 356L, but had far fewer participants at around 30 units total.
This was said to be due to the group buy date of the 356N being too close to that of the 356L. Therefore, not many people joined due to financial reasons and that makes the 356N the rarest OTD excluding prototypes and special editions.
And yes, the naming scheme is pretty much the same. The 356L is designed for use with Linear switches in mind, while the 356N is designed for Non Click (aka tactile) switches in mind.
You might be wondering how a board can be designed for a particular switch.
The designer Eungsam was very meticulous and prototyped every one of his boards multiple times (with his own money) until the boards were "perfect" by his high standards. Then provided those boards to the OTD community at almost no profit.
He used the same PCB material as that of OG Cherry boards (CEM-3) instead of the usual FR4 to replicate the feeling of OG Cherry boards into the 356N. Cherry PCBs are over 1.5T in thickness while the 356N's PCB is a very thin 1.2T to help the PCB flex more and allow for a better typing feel.
Eungsam also thought out the case design so there is space deliberately left over in the bottom of the case. This helps increase pleasant pinging sounds made by tactile switches. The 356N is also the first OTD (or first Kustom) to use a rubber band in between the PCB and plate to produce a "bouncy" typing feel while helping to reduce unpleasant sounds.
The main difference difference between the 356N and the 356N MK2, is the anodizing. Both have a "hairline" anodizing where you can see lines running across. However, the 356N has the "hairline" running vertically as opposed to the 356N MK2's horizontal "hairline".
Groupbuy Date: June~July, 2008
Layout: Winkey 87
Units Made: +- 30 (2 Chrome, Rest is Silver)
Colors Available: Silver, Chrome
Controller: Holtec 628A
Types of Plates Available: Aluminum (Red), Polycarbonate Half
Engraving: No
Connection Type: PS2
Photo credits to:
OTD 스타도리 [Pic 1]
Random dude on google [Pic 2]
OTD 지제면민 [Pic 3]
OTD 이동진 [Pic 4]
OTD 이동진 [Pic 5]
215821-1
215823-2
215825-3
215827-4
« Last Edit: Sat, 23 March 2019, 11:33:13 by notflipperdan420 »
  • dalla dalla
« Reply #3 on: Sat, 16 March 2019, 17:45:19 »
356CL
Here we are at the legendary 356CL. The holy grail. The grandfather of all modern day Kustoms. It's the board that set the standard.
To say it has impacted modern day Kustom design is an understatement. It's the first Kustom ever to utilize a brass weight insert, and first Kustom ever to have an angled case design.
You don't see many boards nowadays that don't have an angled case design and or a brass weight, right?
The 356CL wasn't born that easily. Even after countless prototypes, there were many issues.
Most notably, due to an problem with the aluminum used for the case, the ano left streaks (lines) on what would be the top half of many 356CLs. These top cases would later become 356CL DGE, but more detail on that in my next post.
Eungsam with his high standards, remade all the top cases due to this issue. That is why there is such a big color difference between the top and bottom half of most CLs.
Groupbuy Date: June 2009
Layout: Winkeyless 84
Units Made: Around 90 ~ 120 units. (Some say 60 Gunmetal 30 Black, some say 90 Gunmetal, 30 Black)
Colors Available: Gunmetal, Black
Engraving: Yes
Photo credits to my good friend rv_companyz (go check him out on Instagram) :thumb:
217478-0
217480-1
217482-2
217484-3
217486-4
« Last Edit: Wed, 17 April 2019, 09:59:06 by notflipperdan420 »
  • dalla dalla
« Reply #4 on: Sat, 16 March 2019, 17:45:27 »
Reserved
  • dalla dalla
« Reply #5 on: Sat, 16 March 2019, 17:45:34 »
Reserved
  • dalla dalla
« Reply #6 on: Sat, 16 March 2019, 17:45:41 »
Reserved
  • dalla dalla
« Reply #7 on: Sat, 16 March 2019, 17:45:54 »
Reserved
  • dalla dalla
« Reply #8 on: Sat, 16 March 2019, 17:46:09 »
Reserved
  • dalla dalla
« Reply #9 on: Sat, 16 March 2019, 17:46:17 »
Reserved
  • dalla dalla
« Reply #10 on: Sat, 16 March 2019, 17:46:26 »
Reserved
  • dalla dalla
« Reply #11 on: Sat, 16 March 2019, 17:46:35 »
Reserved
Offline SixtyLife
« Reply #12 on: Sat, 16 March 2019, 18:31:40 »
sweet
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
Offline xondat
  • i'm not a star
« Reply #13 on: Sat, 16 March 2019, 18:35:05 »
malliji ma!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #14 on: Sat, 16 March 2019, 18:36:08 »
Fantastic. Looking forward to this.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #15 on: Sat, 16 March 2019, 20:53:37 »
Great thread!
Offline subcat
« Reply #16 on: Sat, 16 March 2019, 20:57:10 »
not gonna do one on the cheat?
Offline HPE1000
  • Keycap Paparazzo
« Reply #17 on: Sat, 16 March 2019, 20:59:27 »
this will be interesting for sure :)
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #18 on: Sun, 17 March 2019, 02:11:39 »
I wonder if that's the joke.
Offline funderburker
« Reply #19 on: Sun, 17 March 2019, 03:01:14 »
Can't wait to read this. Thank you for doing this.  :thumb:
Keyboard design by Skepur
Offline The_Boom_Boy
« Reply #20 on: Sun, 17 March 2019, 06:48:33 »
Nice to see this sort of consolidation of information  :thumb:
  • dalla dalla
« Reply #21 on: Sun, 17 March 2019, 07:26:51 »
The reason I cut out The Cheat was
1. It's not considered an "OTD" board by many due to the fact that the groupbuy wasn't run by Eungsam (응삼), the designer of the 356 series, 456GT, and 360Corsa.
2. The guy who ran the groupbuy, Aqua (아꽈) has low key scammed and still hasn't shipped out all units while going afk.
3. Some additional info regarding The Cheat. Groupbuy was ran on November, 2010 and supports full NKRO. Color options were Red, Silver, and Black.
Offline vegs
« Reply #22 on: Sun, 17 March 2019, 09:36:17 »
Can't wait!
hhkb pro 1 | hhkb bt | hhkb hybrid | haus | unikorn se
buy less
« Reply #23 on: Sun, 17 March 2019, 13:29:35 »
But Koala wasn't a Eungsam board either
  • dalla dalla
« Reply #24 on: Sun, 17 March 2019, 15:11:00 »
Yes, but the Koala is considered an "OTD" board by most, opposed to The Cheat. Also there is a lot more to talk about regarding the Koala.
Offline pr0ximity
« Reply #25 on: Sun, 17 March 2019, 15:29:29 »
What about 356CLS?
Offline Yuna
« Reply #26 on: Sun, 17 March 2019, 16:01:03 »
What about MX-Mini  :)
Offline Remsky
  • Lubed switch count > Puddsy post count
« Reply #27 on: Sun, 17 March 2019, 16:11:07 »
356L
Layout: Winkey 87
Really hope that aluminum came from the right side of the wall :dafoe:
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
« Reply #28 on: Sun, 17 March 2019, 16:35:55 »
Very true, I could write a book about koala ****
« Reply #29 on: Sun, 17 March 2019, 16:36:52 »
What about 356CLS?
It's more an addendum under CL
Offline SixtyLife
« Reply #30 on: Sun, 17 March 2019, 17:49:49 »
would also love to know the story behind this guy:
Offline dallman5
« Reply #31 on: Sun, 17 March 2019, 17:53:35 »
On a similar note, I was always curious about the 356W.
(https://geekhack.org/index.php?topic=35864.msg1173750#msg1173750)
LF: OG Cherry APL (lasered), Artisans
Current collection:
Norbatouch (Galaxy Blue) | Mira SE (Lunar Grey, WKL) | HHKB Pro 1 (KB300BN) | Noxary X60 (Grey, HHKB) | KBDFans 5 Degree (Silver) | AEK64 (Grey) | Norbaforce (Tactical Black, WKL)) | Realforce 86U (White) | TGR 910 RE (Polycarbonate) | LZ-SQ (Black) | LZ-CLS (Grey, WKL) | Duck Orion v1 (Silver, WK)) | Nissho KB106DE | HHKB Pro 1 (KB300B) | LZ CLS-S (Blue, Poker) | Realforce 87U 10th Anniversary) | Realforce 104UK | TGR Alice (Grey on Pink) | Singa (Blue, WKL)  | Quantrik QXP (Blue Grey, WKL) | LZ-GH v2 (Black, WK) | KMAC Happy (Red, Poker)) | IBM Model M SSK (APL) | TGR 910 SE (Pink on Blue) | GSKT-00 (Silver, Poker) | OTD Koala (Silver, WKL) | Realforce R2 PFU Edition (Ivory) | IBM 3279 Beamspring (APL) | TGR Tris (Blue) | LZ-GH v2 (Blue, WKL)) | TGR Jane v2 (Blue-grey, WKL) | LZ-MP (Shine Grey, WKL)  | TGR x Singa Unikorn (Purple) | Justsystems x Realforce 108UG) | IBM Model F Unsaver (APL) | TGR Jane V2 CE (Multicolor, WKL) | Realforce 87U (Blank Black) | Lin Montage (Light Blue, WKL) | GSKT-00 AEK R2 (Grey, HHKB) | Leopold FC660C (Blank Black) | Duck Viper v3 (Grey on Black) | Rama Works M6-C RWxRW | LZ-GH v1 (Black, WKL) | Gok 7v (Grey) | biso x beaming Kei (SS, HHKB) | zacheadams x bisoromi little z | Matrix Noah (Silver/Grey, WKL) | Lin Whale (Pink, WKL) | TGR Alice (Polycarbonate) | Rama Kara (Noct) | Lin Whale75 (Burgundy, F13) | Realforce 89 (Ivory) | Hand Engineering Haus (Bluegrey) | Haytco CAKE60_R1 (Pantone 4167C) | LZ-XE (Grey, WKL) | Noxary X60 V2 (Grey, WK) | Daji Ochocuatro (Grey, WKL) | HHKB Hybird Type-S 25th Anniversary (Snow) | LZ-REs (Grey, WKL) | Matrix 8xv 3.0 (Blue-Black/Deep Grey, WKL) | Realforce 23UB | Biso RS60 (Black, WK) | TGR x MXF Koala (Grey/Black, WKL)
Italics = Incoming, Black = Gone
Offline xondat
  • i'm not a star
« Reply #32 on: Sun, 17 March 2019, 18:19:42 »
Holy ****, I had no idea this even existed :eek: :eek:
« Reply #33 on: Sun, 17 March 2019, 18:21:12 »
IIRC nasby has it, and it was an early 360C proto
Offline hitlu
  • [LF] Ogres and Colonel
« Reply #34 on: Sun, 17 March 2019, 19:23:12 »
new one?
old ones has gone to be history.
pls jump to the new one first.
Colonel or Ogre
Offline vegs
« Reply #35 on: Mon, 18 March 2019, 02:47:44 »
new one?
hitlu pls :))
buy less
« Reply #36 on: Mon, 18 March 2019, 02:52:31 »
new one?
hitlu pls :))
i think he means "do corsa first" but even corsa is 6 years old at this point
Offline hayt
« Reply #37 on: Mon, 18 March 2019, 12:26:38 »
356L
Layout: Winkey 87
This is awesome, thanks for doing this!
Any why the # is blanked out? Just curious ty
Offline HPE1000
  • Keycap Paparazzo
« Reply #38 on: Mon, 18 March 2019, 12:31:12 »
356L
Layout: Winkey 87
prob just so ppl cant track who is selling/buying the boards and get blacklisted if they are flipping, just a thought
Offline _GMK_
  • not affiliated with GMK
« Reply #39 on: Mon, 18 March 2019, 13:09:19 »
Reserved
« Reply #40 on: Mon, 18 March 2019, 15:17:31 »
356L
Layout: Winkey 87
that is exactly what it is, OTD.kr and kbdlab ban for flipping, which is why the Korean community flips to us through MM
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #41 on: Mon, 18 March 2019, 15:22:41 »
356L
Layout: Winkey 87
The first boards made was actually prohibited to sell. Other boards have restriction on flipping (hence why bundles are so popular there) and selling outside of Korea. Only 360c was avail to the world.
Very busy with studies atm.
« Reply #42 on: Tue, 19 March 2019, 11:15:51 »
Excited to see this thread get filled out
Looking at crazy OTDs is always a good time  :))
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #43 on: Sat, 23 March 2019, 11:48:32 »
Reading about the effort and thought that went into the first designs is wild. Thanks for sharing :thumb:
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #44 on: Sat, 23 March 2019, 11:54:04 »
Great! An update on the N. Every update gets more and more exciting.
« Reply #45 on: Sat, 23 March 2019, 15:51:56 »
Chrome N is grails
Offline ArchDill
« Reply #46 on: Sat, 23 March 2019, 21:11:42 »
This is pretty rad. Excited to read these!
Offline stolenweapon
« Reply #47 on: Sun, 24 March 2019, 05:16:46 »
cool moves dan
OTD 356CL Black | 2x OTD 356CL Gunmetal | OTD 356.2 Factory Gray Ano 1/2 | 2x OTD 356.2 Blue Grey | 2x OTD 356mini Military Green | 5x OTD 356mini Red | OTD 356mini Black | 9x OTD 360C Apple Silver | 2x OTD 360C Hyper Grey | OTD 356L | 2x OTD 356N MKII Black | OTD 456GT Pink & Black | 3x OTD 356 Pad (2x Black, 1x Military Green) | 2x OTD Koala WKL Silver & Black | OTD Koala WK Silver & Black
TGR Jane V2 Pink Prototype 1/1 | TGR Jane V2 1/2 Brushed Toblerone Weight | 8x TGR Jane V2 | 6x TGR Jane CE V2 | TGR 910RE | TGR 910 VKC | TGR Alice Purple 1/5 | TGR Alice Red | TGR-03 | TGR Tris
LZ-SE | 3x LZ-RE | LZ-CP | LZ-MP SE
Keycult No.2 Stainless Steel | 2x KMAC Happy | 2x DK Saver MX & Alps
  • dalla dalla
« Reply #48 on: Mon, 25 March 2019, 02:49:14 »
Offline dorf
  • divine creator
« Reply #49 on: Tue, 23 April 2019, 09:00:27 »
I enjoy reading the story behind these boards
