Author Topic: [IC] Brutal 60 - 60% Keyboard Inspired by Brutalist Architecture  (Read 38335 times)
Offline upas
Hello again everybody,
I'm Upas, from CannonKeys. You might know me from the Satisfaction 75 (which unfortunately is delayed again). But a delay there means a new opportunity for one of my other designs to run - the Brutal 60.
Note: All images in this post are PHOTOS, not renders!
IC FORM HERE: https://goo.gl/forms/KtGH5dBRbFCQuYbf1
The Brutal 60 is roughly inspired by the Boston City Hall - an iconic example of Brutalist architecture. It features a wider top than bottom, and aggressive chamfer where the top meets the bottom. When looking at it, the seam you see on many boards is hidden. So in a sense, it's a seamless design!
Here are some of the technical details:
Aluminum top and bottom
White FR4 plate offered in both ISO and ANSI, Tsangan or Standard, with split Rshift, stepped caps, split backspace
FR4 ALPS plates are available as addons
No PCB included
Burger mount (top) - 12 o-rings will be provided with every kit
7.5 degree angle
20 mm front height (Same as Tofu)
34 mm back height
Acoustic polyfill will be provided for the interior
Weighs 1 kg (2.2 lbs) without plate/PCB/switches
I have already done a production run of this keyboard for a smaller, private GB. I intended to run this after the Satisfaction75 group buy, but given the delays, I can move up the timeline. Given that this has already been produced with high quality, this IC phase will be relatively quick. Once enough interest has been expressed, I will move into the GB phase. Fulfillment should also be relatively quick, given I already have a great factory lined up.
Here is a sound test of the board, with the acoustic polyfill inside, with lubed gat yellows, o rings for the burger mount, and an FR4 plate.
More photos:
The target cost will be no more than $200 including shipping (to the US - my apologies to others!). I can't promise that I'll achieve this price point, but that is the goal. One thing to note - this is a 60% that's on the cheaper side. Which means the bar for quality will not be as high as something like the keycult no 1. As an example, here are a few damages that would still be considered A-stock, with justification.
In this image, the dent is right under the seam. It's not possible to see when placed on a desk, and very minor.
In this image, the dent is so small that it wouldn't be visible once the board is assembled.
In general, large defects to visible faces will make a board B stock. But minor issues, small issues that won't be visible, or small dents on the bottom of the case that are not visible when the keyboard are on the desk will not cause a B stock evaluation.
This might change your interest in this board, but the idea here it to make this a very accessible, but beautiful case design that people can buy.
I may also offer carbon fiber plates as an option for this GB, but the layouts will be more limited.
If interested, please fill out this form: https://goo.gl/forms/KtGH5dBRbFCQuYbf1
« Last Edit: Mon, 01 April 2019, 16:04:23 by upas »
Offline Rensuya
  • Blue is my spirit animal
    • Link to the discord!
Re: [IC] Brutal 60 - 60% Keyboard Inspired by Brutalist Architecture
« Reply #1 on: Sun, 24 March 2019, 16:26:54 »
That's a sexy blue
Offline Lbibass
« Reply #2 on: Sun, 24 March 2019, 16:30:57 »
This looks familiar! ;)
Offline walie
« Reply #3 on: Sun, 24 March 2019, 16:31:47 »
In for this. I've been looking for an affordable top mount 60% case
Offline temp0321
« Reply #4 on: Sun, 24 March 2019, 16:32:22 »
so in for this!
Offline oldcat
  • 65% is Life
« Reply #5 on: Sun, 24 March 2019, 16:32:29 »
Good price! GLWS!
By the way, shipping to some countries can be as high as more than 60 dollars. Might want to consider that :)
« Last Edit: Sun, 24 March 2019, 16:34:29 by oldcat »
« Reply #6 on: Sun, 24 March 2019, 16:33:14 »
i will endorse any meme i see
Offline upas
« Reply #7 on: Sun, 24 March 2019, 16:37:32 »
Good price! GLWS!
Thank you for reminding me about this! I have edited the post to clarify my goal is to keep it at 200 shipped for the US.
Offline oldcat
  • 65% is Life
« Reply #8 on: Sun, 24 March 2019, 16:38:37 »
Good price! GLWS!
Nice profile logo too!
Offline Nigolski
« Reply #9 on: Sun, 24 March 2019, 16:41:49 »
brutal
Offline tiydal
« Reply #10 on: Sun, 24 March 2019, 16:53:16 »
watching, interested! any idea on shipping to the UK?
Offline futurecrime
  • Get Zooted
« Reply #11 on: Sun, 24 March 2019, 16:53:32 »
Really bloody lovely looking.
Offline otanishock
  • One of the cool kids :>
  • ファーストラブ
« Reply #12 on: Sun, 24 March 2019, 17:17:28 »
This brutal keyboard is looking brutally brutal.
Offline japanesehorrorwriter
« Reply #13 on: Sun, 24 March 2019, 17:43:29 »
top mount. inexpensive. all the extras. little dinks to make it cheaper. brutally good.
Offline xondat
  • i'm not a star
« Reply #14 on: Sun, 24 March 2019, 18:04:12 »
Sounds nice when typing, and not brutal on the wallet :blank:
Offline pr0ximity
« Reply #15 on: Sun, 24 March 2019, 19:02:51 »
Any pictures of the plate?
Offline BserLarry
« Reply #16 on: Sun, 24 March 2019, 20:07:23 »
HHKB compatible plate?
Offline upas
« Reply #17 on: Sun, 24 March 2019, 20:19:23 »
Potato pics below
Yes, see below :)
Offline _GMK_
  • not affiliated with GMK
« Reply #18 on: Sun, 24 March 2019, 20:35:42 »
Is this US only?
Are the edges so sharp that they're uncomfortable?
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #19 on: Sun, 24 March 2019, 20:49:46 »
ne machicolations avail?
Offline upas
« Reply #20 on: Sun, 24 March 2019, 20:57:02 »
Is this US only?
The edges aren't as bad as the Macbook Pro
Those would make it expensive to machine  :))
Offline equalunique
« Reply #21 on: Sun, 24 March 2019, 21:28:53 »
I like this design
Sent from my LG-H918 using Tapatalk
Offline ideus
  • Björkö.
« Reply #22 on: Sun, 24 March 2019, 21:38:19 »
Besides being top mounted, I ain't sure what else this design might offer beyond any other regular sixty.
Offline upas
« Reply #23 on: Sun, 24 March 2019, 21:49:33 »
I've been asked to share details on the mounting. It's a top mount with a twist. It's burger mount - which was pioneered by hineybush.
This is the case before the plate is installed:
Notice that every plate mounting point has a little cutout for an o-ring. It's not as deep as an o ring, and a little bit wider. This is so that the o ring has space to expand when it compresses, but is bounded by the edges of the o-ring indentation.
This also means that when installed, the o-rings stay in place:
Now when we install the plate, it's sitting on o-rings, and does not touch the top case.
When we screw the plate in, we can use another o ring on the other side. This o ring isn't constrained so it just compresses and squeezes out.
Completed:
So you can use this as any traditional top mount, or you can use the o rings to provide a bit of isolation.
Offline The_Boom_Boy
« Reply #24 on: Sun, 24 March 2019, 21:59:28 »
WKL top? I think it would fit with the brutalist aesthetic. Other than that great board. Love the fact that there isn't a fat brass piece in the bottom and the targeted price.
Offline upas
« Reply #25 on: Sun, 24 March 2019, 23:11:53 »
Only planning on offering a standard top in order to keep the price down.
« Reply #27 on: Mon, 25 March 2019, 02:05:49 »
Fair.
Offline Gonsterek
« Reply #28 on: Mon, 25 March 2019, 08:46:59 »
i love the design, it's so simple and minimalistic
Offline vicissitude
« Reply #29 on: Mon, 25 March 2019, 09:09:31 »
Love this blue color.  :thumb:
Good choice.
Offline Jaxxstatic
  • Haptic Recon
« Reply #30 on: Tue, 26 March 2019, 15:14:39 »
CNC 60% burger mount under $200 AFTER shipping? I'm in 100%. Another  :thumb:
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #31 on: Tue, 26 March 2019, 15:19:36 »
let's get it! hhkb top hhkb top hhkb top hhkb top hhkb top
Offline pixelpusher
« Reply #32 on: Tue, 26 March 2019, 15:21:24 »
HHKB is so 2016.  WKL is the way now.  OH, and HHKB is unusable, so there's that.   :eek:
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #33 on: Tue, 26 March 2019, 15:36:55 »
Will this layout be supported?
https://cdn.shopify.com/s/files/1/1473/3902/files/1_a6f90a3a-cefe-4e59-b4de-b56a80aa8376.jpg?v=1549504097
Wondering about this too. If not, I'm still super interested! Would be a beautiful and affordable build.
Offline upas
« Reply #34 on: Tue, 26 March 2019, 15:50:52 »
I will not be offering a plate with this layout, but I'll post DXF files after the group buy completes so that others can create their own plates.
Offline teobeo94
« Reply #35 on: Tue, 26 March 2019, 16:25:57 »
Excited for the GB! Just curious, would this burger mount (top mount w/ O-rings) differ in feels in comparison to gasket mount?
« Reply #36 on: Tue, 26 March 2019, 19:41:27 »
i am interested in that blue ....
Offline mrpetrov
« Reply #37 on: Thu, 28 March 2019, 22:57:47 »
This weekend...! Can I get a whoop whoop?
Offline otanishock
  • ファーストラブ
« Reply #38 on: Thu, 28 March 2019, 23:19:45 »
There are so many different implementations of gasket mount. Which one are you referring to? This burger mount system is also somewhat a variation of gasket mount as well (if you put on those gasket washers).
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #39 on: Fri, 29 March 2019, 13:06:30 »
I assume they mean like the Meme, Leaf, Volcano, etc which has the plate pressure-mounted with gasket-like strips around the edges.
Offline mrpetrov
« Reply #40 on: Sun, 31 March 2019, 23:31:20 »
Here you go! The board is really awesome, I will do a typing test tomorrow once my kids stop the noise pollution in the house.
216418-0216416-1
Typing test here:
« Last Edit: Mon, 01 April 2019, 00:24:16 by mrpetrov »
Offline heavyheaded
« Reply #41 on: Mon, 01 April 2019, 13:51:34 »
Strange sentiment as I have 3 plugged in right now and am looking at 3 more on my desk...
Offline equalunique
« Reply #42 on: Mon, 01 April 2019, 14:53:27 »
Hhkb pls
Offline Rensuya
« Reply #43 on: Mon, 01 April 2019, 17:46:57 »
+1 to HHKB
Offline pixelpusher
« Reply #44 on: Tue, 02 April 2019, 07:35:43 »
Meh, I own 3.  I regret them all.  But they look nice :)
« Last Edit: Tue, 02 April 2019, 07:38:25 by pixelpusher »
Offline TuCZnak
« Reply #45 on: Tue, 02 April 2019, 10:39:38 »
See, if you used a proper layout you wouldn't need 3 keyboards at the same time kappa
Offline oh_chesteroni
« Reply #46 on: Tue, 02 April 2019, 11:18:24 »
Hahaha this made my day. Thank you.
Offline click clack jack
« Reply #47 on: Tue, 02 April 2019, 21:32:10 »
I am in like Joe Biden.
Offline upas
« Reply #48 on: Wed, 03 April 2019, 14:09:35 »
Hey guys, still waiting on approval for the actual GB thread, but the GB is live on my site!
https://cannonkeys.com/products/gb-brutal-60
Offline Capsy
« Reply #49 on: Wed, 03 April 2019, 14:16:30 »
Let's gooooooooo !!
