Author Topic: [IC] Custom/Switch Stickers - ONLY $1 for 128 stickers - Taking votes on color  (Read 48903 times)
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
POLL FOR COLORS IS HERE: https://docs.google.com/forms/d/16CjcnysT9AwLFSU5ldnmnMLO2owh2axfIodIIrOkf6s/viewform
Branching off from this thread: http://geekhack.org/index.php?topic=45931.0
Since I was able to get good pricing and finally some good shipping rates for individual packages, I am planning on starting a group buy for these switch stickers.
The IC is to see if there will be a good number of orders for switch stickers. The designs, colors, shipping costs and all are mentioned below.
Switch Stickers ???
They make your board look pretty! The sticker is used to eliminate the small movement (left-to-right) in the plastic part of the switch, so it is not something major as oiling & greasing, but the sensitive keyboard enthusiasts could not stand that tiny flaw and made stickers that fit perfectly in that small crack of the switch.
Also helps with PCB switches, think about it, the plate already helps significantly in stabilizing the switch since it holds the bottom of the switch and the legs that hold the top half in place.  On PCB mounted switches you only have the contacts, legs, and potentially a diode or LED to stabilize it, but the top half of the housing has more room to wiggle and play.  So if the top is loose on PCB mounted, it will wobble more.  The sticker is supposed to make the top less wobbly and stabilize it more.
These stickers would go really well with this GB as it would show of your stickers!
The Design
Click below to show the sticker designs
The vinyl is 3mil for colored and 4mil for the metallic ones.
Below are the three designs that will be available:
Original:
Moose (Best IMO):
Spider (Maybe not):
Canceled
The sheets will be 6"x12" and have 8x16 stickers.
See my review of these here: http://geekhack.org/index.php?topic=46665.msg992036#msg992036
The Colors
Colors can be seen here: http://geekhack.org/index.php?topic=46665.msg992347#msg992347
MOQ
There is no MOQ on total orders but atleast 10 sheets for any color for the whole GB, can be combination of any of the 3 designs (Eg, 3O, 3M, 4S).
This is not for individual orders, this is for the complete GB
Time Frame
I would like to get this done as quickly as possible. I will be sending samples to jdcarpe in the next couple of days. Samples, sent and he approves of them.
Once the GB starts:
- 3 week - ordering
- 2 weeks - invoicing
- 2 days - production
- 1 week - prepare for mailing
- Around 2 weeks - shipping from me to you
So around 2 months from GB start to receiving product
The Costs + Shipping
Each sheet will contain 8x16 stickers = 128 stickers folded in half and be mailed in a CD/DVD bubble mailer by Registered Indian Post.
The price for any sheet would be $1 only!
Weight of bubble mailer + some extras (Surprise!) = 25g
Weight of one sticker sheet = 12g
For shipping within India: $1.5/kg
Shipping will cost (Same worldwide):
$4 for first 100g
$1 for every additional 100g
So you can get upto 6 sheets in the base shipping cost ($4), and upto 7 more for each extra 100g ($1).
Maximum weight is 2000g. If you want to order more, will have to use bulk mailer, contact me via PM as shipping varies depending on location for bulk orders.
PayPal will be the only mode for payment.
These costs have been mentioned factoring all costs such as productions, costs for getting these to me, bubble mailer package, etc as well as PayPal fees. So what you see is what you pay.
More Stickers!
If you have some design you want made into a sticker this can be arranged at the give prices below. Any design can be plotted as long as it is in black and white.
Eg:
The black part will be made into a sticker
Complex designs can be printed on transparent sheet, thus having an opaque look or printed on white vinyl. They will then be cut along a borderline  based of your design.. Just like printing a sticker at home and cutting it out, except instead of being on paper it would be on clear or white vinyl.
Eg.
The Pikachu would be printed and cut along the white part, it can be cut without a border but there is a limitation on the detail for small sized stickers.
There is no MOQ for custom designs, you can get even one sticker printed.
Costing would be $ 0.02 per sq. inch printed or plotted.
Release stickers (Area around sticker not needed removed and a clear tape added on top to peel the sticker to stick it somewhere and then remove the tape) would cost $0.09 per sq. inch.
If vinyl is not from Table 1.1 charges would be halved and price of vinyl used added. Shipping weight for 1sq inch of vinyl is 0.175g.
All custom stickers requested so far: https://docs.google.com/spreadsheet/ccc?key=0ApXIrLtiUwFVdGMyWVc3TFVvSEJlQlIwRHhaUnJVS1E&usp=sharing
Size (net) is the actual size of the sticker
Size(gross) is the size of the vinyl used for cutting the sticker as there are extras (around 2-3mm) on the sides to accommodate releasing and cutting the stickers.
Weight and price is calculated based on the gross size of the sticker.
Vinyl Please!
I have gotten some message regarding people wanting to buy vinyl only, this option will also be available at below rates:
Add $0.5 extra to shipping for larger bubble mailers
However the weight of the bubble mailer will increase from 25g to 70g.
Vinyl will cost you $0.01 per sq inch for any of the vinyls listed in the Table 1.1 and at given costs in Table 1.2.
For the vinyl from Paper Street Plastics contact me via PM.
Max size of vinyl is 12"x12", if you want bigger sizes, PM me and we'll work something out as then I have to use different packaging and shipping depending on quantity.
Acknowledgement
I would like to thank the following members:
mkawa - inspiring me to go ahead and do this
infiniti - for cutting and tetsing the true first batch of the stickers
BlueBar - Providing scans of the Korean Sticker Sheet
jdcarpe - Volunteering to inspect quality of the sticker sheet
codyeatworld - Assistance in GB webapp
pillon - For original design files at KBDMania
Bulk Orders
I would like to invite vendors to contact me for bulk orders if they would like to stock these in their online stores, I will see bulk ordering options in those cases and see if prices can be reduced further by eliminating extras that ship out to other members.
Feel free to leave feedback, express interest, raise queries!
Please mention the colours you are looking to get the stickers in!
Thanks
« Last Edit: Mon, 02 September 2013, 11:33:34 by MOZ »
Re: [IC] Switch Stickers - ONLY $1 for 128 stickers. And Custom Stickers
« Reply #1 on: Tue, 06 August 2013, 10:53:26 »
I'm in.
Offline Photoelectric
« Reply #2 on: Tue, 06 August 2013, 11:00:10 »
In!  Also need better photos of the available colors :)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #3 on: Tue, 06 August 2013, 11:00:50 »
Those metallics look pretty tasty. Will those be available?
Offline JPG
  • Model F is my new passion!
« Reply #4 on: Tue, 06 August 2013, 11:01:01 »
What are the advantages and disadvantages of each design?
Offline Dubsgalore
« Reply #5 on: Tue, 06 August 2013, 11:02:22 »
dat price
im in
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #6 on: Tue, 06 August 2013, 11:02:27 »
Count me in, I've got 100 clears here just waiting for white stickers.
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #7 on: Tue, 06 August 2013, 11:04:08 »
I am in for lots
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #8 on: Tue, 06 August 2013, 11:05:28 »
Also in.
Offline HannibalChew
  • Formerly PixelScript
    • gaffworks
« Reply #9 on: Tue, 06 August 2013, 11:11:13 »
I'm in!
Offline MOZ
  • Busy making stuff
« Reply #10 on: Tue, 06 August 2013, 11:21:12 »
I will be getting a scan of the catalog soon,  so we have more accuracy for the colors.
And all colors including the metallic will be available.
If there is some specific vinyl you want and is not available here,  I can try and source some and best would be if you could link me to it.
Offline MOZ
  • Busy making stuff
« Reply #11 on: Tue, 06 August 2013, 11:26:08 »
Personal preference,  each design covers different amount of surface area.
The original in the minimalistic design, moose covers the 4 rounded corners and finally spider covers the small tabs on the sides of the bottom switch housing.
I will post pictures of all three once the design is completed.
« Last Edit: Tue, 06 August 2013, 13:19:15 by mohitgarg »
Offline elton5354
« Reply #12 on: Tue, 06 August 2013, 11:40:03 »
In!
I want metalized gold and a bunch of others.
« Last Edit: Tue, 06 August 2013, 11:42:50 by elton5354 »
Offline BlueBär
« Reply #13 on: Tue, 06 August 2013, 11:42:22 »
One sheet for 1$? I'm in for... 10? ;D
Offline MOZ
  • Busy making stuff
« Reply #14 on: Tue, 06 August 2013, 13:28:48 »
I'm not sure if this was clear or not in the OP, but you can also get any other designs, not limited to switch stickers but any sort of designs if you want, costing and other details are in the OP.
Offline MOZ
  • Busy making stuff
« Reply #15 on: Tue, 06 August 2013, 13:30:47 »
Some vinyl that I am interested in and haven't found are:
- Metallic colors, I'm not talking about gold, silver, but blue,red,yellow,etc in metallic finishes.
- Metallic copper vinyl
If you know any suppliers for low quantities shipping world wide or are willing to proxy, please let me know.
Offline JPG
« Reply #16 on: Tue, 06 August 2013, 13:32:41 »
Well I am in for sure!
« Reply #17 on: Tue, 06 August 2013, 13:33:08 »
Metallic copper would be :thumb:
Offline mashby
    • Mashby
« Reply #18 on: Tue, 06 August 2013, 13:36:04 »
Mimic had colors with sparkles in them at one time. He called them metallic.
Metallic Red Switch Stickers - Closeup by Michael Ashby, on Flickr
Offline MOZ
  • Busy making stuff
« Reply #19 on: Tue, 06 August 2013, 13:43:59 »
Thanks Mashby. I've seen those, and as I mentioned, if someone can source these for me, I can get the stickers made.
Updated OP with information regarding colors.
There was a slight issue with the weight measurement, and that has been fixed, please check.
Offline Tarzan
  • formerly known as Greystoke
« Reply #20 on: Tue, 06 August 2013, 14:23:49 »
Interested!
Would really like some in a nice dark green, or even some lighter shades of green.  Or white...   ;D
Offline BlueBär
« Reply #21 on: Tue, 06 August 2013, 14:26:39 »
Sparkles!
More sparkles!
Copper! (no sparkles though ;__;)
« Last Edit: Tue, 06 August 2013, 14:30:09 by BlueBär »
Offline jil_jil32
  • Tokyo Press <3
« Reply #22 on: Tue, 06 August 2013, 14:34:30 »
So cool!
Offline gnubag
« Reply #23 on: Tue, 06 August 2013, 14:36:51 »
to make the changes clear:
minimum order of 10 sheets would be base shipping price + $1 for 100g more. ($14 for 10 sheets + misc. cost)
without breaking the next level of pricing you can get 2 sheets more. ($16 for 12 sheets + misc. cost)
Offline MOZ
  • Busy making stuff
« Reply #24 on: Tue, 06 August 2013, 14:48:19 »
Points to clear:
- There is no minimum order per person of 10 sheets, that is MOQ for the GB for any one color, can be combination of the designs as well, thus going by the interest so far, this is almost redundant
- There are no misc cost, the prices mentioned includes all costs, so the $3 for base shipping and extra $1 for 100g is including the misc costs.
"without breaking the next level of pricing you can get 2 sheets more. ($16 for 12 sheets + misc. cost)" - Didn't get this.
Offline gnubag
« Reply #25 on: Tue, 06 August 2013, 14:57:01 »
Points to clear:
oh my bad. l0l ignore everything
Offline MOZ
  • Busy making stuff
« Reply #26 on: Tue, 06 August 2013, 15:06:45 »
Sparkles!
More sparkles!
None of them ship to India, will need a proxy. :(
Offline MOZ
  • Busy making stuff
« Reply #27 on: Tue, 06 August 2013, 15:08:37 »
Design has been done and finalised, just final cut has to be tested, which will be done in the next couple of days and test package mailed to jdcarpe.
Also updated OP with details regarding my location, delay if extra vinyl has to be sourced, pricing for these extra vinyls sourced, made shipping details clearer.
    • gaffworks
« Reply #28 on: Tue, 06 August 2013, 15:19:32 »
Will the shipping cost change depending on where it's being shipped to?
Offline MOZ
  • Busy making stuff
« Reply #29 on: Tue, 06 August 2013, 15:27:08 »
No. Same prices worldwide, except for bulk orders (Above 2kg).
Offline esoomenona
  • Gnillort?
« Reply #30 on: Tue, 06 August 2013, 15:27:54 »
I demand royalties for using my name and likeness!
Offline MOZ
  • Busy making stuff
« Reply #31 on: Tue, 06 August 2013, 15:33:24 »
But your name is esoomenona! :P
Offline BlueBär
« Reply #32 on: Tue, 06 August 2013, 15:35:45 »
That's ok, we got some members from Australia (for the first two), we just got to make a list which sheets we want. I would like some of that holographic blue and red for example.
Offline MOZ
  • Busy making stuff
« Reply #33 on: Tue, 06 August 2013, 16:08:03 »
We can make the list, however actual ordering of vinyl would be done once payment for orders with special vinyl are paid for. I have updated OP with dimensions of the sheet (6"x12").
So for the ones you have posted it would be $3 + shipping from Ebay delaer to Aus Proxy + Aus Proxy to me + Shipping from me to you. These won't be cheap that is for sure, however you get exactly what you want.
« Reply #34 on: Tue, 06 August 2013, 16:44:54 »
I'm interested.  Seems inexpensive enough.  I still don't fully get the point to stickers but at this price it can't hurt to experiment.
« Reply #35 on: Tue, 06 August 2013, 17:13:12 »
Pretties and a slight decrease in rotation / wobble :)  Some claim a reduction in dust / dirt accumulation, which I suppose could be true, because some of the used vintage switches I've opened up had what looked like lint inside and some dirt.
Offline MOZ
  • Busy making stuff
« Reply #36 on: Tue, 06 August 2013, 17:16:52 »
Besides better looks and stabling wobbly switch, these help PCB mounted switches as nubs pointed out:
Yup.  Think about it, the plate already helps significantly in stabilizing the switch since it holds the bottom of the switch and the legs that hold the top half in place.  On PCB mounted switches you only have the contacts, legs, and potentially a diode or LED to stabilize it, but the top half of the housing has more room to wiggle and play.  So if the top is loose on PCB mounted, it will wobble more.  The sticker is supposed to make the top less wobbly and stabilize it more.
« Reply #37 on: Tue, 06 August 2013, 17:20:24 »
Hmm, thanks for the info guys!  As I said, at this price point, I'll go for it.  :)  Whether or not I notice a difference, we shall see.  :P
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #38 on: Tue, 06 August 2013, 18:14:37 »
I'm in for quite a few.
Offline n0rvig
« Reply #39 on: Tue, 06 August 2013, 18:21:53 »
I'd be in for a few. Decent price to experiment with. Colours? Pink or grey.  :thumb:
« Last Edit: Tue, 06 August 2013, 22:32:41 by n0rvig »
Offline MOZ
  • Busy making stuff
« Reply #40 on: Tue, 06 August 2013, 18:35:02 »
Colors, people mention the colors you'd like!
« Reply #41 on: Tue, 06 August 2013, 18:40:48 »
Okay :)  Having thought about it carefully, I'm interested in these (in metallic or glittery shades if possible): sky blue / aqua, pink, and brushed silver.
« Last Edit: Tue, 06 August 2013, 19:16:24 by Photoelectric »
Offline jonathanyu
« Reply #42 on: Tue, 06 August 2013, 18:41:53 »
i'm in! $1 for 128 stickers? :D i will buy every color!
Offline BlueBär
« Reply #43 on: Tue, 06 August 2013, 19:04:51 »
Colors? If possible holographic blue and red, glitter blue and red (I messaged the Aus vendor on ebay if he would ship to India as well btw), copper (there's quite a few suppliers for that so didn't contact anyone yet).
From the current colors, white, black, brushed silver and gold, normal glossy silver and a dark blue.
Edit: Would A4 be fine as well size wise? It's slightly smaller than 12" but wider than 6". Glossy and matte copper.
« Last Edit: Tue, 06 August 2013, 19:12:10 by BlueBär »
Offline MOZ
  • Busy making stuff
« Reply #44 on: Tue, 06 August 2013, 19:07:13 »
Thanks a lot for the assist. I really appreciate your efforts.
Offline BlueBär
« Reply #45 on: Tue, 06 August 2013, 19:14:05 »
Bumping this because I edited it :)
Offline MOZ
  • Busy making stuff
« Reply #46 on: Tue, 06 August 2013, 19:18:14 »
Yes. It would be fine.
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #47 on: Tue, 06 August 2013, 19:24:44 »
Light/sky blue, metallic pink, copper...maybe metallic white, too.
Offline JPG
« Reply #48 on: Tue, 06 August 2013, 19:35:40 »
My color choice would probably be: Green, sky blue, red, gold, silver (like 2 of each). Ain't 100% sure about red, but the others are quite sure.
Offline BlueBär
« Reply #49 on: Tue, 06 August 2013, 19:35:53 »
That's great! Because they ship to India. Shipping would be about 5.40$ first and about 1.20$ for every additional one for the matte, $3,75 and $1,87 for every additional one for the glossy. Like that we can still get a price of around 6$ for the sheets for a MOQ of 10, which is a still a very good price for such a quite unique colored sticker sheet.
