Okay, keycaps update:
(1) From what I understand, there’s going to be a separate massdrop sale for dye-sub printed keycaps, hopefully up within a few days. Unfortunately DCS keycaps are difficult (read: expensive) for SP to do dyesubs on, and DCS Alps keycaps are also substantially more expensive than DSA. As a result, the dyesub keycaps are going to also be DSA. (Which I’m pretty frustrated about, but oh well, it is what it is. They should still be quite pretty; just not ideal to type on.)
(2) I’m hoping there can also be DCS blanks offered, but I’m not sure exactly when that will get up, or if it’ll be easy to hit MOQ. DCS blanks would also be more expensive than DSA. Alps DCS in particular is pretty pricey. We’ll see how it goes.
(3) Finally, I’m hoping that Tai Hao can make blank and/or doubleshot ABS caps (especially hopefully for Alps, but MX would be nice too). I’m not sure if they can do the spacebar, but all the other key shapes are stuff they could do in the 80s and 90s for Alps-mount caps (I believe also for costar-style stabilizers), so I’m hopeful they haven’t lost that ability since then. Contacting Tai Hao and figuring out just what’s possible, then organizing it, etc. might take a few weeks. So no promises, just a hope.
